Thread: 2016 Leon blower motor stopped working
Results 11 to 20 of 26
  1. Re: 2016 Leon blower motor stopped working
    1840 Post(s)
    Is it a stop/start model?
  2. Re: 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    Yep, but ignore that last post. Was the battery. After a quick drive all warning lights gone.
    Original issue of the fan still remains though.
  3. Re: 2016 Leon blower motor stopped working
    1840 Post(s)
    Modern cars are so sensitive to a weak battery. Have you checked the continuity of the wire?
  4. Re: 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    Sorry been a bit busy with work. Was going to do this at the w/e, but today the mrs put the rear wiper on whilst driving and immediately all the same warning lights as before have come on - abs/traction/headlight range/start/stop etc. Wondering if there's an electric gremlin somewhere that's either killed the 2 week old battery (shows fully charged on my basic traffic light style tester) or the loom has got damaged and is earthing somewhere.
    Found this thread - intermittent-issue-help-please.438169/#post-4723964 - which says the blower/12v socket and rear wiper are on the same circuit. But it's for a mk2 rather than a mk3 and there's no 373 relay on my wifes.
    Spoke to a mate who is good with this sort of things. He thought it might be a relay so tried plugging a phone charger into the 12v socket with ignition on and removed the relays one at a time to see if one would turn the power off to the 12v socket but none did.
    Tried all the relays in the fusebox under the bonnet and behind the glovebox so am guessing there is no relay for it.
  5. Re: 2016 Leon blower motor stopped working
    1840 Post(s)
    Private message me the cars reg? Do you have any signs of damp in the cabin?
  6. Re: 2016 Leon blower motor stopped working
    Mar 2014
    midlands
    Will do, thank you. Not noticed anything. It started happening in the middle of the recent 6 week or so dry spell. But saying that it does mist up quite easily in winter.
    Are there various modules under the carpets?
  7. Re: 2016 Leon blower motor stopped working
    #17
    1840 Post(s)
    There is nothing in the knows faults on my system that matches but a few months ago we did have a 2016 Altea that was doing some very odd things I could not pinpoint and then the owner said smoke had come out of the passengers door lock! I found this in there which was a manufacturing fault where the door harness had become trapped, it wiped out the CAN BUS and convenience units.
  8. Re: 2016 Leon blower motor stopped working
    #18
    Mar 2014
    midlands
    Worth a look, thanks. Will investigate that and the rest of the wiring as much as i can over the w/e.
    Do you know where abouts the convenience unit/module is?
  9. Re: 2016 Leon blower motor stopped working
    #19
    Mar 2014
    midlands
    My mates just dropped off my vcds. Plenty of codes this time around. Cleared them and same ones come back. Log below (I've snipped out the ones with no faults)
    Code:
    Friday,30,April,2021,15:29:31:41541
    VCDS Version: 21.3.0.0 (x64)
    Data version: 20210226 DS325.0
    Ross-Tech: Home
    VIN: VSSZZZ5FZGR009866   License Plate: SEATV3
    Mileage: 108266km-67273mi   Repair Order:
    Chassis Type: 5F-SE37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F
    VIN: VSSZZZ5FZGR009866   Mileage: 108266km-67273miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    55-Headlight Range -- Status: Malfunction 0010
    5F-Information Electr. -- Status: OK 0000
    Address 01: Engine (2D2D2-CXXB)       Labels:. 04L-907-309-V1.clb
       Part No SW: 04L 906 056 CL    HW: 04L 907 445 B
       Component: R4 1.6l TDI   H06 2370
       Revision: 22004001
       Coding: 01114012432519090000
       Shop #: WSC 00049 770 00124
       ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
       ROD: EV_ECM16TDI03004L906056_002_VW37.rod
       VCID: 79F93CB0F87B174384-802C
    1 Fault Found:
    25126 - Databus
              U1123 00 [039] - Received Error Message
              Not Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 6
                        Fault Frequency: 1
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:09:38
                        Engine RPM: 0.00 /min
                        Normed load value: 0.0 %
                        Vehicle speed: 0 km/h
                        Coolant temperature: 52 °C
                        Intake air temperature: 29 °C
                        Ambient air pressure: 990 mbar
                        Voltage terminal 30: 12.453 V
                        Unlearning counter according OBD: 40
                        CAN status - engine control module: 0
                        Cruise Control System (CCS): status: Initialization
    Readiness: N/A
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-ESP-V1.clb
       Part No SW: 3Q0 907 379 T    HW: 3Q0 907 379 C
       Component: ESC           H32 0393
       Revision: 00000000    Serial number: 61335000000399
       Coding: 20EE8A9224200975007F060641C9240451249000608224F200410070C002
       ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
       ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
       VCID: 4B95B678E26755D366-801E
    2 Faults Found:
    4197 - Rear Left Wheel Speed Sensor
              C101C 14 [137] - Open or Short to Ground
              MIL ON - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 8
                        Date: 2021.04.29
                        Time: 15:09:39
    16417 - Display for Tire Pressure Monitoring
              C1146 02 [137] - Signal Failure
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 8
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:09:48
    Address 08: Auto HVAC (J301)       Labels:| 5G0-907-426.clb
       Part No SW: 5F0 907 426 M    HW: 5F0 907 426 M
       Component: AC Manuell    H02 1001
       Revision: 00001K09
       Coding: 00100104200100001000000000001000
       Shop #: WSC 00049 770 00107
       ASAM Dataset: EV_ACManueBHBVW37X 003017
       ROD: EV_ACManueBHBVW37X_003.rod
       VCID: 3467CD849F992A2B17-8060
    1 Fault Found:
    459779 - Local Databus
              U1030 00 [009] - Electrical Malfunction
              [New feature! Extended UDS fault detail is only supported by current gen. interfaces]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 8
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:11:33
    Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
       Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 M
       Component: GW MQB High   212 2223
       Revision: --------    Serial number: 21051510800445
       Coding: 030100F40F087300EA000040000F00010001050000000000000000000000
       ASAM Dataset: EV_GatewConti 013020
       ROD: EV_GatewConti_013.rod
       VCID: 75E13080D4637323E0-8020
       Generator:
       Multifunction steering wheel control module:
       Subsystem 2 - Part No SW: 5F0 959 537 B    HW: 5F0 959 537 B
       Component: E221__MFL-PR6  H04 0130
       Serial number: 000000000A1238290415
       Coding: 002000
       Battery Monitoring Control Module:
    1 Fault Found:
    66567 - Local Databus
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 5
                        Reset counter: 8
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:09:38
                        Terminal 30 power supply: 12.2 V
                        Terminal 15: On
    Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
       Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
       Component: EPS_MQB_ZFLS  125 1061
       Coding: 0103
       ASAM Dataset: EV_SteerAssisMQB 012140
       ROD: EV_SteerAssisMQB_012_VW37.rod
       VCID: 43859E58CA379D939E-8016
    2 Faults Found:
    20228 - Databus
              U1123 00 [008] - Received Error Message
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Priority: 6
                        Reset counter: 48
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:15:31
                        Motor status: 01
                        System status: Driving mode
                        Supply voltage: 11.75 V
                        Temperature: 27.0 °C
                        KFC: 4F
                        KFA: 00 04
                        Freeze frame conditions: 21
                        uAdSensI_U1V2Filtered_gdu16: 1.20 V
                        uAdSensI_U5VFiltered_xdu16: 0.00000 V
                        uioUdNotFilt_xdu16: 11.91 V
                        uAdSensI_SwitchedKl30_xdu16: 11.91 V
                        ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
    19716 - Databus
                 Freeze Frame:
                        Fault Priority: 6
                        Reset counter: 48
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:15:31
                        Motor status: 01
                        Supply voltage: 12.00 V
                        KFC: 4D
                        KFA: 00 04
                        uioUdNotFilt_xdu16: 12.08 V
                        uAdSensI_SwitchedKl30_xdu16: 12.06 V
    Address 55: Headlight Range (J431)       Labels:| 5Q0-907-357.clb
       Part No SW: 5Q0 907 357     HW: 6R0 907 357 A
       Component: LWR-ECU       005 0080
       Revision: --------    Serial number: --------------
       Coding: 048C000009000000
       ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
       ROD: EV_HeadlRegulVWLWRMQB.rod
    1 Fault Found:
    13705985 - Databus
              U1123 00 [137] - Received Error Message
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 8
                        Mileage: 108266 km
                        Date: 2021.04.29
                        Time: 15:09:38
  10. Re: 2016 Leon blower motor stopped working
    #20
    1840 Post(s)
    That interface is too old to provide some important detail. That looks like a fault with the CAN BUS module
  1. Please Help Heater blower motor and wiper jets just stopped working HELP somebody Please
    By Rossh in forum Touran - Sharan - Caravelle
    Last Post: 07-11-2018, 07:40 PM
  2. Question Washer motor and heater blower fan stopped working VCDS scan included
    By adamkm in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 02-09-2014, 01:17 PM
  3. Heater/Blower stopped working
    By scottjay86 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-02-2010, 12:10 AM
  4. Please Help Heater/Blower Motor Intermitant now stopped?
    By waynex1 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 01-07-2008, 09:30 AM
  5. mk3 vento blower stopped working
    By aphex2k in forum Golf MK3 - 1993 - 1999
    Last Post: 02-03-2008, 11:51 PM
