Thread: Audi key fob programming
Results 1 to 10 of 16
  1. Audi key fob programming
    May 2012
    Manchester
    9 Post(s)
    Hey guys, i am going to pick up my Audi A7 (3.0 BiTDi 2016 reg) this weekend however ive just been informed it only has one key. What would be the process to get a replacement key (without going to the dealership of course)
    Is it something easily done via VCDS or alternative? I have been blank keys are approx £30 on ebay. Any thoughts and ideas would be appreciated
    2008 Audi A6 C6 S-Line Saloon, 2.0 Diesel with Multitronic Gearbox. BRE engine code and remapped to 170BHP (Stock was 140) Has 85k on the clock
  2. Re: Audi key fob programming
    Dec 2007
    Dudley, West Midlands
    44 Post(s)
    Highly unlikely VCDS will do it, there probably isnt a key tag with the secret key code with it either.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Audi key fob programming
    May 2012
    Manchester
    9 Post(s)
    what is the key tag? is it required? sorry i have literally no experience with any of this
  4. Re: Audi key fob programming
    Dec 2007
    44 Post(s)
    Vcds is a good tool, but it wont do anything unless its done correctly, you need the proper login for the immobiliser which is the skc on the tag supplied with the keys if you expect vcds to have any chance.
    When you say blanks? Used keys can now be unlocked around £15-20 but you need to get the correct key, you need a new blade as well really, then a locksmith (automotive) should be able to add a key
  5. Re: Audi key fob programming
    May 2012
    Manchester
    9 Post(s)
    ah thanks Dean, that makes sense. i have found something like this on ebay:
    AUDI 3 BUTTON REMOTE SMART KEY FOB CASE SHELL A4 A5 A6 A7 Q5 Q7 ETC REPLACEMENT | eBay
    However im not sure if im being gullible thinking its as simple as purchasing that and coding with a minimal total cost?
  6. Re: Audi key fob programming
    Dec 2007
    44 Post(s)
    Thanks an empty case, no real use to you at all,
    You need to open the key and get the part number
    Then find a used one, pay and unlock it then try and get a locksmith to code it.
  7. Re: Audi key fob programming
    Jul 2010
    uk
    183 Post(s)
    See if Andy at Audi Upgrades can help you.
    Audi Upgrades | OEM Level Retrofits
  8. Re: Audi key fob programming
    May 2012
    Manchester
    9 Post(s)
    thanks guys! i have been quoted £370 from the dealer and £250 from someone off ebay too. Will give andy a call and see what he says. I havent got the car yet so cant get any numbers/info off it. Im manchester based so if anyone else local can assist id really appreciate it!
  9. Re: Audi key fob programming
    Apr 2009
    Surrey
    180 Post(s)
    Quote Originally Posted by k114l3d View Post
    If the car only has the one key then you should delete all the keys currently paired to the car and then readd the one you have. That way you can be sure no one who has one of the missing keys can start your car. If I recall correctly the C7 came with 3 keys as standard - 2 remote keys and an emergency plastic blade key. It would originally have come with a plastic tag which contains a code that allows the immobiliser to be properly paired to the car. If you can get sight of the V5 for the car when you pick it up you could hopefully see the name and address of the previous owner and contact them to see if they have the missing keys. Unfortunately GDPR means that the PO is no longer listed on the V5
  10. Re: Audi key fob programming
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    If you buy it and it does (god forbid) gets stolen you might be in for an interesting conversation with your insurers.
  1. Vag programming audi tt
    By Scott2Hotty in forum VCDS - Help Requests
    Last Post: 07-09-2017, 02:37 AM
  2. Please Help A4 Audi key programming
    By Maverick610 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-10-2008, 03:35 PM
  3. audi a4 key programming
    By taff503 in forum New Member Introductions
    Last Post: 27-07-2008, 04:13 PM
  4. Audi Fob Programming
    By dan_chaggs in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 06-03-2008, 09:52 AM
  5. Key Fob programming for Audi
    By Sevarg in forum New Member Introductions
    Last Post: 13-09-2007, 09:48 PM
