Thread: A3 (with electronic parking brake ) rear brake disc replacement - some questions
  1. A3 (with electronic parking brake ) rear brake disc replacement - some questions
    Nov 2017
    Newmilns
    Hi - My rear brake pads are down to metal and damaged the disc - Looking to replace both discs & pads - Model has electronic parking brake - I have VCDS software which I believe I need to get the electronic drive to reset itself - so looking for answers to some other basic questions since my Haynes Manual only covers up to 2012 & does not discuss electronic parking brake systems :-
    1) What is the torque setting for the caliper bolts ( my old A3 8P was 35nm) - is this same for electronic brake version 8V ?
    2) Do these bolts need to be replaced when fitting new pads or OK to re-use old ones ?
    3) Is it possible to remove the disc without having to remove the caliper carrier ?
    4) If not - what is the correct torque settings for the carrier bolts ( old A3 stated 65nm), however saw a A6 video which seem to suggest much higher torques ~114-120nm
    2013 A3 1.6tdi sportback
  2. Re: A3 (with electronic parking brake ) rear brake disc replacement - some questions
    Nov 2017
    Newmilns
    1/2) In absence of any other information I decided to use same settings as old audi - ie re-used caliper bolts and torques to 35nm
    3) Great design (not) - definately needed to remove the carrier to get the discs off
    4) It appeared like the torque I needed to break them free was much greater than 65nm - so in absence of any new data = reused same bolts and torques to 70nm - more than old A3 ie 65nm
    If anyone can confirm the correct torques - much appreciated
  3. Re: A3 (with electronic parking brake ) rear brake disc replacement - some questions
    Nov 2017
    Newmilns
    In the absence of any information re torque - actually used the erwin site and did a flat rate 1HR charge and managed to download repair section for brakes ( + others) which detailed out the correct torque setting - for anyone else the bracket is torqued to 90nm+ 90 degree . Now need to source new bolts and torque to correct spec - do not want to do with existing bolts and risk damaging them and getting them stuck in
  4. Re: A3 (with electronic parking brake ) rear brake disc replacement - some questions
    1840 Post(s)
    NEVER retorque a TTY fastener to its original spec, if you have to reuse a TTY stick to the old idea of M8 20Nm, M10 45Nm.
  5. Re: A3 (with electronic parking brake ) rear brake disc replacement - some questions
    Nov 2017
    Newmilns
    what would an acceptable torque if reusing a M12 bolt ?
  6. Re: A3 (with electronic parking brake ) rear brake disc replacement - some questions
    1840 Post(s)
    50 maybe 60 but not TTY wise the usual 70 but reusing a TTY is not a good idea, only in exceptional circumstances.
  7. Re: A3 (with electronic parking brake ) rear brake disc replacement - some questions
    Nov 2017
    Newmilns
    Thanks - I actually torqued them up to 70nm which is still lower than the spec TTY from Audi of 90nm+90deg - should suffice until I can get new bolts and torque to spec.
  1. Question Changing Rear Brake Pads with Electronic Parking Brake
    By Mikeinho in forum Golf MK7 - 2013 - 2019
    Last Post: 24-08-2019, 03:10 PM
  2. Noisy rear brake calliper (electronic parking brake)
    By peter goble in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 07-08-2016, 06:41 PM
  3. Important HELP - Rear brake disc/ wheel bearing replacement
    By azumore in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-07-2015, 08:53 AM
  4. Question 2004 1.9tdi rear brake disc/pad replacement
    By unclespevie in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-11-2012, 01:36 PM
  5. electronic parking brake [EPG]
    By gtijohnny in forum VCDS - General Questions
    Last Post: 17-11-2008, 01:40 AM
