Thread: Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
  1. Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
    Jul 2018
    Birmingham, West Midlands
    8 Post(s)
    Hi I am trying to fit a GTD multi function steering wheel into a Scirocco.
    The steering wheel is installed but none of the buttons / controls work....
    Does the steering wheel need to coded with VCDS? If so what needs to be done?
    Will post a full scan here when I’ve done one.
  2. Re: Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
    1841 Post(s)
    The steering column controller needs to be coded.
  3. Re: Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
    Jul 2018
    8 Post(s)
    How would you code the steering column controller?
    Go into coding and play around with the settings in there?
    Normally VCDS gives an explanation of what the binary / bits mean or so?
    ie with / without cruise control, with DSG / flappy paddle etc....
    Obviously it would make sense to do a scan first to preserve the original
    coding and write it down then start playing around with it?
    Other than the steering column controller is there anything else that needs doing?
    Is there know additional wiring needed or depinning / repinning of the steering connector to the ECU?
    The only difference with the GTD steering wheel is that it has volume control which the original didn’t - will that cause a problem?
    Thank you
  4. Re: Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
    1841 Post(s)
    I am not into retro fits except for myself as they are too much pain doing them for customers, go into the steering wheel as VCDS calls it and copy the long coding then save it to a text file, then you can look at the coding table and there should be text to help but not always.
  5. Re: Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
    Jul 2018
    8 Post(s)
    Is the coding table part of VCDS if so where is it? Or do I have to look it up somewhere? Appreciate your help.
  6. Re: Retrofit GTD MFSW / Steering Wheel into a Scirocco - Help?
    1841 Post(s)
    Go into the controller and top right of the functions is coding, click on this and a second or two later the coding table will open.
  1. Upgrading the standard B6 steering wheel to B6 MFSW
    By Monzta in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2021, 11:15 PM
  2. scirocco r steering wheel
    By manity in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 17-02-2016, 09:48 AM
  3. Mfsw and cruise retrofit finished- buttons don't work on wheel :(
    By blake1312 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-01-2015, 12:38 AM
  4. Question Slip ring-steering sensor question (MFSW retrofit)
    By vsheremeti in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-01-2011, 07:05 PM
  5. New Scirocco's Steering Wheel???
    By ben-golf in forum Scirocco - 2008-
    Last Post: 07-05-2008, 10:57 PM
