Thread: Possible boost leak
  1. Possible boost leak
    Oct 2019
    Bolton
    Hi all the car is a A4 b6 1.9tdi 130bhp Avf quattro. I've replaced all egr and turbo vacuum hoses. Replaced the N75 valve. Had the turbo rebuilt, replaced hose off the bottom of the turbo. Took it for a few runs pulls a lot better but it doesn't feel 100%. Doesn't want to spin the wheels in 1st gear either. When on the the motorway around 80/90 the eml on with P0234 code. I'm still getting what sounds like a blow off valve which I thought before having the turbo rebuilt was the the turbine hitting the housing. The egr is blowing oil out the 2 holes at the top. I've ordered a new egr valve plus a new non return valve. Any help would be appreciated. Thanks
  2. Re: Possible boost leak
    1841 Post(s)
    P0234 is overboost, are you sure it isn’t P0235?
  3. Re: Possible boost leak
    Oct 2019
    Bolton
    100% p0234
  4. Re: Possible boost leak
    1841 Post(s)
    You don’t have a leak then, in my experience that vast majority of overboost codes are a fault inside the turbo, very occasionally I have seen the MAP sensor over read and even stick at 2880mBar. You need to do a boost graph in measuring blocks 011 with requested and actual boost displayed.
  5. Re: Possible boost leak
    Oct 2019
    Bolton
    How would you explain the turbo whoosh when letting off the revs. Also the off the the mark pull in 1st being low in power. Do you think there could be a build up of oil in the pipe bend just off the intercooler that could be caking the map sensor?
  6. Re: Possible boost leak
    1841 Post(s)
    The noise from the turbo is a characteristic of a problem with the VNT mechanism, I would describe it as a chattering breath that needs a shot of Ventolin.
  1. Please Help constant full boost!!! boost leak? MAP sensor?
    By boratdi150 in forum Bora - 1998 - 2005
    Last Post: 21-11-2017, 09:56 PM
  2. Question S3 boost leak - or not... as it seems
    By acmo in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 02-09-2015, 08:30 PM
  3. Question HELP boost leak?
    By SuperCharger28 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-07-2015, 05:26 PM
  4. Audi A4 1.9 TDI (110) Oil leak and Possible boost leak?
    By officialuk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-02-2011, 10:45 AM
  5. Boost Leak?
    By FOOTSY in forum Polo - Derby - Lupo - Fox
    Last Post: 17-01-2008, 10:22 PM
