Thread: Slow to get up to temperature
  1. Slow to get up to temperature
    Jul 2015
    Ipswich, Suffolk
    Hi all, I hope I am not being a pain.
    Can you please shed some light on a problem I have discovered. With an ambient temperature of below 10 C, it can take up to 20 miles for the car to reach running temperature on the gauge.
    It could be as simple as the Thermostat stuck open, but I believe there is a second Thermostat that opens to feed water to the transmission, to cool the oil, does such a thing exist? this could also be at fault.
    Has anyone had any experience of this problem and what fixed it?
    Any help would be appreciated.
    Pat J.
    "Too much power is just enough." Carrol Shelby.
  2. Re: Slow to get up to temperature
    Jun 2006
    UK, Mids
    Yes, what year and engine?
    Audi A8 - 2015 - 3.0TDI
  3. Re: Slow to get up to temperature
    Jul 2015
    Ipswich, Suffolk
    Registered 2014 but it is a 2013 model, 4.2TDi 350 BHP. CDSB engine.
  4. Re: Slow to get up to temperature
    Oct 2019
    Peterborough, England
    23 Post(s)
    One of my D4s had an open valve/thermostat for the gearbox and oil cooling system.
    However, id did not affect the car getting up to temp at all (coolant temp wise anyway).
    i think it just affected the gearbox oil cooling.
    Does your car warm up quicker if you turn the climate control to Econ mode or even Off completely?
  5. Re: Slow to get up to temperature
    Jul 2015
    Ipswich, Suffolk
    Tried it today with the Climate switched off and it took roughly the same time.
  6. Re: Slow to get up to temperature
    Oct 2019
    23 Post(s)
    Might be easiest to replace the temp sender first.
    i think it sits at the top of the engine and should be reachable once the plastic cover is removed.
    check the Etka on line for the exact location. If it is where I said, then it is a 10 - 20 minute job if that.
  1. very slow
    By pete99 in forum Forum support and issues
    Last Post: 14-08-2012, 03:18 PM
  2. High Temperature Warning when the temperature is fine
    By Hairsy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-01-2012, 05:46 PM
  3. Slow Temperature Increase
    By LeBron in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-07-2010, 08:09 AM
  4. Temperature gauge reading lower than actual temperature
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2009, 04:29 PM
  5. slow A4 2.5 tdi
    By wavey-davey in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-07-2009, 08:48 PM
