Thread: ACC, Parking Sensors and Stop Start not working
  1. ACC, Parking Sensors and Stop Start not working
    Jul 2012
    United Kingdom
    Hi all,
    I have a major issue with my 2013 VW Golf MK7 GT, 2.0 TDI
    One day in the evening I got an ACC error on the dash, then over the next few days the parking sensors and stop start also errored.
    I have changed the battery.
    I have checked the fuses, 2 fuses are not working (even if I swap them out with known fuses) these are locations 22 and 23 in the engine fuse box.
    I cannot interrogate the modules in VCDS as they are unreachable.
    Any ideas?
    Thank you in advance.
    Code:
    Sunday,04,April,2021,14:32:32:29712
    VCDS Version: 21.3.0.0 (x64)
    Data version: 20210226 DS325.0
    Ross-Tech: Home
    VIN: WVWZZZAUZDW134123   License Plate:
    Mileage: 118418km-73581mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 55 5F
    VIN: WVWZZZAUZDW134123   Mileage: 118418km-73581miles
    01-Engine -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: Cannot be reached 0100
    13-Auto Dist. Reg -- Status: Cannot be reached 0100
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CRBC)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 021 DS    HW: 04L 907 309 D
       Component: R4 2,0L EDC   H22 5514
       Revision: 83H22---
       Coding: 01190032034505082000
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_ECM20TDI01104L906021DS 002009
       ROD: EV_ECM20TDI01104L906021DS_002.rod
       VCID: 79F2FF63F8AD424384-802C
    2 Faults Found:
    9803 - No Communications with Parking Assist Control Module A
              U0159 00 [039] - -
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
                        Engine RPM: 771.00 /min
                        Normed load value: 18.8 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 88 °C
                        Intake air temperature: 58 °C
                        Ambient air pressure: 1010 mbar
                        Voltage terminal 30: 13.340 V
                        Unlearning counter according OBD: 40
                        Limitation: accelerator pedal: 0.0 Nm
                        CAN status - engine control module-Bits 0-7: 0
                        Cruise Control System (CCS): status-Bits 0-7: 7
                        CAN status - transmission control module-Bits 0-7: 0
                        CAN status - brake control module 1-Bits 0-7: 0
                        CAN status - brake control module 2-Bits 0-7: 0
                        selected gear-Bits 0-7: 0
    4709 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [039] - -
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
                        Engine RPM: 770.00 /min
                        Normed load value: 18.4 %
                        Voltage terminal 30: 13.380 V
    Readiness: 0 0 0 0 1
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
       Part No SW: 5Q0 907 379 AC    HW: 5Q0 907 379 D
       Component: ESC           H75 0437
       Revision: 00000000    Serial number:
       Coding: 01FA8AA120230A700378060201C62980510450C0608094F3F4685026C0
       ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
       ROD: EV_Brake1UDSContiMK100IPB_008.rod
       VCID: 7DFAEB73EC857E63A8-8028
    2 Faults Found:
    8196 - Databus
              U1121 00 [137] - Missing Message
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
    8260 - Databus
              U1121 00 [009] - Missing Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
    Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
       Part No SW: 5G0 907 044 R    HW: 5G0 907 044 R
       Component: Climatronic   H02 0503
       Revision: 00001K06
       Coding: 00120104202100011005000000101000
       ASAM Dataset: EV_ACClimaBHBVW37X 002017
       ROD: EV_ACClimaBHBVW37X_002_VW37.rod
       VCID: 3668345F89336D3B29-8062
    1 Fault Found:
    328197 - Motor for Right Temperature Flap
              B108D 54 [009] - Missing Calibration / Basic Setting
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
       Part No SW: 5Q0 937 084 Q    HW: 5Q0 937 084 Q
       Component: BCM MQBAB H   H14 0106
       Serial number: 00011308600381
       Coding: 03000A46C24122FB0FA44080B11C0728100A000000000000000000000000
       ASAM Dataset: EV_BCMCONTI 010001
       ROD: EV_BCMBOSCH_010.rod
       VCID: 4688449FF9D3FDBBB9-8012
       Wiper motor control module:
       Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
       Component: WWS    130309  042 0551
       Serial number:         130312105424
       Coding: 0E4DD5
       Rain/Light Recognition Sensor:
       Subsystem 2 - Part No SW: 5Q0 955 547     HW: 5Q0 955 547   Labels: 5Q0-955-547.CLB
       Component: RLFS  024 0042
       Serial number: Y13M04D02H07M27S36S4
       Coding: 00A8DD
       Anti-theft alarm system sensor:
       Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
       Component: Sensor, DWA  005 0313
       Serial number: 000000000ZY130590BJX
       Alarm horn:
       Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
       Component: Sirene, DWA  004 0311
       Serial number: 00000000000056247127
    No fault code found.
    Address 10: Park/Steer Assist
    Cannot be reached
    Address 13: Auto Dist. Reg
    Cannot be reached
    Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
       Part No SW: 5Q0 959 655 M    HW: 5Q0 959 655 M
       Component: AirbagVW20    011 0361
       Serial number: 003M1R026U9E
       Coding: 98CCC000000000005C0000CF00C800000065
       ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
       ROD: EV_AirbaVW20SMEVW37X_VW37.rod
       VCID: 4A9070AFEDCB19DB5D-801E
       Left seat belt tensioner:
       Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
       Component: BeltPretRevFL  H35 0340
       Serial number: 34169677A27031350346
       Coding: 333135
       Right seat belt tensioner:
       Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
       Component: BeltPretRevFR  H35 0340
       Serial number: 34169676A27031340114
       Coding: 333135
       Crash sensor for side airbag: driver side:
       Subsystem 3 - Part No SW: -----------    HW: 480 002 203 13
       Component: SideSensor_Df  001 0887
       Serial number: 357670000006A9494C0$
       Coding: 2D2D2D
       Front Passenger's Side Airbag Crash Sensor:
       Subsystem 4 - Part No SW: -----------    HW: 480 001 903 13
       Component: SideSensor_Pf  001 0887
       Serial number: 358670000000E9FC3C08
       Coding: 2D2D2D
       Rear Side Airbag Crash Sensor (on driver's side):
       Subsystem 5 - Part No SW: -----------    HW: 480 402 003 13
       Component: SideSensor_Dr  001 6149
       Serial number: 3516502B90FBDE34A06W
       Coding: 2D2D2D
       Passenger side rear thorax airbag crash sensor:
       Subsystem 6 - Part No SW: -----------    HW: 480 401 903 13
       Component: SideSensor_Pr  001 6149
       Serial number: 3526502B30FAE8A4114I
       Coding: 2D2D2D
       Crash sensor for front airbag: driver side:
       Subsystem 7 - Part No SW: -----------    HW: 480 401 503 13
       Component: FrontSensor_D  001 6149
       Serial number: 3556502AF0FAE89102D.
       Coding: 2D2D2D
    Address 16: Steering wheel (J527)       Labels:. 5Q0-953-549.clb
       Part No SW: 5Q0 953 507 AG    HW: 5Q0 953 549 A
       Component: Lenks. Modul  007 0070
       Revision: --------    Serial number: 22031304220263
       Coding: 0D00
       Shop #: WSC 40195 333 37120
       ASAM Dataset: EV_SMLSKLOMQB 009001
       ROD: EV_SMLSKLOMQB_009_VW37.rod
       VCID: 7BFEE56BF291705396-802E
    No ASAM data for: "EV_SMLSKLOMQB" (VW37)
    Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
       Part No SW: 5G0 920 970 A    HW: 5G0 920 970 A
       Component: KOMBI         336 0555
       Coding: 27A401002F90260001886A01040000
       ASAM Dataset: EV_DashBoardVDDMQBAB 008026
       ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
       VCID: 2854EA2753870BCBAB-807C
    4 Faults Found:
    16777028 - Function Restricted due to Interrupted Communications
              U1110 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
    16776960 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    16776961 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    16776980 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 F    HW: 5Q0 907 530 F
       Component: GW MQB High   125 1109
       Revision: --------    Serial number: 0000424965
       Coding: 030100040B087300EF00065C080F00010001000000000000000000000000
       ASAM Dataset: EV_GatewLear 006010
       ROD: EV_GatewLear_006.rod
       VCID: 346C0E579F4F7F2B17-8060
       Generator:
       Multifunction steering wheel control module:
       Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H14 0035
       Serial number: 23130000311330040291
       Coding: 2C0000
       Battery Monitoring Control Module:
       Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
       Component: J367-BDMHella  H03 8042
       Serial number: 9839580103
    2 Faults Found:
    131594 - Parallel Parking Assistance Control Module
              U104E 00 [009] - No communication
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
                        Terminal 30 power supply: 13.3 V
                        Terminal 15: On
    131671 - No Communications with Cruise Control (Front) Distance Sensor
              U0235 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
                        Terminal 15: On
    Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
       Part No SW: 5Q0 959 593 A    HW: 5Q0 959 593
       Component: TSG FS        012 0006
       Serial number: 26031304080180
       Coding: 003B0220D001048000001000
       ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
       ROD: EV_DCUDriveSideEWMAXCONT.rod
       VCID: 3F86517BA609AC73FA-806A
       Rear Driver Side Door Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG DRV  007 0002
       Serial number: 00000000000001079025
       Coding: 0D0000
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 L
       Component: EPS_MQB_ZFLS  119 1021
       Coding: 83
       ASAM Dataset: EV_SteerAssisMQB 008022
       ROD: EV_SteerAssisMQB_008.rod
       VCID: 3D7A2B73AC05BE63E8-8068
    2 Faults Found:
    19204 - Databus
              U1123 00 [008] - Received Error Message
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 88
                        Reset counter: 84
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 13.25 V
                        Temperature: 30.0 °C
                        KFC: 4B
                        KFA: 00 04
                        Freeze frame conditions: 21
                        uAdSensI_U1V2Filtered_gdu16: 1.20 V
                        uAdSensI_U5VFiltered_xdu16: 5.05865 V
                        uioUdNotFilt_xdu16: 13.31 V
                        uAdSensI_SwitchedKl30_xdu16: 13.31 V
                        ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
    23552 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
                        Motor status: 01
                        KFC: 5C
                        KFA: 00 00
                        Freeze frame conditions: 5F
    Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
       Part No SW: 5Q0 959 592 A    HW: 5Q0 959 592
       Component: TSG BFS       012 0006
       Serial number: 28021302090988
       Coding: 003B0020DE01048000801000
       ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
       ROD: EV_DCUPasseSideEWMAXCONT.rod
       VCID: 3E782C7FA103A57BF1-806A
       Rear Passenger Door Control Module:
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Component: Fond FHSG PSG  007 0002
       Serial number: 00000000000001069660
       Coding: 050000
    Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
       Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
       Component: LWR-ECU       005 0070
       Revision: --------    Serial number: --------------
       Coding: 029E000001000000
       ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
       ROD: EV_HeadlRegulVWLWRMQB.rod
       VCID: 75EAF353D4B52623E0-8020
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD1.clb
       Part No SW: 5G0 035 858     HW: 5G0 035 858
       Component: MU-S-ND-ER    039 0170
       Serial number: V5F01503130047
       Coding: 02730001FF00000021111201002800001F0100060100010045
       ASAM Dataset: EV_MUStd4CPASE 002036
       ROD: EV_MUStd4CPASE_VW37.rod
       VCID: 69D2AF23880DF2C374-803C
       Display and control head 1 for information electronics:
       Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
       Component: ABT_Std_Nav  H44 0020
       Serial number: VWZ8Z9N3401GBG
       Data carrier:
       Subsystem 2 - Part No SW: 5G0 919 866 D    HW: -----------
       Component:  ECE 2013  --- 0021
       Serial number: --------------------
    3 Faults Found:
    7173 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
                        Voltage terminal 30: 13.3 V
                        BAP-BAP_Function_ID: 02
    7178 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
    7195 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:11
    End-------------------------(Elapsed Time: 03:40)--------------------------
  2. Re: ACC, Parking Sensors and Stop Start not working
    1836 Post(s)
    If you have damp in the car (a perpetual Golf 7 problem) the main relay inside the glovebox can suffer condensation and shuts almost everything down.
  3. Re: ACC, Parking Sensors and Stop Start not working
    Mar 2022
    Durban
    Was there a fix on this one?
    I am experiencing similar problems.
    Quote Originally Posted by lithium View Post
    Hi all,
    Any ideas?
    Code:
    Ross-Tech: Home
       Revision: 83H22---
    2 Faults Found:
              U0159 00 [039] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
              U0235 00 [039] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    2 Faults Found:
    8196 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
    8260 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 4
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
       Revision: 00001K06
    1 Fault Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
       Coding: 0E4DD5
       Coding: 00A8DD
       Alarm horn:
    Cannot be reached
    Cannot be reached
       Coding: 333135
       Coding: 333135
       Coding: 2D2D2D
       Coding: 2D2D2D
       Coding: 2D2D2D
       Coding: 2D2D2D
       Coding: 2D2D2D
       Coding: 0D00
    4 Faults Found:
              U1110 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
    16776960 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    16776961 - Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
    16776980 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
       Generator:
       Coding: 2C0000
    2 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
                        Terminal 15: On
              U0235 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:06
                        Terminal 15: On
       Coding: 0D0000
       Coding: 83
    2 Faults Found:
    19204 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 88
                        Reset counter: 84
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:05
                        Motor status: 01
                        KFC: 4B
                        KFA: 00 04
    23552 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
                        Motor status: 01
                        KFC: 5C
                        KFA: 00 00
       Coding: 050000
       Data carrier:
    3 Faults Found:
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:08
              U1111 00 [009] - -
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 44
                        Mileage: 118418 km
                        Date: 2021.04.04
                        Time: 14:22:11
  4. Re: ACC, Parking Sensors and Stop Start not working
    1836 Post(s)
    That is often water damage to the sensor or it has been stolen which is a big problem, then a new one has to be set up by an ADAS specialist and the one we use charges £280, we have a 2015 R here today with the same issue... plus others! The sensor, part number 5Q0 907 541 J, is £1600.84 but when stolen, there is often wiring damage to deal with so typical it ends up as a £2k job.
  1. Parking sensors not working
    By I_Need_Help in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-04-2018, 08:46 PM
  2. Replies: 4
    Last Post: 19-03-2018, 11:04 AM
  3. Parking sensors not working ? Please help
    By Q7quattro in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 22-05-2014, 07:17 PM
  4. Parking sensors not always working
    By Little_Legs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 06-12-2011, 08:52 PM
  5. parking sensors not working
    By Bizzie in forum Octavia
    Last Post: 24-12-2010, 09:36 PM
