Thread: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
  1. Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    Birmingham, West Midlands
    Hi I am looking to swap out my engine for another 1.6 FSI.
    Looking at ETKA there is a few engine codes I can use BKG, BLN, BAG, BLP, BLF.
    They only noticeable difference I can see is with the fuel pump and fuel lines......
    See images below.
    My BAG Engine code variant has the older style HPFP with 4 mounting bolts and 3 lines / pipes coming from it (the newer ones have only 3 mounting bolts and 2 lines / pipes coming
    from the pump).
    Looks like mine has additional breather line? The fuel tank images from ETKA also show 2 options for part number 3 (or 3A) - where it either has 2 lines / pipes or 3 lines / pipes.
    Would one be redundant or would I need to remove the additional pipe? Or do I need different fuel pump (LPFP / in tank pump) and fuel tank to be able to retrofit this engine?
    Will there be any issue retrofitting another engine to my vehicle?
    Will anything need to be coded or paired? Or is it simply a straight swap?
    Appreciate any help.
    Thanks.
  2. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    47 Post(s)
    1100 Post(s)
    A quick look shows the pre 2005 BAG had different cams so if yours is a 2004, the late cams may upset the ECU.
    IF you like me are furious at this undemocratic ban on the sale of new petrol and Diesel engined cars, please sign this petition https://petition.parliament.uk/petitions/556842
  3. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    Ahh ok so need to find an engine that is like for like? Has to have the same HPFP? Has to be BAG from 2004?
  4. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    47 Post(s)
    1100 Post(s)
    Is yours 2004?
  5. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    Yep mine is from 2004.
  6. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    47 Post(s)
    1100 Post(s)
    I think with the early cams the ECU may get confused, the HPFP SHOULD just be a matter of fitting the later type but these ECU's are so sensitive I have seen them object to even having the slightly incorrect gearbox fitted.
  7. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    Ok so it has to be an early BAG engine which is the one with the square / rectangular looking silver HPFP? With 4 x mounting bolts?
    from what I can see the later HPFP only has 3 mounting bolts....
    therefore also has a different rocker cover?
    guess that means you can’t swap rocker covers and cylinder heads over?
  8. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    47 Post(s)
    1100 Post(s)
    I can't see a problem in swapping the heads.
  9. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    Got myself another BAG engine from an 8P Audi...... done half the mileage that mine has..... ~100,000
    Same early style fuel pump on it too which means I can transfer my ancillaries onto this engine.
    Looks like its had work on it already.....new chains (oil pump chain and timing chain), new chain guides, new tensioner....
    Also looks like a new head gasket.....it also had a VW parts box with roller coc on it (036 109 411 D) so think some cylinder head work has been done too....new rockers, tappets etc.....
    Intake valves look super clean.....either new....or have been walnut blasted / cleaned.
    Exhaust valves don't look like they've been touched though?
    What checks should I do on this other engine to ensure it is ok prior to fitting?
  10. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    47 Post(s)
    1100 Post(s)
    There isn't much more you can do, good luck with the fitting.
  1. Vag com engine module log in code required passat 2.5 tdi 2004 (bdg engine code)
    By garyjwilson in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-07-2015, 05:24 PM
  2. Vag com engine module log in code required passat 2.5 tdi 2004 (bdg engine code)
    Last Post: 30-06-2015, 02:31 PM
  3. Access code for engine control unit...A4 '10' chassis 8K 2.0L TFSI engine code CDNCAs
    By baylissboy in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 18-02-2015, 10:17 PM
  4. Replies: 1
    Last Post: 25-05-2013, 12:43 PM
  5. Question Audi a4 b5 engine swap turbo engine
    By mcgill1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-06-2011, 05:41 PM
