Thread: Avant high level brake light out.
  1. Avant high level brake light out.
    Apr 2021
    Chester , England
    Hi , my A6 avant third or high level brake light has stopped working , i have connected it directly to a battery and it works fine . I assume I should get 12 volts at the plug when the pedal is pressed but I am getting nothing .
    I have checked that the connection is not corroded and all the fuses at each end of the dash and now at a loss . I can only think that it might be a broken wire somewhere.
    Has anyone else experienced this and what was done to repair it..
  2. Re: Avant high level brake light out.
    Jan 2018
    GB
    Are you checking the voltage at the plug end from the plug itself or from a clean wire?... I've had problems before where the small connector at the end of the cable has failed (female from memory). It's quite delicate and can suffer from damp getting in...ive also had one of the pins from the light connection break inside it. The most common fault for me has been the light itself failing (been through 3).
    Sent from my GM1913 using Tapatalk
  3. Re: Avant high level brake light out.
    Jul 2008
    Lisburn
    15 Post(s)
    an other point to note that didn't help me when diagnosing a faulty light - when the car detects a fault - broken wire, bulb, whatever - it will cut the power to said light.
    so you will need to do a continuity check on wires rather than try and find the 12V.
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. B8 Avant high level brake light replacement
    By vincentbob in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-08-2018, 04:14 PM
  2. Please Help A6 C5 Avant High level/third brake light problem...
    By Stavros_Davros in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 12-09-2017, 01:52 AM
  3. Question replacing high level brake light a6 avant
    By RobTA6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 25-03-2016, 12:24 PM
  4. How Do I Change High Level Brake Light On Avant
    By dln6376 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-04-2014, 05:21 PM
  5. B7 Avant high level brake light
    By Brianx5 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-06-2009, 06:18 PM
