Thread: 03395 Control module for High Bean Assistant
  1. 03395 Control module for High Bean Assistant
    Aug 2007
    Hook Hampshire
    21 Post(s)
    I have a Q5 3.0Tdi 2014. A dash warning has appeared stating "Main Bean Assist System Fault". I have scanned the car with VCDS and a fault code "03395 Control module for High Bean assistant"
    Has anyone experienced this problem and how best to fix it.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  2. Re: 03395 Control module for High Bean Assistant
    131 Post(s)
    1973 Post(s)
    Does it define the code any further such as saying UDS protocol required.
  3. Re: 03395 Control module for High Bean Assistant
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Hi Crasher. It doesn't say that so I have copied the info from VCDS below. Interestingly, the High Beam Assist module does not show a fault code, so maybe a wiring fault to the module. I cant even find out where the module is or any wiring diagrams. I know the headlight module is behind the glove box but without wiring diagrams...?
    Sunday,28,March,2021,13:22:59:10945
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
    VCDS Version: 20.12.0.1
    Data version: 20201125 DS322.1
    www.Ross-Tech.com
    VIN: WAUZZZ8R2EA097785 License Plate: Q5
    Mileage: 122240km-75956mi Repair Order:
    Chassis Type: 8R-AU48 (8R0)
    Scan: 01 02 03 05 08 09 15 16 17 19 20 36 42 44 46 52 53 56 5F 62
    6C 6D 72
    VIN: WAUZZZ8R2EA097785 Mileage: 122240km-75956miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    20-High Beam Assist. -- Status: Sporadic communication error 1000
    36-Seat Mem. Drvr -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    Address 09: Cent. Elect. (J519) Labels:. 8K0-907-063.clb
    Part No SW: 8K0 907 063 DJ HW: 8K0 907 063 DJ
    Component: BCM1 1.0 H16 0103
    Revision: 09016001 Serial number: 00000063156202
    Coding: 260000118174AFE01781400300001D0D4F9D4708A709022100 0008004400010200020034000000
    Shop #: WSC 13938 002 104857
    VCID: 7AF07FCCF5F598544C-802E
    Subsystem 1 - Part No SW: 8R2 955 119 A HW: 8R2 955 119 Labels: 1KX-955-119.CLB
    Component: WWS416 140207 H11 0050
    Serial number: 90243015140116093743
    Coding: 01DD13
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 22294438
    Coding: 02005C
    Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
    Component: E1 - LDS H03 0031
    Serial number: 00000000002002140413
    Subsystem 4 - Part No SW: 4G0 907 410 HW: 4H0 907 410
    Component: EHL2 V07.03 H30 0030
    Serial number: 0000002274537R1JB802
    Subsystem 5 - Part No SW: 3D0 941 329 HW: 3D0 941 329
    H05 0012
    Subsystem 6 - Part No SW: 3D0 941 329 HW: 3D0 941 329
    H05 0012
    Subsystem 7 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: E6780217000000000001
    1 Fault Found:
    03395 - Control Module for High Beam Assistant
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 121786 km
    Time Indication: 0
    Date: 2021.03.19
    Time: 12:30:29
    Address 19: CAN Gateway (J533) Labels:. 8T0-907-468.clb
    Part No SW: 8R0 907 468 P HW: 8R0 907 468 D
    Component: GW-BEM 5CAN-M H11 0060
    Revision: 1Z120030 Serial number: 3041Z142040558
    Coding: 80CF07FF00
    Shop #: WSC 06335 000 00000
    VCID: 4C9CE914EFE1D6E4AE-8018
    Subsystem 1 - Part No SW: 8R0 915 181 C HW: 8R0 915 181 C
    Component: J367-BDMHella H07 8043
    Serial number: 9622122603
    Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
    Component: J532_DCDCStab H17 0042
    Serial number: 14051003428021200181
    2 Faults Found:
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 5
    Reset counter: 179
    Mileage: 121149 km
    Time Indication: 0
    Date: 2021.02.21
    Time: 01:42:58
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.40 V
    Count: 7
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 179
    Mileage: 121786 km
    Time Indication: 0
    Date: 2021.03.19
    Time: 12:30:29
    Freeze Frame:
    Bin. Bits: 01111
    Voltage: 13.00 V
    Count: 6
    Bin. Bits: 10000
    Time: 4.90 s
    Address 20: High Beam Assist. (J844) Labels:. 8K0-857-511.clb
    Part No SW: 8T0 857 511 AD HW: 8T0 857 511 AD
    Component: FLA H04 0012
    Revision: AA001002
    Coding: 02022064747464545425363E00
    VCID: 7CFC79D4FFC1A6645E-8028
    No fault code found.
    Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
    Part No SW: 8R2 035 670 M HW: 8R2 035 670 E
    Component: H-BNT-EU H48 1036
    Revision: -------- Serial number: 208BZ0E7513296
    Coding: 160101060005E1EF45828F5E00000403040000000000000000
    Shop #: WSC 13938 002 1048576
    VCID: 3E78B3DCA95D747430-806A
    Subsystem 1 - Part No: 8R0 060 884 GS
    Component: EUR 2020 3001
    Subsystem 2 - Part No SW: 8R0 919 604 A HW: 8R0 919 604 A
    Component: DU7 High H42 0104
    Serial number: A130BZ0E2948817
    Subsystem 3 - Part No SW: 8T0 919 611 L HW: 8T0 919 611 C
    Component: E0380 Bedient H02 0030
    Serial number: 00000001767878
    Subsystem 4 - Part No: 8R0 060 961 F
    Component: CD-Database 5571
    2 Faults Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 120970 km
    Time Indication: 0
    Date: 2021.02.16
    Time: 17:36:26
    Freeze Frame:
    Text: DUA130,Front,M,0,0,6
    03623 - Invalid Security/Release Code
    000 - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 98
    Mileage: 120970 km
    Time Indication: 0
    Date: 2021.02.16
    Time: 17:36:25
    Freeze Frame:
    Hex Value: 0x0004
    Hex Value: 0x000B
    Count: 6
  4. Re: 03395 Control module for High Bean Assistant
    131 Post(s)
    1973 Post(s)
    The high beam assist itself says no problems even though in the scan it report a comms error (I see this a lot on VCDS), the error appears to be it communicating with the CAN BUS unit and the central electrics. The infotainment is report it needs a Software Version Management check so it needs to go on ODIS which with Guided Fault Finding will probably help with the CAN error as well as SVM, what is the ABS fault?
  5. Re: 03395 Control module for High Bean Assistant
    Aug 2007
    Hook Hampshire
    21 Post(s)
    The ABS fault has been there for a long time and seems to be a normal quirk when Drive Select is added by VCDS and not part of the new vehicle spec. Why I added Drive Select I don't know. These days, I just get in and drive it.
    I'll book it into Nottingham when I am next visiting my daughter. I assume C&R can look into this.
  6. Re: 03395 Control module for High Bean Assistant
    131 Post(s)
    1973 Post(s)
    No problem, I would start by using VCDS to read all the controllers, save and clear; then use ODIS as it can get preoccupied with other faults and is SO slow and clunky to use one can lose the will to live...
  1. High Bean Assist sensitivity
    By shabazmo in forum A7 - S7
    Last Post: 08-01-2018, 10:46 AM
  2. Predictive Efficiency Assistant
    By deano179 in forum Q7 - 4M Forum - 2016 -
    Last Post: 10-03-2016, 10:43 AM
  3. Replies: 5
    Last Post: 15-10-2012, 10:20 PM
  4. Question steering control module for cruise control
    By doggydoctor in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-07-2012, 11:02 AM
  5. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
