Thread: Engine Seized - MK6 GTD / Just 'Ticking'
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #11
    1840 Post(s)
    We have had two where is was associated with a worn DMF, not a SMF conversion. Dean, it is an incredibly comprehensive package including injectors, full timing belt set up including HPFP, oil filter, glow plugs and vacuum pump. If you consider the injectors alone are £2k and the HPFP £1.5k...
  2. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #12
    Dec 2007
    Dudley, West Midlands
    43 Post(s)
    That suddenly doesn’t sound too bad after whats been forked out here.
    Regards Dean Warren. VCDS owner/user
    A6 C7 3.0 BiTDi Quattro Avant 2012 S-Line Tech pack tour Pack ACC Blind spot folding mirrors Sold
    S6 C8 3.0 TDI Quattro Avant 2021 360 Camera Bose Extended leather.
  3. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #13
    Oct 2018
    London
    Hey all,
    I have an update from the mechanic - He has removed the top cover and bottom cover and theres no obvious damage
    He said once he removed the coupler (1 or 2) then the engine turns - once he puts them back on the engine doesnt turn?
    He said that the Flywheel, Gearbox, Starter motor and oil pump are all ok and theres no signs of any damage to the pistons (seen in the pictures below which I just took from visiting him)
    Attachment 37983
    Attachment 37984
    Attachment 37985
    Attachment 37986
    The coupling itself is fine he says as theres no cracks, nicks, dents so hes going to look deeper
    Has anyone else had this issue in the past?
  4. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #14
    Dec 2007
    43 Post(s)
    The pictures dont appear to work,
    What do you mean by coupler 1 and 2 ?
  5. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #15
    Oct 2018
    London
  1. '09 plate, 40k & engine seized - suggestions please
    By fergusmalhoon in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-11-2013, 05:32 AM
  2. Question A4 b5 1.8t seized engine
    By matty18T in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2011, 10:38 AM
  3. Question VW Golf engine seized - Cat D
    By tsam19 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2010, 10:34 AM
  4. Seized engine in '98 1.8T estate - any help or buyers
    By wheelywonderful in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-09-2009, 05:50 PM
  5. AUDI A4 TDI seized engine
    By oily-life in forum New Member Introductions
    Last Post: 03-02-2008, 03:47 PM
