Thread: Q5 service and tyre life
  1. Q5 service and tyre life
    Jan 2009
    Can someone please help. Tyres. I have continental contact sport 235/55 r19 W the car only covered Q5 2019 4.0tdi Quattro covering 9500 miles and really needed 2 new tyres on the front. I’ve tried to put different better longer wearing on and was told they have to be same as the back. All replace all 4. The back are absolutely fine and have not worn at all. So question can you not replace two different on the same axle. I’ve been told you can’t do that from the dealer. And also they need to check the back because they may need to be replaced too if the calculations are out. Could this be that the short life of the front tyres maybe there is something wrong with the Quattro mechanism. ?
    Also. Always had Audi and always been oil service 1st. Inspection 2nd. This has said it needs both on 11000 miles. I’ve never had to do the inspection as it’s 1st service. Is this correct. Thanks in advance.
  2. Re: Q5 service and tyre life
    Aug 2007
    Hook Hampshire
    21 Post(s)
    The book says that tyres on front and back must be within 2mm of each other, but I don't pay any attention to that. Its because its a permanent 4 wheel drive as opposed to having a haldex box which varies the engagement of the rear wheels.
    I use Goodyear Excellence and get about 40k miles from the tyres. 255 45 20
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  1. Audi 'Long Life' service & service indicator
    By davej311 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-09-2011, 09:18 AM
  2. Front Tyre life
    By LesD in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-04-2011, 11:26 PM
  3. Le Mans 19" tyre average life
    By V5 Man in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-04-2010, 12:04 PM
  4. A4 2.0 TDI SLINE 170PS Quattro Tyre Life
    By crp28 in forum Audi A4 - Archive Topics
    Last Post: 13-02-2008, 02:35 PM
  5. Tyre life
    By barney2 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 25-11-2007, 12:34 AM
