Thread: 2.0TDI - 140, Whistle? Air leak on idle
  1. 2.0TDI - 140, Whistle? Air leak on idle
    Dec 2006
    MK5 Golf, 2.0TDI - 140, Whistle? Air leak on idle
    Check question...
    A mate of mine appears to have a air leak which is producing the sound of a whistle / hist on idle and under load..
    (before you say it... no its not the general nosie of the turbo!)
    Any common hoses on theses lumps which fail??
    Car appears to be running as expected, no loss of power or loss in MPG, no over rev's from auto chock etc etc...
    Im going to nip out shortly and have a look so any thoughts??
    Rick
  2. Re: 2.0TDI - 140, Whistle? Air leak on idle
    May 2007
    Liverpool
    Just check all the vacum pipes going to and from the turbo, check for lose connections and splits. Look everywhere there are quite a few.
    1998 Audi A4 2.8 V6 quattro
  3. Re: 2.0TDI - 140, Whistle? Air leak on idle
    Dec 2006
    Quote Originally Posted by chrisvrscrx View Post
    Cheers... is there a common hose?
    I will let you know my findings!
    Rick
  4. Re: 2.0TDI - 140, Whistle? Air leak on idle
    Dec 2006
    Just checked and the noise is the turbo spooling at 1500 rpm, its seems to be louder than normal, its pretty hard to exlain but its a "brrrrr" noise... once the rpm gets to around 2000rpm you hear the turbo whistling as normal and the sound fades under the noise of the engine..
    Just checked on another 2.0 TDI and the noise is there but its only about half as loud...
    Any ideas??
    Rick
  5. Re: 2.0TDI - 140, Whistle? Air leak on idle
    May 2007
    Liverpool
    Whats the mileage? Did you check all the hoses?
  6. Re: 2.0TDI - 140, Whistle? Air leak on idle
    Dec 2006
    Hi mate,
    Milage is around 35k on the effected car, and the milage on the car we compared is at 46k.
    I checked all the hoses i could, without taking the shield off.
    Theres no air leak of which i can seE??
    Rick
  7. Re: 2.0TDI - 140, Whistle? Air leak on idle
    Nr Falkirk
    If it's not effecting power masively I'd say it wasn't an air leak as the lack of a signal to the ECU would put it into limp home mode or just make it feel real slow I sorted a 1.9 Ibiza and the change was like night and day.
    Sounds like it might be a Turbo on the way out to me.
    Wonder if the sound is poor oil flow to the bearing on the turbo
    Ta Des
  1. Turbo whistle - right or not?
    By BenR in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 11-10-2007, 06:41 PM
  2. 2.0TDI developed a whistle/ whine on mid to high revs
    By Matt B in forum Chat - Anything with wheels
    Last Post: 10-10-2007, 10:50 AM
  3. What to buy A6 2.0TDI or A6 2.7TDI or A4 2.0TDI
    By sanstorm999 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-08-2007, 01:07 PM
  4. turbo Whistle
    By markclemo in forum Audi A3 - Archive Topics
    Last Post: 23-02-2007, 04:41 PM
  5. Air Induction Whistle
    By JSGTTDI in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-01-2007, 06:23 PM
