Thread: Should there be a change to this long code?
  1. Should there be a change to this long code?
    Sep 2008
    Belfast
    6 Post(s)
    Hi guys, I have just fitted a towbar and dedicated wiring module to my 2010 A6 4F Avant 3.0TDI (CDYA) and when coding '01 engine' there is no labels available for the ECU in the Long Adaptation. Does anybody know if the following long code needs adapted for a Westfalia Detachable?
    010D002C190F0128
    Many thanks
    Graeme
    Sent from my VOG-L09 using Tapatalk
    Regards... Graeme
    2010 Audi A6 3.0 TDI Quattro Le Mans Avant (CDYA) Daytona Grey
  2. Re: Should there be a change to this long code?
    1840 Post(s)
    Unless doing this with ODIS, if the menu doesn’t have the correct options, contact Ross Tech.
  3. Re: Should there be a change to this long code?
    Sep 2008
    Belfast
    6 Post(s)
    Unfortunately I can't contact Ross-Tech as the lead belongs to a friend so because of this, they will not offer support to me. I know the label file is missing for my ECU so I was hoping someone here would have been able to offer support.
    Regards... Graeme
  1. Audi A3 8P ABS Long Code
    By cZm in forum VCDS - Help Requests
    Last Post: 22-04-2016, 01:59 PM
  2. Long Code Helper - Should I be able to see this?
    By Dpanic in forum VCDS - General Questions
    Last Post: 19-06-2013, 02:10 PM
  3. how long to change a gearbox?
    By mikecarty51 in forum Polo - Derby - Lupo - Fox
    Last Post: 13-12-2010, 09:51 PM
  4. vcds long code helper simulator
    By a8 tech in forum VCDS - Help Requests
    Last Post: 23-05-2010, 08:52 AM
  5. Long Code to enable Lap timer
    By ttguy in forum VCDS - General Questions
    Last Post: 21-04-2008, 10:29 PM
