Thread: Handbrake adjustment
  1. Handbrake adjustment
    Feb 2021
    Lincoln, England
    My Altea handbrake has been getting progressively weak for a while now to the point where i have to pull it on about ten clicks to get it to hold the car. I have seen Youtube videos how to adjust it but the problem is accessing the gubbins.
    I tried to prize of the rear of the centre console as i understand it's retained by four "clips" but i backed off with the broad flat head screw driver because it felt like any more applied pressure would snap the housing.
    Any ideas with this problem please?
    Cheers.
    Neil.
  2. Re: Handbrake adjustment
    1994 Post(s)
    If you need to adjust the cable a caliper has failed, usually the right, the adjuster is only there to set up the system, no in service adjustment is required. If you look under the car at the handbrake lever, you will see it is not returning to its stop.
  3. Re: Handbrake adjustment
    Feb 2021
    Lincoln, England
    Crasher, you my friend are spot on, i took my car to my go-to service centre and guess what.........a rear caliper had seized and you got it.....the offside one.
    Cheers.
  4. Re: Handbrake adjustment
    1994 Post(s)
    On the PQ35 platform (Golf 5,6, Altea etc) we do roughly four times as many right calipers as left and even then some of the lefts we do are because the customer requests it.
  1. Question A4 b6 cab handbrake adjustment
    By WestHamGeezer 父 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-06-2017, 05:22 PM
  2. Handbrake adjustment
    By monty9120 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2016, 08:10 PM
  3. Handbrake adjustment
    By ytre in forum Jetta MK3 - 2005 - 2013
    Last Post: 08-08-2011, 07:27 AM
  4. Handbrake Adjustment
    By grahamcoutts in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-10-2008, 07:51 AM
  5. Handbrake adjustment
    By antonb in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-02-2008, 03:47 PM
