Thread: Interior fan failing
Results 1 to 10 of 11
  1. Interior fan failing
    Mar 2017
    Hampshire UK
    I've just noticed the fan on my 04 Touran has stopped working on settings '1' and '2'. Settings '3' and '4' are fine. Would this be a switch fault or something deeper?
    Thanks.
    1 person in 10 understands binary, the other one doesn't.
  2. Re: Interior fan failing
    133 Post(s)
    1991 Post(s)
    The speeds are set using a set of resistors in a pack placed in the blower which cools them down as on lower seating, there is a lot of heat wasted. Normally when the resistor pack fails all but the max speed are lost but we are replacing a LOT of these fans and resistors which are separate parts.
  3. Re: Interior fan failing
    Mar 2017
    Hampshire UK
    Hi, hence the question. What dealings I've had on other cars has been all failed except max. Is this a dash out job or keyhole surgery through the radio dock?
  4. Re: Interior fan failing
    133 Post(s)
    1991 Post(s)
    The blower and resistor are glovebox out jobs.
  5. Re: Interior fan failing
    Mar 2017
    Hampshire UK
    Ok, not so bad then. Job for when it's not so hot outside.
    Thanks.
  6. Re: Interior fan failing
    133 Post(s)
    1991 Post(s)
    I just mowed the lawn, nearly died of heat stroke
  7. Re: Interior fan failing
    Mar 2017
    Hampshire UK
    A quick look around suggests I'm looking for a 4 pin socket with a sort of heatsink arrangement on the back of it. Would that be right?
  8. Re: Interior fan failing
    133 Post(s)
    1991 Post(s)
    That is the variable resistor from the Climatronic from memory
  9. Re: Interior fan failing
    Mar 2017
    Hampshire UK
    Ok, watched a couple of youtube vids and plucked up the courage to go a'rummaging.
    With the soft cover off from the underside of the glovebox, I found a resistor pack, unplugged it and tested it as per one of the videos. It does appear to be kaput. Tried the fan without it and only speed 4 works, plugged it back in and had 3 and 4, so I do feel I'm heading in the right direction.
    Part on order.
  10. Re: Interior fan failing
    Mar 2017
    Hampshire UK
    Yay! £8.50 part off fleabay, 5 minutes of fitting and I've got 4 speeds again.
    Thanks for the guidance.
  1. Please Help bulb failing
    By barrymorri in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-02-2012, 11:38 AM
  2. Failing Maf Symptoms
    By PETER G in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-02-2009, 11:52 AM
  3. failing MAF
    By kite in forum VCDS - Help Requests
    Last Post: 04-12-2008, 09:33 AM
  4. A6 Air con failing
    By John540 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-05-2007, 09:08 PM
  5. MAF keeps failing?
    By cookie_monster in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-09-2006, 12:48 PM
