Thread: Passat 1.6 TDI p0407
Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 81
  1. Re: Passat 1.6 TDI p0407
    #41
    134 Post(s)
    2025 Post(s)
    What fault codes are you getting?
  2. Re: Passat 1.6 TDI p0407
    #42
    Jul 2016
    Uk
    At the start just 0407 but that goes away once it has been started a few times
  3. Re: Passat 1.6 TDI p0407
    #43
    134 Post(s)
    2025 Post(s)
    I did warn you over aftermarket EGR valves, that is exactly what happened to me on a Golf 6 about five years ago.
  4. Re: Passat 1.6 TDI p0407
    #44
    Jul 2016
    Uk
    How can I completely bypass the EGR for testing to see if car idles better? I thought I'd be safe with borgwarner
  5. Re: Passat 1.6 TDI p0407
    #45
    134 Post(s)
    2025 Post(s)
    You must know me by now and my obsession with emissions, I don’t know how to bypass these valves as I refuse to get involved with it.
  6. Re: Passat 1.6 TDI p0407
    #46
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    The one thing I have noticed today is a funny smell coming from the car which is hard to describe.. it's like gas or electrical smell
    I would check around where all the work has been done for gas leaks.
    Look all around the back of the engine in the dark with a torch.
    You should see any gas leaks.
    Do it from a cold engine start.
  7. Re: Passat 1.6 TDI p0407
    #47
    134 Post(s)
    2025 Post(s)
    If you disconnected the DPF (you have to really) did you use a new turbo gasket and clamp? These are notorious for not liking to being reused.
  8. Re: Passat 1.6 TDI p0407
    #48
    Feb 2020
    Bradford
    41 Post(s)
    I think you may have more then one fault, the passat ecu's (not usually on 1.6) do have issues though which i have come across on here. Im not saying its the ecu but its possibility for a single cause of these faults
    For P0407 fault diagnosis, i'd monitor the egr wiring. It should be a 5 wire system. You have a thicker power and ground for the motor. Three wires for the position sensor. A shared 5v and a shared ground, and signal wire back to the ecu. The 5v power and ground in particular needs monitoring to see if it drops out since its shared and that naturally carries higher chance of something dropping out.
    If no problems with the 5v wires the signal wire checking to see what voltage the egr is outputing and what voltage is reaching the ecu.
    Easier said than done but this needs checking for clarity as to whats causing the fault code
  9. Re: Passat 1.6 TDI p0407
    #49
    Jul 2016
    Uk
    I'll shall try and check some of these things mentioned.
    What I don't get is it only happens on the first couple of starts after that the car drives fine with no hiccups? If it's drove with the error it's into limp mode.
    I have drove it for 50 miles to see if that changes anything (ecu learning) but no.. next day start the car error comes up leave it for 1 min idling and it's good to go after a restart.
  10. Re: Passat 1.6 TDI p0407
    #50
    Jul 2016
    Uk
    The other thing I will be trying is swapping over the motor part from my "VW" egr to the "borgwarner" egr if they are indeed fussy I wonder if it's within the electronics of the motor rather than any mechanical part of the EGR.
    My "VW" motor does not have any stripping of the plastic so should be fine to change and hopefully not a pain to do
  1. Question P0407 Code
    By Teamin in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-01-2018, 11:22 PM
  2. Error code P0407 on 2011 Touran 1.6. EGR valve needs replacing?
    By ger80 in forum Touran - Sharan - Caravelle
    Last Post: 30-11-2016, 05:09 PM
  3. Dirty Passat.. Nice Day.. Bored at Work = SUPER SHINY PASSAT!!
    By ToMBoY_C in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 30-04-2010, 12:10 PM
  4. Replies: 0
    Last Post: 09-04-2010, 03:07 PM
  5. Question Boot mounted CD changer from 1997 Passat to 2003 Passat
    By philnewman2002 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-12-2008, 02:52 PM
