Thread: A7 Leak Issue
  1. A7 Leak Issue
    Jan 2020
    Billericay, UK
    I bought my A7 55 TFSI Vorsprung edition new on 1/3/2020. I’ve only done 1,000 miles since then. Thought I’d vacuum the interior, and noticed mould on the rear footwell mat behind the drivers seat. When I checked, the footwell was soaked! Took it in to my main agent to have it checked. Turns out that Audi are aware that some of their A7 are fitted with grommets in the floorpan that weren’t sealed properly when making the car. So, they had the car for 9 days and had to remove the seats, carpets etc, fit ‘redesigned’ grommets and seal them properly. All done under warranty of course. My reason for posting is just to suggest you check you don’t have the same problem. Hope not!
  2. Re: A7 Leak Issue
    1840 Post(s)
    I hope that VAG get the hang of water ingress when they put a half tonne tray of Lithium Ion batteries under the floor running at 396 volts
  3. Re: A7 Leak Issue
    Jan 2016
    West Lothian
    14 Post(s)
    Appreciate the sharing of the info. Thankfully something I have not experienced and despite it being covered I would have been really hacked off it had happened to me!
    VW Passat GT 4 Motion 2.0 BiTdi, '16MY in Midnight Blue, keyless entry, memory seats, active info display and Discover Nav Pro
    Audi A7 20MY Vorsprung 3.0tdi in Daytona grey, with optional rear cup holders! (Previously A7 16my S Line)
  1. Car lock issue and gear box leak
    By checkmate in forum Audi A4 - B9 Forum - 2015 -
    Last Post: 15-05-2019, 11:47 AM
  2. Please Help Troubleshooting on my first car - A4 Avant estate 1999 - A-frame water leak, footwell leak etc.
    By damn_seagulls in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-01-2014, 10:02 PM
  3. 2.5tdi diesel fuel leak from injector leak off pipes after being replaced.
    By white.akita in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-03-2012, 09:46 PM
  4. Coolant leak / heater issue
    By Steve2.7T in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 23-12-2009, 12:03 AM
  5. temp gauge water leak, fuel leak all sorted
    By a6rom in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 23-02-2009, 12:44 PM
