Thread: What tyre pressures are people running?
  1. What tyre pressures are people running?
    Mar 2021
    Ripon
    7 Post(s)
    Seems that the trend is for manufacturers to recommend very high pressures (38 psi) to maximise fuel economy. This seem to make the ride a lot harder and less comfortable.
    What tyre pressures are people using? On my previous car a Mazda 6 I ran 32 psi all round on smaller 17 inch wheels and it felt a lot more comfortable. I have been running 36 psi but I am tempted to drop them to 34 or less to see if things improve.
  2. Re: What tyre pressures are people running?
    Sep 2019
    Glasgow
    What size of tyres do you have?
  3. Re: What tyre pressures are people running?
    Mar 2021
    Ripon
    7 Post(s)
    Running 235/45R18 XL Michelin primacy 4's.
  4. Re: What tyre pressures are people running?
    Sep 2019
    Glasgow
    Same tyres I have. They recommend 38psi all round but I wouldn’t advise that. I’ve found way too much road noise and you will find too this will overinflate them. There’s a comfort recommendation of 33psi all round but i noticed my fuel consumption got worse. Try 34 on the fronts and 35 on the backs or just do 35 all round. I’m considering replacing mine with the 17s (215/55/17) from current SEL model. I’m in the car all day and road noise can be an issue with the 18s and also poor road surfaces the 18s aren’t great.
  5. Re: What tyre pressures are people running?
    Mar 2021
    Ripon
    7 Post(s)
    Had it at 35 psi all round for a few months and that seems about the best compromise. Still make sure I steer well clear of any pot holes or recessed drain grates. Better shocks required I think!
  6. Re: What tyre pressures are people running?
    May 2012
    Everywhere
    308 Post(s)
    Can't beat dual rate dampers , special valving allows for maximum comfort but firms up when pressing on , didn't realise they were stock on the Stuttgart until I looked into
    BILSTEIN B4 DampMatic® , I run 40 psi with no loss of comfort .
    Koni ACTIVE are also dual rate .
  1. Tyre pressures & Tyre wear?
    By derekm in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-03-2010, 09:22 PM
  2. Tyre pressures and tyre pressure warning light
    By Foxtrot Oscar in forum Golf MK6 - 2009 - 2013
    Last Post: 26-07-2009, 07:14 PM
  3. Tyre pressures
    By saintsman in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-06-2009, 05:14 PM
  4. Tyre pressures
    By davegilsenan in forum Golf MK4 - 1999 - 2004
    Last Post: 23-08-2008, 05:22 PM
  5. Tyre Pressures
    By noddy1875 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2008, 10:31 PM
