Thread: Rear brakes replacement - Audi Q7 4M
  1. Rear brakes replacement - Audi Q7 4M
    Jan 2020
    Norway
    I'm going to replace rotors and pads for my rear brakes. However I can not connect to module 53 Parking brake for opening the brake calipers. From the manual this is the procedure for Audi A6, but I can't see a manual for 2016- Q7 4M. However I find the same "start lining change mode" under module 3 ABS brakes. Is this the way to open the rear brake calipers in order to change pads? I have attached my screen print below.
    Thank you for your help!
  2. Re: Rear brakes replacement - Audi Q7 4M
    1840 Post(s)
    It isn't done in address 53, it is in address 03 ABS as per your picture.
  1. How To Audi A6 Allroad (2006 3.0 TDI) - Rear Air Bag and Rear Control Arm Replacement Advice
    By JACQuattro7 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-12-2019, 12:07 AM
  2. Question Audi A4 cabriolet brakes binding front nearside, rear offside to a lesser extent
    By geoffreytro in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2017, 11:24 PM
  3. Replies: 7
    Last Post: 02-01-2013, 01:16 PM
  4. Question Audi A4 avant rear motro replacement.
    By dworme in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 29-07-2012, 10:03 PM
  5. Question audi cabriolet 92-00 rear window replacement
    By gtbugboy in forum Chat - Anything with wheels
    Last Post: 12-05-2008, 08:33 PM
