Thread: Turbo Issues Fault Code P334B
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
  1. Re: Turbo Issues Fault Code P334B
    Dec 2017
    Swansea, Wales
    If it is seized, the spindle and the bore get damaged and have to be reengineered so it has to come off. The way to check is remove the actuator arm clip and see if the spindle is free, if not it will need a rebuild.
    Indeed, that's what I'm thinking. But do you know how easy it is to get the circlip off? I'm just wondering because of where it's located.
  2. Re: Turbo Issues Fault Code P334B
    1837 Post(s)
    They are a latch over design which locks into a grove and are easy to remove if you know how. Only attempt this with the engine stone cold. If I was at work I could show you a picture of the clip.
  3. Re: Turbo Issues Fault Code P334B
    Dec 2017
    Swansea, Wales
    Would you mind doing that when you're next in work? Would much appreciate. Is it best attacked from above or below?
  4. Re: Turbo Issues Fault Code P334B
    1837 Post(s)
    Remind me Monday. It is on the back of the engine so from above and over the back
  5. Re: Turbo Issues Fault Code P334B
    Dec 2017
    Swansea, Wales
    Here's your reminder. Thanks.
  6. Re: Turbo Issues Fault Code P334B
    1837 Post(s)
    I use a trade system at home on my iPad but I have ETKA as well at work. I could see there was a servo motor kit (04E 198 725 G) and this contains the clip (3) but it is not available on its own (so if you do remove it, don't lose it!) and ETKA does not show a picture of the kit or the clip or retaining washer as it is referred to in the kit contents list. I seem to remember the clips have an over the top lock but the diagram just shows it as a conventional circlip.
  7. Re: Turbo Issues Fault Code P334B
    #17
    Dec 2017
    Swansea, Wales
    Ta very much. That's great. I'll update as and when something exciting happens.
    BTW: interesting re-design of the actuator. In all the images I've seen online (obvs not this exact version), the arm disappears into the body of the actuator.
  8. Re: Turbo Issues Fault Code P334B
    #18
    Dec 2017
    Swansea, Wales
    Do you happen to know whether that's the closed or open wastegate position? Without seeing a fully working one it would be hard to tell how much travel there should be, and in which direction. I'm assuming that's closed, and that the arm moves to the right in the diagram in order to open. From the fault codes I've seen I suspect mine isn't closing fully - I'm never getting overboost faults.
  9. Re: Turbo Issues Fault Code P334B
    #19
    1837 Post(s)
    I can't remember which way that depicts but it is irrelevant, if the arm is disconnected there is a surprising arc of travel and it should be very easy to move.
  10. Re: Turbo Issues Fault Code P334B
    #20
    Dec 2017
    Swansea, Wales
    OK thanks. Damn it's a difficult place to get to though. Or maybe it's just me be a short@r$e.
  1. Please Help Recon turbo with po299 fault code
    By Leon48 in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 23-03-2016, 09:59 AM
  2. Turbo fault code
    By mini-mad-matt in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-10-2015, 10:35 AM
  3. B6 1.8 TURBO P0103 FAULT CODE, any ideas???
    By deian3387 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-11-2009, 10:09 PM
  4. Tdi 110- Turbo? Fault Code 17958
    By lastyboy in forum Archive posts
    Last Post: 18-10-2007, 10:09 AM
  5. 130 PD Turbo pressure problem fault code 17964
    By julesuk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2007, 11:55 PM
