Thread: 2010 audi s4 recode Abs Module
  1. 2010 audi s4 recode Abs Module
    Mar 2021
    Usa Michigan
    Hello everyone i have 2010 audi s4 got problem with abs module i send it to repaired they email me the processor is bad and they said it can not be fixed.
    Now can i buy a used one but how do i coded because i cant get anything from the old module. Just need to know if someone had an idea how to coded or it should be only option dealer?
  2. Re: 2010 audi s4 recode Abs Module
    1995 Post(s)
    VCDS should have a pop up with the coding choices you can work out using your Pr codes.
  3. Re: 2010 audi s4 recode Abs Module
    Mar 2021
    Usa Michigan
    Thank u for quick reply. Other questions is does I have to get long coding because I read some module they don't have long coding?
  4. Re: 2010 audi s4 recode Abs Module
    1995 Post(s)
    I can't recall but it is probably only a short form coding. The ABS unit may also be VIN protected.
  5. Re: 2010 audi s4 recode Abs Module
    Mar 2021
    Usa Michigan
    Thank you for your help . This is my module i can see they reprogram it in 2010 when the car was new.My question is what are those numbers BB-No: and Box-ID are they codes what i need?
    Thanks again for your help
  6. Re: 2010 audi s4 recode Abs Module
    1995 Post(s)
    The sticker in picture 1 I don't recognise, the others don't look like the soft coding value.
  1. Recode audi 8p door module
    By Andyhot in forum VCDS - General Questions
    Last Post: 15-09-2019, 08:03 PM
  2. How to recode Bluetooth module to q7
    By anilsandhu420 in forum VCDS - Help Requests
    Last Post: 10-11-2018, 05:33 PM
  3. Anyone near Ashford Kent who can recode airbag module
    By Demo8Dan in forum VCDS - Help Requests
    Last Post: 14-12-2015, 12:52 AM
  4. audi A3 8p, need to recode ESP ???
    By sthomson1 in forum VCDS - Help Requests
    Last Post: 28-06-2010, 07:22 AM
  5. Comfort module replaced, does keyfob need recode?
    By Golf-Princess in forum Golf MK4 - 1999 - 2004
    Last Post: 28-04-2010, 10:49 PM
