Thread: 09 A5 2.0TFSI stuttering at low RPM
  1. 09 A5 2.0TFSI stuttering at low RPM
    Apr 2021
    Derby
    I’m looking to see if anyone else has had this problem. I’ve a petrol, manual A5, regularly serviced and no other issues or warning lights.
    When I slow down in traffic etc and rpm drops to 1100 rpm in any gear the car will stutter quite badly. Only when it’s warmed up and if I accelerate the problem goes away at 14/1500 rpm.
    Local Audi specialist is unsure so any info would be much appreciated!
  2. Re: 09 A5 2.0TFSI stuttering at low RPM
    1837 Post(s)
    Do you know if the timing chain has been done and what the coil pack and plug history are? Was it ever subject to a rebuild by Audi for heavy oil consumption?
  3. Re: 09 A5 2.0TFSI stuttering at low RPM
    Apr 2021
    Derby
    Thanks for your reply. The timing chain was done in October last year. Very few miles done since. Unsure of coil pack and plug history but it is getting looked at next week. Starts fine every time which made me hesitant to think plugs or coil pack.
  4. Re: 09 A5 2.0TFSI stuttering at low RPM
    Apr 2021
    Derby
    Again as far as I’m aware it didn’t suffer from the heavy oil consumption. The cylinder head was stripped out and cleaned. New inlet valves, exhaust valves done in October also.
  5. Re: 09 A5 2.0TFSI stuttering at low RPM
    1837 Post(s)
    When you were describing the problem it immediately suggested to me it had been apart. If there are no codes of any type, I would start with new NGK plugs and genuine coil packs.
  6. Re: 09 A5 2.0TFSI stuttering at low RPM
    Apr 2021
    Derby
    It’s going in on Wednesday to an Audi specialist. As it only happens when the car warms up I wasn’t sure. Will see what codes they get if any. Car is quiet and smooth otherwise.
    Thanks again for responding.
  1. ' Stuttering'
    By ihs61 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2012, 10:00 AM
  2. car stuttering low speed
    By audi-nutz in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-07-2008, 01:32 PM
  3. stuttering
    By ian00uk in forum Golf MK4 - 1999 - 2004
    Last Post: 03-11-2007, 03:59 PM
  4. Golf GTI 1.8T stuttering
    By Tony in forum Archive posts
    Last Post: 20-07-2007, 09:00 AM
  5. MK3 16v Stuttering....
    By Jobs12 in forum Golf MK3 - 1993 - 1999
    Last Post: 26-01-2007, 04:40 PM
