Thread: Car won't start
Results 1 to 10 of 11
  1. Car won't start
    Mar 2021
    Bristol
    I'm literally stuck! I'm currently rebuilding a mk2 seat leon 2010 Cr170 cega and the wiring loom is done and been double checked against another cega for mistakes but all is correct. We also checked for any breaks in the wires but there's nothing. The car just won't start but cranks. Do you have any idea on what it could be please or anything I could try? We checked the relays, fuses and put vcds on it and the code it keeps throwing up is 01314/004 no communication.
  2. Code 01314/004 no communication cega engine
    Mar 2021
    Bristol
  3. Re: Code 01314/004 no communication cega engine
    131 Post(s)
    1976 Post(s)
    Do you see this code only in the instruments or in other controllers?
    01314 - Engine Control Module: No Communications
    Can you communicate with the engine ECU?
  4. Re: Car won't start
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    It looks like the ECU isn't getting power to all the pins required.
    Check against the other CEGA which ECU pins have power while running if you can.
    Have a look at this thread which applies to a Passat, but you might get something useful from it.
    Please Help No power to the ECU (vwaudiforum.co.uk)
  5. Re: Car won't start
    Mar 2021
    Bristol
    Many thanks I will check that now. Also should mention the code is coming up in more than the instruments section.
  6. Re: Code 01314/004 no communication cega engine
    131 Post(s)
    1976 Post(s)
    You need to check that the large 94 pin plug (T94a) at the ECU has permanent live from the battery at pin 92 (fuse 10 in the engine bay) and switched ignition live at T94a 3, 5 and 6 (fuse 13 in the engine bay). It must have permanent earth at T94a 1, 2 and 4. If there is no power to fuse 13, bridge the 1 and 2 sockets of the ECU relay position. The ignition on signal is from the BCM via the line 15v relay to fuse 2 in the dash side and to the ECU at T94a 87.
  7. Re: Car won't start
    Mar 2021
    Bristol
    Code:
    Chassis Type: 1P-SE35 (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: VSSZZZ1PZAR042953   Mileage: 305140km-189605miles
    01-Engine -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    08-Auto HVAC -- Status: Cannot be reached 1100
    15-Airbags -- Status: Malfunction 0010
    16-Steering wheel -- Status: Malfunction 0010
    2E-Media Player 3 -- Status: Cannot be reached 1100
    42-Door Elect, Driver -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: Cannot be reached 1100
    56-Radio -- Status: Cannot be reached 1100
    62-Door, Rear Left -- Status: Cannot be reached 1100
    72-Door, Rear Right -- Status: Cannot be reached 1100
    Address 01: Engine
    Cannot be reached
    Address 03: ABS Brakes
    Cannot be reached
    Address 08: Auto HVAC
    Cannot be reached
    Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
       Part No SW: 5K0 937 086 C    HW: 5K0 937 086 C
       Component: BCM PQ35 M    011 0028
       Revision: BC011001
       Coding: 4E180A3E9825B0C046880080940081CC056100A842018160648040000000
       Shop #: WSC 04941 123 12345
       VCID: 34240DF697508F26C7-8060
    30 Faults Found:
    00153 - Windshield Wiper Motor;  Driver Side (V216)
                004 - No Signal/Communication
                 Freeze Frame:
                        Fault Status: 01100100
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:36
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.75 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00978 - Lamp for Low Beam; Left (M29)
                010 - Open or Short to Plus
                 Freeze Frame:
                        Fault Status: 01101010
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:05
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00979 - Lamp for Low Beam; Right (M31)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:05
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00984 - Left Tail Light (M4)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:37
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00985 - Right Tail Light (M2)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:37
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00987 - Lamp for Brake Light; Left (M9)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:37
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    00988 - Lamp for Brake Light; Right (M10)
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:37
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01134 - Alarm Horn (H12)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.75 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01135 - Interior Monitoring Sensors
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.75 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:34
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01316 - ABS Control Module
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 2
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01320 - Control Module for Climatronic (J255)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:34
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01331 - Door Control Module; Driver Side (J386)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01332 - Door Control Module; Passenger Side (J387)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01333 - Door Control Module; Rear Left (J388)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01334 - Door Control Module; Rear Right (J389)
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:32
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01493 - Bulb for Blinkers; Front Left (M5)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01495 - Bulb for High-Beams; Left (M30)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01496 - Bulb for Fog-Lamps; Left (L22)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01497 - Bulb for Blinkers; Front Right (M7)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01499 - Bulb for High-Beams; Right (M32)
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01500 - Bulb for Fog-Lamps; Right (L23)
                 Freeze Frame:
                        Fault Priority: 4
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01501 - Bulb for Blinkers; Rear Left (M6)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01502 - Bulb for Rear Fog; Left (L46)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01504 - Bulb for License-Plate Light (X)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:37
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01505 - Bulb for Blinkers; Rear Right (M8)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.70 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01519 - Bulb for Back-Up Lights; Right (M17)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.60 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    01835 - Bulb for Side-Blinkers; Right (M19)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:12:06
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.65 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    02394 - Parking Light Left Front (M1)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:36
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.75 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    02395 - Parking Light Front Right (M3)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:36
                 Freeze Frame:
                            Term 15 On
                        Voltage: 13.75 V
                            ON
                            ON
                            OFF
                            OFF
                            OFF
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
       Component: J234__A0E VW10 HI   1916
       Revision: 20013000    Serial number: 003E2PQ5L01B
       Coding: 0012357
       Shop #: WSC 06402 785 00200
       VCID: 44C45D3607F03FA677-8010
       Subsystem 1 - Serial number: 00000000000000000
       Subsystem 2 - Serial number: 00000000000000000
       Subsystem 3 - Serial number: 6351HTS6OKP876KJ
       Subsystem 4 - Serial number: 6361HTS6TQRO09KJ
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    7 Faults Found:
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:16
    01589 - Igniter for Head-Airbag; Passenger Side (N252)
                001 - Upper Limit Exceeded - MIL ON
                 Freeze Frame:
                        Fault Status: 11100001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:15
    01218 - Side Airbag Igniter; Passenger Side (N200)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:15
    01217 - Side Airbag Igniter; Driver Side (N199)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:15
    00588 - Airbag Igniter; Driver Side (N95)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:15
    01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                010 - Open or Short to Plus - MIL ON
                 Freeze Frame:
                        Fault Status: 11101010
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:14
    01221 - Crash Sensor Side Airbag; Driver Side (G179)
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:03:14
    Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Component: J0527           856 0111
       Coding: 0000532
       VCID: 78BCF9C60BB8AB462B-802C
    1 Fault Found:
    01426 - Controls in Steering Wheel (E221)
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 1P0 920 954 A    HW: 1P0 920 954 A
       Component: KOMBI         H07 0307
       Coding: 410800
       Shop #: WSC 99999 1023 2097151
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
       ROD: EV_Kombi_UDS_VDD_RM09_SK46.rod
       VCID: 2F2E029A7676ACFEBA-807A
    3 Faults Found:
    9453842 - Oil Level Thermal Sensor
              B1041 35 [009] - Signal high time > maximum
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Date: 2021.03.30
                        Time: 00:03:38
    12648448 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Motor: keine Kommunikation]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Date: 2021.03.30
                        Time: 00:03:38
    12656896 - Function Restricted due to Missing Message(s)
              U1111 00 [009] - -
              [Steuergerät für Bremse: keine Kommunikation]
                 Freeze Frame:
                        Fault Priority: 6
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Date: 2021.03.30
                        Time: 00:03:38
    Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
       Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
       Component: J533  Gateway   H16 0231
       Revision:   H16       Serial number: 4320K09B3006A1
       Coding: E9807F06000212000203
       VCID: 699AAC82401202CEA4-803C
    10 Faults Found:
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
    01305 - Databus for Infotainment
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
    01304 - Radio
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
    03272 - Control Module for Audio Interface
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
    Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H07 0307
       Serial number:
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03005
       ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
       VCID: 6A98D38E8D1409D6AD-803E
    No fault code found.
    Address 2E: Media Player 3
    Cannot be reached
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 142    3001
       Revision: 00H17000
       VCID: 312A04E2A842BA0EAC-8064
    5 Faults Found:
                013 - Check DTC Memory
                 Freeze Frame:
                        Fault Status: 01101101
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305140 km
                        Time Indication: 0
                        Date: 2021.03.24
                        Time: 17:15:58
                 Freeze Frame:
                        Voltage: 11.38 V
                            DD
                        Temperature: 9.0°C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305140 km
                        Time Indication: 0
                        Date: 2021.03.24
                        Time: 17:35:34
                 Freeze Frame:
                        Voltage: 11.75 V
                            DD
                        Temperature: 14.0°C
                        RPM: 0 /min
                        Speed: 0.0 km/h
                        Speed: 0.0 km/h
                        Count: 0
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:16:19
                 Freeze Frame:
                        Voltage: 13.50 V
                            DU
                        Temperature: 27.0°C
                        RPM: 1498 /min
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
                        Count: 0
    03803 - Steering Angle Sensor for Steering Aid
                000 - - - MIL ON
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:05:05
                 Freeze Frame:
                        Battery Volts: 13.1 V
                            DU
                        Temperature: 24.0°C
                        Count: 2
                        Steering Angle: 0.00°
                        Count: 0
                            SteerAng n.Init
                 Freeze Frame:
                        Fault Priority: 3
                        Fault Frequency: 1
                        Reset counter: 241
                        Mileage: 305141 km
                        Time Indication: 0
                        Date: 2021.03.30
                        Time: 00:16:18
                 Freeze Frame:
                        Voltage: 13.38 V
                            DU
                        Temperature: 27.0°C
                        RPM: 1498 /min
                        Speed: 50.0 km/h
                        Speed: 50.0 km/h
                        Count: 0
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio
    Cannot be reached
    Address 62: Door, Rear Left
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    End----------(Elapsed Time: 00:40, VBatt start/end: 13.6V/13.6V)-----------
  8. Re: Car won't start
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    " Also should mention the code is coming up in more than the instruments section. "
    That scan throws a different light on everything.
    Unlikely all those controller have failed.
    Either they have no power or the communications bus is down.
    Check all the engine bay fuses, especially the large open fuses.
  9. Re: Car won't start
    131 Post(s)
    1976 Post(s)
    As Phil says, you have more than one problem there
  10. Re: Car won't start
    Mar 2021
    Bristol
    Hi guys thanks for the replies. I've still no luck on the car starting 😔 I will attach a updated scan and see if anybody can shed some light?
  1. Replies: 2
    Last Post: 09-11-2020, 04:20 PM
  2. Please Help Engine Start System Fault [Access/Start Authorisation Switch (E408)]
    By norg2072 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 13-07-2020, 12:06 PM
  3. Replies: 1
    Last Post: 19-08-2019, 10:45 PM
  4. Solved BLB engine too hard to start... but after starting the next start is normal..
    By matrixpt in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-05-2014, 11:51 AM
  5. Please Help On start up intermittent glow plug flashing non start engine fault garage flashes up
    By dazcheff in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 19-09-2012, 08:39 PM
