Thread: VCDS Coding for A6 C8 platform
Results 11 to 20 of 29
  1. Re: VCDS Coding for A6 C8 platform
    Jan 2020
    Shefford
    12 Post(s)
    My C8 has the mirror dip as standard. It’s a 2020 SLine
  2. Re: VCDS Coding for A6 C8 platform
    Jan 2021
    Ireland
    7 Post(s)
    Quote Originally Posted by artheb View Post
    Yes, did that with bonnet open. Tried for unlock and lock. Doesn’t work.
    Mirror dip does not work either when I move the switch to the passenger mirror.
    Which app did you use? Could you post a screenshot of the chirp coding ?
    Have you checked in your car menu settings if the option is ticked
    After coding reset your MMI by holding power button for 10 sec. you should see the acoustic confirmation option in your settings.
    Mirror dip comes as standard in most C8
    What version do you have?
  3. Re: VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by KevTrem View Post
    If the mirror dip is the same as the C7 put the car in reverse with the mirror switch on passenger side, adjust mirror to where you want it, take car out of reverse. The mirror should now be set, the engine shouldn't need to be running when you do this but the ignition will need to be on.
    This is the step I was missing! I could not remember it when I set my C7 4y ago! Thanks!
    current: 2019 A6 S-Line 40 TDI Avant (de-chromed)
    sold: 2015 A6 S-line Black Edition 2.0 TDI ULTRA
    MODs: CarPlay with RMC, Ambient Lighting
  4. Re: VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    Quote Originally Posted by OBDFIX View Post
    I have avant December 2018. Where in MMI do you have this setting? I may code it again and reset MMI.
  5. Re: VCDS Coding for A6 C8 platform
    Jun 2015
    Ireland
    69 Post(s)
    I figured out that “Acoustic Confirmation” should be in the MMI Central Locking. I don’t have that this option there. I will try to enable it again and reset MMI tomorrow.
    I wonder if MMI version has something to do with it. I know that I need 2470 version to enable wireless CarPlay. My version is much lower than that. I’ll ask dealership if they can upgrade MMI.
  6. Re: VCDS Coding for A6 C8 platform
    Jan 2021
    Ireland
    7 Post(s)
    Just go for an app
    Costs only 10 credits
  7. Re: VCDS Coding for A6 C8 platform
    #17
    Jun 2015
    Ireland
    69 Post(s)
    Just go for an app
    As I said earlier. I already have obd11 . App says that it is enabled and only gives me an option of changing the tone from standard to discontinues, etc. The MMI does not show the acoustic confirmation option. I have reset the MMI.
  8. VCDS Coding for A6 C8 platform
    #18
    Jan 2021
    Ireland
    7 Post(s)
    Do you have alarm system in your car. Chirp is using alarm sounder.
    Also there are two apps
    Make sure you choose right one
    One app enables chirp
    Second changes the tone type.
    1 1 0
  9. Re: VCDS Coding for A6 C8 platform
    #19
    Jun 2015
    Ireland
    69 Post(s)
    Figured it out! Sorry, I looked at the wrong option. Your screenshot made me realise that! It is working now and I got the tone option on the MMI.
    I was looking at the alarm Lock/Unlock beep time!
    Thanks again!
  10. Re: VCDS Coding for A6 C8 platform
    #20
    Jan 2021
    Ireland
    7 Post(s)
    Thanks again!
    You can tweak it further with long coding for example you can have chirp on locking only or change the number of chirps. You can also change the number of hazard light blinks at locking/unlocking
    Enjoy!
  1. B9 VCDS Coding?
    By St3veM in forum Audi A5 - B9 Forum - 2016-
    Last Post: 31-05-2022, 08:44 PM
  2. Vcds coding help
    By A6S in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 07-09-2017, 09:12 AM
  3. Wanted Vcds coding
    By luck333 in forum VCDS - General Questions
    Last Post: 30-05-2015, 10:24 PM
  4. Question Vcds coding
    By Solo12 in forum VCDS - Help Requests
    Last Post: 11-07-2014, 08:03 PM
  5. Attention a3 long coding with vcds
    By a8 tech in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 19-05-2010, 04:44 PM
