Thread: A4 b6 2004 1.8t Cabriolet
  1. A4 b6 2004 1.8t Cabriolet
    May 2021
    Cheltenham
    I have just run a diagnostic on my A4 and it has thrown up so many faults , my main issue at the moment is getting the windows and soft top roof to work . Could anyone kindly point me in the right direction to proceed TIA Franky the logs are attached I hope :-)
  2. Re: A4 b6 2004 1.8t Cabriolet
    108 Post(s)
    1816 Post(s)
    Has this been standing and is it wet/mouldy inside? You have no comms with the J526 roof control unit behind the right rear side trim so check fuse 30 in the dash side fuse board and if it is good, that there is power to the control unit on the large red/lilac wire
  3. Re: A4 b6 2004 1.8t Cabriolet
    Sep 2020
    South Yorkshire, UK
    Also check your wiring looms at the bellows between the door and the body. These multipule faults could be due to the wires being broken. Had a similar issue with my A4. Repaired the loom , cleared the codes and this removed the majority of the other faults. As for yor roof , by fixing the other codes it will help you target the root cause.
    Larry
  1. Question 2004 A4 Cabriolet 3.0 CVT Auto
    By RobA4Cab in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-07-2017, 11:41 AM
  2. Battery for S4 B6 Cabriolet 2004
    By mjhamilton in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 10-11-2014, 11:30 AM
  3. Please Help 2004 a4 cabriolet....... headlights
    By Stevie515 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 10-08-2014, 07:15 PM
  4. 2004 A4 cabriolet 2.5tdi nightmare
    By blaire1988 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2014, 07:42 PM
  5. Odd smell in 2004 A4 Cabriolet
    By shook in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-12-2009, 12:47 PM
