Thread: Removal of rear caliper carrier bolts.
Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
  1. Re: Removal of rear caliper carrier bolts.
    1840 Post(s)
    Rubber! Was thinking more 3lb copper thwacking stick...
  2. Re: Removal of rear caliper carrier bolts.
    Mar 2021
    Ripon
    7 Post(s)
    Right job done. Rubber mallet loosened the discs and they lifted out with a bit of a wiggle and without having to remove the caliper carrier bolts (300mm solid discs).
    Outer pads were seized solid in the pad carriers on both sides due to rust build up. New Brembo discs and pads from ECP (£100) fitted and now all moving freely.
    The only issues I had were poor access to the top caliper bolt (7mm Hex) so I used the bit and an adjustable spanner.
    OBDELEVEN tool was playing up a bit but eventually wound pistons in/out and cleared the two error codes I was left with.
    Glad I did it myself. VW wanted £300 to do it and an indi probably £200 for inferior quality parts. I think I will clean the caliper carriers and regrease the pads annually at service time.
    Thanks for all your advice.
  1. Question rear caliper carrier bolts torque value
    By azen in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-07-2020, 12:55 PM
  2. Brake caliper carrier bolts
    By allymac in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-12-2019, 04:37 PM
  3. Rear brake carrier bolts broken please help!!
    By layerz in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 29-12-2013, 06:45 PM
  4. Question Jetta '08 needs new rear discs. Expect problems with calliper carrier bolts.
    By EdF in forum Jetta MK3 - 2005 - 2013
    Last Post: 11-09-2013, 10:45 AM
  5. Please Help Rear Caliper Carrier Bolts
    By belleekbeetle in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-08-2013, 12:27 PM
