Thread: 2004 t5 2.5tdi axd boost issue.
  1. 2004 t5 2.5tdi axd boost issue.
    Apr 2021
    uk
    hi everyone.
    As the title suggests i have a boost issue with my new t5. i brought the vehicle with the issue, its flat when driving, no power and worst no boost.
    the vehicle has had all the usual new turbo, maf, map, vacuum control valves, intercooler, fuel filter etc
    underboost code present when i bought it. i have come to check the induction side for boost leaks etc and its reading negative boost pressure when reving the engine. going from 1010mbar at 1000rpm to 900mbar at 2500rpm. checked for any blockages and no fault found on the induction system, turbo spools up with boost pipe off creating plenty of pressure and have used mtty vac to create pressure on the sensor and vaccum both reading correctly on live data through the launch that i have.
    question is have any of you come across this issue before?
    regards
    matt
  2. Re: 2004 t5 2.5tdi axd boost issue.
    1837 Post(s)
    What is the fault code number you are seeing?
  1. Strange boost issue (base boost sometimes)
    By fivepointnine in forum Leon
    Last Post: 10-04-2017, 11:48 AM
  2. Brake servo issue and possible linked boost issue
    By slipperyox in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 02-10-2012, 10:06 PM
  3. Question Over boost on a tdi 130bhp, 2004
    By granttd73 in forum Leon
    Last Post: 06-10-2011, 08:27 PM
  4. boost range 2.5tdi
    By willster in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-04-2008, 10:03 PM
  5. T4 2.5TDi boost pressure - what should it be?
    By DubDick in forum The Commercial Range
    Last Post: 04-09-2007, 12:26 PM
