Thread: 2016 Leon blower motor stopped working
Results 1 to 10 of 26
  1. 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    The interior blower has stopped working on the wife's leon (2015 1.6 tdi tech, aircon and dials not climate control)
    Aircon lights up as usual when you turn the fan control dial
    Nothing at all from the fan on any setting even full
    Checked fuse - ok
    popped the blower motor out, turns freely.
    12 direct to the motor and works as it should
    Which makes me think resistor pack.
    However, when this happened on our 08 touran the fan would still work on the unresisted full speed setting whereas this one doesn't
    With prices of resistor packs/new motors being around £155 is there anything else I can check to make sure it's definitely that before forking out?
    With an 500 mile round trip next week need to try and get it sorted asap
    Thanks!
  2. Re: 2016 Leon blower motor stopped working
    1836 Post(s)
    I can’t check the wiring diagram to remind myself of the logic but the controller is described as that and not a resistor and has a new part number 5WA 907 521.
  3. Re: 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    Hi Crasher, thanks for the reply. good to see you're still about.
    Swapped it for a known good fan and controller pack out of a mates and nothing.
    Been googling and found loads of the traditional ' my blower only works on max' but only one about it not working at all.
    That seemed to involve various trips to seat dealer replacing controller/fan/matrix and then the problem being found as the pressure sensor for the aircon.
    Does that sound at all feasible?
    The aircon switches on automatically every time you turn the fan on so am wondering.
    Would it show up on vcds? (getting mine back off my mate tonight)
    Thanks.
  4. Re: 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    Ran vcds this morning got this below.
    I must be doing something wrong as neither of these codes seem to exist when searching on ross-tech.
    google search gives no results either.
    Anyone got any pointers? thanks
    Address 08: Auto HVAC (J301) Labels:| 5G0-907-426.clb
    Part No SW: 5F0 907 426 M HW: 5F0 907 426 M
    Component: AC Manuell H02 1001
    Revision: 00001K09
    Coding: 00100104200100001000000000001000
    Shop #: WSC 00049 770 00107
    ASAM Dataset: EV_ACManueBHBVW37X 003017
    ROD: EV_ACManueBHBVW37X_003.rod
    VCID: 3467CD849F992A2B17-8060
    1 Fault Found:
    459779 - Local Databus
    U1030 00 [009] - Electrical Malfunction
    [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
    Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 6
    Fault Frequency: 30
    Reset counter: 212
    Mileage: 106573 km
    Date: 2021.03.31
    Time: 07:42:51
  5. Re: 2016 Leon blower motor stopped working
    1836 Post(s)
    Have you checked to see if the controller has power on the 2.5mm red/yellow wire?
  6. Re: 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    Thanks for the reply.
    Yes, there's power to it (with ignition on and off)
  7. Re: 2016 Leon blower motor stopped working
    1836 Post(s)
    Then looking at the diagram and knowing the controller/fan are OK, the problem must be with the signal from the I would say the problem must be the signal from the controller.
  1. Please Help Heater blower motor and wiper jets just stopped working HELP somebody Please
    By Rossh in forum Touran - Sharan - Caravelle
    Last Post: 07-11-2018, 07:40 PM
  2. Question Washer motor and heater blower fan stopped working VCDS scan included
    By adamkm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-09-2014, 01:17 PM
  3. Heater/Blower stopped working
    By scottjay86 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2010, 12:10 AM
  4. Please Help Heater/Blower Motor Intermitant now stopped?
    By waynex1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2008, 09:30 AM
  5. mk3 vento blower stopped working
    By aphex2k in forum Golf MK3 - 1993 - 1999
    Last Post: 02-03-2008, 11:51 PM
