Thread: VCDS error on Can Gateway after retrofitting Lane assist and Traffic sign recognition
  1. VCDS error on Can Gateway after retrofitting Lane assist and Traffic sign recognition
    Feb 2021
    Portugal
    Hi all,
    I'm having a problem with my 2015 Touareg because Iretrofited several driver assistance items and cannot turn them working...
    The retrofit I made was adding the windshield camera, image processing unit and rate pitch sensor to have lane assist and traffic sign recognitions.
    The cables are from Kufatec and after conencting all the wires when I connect VCDS, I have errors on module 19 Can Gateway and 8E Image processing.
    This is part of the scan.
    The error on module 8E could be because my gateway cannot handle flexray?
    I need any help from anyone.
    Saturday,10,April,2021,17:02:57:55334
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 21.3.0.0 (x64) HEX-V2 CB: 0.4543.4
    Data version: 20210226 DS325.0
    www.Ross-Tech.com
    VIN: WVGZZZ7PZFD009373 License Plate:
    Mileage: 114642km-71235mi Repair Order:
    Chassis Type: 7P-VW52 (7P6)
    Scan: 01 02 03 05 06 08 09 10 15 16 17 19 22 32 34 36 42 46 52 53
    55 56 5F 62 65 69 6C 72 85 8E
    VIN: WVGZZZ7PZFD009373 Mileage: 114642km-71235miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    06-Seat Mem. Pass -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    22-AWD -- Status: OK 0000
    32-Differential Locks -- Status: OK 0000
    34-Level Control -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    65-Tire Pressure -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8E-Image Processing -- Status: Cannot be reached 0100
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 7P6 907 530 M HW: 7P6 907 530 F
    Component: GW-CAN-L-MOST H13 6042
    Revision: -------- Serial number: 00000001669421
    Coding: 000D0FAD00
    Shop #: WSC 31414 790 00001
    ASAM Dataset: EV_GatewVW526UDS 001007
    ROD: EV_GatewUDS_VW52.rod
    VCID: 42DCB5BC5402537BD97-8016
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
    Component: Batt_Sensor H07 0190
    Serial number: 41328F28565701129653
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
    Component: J532_DCDCStab H17 0042
    Serial number: 14343005053021200181
    Battery Monitoring Control Module 2:
    1 Fault Found:
    0276 - FlexRay Databus
    U1032 00 [009] - Initialization Failed
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 41
    Mileage: 114642 km
    Date: 2021.04.10
    Time: 16:56:52
    Voltage terminal 30: 12.3 V
    Voltage terminal 15: 12.3 V
    Control Module temperature: 35 °C
    System status: Terminal 15 on
    IN ESP_standstill flag: standstill detected
    Engine running: OFF
    IN ZAS_Te_X: On
    Terminal 15 status via CAN: On
    Terminal 15 status: On
    Datenfeld: 0
    Address 8E: Image Processing
    Cannot be reached
    End----------(Elapsed Time: 02:14, VBatt start/end: 12.4V/12.4V)-----------
  2. Re: VCDS error on Can Gateway after retrofitting Lane assist and Traffic sign recognition
    134 Post(s)
    2007 Post(s)
    I had an issue with the flex ray on a 2016 series 2 Touareg a few weeks ago after I had installed a new (used) radio receiver and it was due to “component protection” with the VIN of the donor cars radio conflicting with the VIN stored in the car; as I am a registered ODIS user with GEKO security access I was able to deal with this but it was an odd procedure (my first time) with the car communicating with the VW server in Germany and not telling me what it was doing, it just informed me that the cars build recorded had been amended. This won’t be the problem with the image processor, you have put an address in the CAN installation list that it cannot find.
  1. Traffic sign recognition nearly coded
    By M1tchy in forum VCDS - Help Requests
    Last Post: 11-10-2023, 08:00 AM
  2. Camera-based traffic sign recognition
    By robgr in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 28-10-2020, 07:19 PM
  3. Traffic sign recognition Parameterisation
    By sarah1331 in forum Audi A6 - C8 Forum - 2019 -
    Last Post: 10-03-2020, 12:08 PM
  4. Traffic Sign Recognition
    By Justinos in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 05-11-2018, 12:24 PM
  5. Traffic sign recognition
    By Snatchrat in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 24-01-2017, 09:54 PM
