Thread: Engine Seized - MK6 GTD / Just 'Ticking'
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #11
    49 Post(s)
    1140 Post(s)
    We have had two where is was associated with a worn DMF, not a SMF conversion. Dean, it is an incredibly comprehensive package including injectors, full timing belt set up including HPFP, oil filter, glow plugs and vacuum pump. If you consider the injectors alone are £2k and the HPFP £1.5k...
  2. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #12
    Dec 2007
    Dudley, West Midlands
    29 Post(s)
    That suddenly doesn’t sound too bad after whats been forked out here.
    Regards Dean Warren. VCDS owner/user
    Audi A6 Avant 2.5 TDi (AAT 115BHP) 305k Sold
    A6 180 sport 2.5 TDi Quattro Avant 2001. Half Leather 160K New Cams Fitted @ 154K
    A6 C6 3.0 TDi Quattro S-Line Avant with Exclusive Leather SatNav Bluetooth AMI LED and Xenon's
  3. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #13
    Oct 2018
    London
    Hey all,
    I have an update from the mechanic - He has removed the top cover and bottom cover and theres no obvious damage
    He said once he removed the coupler (1 or 2) then the engine turns - once he puts them back on the engine doesnt turn?
    He said that the Flywheel, Gearbox, Starter motor and oil pump are all ok and theres no signs of any damage to the pistons (seen in the pictures below which I just took from visiting him)
    Attachment 37983
    Attachment 37984
    Attachment 37985
    Attachment 37986
    The coupling itself is fine he says as theres no cracks, nicks, dents so hes going to look deeper
    Has anyone else had this issue in the past?
  4. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #14
    Dec 2007
    29 Post(s)
    The pictures dont appear to work,
    What do you mean by coupler 1 and 2 ?
  5. Re: Engine Seized - MK6 GTD / Just 'Ticking'
    #15
    Oct 2018
    London
  1. '09 plate, 40k & engine seized - suggestions please
    By fergusmalhoon in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-11-2013, 05:32 AM
  2. Question A4 b5 1.8t seized engine
    By matty18T in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-11-2011, 10:38 AM
  3. Question VW Golf engine seized - Cat D
    By tsam19 in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2010, 10:34 AM
  4. Seized engine in '98 1.8T estate - any help or buyers
    By wheelywonderful in forum Passat - B5 Forum - 1997 -2005
    Last Post: 16-09-2009, 05:50 PM
  5. AUDI A4 TDI seized engine
    By oily-life in forum New Member Introductions
    Last Post: 03-02-2008, 03:47 PM
