Thread: Passat 1.6 TDI p0407
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Passat 1.6 TDI p0407
    #11
    47 Post(s)
    1130 Post(s)
    As long as it is fitted correctly they cover it but just check if they are OK with DIY installation.
  2. Re: Passat 1.6 TDI p0407
    #12
    Jul 2016
    Uk
    Well new part fitted today.. My local VW couldn't get the part in a suitable time frame (Needed the car for this weekend) and pulled some faces when mentioning warranty and DIY installation, opted to go for a EGR from darkside developments its a borgwarner which i believe make all parts anyway 300
    Fitted.. started the car and error was still present... turned it off and started again but no start! at this point was panicking lol
    turned out I was out of fuel, I broke down originally on the way to get fuel... topped it up primed the lines and charged the battery for an hour (it died with me trying to start it a few times) and it started... but error still present!
    Used my cheap streetwize scanner error code 0407 pending cleared the error and bingo no more dash error's took it for a drive and all good.
    The only issue I've got now is when I first start the car it has a little blip and drops a few revs/lights go dim for a split second then back to normal? I'm hoping this is the battery not being fully charged or the garage did say I had a bad glow plug?
    Thanks for the help
  3. Re: Passat 1.6 TDI p0407
    #13
    47 Post(s)
    1130 Post(s)
    Yes Borg Warner is a huge OE manufacturer, I hope it goes well.
  4. Re: Passat 1.6 TDI p0407
    #14
    Jul 2016
    Uk
    Hey crasher
    wondering if you know the part number for the turbo oil outlet gasket/seal?
    I have a slight leak from it, its a rectangle gasket that is right up by the turbo
  5. Re: Passat 1.6 TDI p0407
    #15
    47 Post(s)
    1130 Post(s)
    The oil return pipe gasket? PM me your reg.
  6. Re: Passat 1.6 TDI p0407
    #16
    Feb 2020
    Bradford
    35 Post(s)
    Glad it worked out for you. That gasket is a right pain. Even the graphite coating on the replacements is fragile.
  1. Question P0407 Code
    By Teamin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-01-2018, 11:22 PM
  2. Error code P0407 on 2011 Touran 1.6. EGR valve needs replacing?
    By ger80 in forum Touran - Sharan - Caravelle
    Last Post: 30-11-2016, 05:09 PM
  3. Dirty Passat.. Nice Day.. Bored at Work = SUPER SHINY PASSAT!!
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2010, 12:10 PM
  4. Replies: 0
    Last Post: 09-04-2010, 03:07 PM
  5. Question Boot mounted CD changer from 1997 Passat to 2003 Passat
    By philnewman2002 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-12-2008, 02:52 PM
