Re: Power loss - HELP! –
28-05-2021,09:25 PM
Originally Posted by
Educated Fool
Just deciding whether or not to upgrade to OBD12...yes, I know.
Anyway, progress has been made. Following a failure to negotiate a steep hill - no power and even manic clutch slipping wouldn't do it, we looked into several possibilities. As it seemed related to the warming up of the engine we tried disconnecting the temp sensor - this may have had no effect, we shall see - and at the same time the vacuum feed to the EGR valve diaphram. This produced a total change in the behaviour. The power seems to have returned, the revs seem to respond as they should to the throttle pedal and some form of normality appears to have been restored. The suggestion of it being mechanical, as there were no related codes showing, may well be proven correct. I will try a start from fully cold followed by a decent run before I can confirm that it is behaving itself, but fingers crossed.
Thanks again for the comments.
Probably a red herring, but I'll mention it anyway. I used to have a 2005 A6 but it was the 2.0TDi. It developed symptoms similar to the ones you describe - drastic power loss, tons of black smoke, intermittently it would run fine, then run awfully. It was recovered from my office car park and it didn't have enough power drive it onto the back of the recovery truck. There were no codes stored and the Audi dealer it ended up at was stumped. They started replacing parts but to no avail (AMM, ECU, fuel filter, fuel lines, fuel tank, fuel pump). Eventually they found it was a problem with the EGR valve - the flap had become disconnected from the spindle. Sometimes it would stick open and sometimes closed. A new EGR fixed it. Yours is a different engine and year, but the EGR valve is something to check maybe?
Good luck!
MF.
Now: E 53 AMG 4MATIC / Q5 2.0TFSi Prestige
