Thread: VCDS Coding for A6 C8 platform
Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
  1. Re: VCDS Coding for A6 C8 platform
    #21
    Sep 2016
    Ipswich, England
    19 Post(s)
    Quote Originally Posted by OBDFIX View Post
    Just go for an app
    Costs only 10 credits
    I may be missing something but what is the app being discussed here?
    Do I assume you but an amount of credits with the app which get spent with each feature you add/enable?
  2. VCDS Coding for A6 C8 platform
    #22
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by robgr View Post
    Obdeleven
    Yes, it has simplified apps which consume credits when used. You can still code it using long coding but with apps it’s super easy. It also works on the iPhone/android unlike VCDS on windows only.
    current: 2019 A6 S-Line 40 TDI Avant (de-chromed)
    sold: 2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  3. Re: VCDS Coding for A6 C8 platform
    #23
    10 Post(s)
    Bit of a noob with this, but would like to activate wireless CarPlay - is this device ok:
    OBDeleven starter pack - Innovative car diagnostic software
    Only interested in using the apps and will not be long coding.
  4. Re: VCDS Coding for A6 C8 platform
    #24
    Sep 2016
    Ipswich, England
    19 Post(s)
    Quote Originally Posted by artheb View Post
    Obdeleven
    I've downloaded the OBDeleven app and bought the OBDeleven First Gen device from Amazon
    However, I'm unable to connect via the app
    I have tried with the ignition on/engine running, with wifi/data and of course BT
    It brings up a list of BT devices but I've tried them all without success
    Shouldn't it just connect?
    What am I missing?
    The quick start guide was no help
    The device does glow red when inserted
  5. Re: VCDS Coding for A6 C8 platform
    #25
    Jun 2015
    Ireland
    69 Post(s)
    What am I missing?
    I bought it from their website. It was cheaper than Amazon.
    You pair the device through the app. Click on “Home” then “Connect” it will only show the obdeleven device.
    For C8 you need to have ignition ON and bonnet OPEN when you code.
  6. Re: VCDS Coding for A6 C8 platform
    #26
    Sep 2016
    Ipswich, England
    19 Post(s)
    I take it you mean bonnet open just for coding and not also to connect the app?
  7. Re: VCDS Coding for A6 C8 platform
    #27
    Jun 2015
    Ireland
    69 Post(s)
    Yes, just for coding. Not for connecting to the app.
  8. VCDS Coding for A6 C8 platform
    #28
    Jan 2021
    Ireland
    7 Post(s)
    not for connecting OBD but when executing particular app bonnet should be opened.
  9. Re: VCDS Coding for A6 C8 platform
    #29
    Sep 2016
    Ipswich, England
    19 Post(s)
    First dongle from Amazon was faulty (couldn't pair) but second one direct from OBDeleven (a bit cheaper) paired OK
    I initially ran a scan and have the 3 errors below, any guidance would be welcome
    09 Central Electrics, U112300 - Databus error value received, Intermittent
    19 Gateway, U140600 - Static current too high, static
    A5 Driver Assistance, C12B3FD - Driver assistance systems front camera Temporary view limitation, Intermittent
    I believe the third code is related to issue of multiple errors related to any assist functions, e.g. traffic sign recognition, main beam assist etc. as they are all dependent on the front camera
    I recently had my car in for diagnostics for this and the memory seat issue where the seat may reset during moving (seat issue fixed by a SW update)
    The Driver assistance issues are caused by the car going in to 'Fog Mode', if the camera is limited for more than 77s then this mode is triggered (systems may restore by themselves once the view is clear)
    Condensation on the lens can cause this although the camera does have a heating element but might explain why it often occurs shortly after start?
    From my own experience low sun appears to trigger the Fog Mode too
    What it doesn't explain is why my C6 never had theses errors as far as I can recall
    Was told no SW update as this is expected behavior!
    Other than ensuring the wind screen is clear in front of the camera what else can we do?
    Has just occurred to me that perhaps there's an issue with the heating element and/or control of it
  1. B9 VCDS Coding?
    By St3veM in forum Audi A5 - B9 Forum - 2016-
    Last Post: 31-05-2022, 08:44 PM
  2. Vcds coding help
    By A6S in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-09-2017, 09:12 AM
  3. Wanted Vcds coding
    By luck333 in forum VCDS - General Questions
    Last Post: 30-05-2015, 10:24 PM
  4. Question Vcds coding
    By Solo12 in forum VCDS - Help Requests
    Last Post: 11-07-2014, 08:03 PM
  5. Attention a3 long coding with vcds
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-05-2010, 04:44 PM
