Thread: Clutch stiff spot on lifting
  1. Clutch stiff spot on lifting
    Jun 2019
    Braintree
    Hi there just picked up a A4 1.9 TDI 1996 and have a few problems the clutch stick's a bit when lifting just before it begins to bite so I keep nearly stalling and I can't reset the service reminder push and hold trip then ignition on and display still shows in2 flashing the trip button does work so any ideas?.
  2. Re: Clutch stiff spot on lifting
    Mar 2016
    Minervois, France
    53 Post(s)
    It's possible that the clutch pedal movement "sticking" is due to wear or fatigue of the diaphragm spring or the clutch lever inside the transmission housing.
    On 1996-97 A4 a scan tool is needed to reset the service reminder. From 1998 onwards, on some models, this could also be done by using the two buttons on the instrument cluster.
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  3. Re: Clutch stiff spot on lifting
    1836 Post(s)
    That sticking is usually a problem with the release bearing guide sleeve having a wear step or a worn/cracked fork but either way, box out.
  4. Re: Clutch stiff spot on lifting
    Jun 2019
    Braintree
    Cheers guys clutch Has improved with use now works smoothly car had stood for nearly 2 years so can only assume was like that due to lack of use can the service reminder be reset by vagcom VDS ?
  1. Question 1.9 TDi 130PS Stiff Clutch
    By jollyo55 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-07-2014, 01:28 AM
  2. Stiff clutch-any remedys?
    By scottjones924 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2010, 08:31 PM
  3. stiff clutch pedal has returned
    By con1981 in forum Bora - 1998 - 2005
    Last Post: 06-05-2009, 05:46 PM
  4. Stiff clutch pedal
    By RDL001 in forum Golf MK4 - 1999 - 2004
    Last Post: 03-02-2009, 06:39 PM
  5. Clutch gets extrmely stiff after bit of driving
    By Basscrazy in forum Golf MK3 - 1993 - 1999
    Last Post: 16-10-2007, 09:32 PM
