Thread: Why Is My Turbo Red???
  1. Why Is My Turbo Red???
    yorkshire
    After long time fart arsing about ive now got decat, jetex full system new 710n bov fitted to car. ive NEVER noticed this before after ive given my car a good thrash why is my turbo glowing red??? is this normal. plus when i fitted a manual boost gauge i slowly increasd psi to a safe amount but he car hit 3000 revs and just made a thud and cut power?? then when checked turbo the whole bloody thing glowing red like a ufo. help
    A4 TURBO SPORT FAST BUT NO WAY NEAR AS FAST AS PARENTS COROLLA
    ON WAY=S/STEEL EXHAUST SYSTEM, DIVERTER VALVE, FORGE ACUATOR, N75J, SPAX SUSPENSION
  2. Re: Why Is My Turbo Red???
    May 2007
    Turbo is red due to exhaust gases pooring through it at a great rate.
    Normally this is only visable if it is poor light.
    That's why you never wash a hot engine as it would crack.
    You are recommended with a turbo to drive gently for the last couple of minutes to let it spin down and cool, otherwise you shorten it's life.
  3. Re: Why Is My Turbo Red???
    yorkshire
    so if i inrease boost like i did before the whole turbo glowed red that cant be normal
  4. Re: Why Is My Turbo Red???
    May 2007
    Does sound if you are over boosting, which can cause a whole load of problems.
    I presume you understand how a turbo works and what the waste gate is used for. If not I will explain
  5. Re: Why Is My Turbo Red???
    You're definately overboosting that turbo, check all the vacuum pipes are connected and in good order with no splits or colapsing under vacuum. Also check the waste gate maybe jammed shut.
  1. turbo
    By lee736 in forum Golf MK4 - 1999 - 2004
    Last Post: 21-10-2007, 09:19 AM
  2. Turbo Possible??
    By Gee in forum Golf MK4 - 1999 - 2004
    Last Post: 11-10-2007, 08:06 PM
  3. TDi 130 - Need a new turbo :(
    By AsaTDi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-08-2007, 07:35 AM
  4. MK3 TDI turbo dying... remap or hybrid turbo?
    By leoninanegg in forum Golf MK3 - 1993 - 1999
    Last Post: 15-06-2007, 08:48 PM
  5. bad turbo ??
    By geordie in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 19-02-2007, 08:00 PM
