Thread: Audi 2.5 2001
Results 1 to 10 of 12
  1. Audi 2.5 2001
    Oct 2012
    sunderland england
    I have just bought an Audi 2.5 tdi with a few problems, i am focusing on one problem at a time as i am old and not as mobile as i once was. I would like a little help in diagnosing the next fault i have on my list, [ already done quite a few jobs on it ]. This problem is to do with cold start or if car has been left for a while. It takes 9 or 10 seconds to start on a morning, but runs great when it fires up, engine is smooth and has full power, if i switch it off for a couple of minuets then restart, it fires straight up and runs great, the longer i leave it the longer it takes to start, up to a maximum of 10 seconds when totally cold, i have checked the leak back pipes and they are in good condition and all dry, no signs of a leak anywhere, does anyone know where i should start looking next, the car has no code faults showing, any help would be appreciated on this matter, i have looked on our forum for quite a while but haven't found the same problem as mine, engine has done 157k
  2. Re: Audi 2.5 2001
    1840 Post(s)
    Remove and test the glow plugs but take great care as they love snapping. Even if they test OK, do not re-use them. My business partner has a 2005 Allroad and this was having hot start problems, I checked the cranking RPM (pump plug disconnected) and the cranking RPM was too low but this can also cause cold starting. The AKE engine should have pressure check valves in the return lines from injectors 1 and 4 back to the pump, often these are missing or the wrong way around and non AKE units can benefit from them being retro fitted, part number 059 130 789, these are £37.26 inc VAT retail from any Audi dealer.
  3. Re: Audi 2.5 2001
    Oct 2012
    sunderland england
    Thank you for your reply, will have them checked, but it feels like no fuel to me, as after it has started i can switch it off after 5 seconds of running and it starts straight up and runs fine, [ i was wondering if there was a lift pump on this model [2001 2.5 tdi ]
  4. Re: Audi 2.5 2001
    1840 Post(s)
    Is it an AKE and are the check valves there?
  5. Re: Audi 2.5 2001
    Oct 2012
    sunderland england
    i have never heard of check valves and as new to these vehicles i don't know if it is an AKE, please would you explain please, as this is my first allroad audi, how would i be able to tell?, thanks again
  6. Re: Audi 2.5 2001
    May 2009
    Ramsey, New Jersey, USA
    69 Post(s)
    Quote Originally Posted by johnkarl View Post
    Your car should have a build sticker in the spare wheel well in the boot, and/or on the inside cover of your service book. This sticker lists the engine code and gearbox code, along with lots of other useful stuff like the paint code, interior colour code and codes for all the options fitted to the car.
    Regarding the check valves, Crasher mentioned these a couple of posts ago - "The AKE engine should have pressure check valves in the return lines from injectors 1 and 4 back to the pump, often these are missing or the wrong way around and non AKE units can benefit from them being retro fitted, part number 059 130 789, these are £37.26 inc VAT retail from any Audi dealer." It's worth tracing the fuel return lines to see if they are fitted. If they are faulty, missing, or fitted the wrong way around, I'm guessing this can mean fuel pressure can drop when the pump isn't running, and the long crank time is as a result of fuel pressure having to build up again.
    Cheers!
    MF.
    Now: E 53 AMG 4MATIC
    / Q5 2.0TFSi Prestige
  7. Re: Audi 2.5 2001
    Oct 2012
    sunderland england
    It has the sticker in my service book and it is an AKE engine, i will check to see if it has these fitted on Sunday as am fishing all day tomorrow, thanks for your help and information on this matter, do you know if it has a lift pump in the tank on this model as i seem to have what looks like a brand new lift pump in the box with a few other spares i got with the car, thanks again
  8. Re: Audi 2.5 2001
    1840 Post(s)
    There is a pump in the tank but it is not a lift pump... I know, confusing; it actually has two pumps, one electric and the other “suction jet” (6) and the system is designed to keep a swirl pot of fuel the the tanks right side, full of fuel and is necessary due to the saddle bag design of the pump which also requires two level senders. The VEP then draws fuel from the pot.
  9. Re: Audi 2.5 2001
    Oct 2012
    sunderland england
    OMG what have i gotten myself into he he he, thanks for your reply Crasher mate, will the failure of any of these components cause my problem mate
  10. Re: Audi 2.5 2001
    1840 Post(s)
    If the circulation pump or relay fail, this starts to cause lowish fuel level running problems which it did on my business partners 2005 AllRoad and as on the same car, a slow starter can also cause poor cold starting as can failed glow plugs and faulty/missing return line check valves. IF after cranking when it starts you get a puff of smoke then that can be glow plugs or the Commencement Of Injection fuel pump timing.
  1. 2003 Audi RS6 C5 cat back exhaust fitted to 2001 Audi allroad 2.5tdi
    By skyegtb in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 03-10-2016, 09:13 PM
  2. Question Audi A4 2001 8E5, B6 2001 Estate 1.9 TDI engine mount with sensor
    By CaptainBucko in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-10-2015, 09:37 AM
  3. Question Changing my 2001 Audi Concert for a Non Audi Head Unit - Advice please
    By m1keee in forum In Car Entertainment
    Last Post: 23-07-2011, 01:30 PM
  4. audi s8 2001
    By brandondk in forum A8 - S8 - V8
    Last Post: 18-10-2009, 05:53 PM
  5. Question Audi A3 (2001)
    By puddlechucker in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-06-2009, 10:28 PM
