Thread: Fuel gauge - random behaviour?
Results 1 to 10 of 11
  1. Fuel gauge - random behaviour?
    Feb 2014
    Oxford
    7 Post(s)
    My fuel gauge has started behaving erratically - most of the time showing zero but occasionally showing full (max). It says what it says from start up and doesn't change while driving, and yes there is fuel in it, plenty!
    It seems a bit odd for it to be the sender, especially going from empty to full, usually a dudd sender reads one or the other, not both?? I've checked the plug and connections to it, all seems ok. I even tried disconnecting the battery for a while and reconnecting it to see if that reset the system - no luck.
    Any ideas?
  2. Re: Fuel gauge - random behaviour?
    Feb 2020
    Bradford
    40 Post(s)
    I suppose its time to start to verifying. Verify you have a good power and ground at the fuel pump, verify signal output voltage, verify that voltage is getting to the cluster
  3. Re: Fuel gauge - random behaviour?
    Feb 2016
    London
    13 Post(s)
    Quote Originally Posted by Mr Zap View Post
    Any ideas?
    You need to give details on your model of car as there are known issues related to specific models.
    2011 A6 Allroad 3.0TDI
  4. Re: Fuel gauge - random behaviour?
    1836 Post(s)
    Due to the saddle design of the tank, it is a dual sensor system, the gauge can be tested and the sender outputs viewed in measuring blocks.
  5. Re: Fuel gauge - random behaviour?
    Feb 2014
    Oxford
    7 Post(s)
    Ok, well re vehicle details it's a C6 '05 reg Quattro, 3ltr TDI estate 224bhp. Does that help? I've heard they can suffer from dash failures due to dry solder joints?
    The fuel gauge has shown zero once or twice before but has always recovered, this time is the first for the zero to max fluctuation and for the past couple of days it's shown zero permanently.
    I can't take the car off the road right now to pull the cluster out and have a look so my only option is to keep the tank filled up!!
  6. Re: Fuel gauge - random behaviour?
    Feb 2016
    London
    13 Post(s)
    Could well be the common issue on these cars of the wiring failure in the tank sender. Try removing the metal cover under the drivers side rear seat and giving the top of the pump enclosure a good thump or 2 with a heavy blunt object and see if it kicks it into action. Mine does this occasionally but has been OK for the last 9 months.....
  7. Re: Fuel gauge - random behaviour?
    Feb 2014
    Oxford
    7 Post(s)
    OMG ... it worked!! Gentle couple of taps with the battery end of the cordless drill and hey presto! Thanks C6Allroad.
    Has anyone figured out why this works, i.e. what's wrong? Is it a stuck float gauge, or wiring issue etc?
  8. Re: Fuel gauge - random behaviour?
    Jul 2008
    Lisburn
    15 Post(s)
    there is audi documentation on line and repair kit for it, not sure if it was a recall?
    there is a link somewhere to the recall notices, i will see if i can dig something out for you
    TSB is what i was looking for not recall..
    https://drive.google.com/file/d/1YFI...ew?usp=sharing
    https://drive.google.com/file/d/1syD...ew?usp=sharing
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  9. Re: Fuel gauge - random behaviour?
    Feb 2016
    London
    13 Post(s)
    It's a wiring issue but one way to avoid repeated failure after giving it a thump is to not overfill the tank i.e once the pump stops don't try to squeeze more in.
  10. Re: Fuel gauge - random behaviour?
    Feb 2014
    Oxford
    7 Post(s)
    Sorry to say this but I've since had to thump the tank twice more, and that's without putting any more fuel in, let alone overfilling it.
    I've now seen the stuff online about this, including youtube videos and the vastly overpriced repair kit so at some point I guess I'm going to have to pull the thing out and see what's what for myself. I don't like the £190 price tag for a brand new assembly though so I'm wondering if the thing would suffer any ill effects if I just cut the connectors off and solder & heatshrink the wires? They seem to be part of the overall assembly so the chances of ever needing to separate them again are at best pretty minimal.
  1. Random fuel gauge and range
    By Geoff35 in forum A1
    Last Post: 19-05-2019, 03:52 PM
  2. Ios6 random behaviour with MMI
    By Andy McDonald in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 25-09-2012, 11:27 AM
  3. Odd door lock and fuel gauge behaviour: related?
    By SebRogers in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2009, 08:03 PM
  4. Odd fuel gauge behaviour
    Last Post: 17-05-2009, 12:37 AM
  5. Mk3 TDi random fuel gauge?
    By wardyma in forum Golf MK3 - 1993 - 1999
    Last Post: 20-09-2006, 03:47 PM
