Thread: Turbo Issues Fault Code P334B
Page 5 of 5 FirstFirst ... 345
Results 41 to 43 of 43
  1. Re: Turbo Issues Fault Code P334B
    #41
    Dec 2017
    Swansea, Wales
    If the wastegate sidle is corroded, the new motor will strip its gears, make sure they will accept a warranty if this happens as if you fit a new actuator to a seized turbo there is no warranty.
    I learned a LOT today. I've had the problem explained and shown to me by Audi. They attempted to replace the control arm on the actuator/turbo. And yes, it is available as a separate part - cost is £28. They were able to free the existing arm from the actuator end (held by circlip) but failed to removed it from the turbo end. So basically, the arm is "seized " on the lever at the turbo end. They'd previously told me that the turbo was seized and wanted to replace at a cost of nearly £2000. They don't want to try too hard to free it, obviously, because they want to charge for a new turbo. The technician demonstrated to me that the wastegate itself is free. So the turbo is OK (probably) and the actuator is OK (probably). I'm getting the new arm and they're putting the car back to how it was. I'll ask my friendly local garage to try and un-seize the arm and connect the new one. We'll see.
  2. Re: Turbo Issues Fault Code P334B
    #42
    Dec 2017
    Swansea, Wales
    If it is being done by the dealer they will have to replace the turbo or the actuator with the repair kit 04E 198 725 G, the parts supply system dictates that they have no other choice unless there is a hidden part number I have not seen inside a TPI.
    It's been a while so I thought I should just give an update for completeness. As I mentioned before, the control rod was seized at the turbo side and Audi weren't willing to try and free it. They gave the car back to me as was, although they didn't actually replace the circlips, together with the replacement control rod. So at Audi, I basically spent £88 - £60 for diagnostics and £28 for the new control rod.
    I took my car to a local garage and asked them to free the control rod, on the understanding that if they broke the turbo I'd bear the costs. They succeeded in freeing the control rod - it was tough but they managed it eventually. They installed the new control rod and circlips. Cost ..... £50.
    So in total, including what I'd paid to the first garage I took the car to, I've paid less the £200. Audi wanted close to £2,000. Even the first local garage were planning on removing the whole turbo and sending it away.
    Car is now fine. No more error codes or warning lights. Lessons well and truly learned.
  3. Re: Turbo Issues Fault Code P334B
    #43
    108 Post(s)
    1816 Post(s)
    It is what we do when they are seized, we want a repair that is guaranteed.
  1. Please Help Recon turbo with po299 fault code
    By Leon48 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 23-03-2016, 09:59 AM
  2. Turbo fault code
    By mini-mad-matt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-10-2015, 10:35 AM
  3. B6 1.8 TURBO P0103 FAULT CODE, any ideas???
    By deian3387 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-11-2009, 10:09 PM
  4. Tdi 110- Turbo? Fault Code 17958
    By lastyboy in forum Archive posts
    Last Post: 18-10-2007, 10:09 AM
  5. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
