Thread: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
Results 11 to 20 of 34
  1. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Thanks fingers crossed it won’t be too challenging.
    Going to do it at a friends garage so will have all the kit I need there.
    Is the best way or only way to do the job to remove front lock carrier / slam panel and remove engine that way?
    Only thing I saw that might be a bit of a pain. It’s missing some of the exhaust studs.
    Are these easy to install / remove? (Thinking of either buying some new ones or taking them off the other engine?)
  2. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    1840 Post(s)
    Get new studs from TPS, double jam nut them to install.
  3. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    8 Post(s)
    Well it’s confirmed after doing a compression check that cylinder 2 is down on compression.
    Readings are:
    Cylinder 1 135psi
    Cylinder 2 100psi
    Cylinder 3 145psi
    Cylinder 4 140psi
    Didnt so the a leak down test as don’t have the correct equipment.
    Need to buy one to further investigate to see if it’s the pistons / piston rings leaking or if it’s a cylinder head issue
    Could be worn valve guides or burnt valves???
    Is it worthwhile investigating further?
    Ive got another engine ready to be installed.
    Guess I could always remove the head off the old engine to see what it looks like?
  4. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    1840 Post(s)
    With a BAG it is nearly always a worn exhaust valve guide causing a valve to burn, personally I would rebuild; we are just doing a BMY...
  5. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    Jul 2018
    8 Post(s)
    So got the rocker cover off and some of the tappets are stuck. Some spring back and forth and others seem seized? Is this normal or do they need replacing?
    they are called equalising element hydraulic 030 109 423
  6. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    1840 Post(s)
    They don’t have much movement and you should replace them anyway, aftermarket they are the rings are dirt cheap and available everywhere as they are used right up into the big Audi engines.
  7. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    #17
    Jul 2018
    8 Post(s)
    Got the engine in and it all runs ok.
    But it’s overheating.
    Guessing one of the thermostats isn’t working or the head / engine is blocked?
    Any suggestions would be appreciated.
  8. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    #18
    1840 Post(s)
    Does the fan come on?
  9. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    #19
    Jul 2018
    8 Post(s)
    Yep fan comes on.
  10. Re: Engine Swap - Fitting a 1.6 FSI BLF or BLP into a BAG engine code
    #20
    1840 Post(s)
    Have you monitored the temperature at the head sensor and the radiator lower left outlet using measuring blocks?
  1. Vag com engine module log in code required passat 2.5 tdi 2004 (bdg engine code)
    By garyjwilson in forum Passat - B5 Forum - 1997 -2005
    Last Post: 20-07-2015, 05:24 PM
  2. Vag com engine module log in code required passat 2.5 tdi 2004 (bdg engine code)
    Last Post: 30-06-2015, 02:31 PM
  3. Access code for engine control unit...A4 '10' chassis 8K 2.0L TFSI engine code CDNCAs
    By baylissboy in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 18-02-2015, 10:17 PM
  4. Replies: 1
    Last Post: 25-05-2013, 12:43 PM
  5. Question Audi a4 b5 engine swap turbo engine
    By mcgill1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-06-2011, 05:41 PM
