Thread: Mark 7 GTD cambelt replacement?
  1. Mark 7 GTD cambelt replacement?
    My 2015 GTD needs a new cambelt + water pump, although it's only done 44,000 miles? Has anyone had these replaced by a main dealer recently and if so how much did it cost. Would like to have a rough idea before I ring them?
  2. Re: Mark 7 GTD cambelt replacement?
    1840 Post(s)
    About £450 at an indi inc water pump. INSIST on G12Evo coolant being used.
  3. Re: Mark 7 GTD cambelt replacement?
    Hi Crasher - thanks for prompt reply. Any specific reason re the G 12 Evo coolant?
  4. Re: Mark 7 GTD cambelt replacement?
    1840 Post(s)
    G12 Evo has been the factory fill since 2017 and HOPEFULLY will prevent MQB platform heater matrix blockage due to Silicate fallout in G13.
  5. Re: Mark 7 GTD cambelt replacement?
    Mar 2011
    S/land UK
    Bugger just used G13 after my cambelt/water pump change, is the Silicate from the G13 or from the silicate bag in the coolant tank ?
    By the way the cam belt did look as though it was failing even though it had only done 12k. do think it was because it was a Dayco belt ?
    Audi A6 AllRoad 2.5tdi (sold) Golf mk5 2.0 Gttdi 4 motion (sold)
    Jaguar S type 2.7d Sport (sold)Golf mk4 1.9 Gttdi (sold)
    Audi A6 1.9 Sport (sold)
    Golf mk6 GTD (sold)
    Golf mk7 GTD
  6. Re: Mark 7 GTD cambelt replacement?
    1840 Post(s)
    Dayco belts are perfect, I have never had an issue with them and often when you remove the factory fit belt it is Dayco and the VAG repair sets often come with one. The Silicate cartridges are there to prevent Silicate fallout from G13 but VAG gave up on it four years ago. If the cartridges 4E0 121 176, are not replaced with the coolant, G13 degrades even faster.
  1. Question No Replacement Seatbelt for Mark 4 Golf?
    By ChrisK50 in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2017, 06:28 PM
  2. Cambelt Replacement
    By David1953 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-07-2011, 01:19 PM
  3. Cambelt Replacement
    By spike240 in forum 80 - 90
    Last Post: 07-04-2011, 05:49 PM
  4. Please Help Mark 5 GTI Cambelt change
    By Apophis in forum Golf MK5 - 2004 - 2009
    Last Post: 19-09-2009, 10:43 PM
  5. Mark 4 Golf Cambelt
    By mdcooper in forum Golf MK4 - 1999 - 2004
    Last Post: 09-01-2008, 02:12 PM
