Thread: VCDS Coding for A6 C8 platform
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Hello there,
    is there any list of the VCDS coding for C8 platform? I would like to enable few things on my C8 which I had on my C7
    Rear DLR on
    Chirp on lock
    Handbrake on when parking selected
    Start/stop memory
    TIA!
    current: 2019 A6 S-Line 40 TDI Avant (de-chromed)
    sold: 2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  2. Re: VCDS Coding for A6 C8 platform
    Nov 2019
    I use OBDeleven, can activate most things with that.
    Bit pricey but super simple to use.
  3. Re: VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by MILBY3183 View Post
    Just found a lot of info on their forum
    Code:
     https://forum.obdeleven.com/thread/10338/list-c8-obdeleven-configurations
  4. Re: VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Looking at obdeleven not sure how the pricing works. Do I need the Pro version plus activation to have it working ?
  5. Re: VCDS Coding for A6 C8 platform
    Nov 2019
    You only need pro if your going to long code yourself
  6. Re: VCDS Coding for A6 C8 platform
    Jan 2021
    Ireland
    7 Post(s)
    Quote Originally Posted by artheb View Post
    Hello there,
    Rear DLR on
    Chirp on lock
    Start/stop memory
    TIA!
    Here we go
    Rear DLR on (Scandinavian Rear Lights)
    Module 9 (Central Electrics)
    Long Coding
    Enable SL_AT_DRL
    Chirp on lock
    Module 46 (Comfort System)
    Adaptation
    Sounder Settings
    Beeptime Closing Central Locking
    Choose between: no beep, single beep, double beep
    Handbreak on when parking selected
    Select Control Module
    Module 03 (ABS)
    Adaptation
    Automatic parking brake
    Select Activated
    Start/Stop memory - not available at least for now.
    Enjoy!
  7. Re: VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by OBDFIX View Post
    Here we go
    Long Coding
    Enable SL_AT_DRL
    Chirp on lock
    Adaptation
    Sounder Settings
    Module 03 (ABS)
    Adaptation
    Select Activated
    Enjoy!
    Got obdeleven and I got Scandinavian dlr and auto parking brake working. Chirp on lock does not work for me. It also does not work on my wife’s 2021 Skoda Kodiaq
    I was also hoping for:
    mirror dip on reverse
    boot closing from the boot release button
    Did anyone got the above working on c8 platform?
  8. Re: VCDS Coding for A6 C8 platform
    Nov 2019
    Chirp Unlock worked on mine, did you have bonnet open when coding ?
    mirror dip shouldn’t need coding, you need to move the mirror adjustment switch to the right hand mirror then when you engage reverse it will dip
  9. VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Yes, did that with bonnet open. Tried for unlock and lock. Doesn’t work.
    Mirror dip does not work either when I move the switch to the passenger mirror.
    Which app did you use? Could you post a screenshot of the chirp coding ?
  10. Re: VCDS Coding for A6 C8 platform
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    If the mirror dip is the same as the C7 put the car in reverse with the mirror switch on passenger side, adjust mirror to where you want it, take car out of reverse. The mirror should now be set, the engine shouldn't need to be running when you do this but the ignition will need to be on.
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  1. B9 VCDS Coding?
    By St3veM in forum Audi A5 - B9 Forum - 2016-
    Last Post: 31-05-2022, 08:44 PM
  2. Vcds coding help
    By A6S in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-09-2017, 09:12 AM
  3. Wanted Vcds coding
    By luck333 in forum VCDS - General Questions
    Last Post: 30-05-2015, 10:24 PM
  4. Question Vcds coding
    By Solo12 in forum VCDS - Help Requests
    Last Post: 11-07-2014, 08:03 PM
  5. Attention a3 long coding with vcds
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-05-2010, 04:44 PM
