Thread: Aircon noise
Results 1 to 8 of 8
  1. Aircon noise
    Feb 2017
    Preston, UK
    Hi all,
    When I turn the aircon on (It works as expected) there's a noise from behind the dash, almost like a dry bearing noise? It isn't noticeable from the engine bay, so what's behind the dash as I assume the compressor etc would be on the engine side?
    All functions work, but this "dry" noise is new!
  2. Re: Aircon noise
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    88 Post(s)
    Quote Originally Posted by acattanach View Post
    Hi all,
    The blower unit itself is in the dash and an item with standard type bearings perhaps it has a dry / worn bearing?
    There are several actuator motors for various flaps in the climatronic HVAC system, if you have such but they are much smaller so don't usually make the same familiar bearing noise if worn and would only do so for short periods of time when in use.
  3. Re: Aircon noise
    Feb 2017
    Preston, UK
    Quote Originally Posted by DMitch16 View Post
    Thanks, the noise only starts when Aircon is clicked, normal blowers/heater it's not there.
    Do you think it's worth getting the motor out or is it unrelated?
  4. Re: Aircon noise
    134 Post(s)
    2009 Post(s)
    It could be low on gas
  5. Re: Aircon noise
    Feb 2017
    Preston, UK
    It was indeed, Garage did a leak test and says it's the Condenser radiator.
    Tempted to have a do myself, there seems to be many options from Euorparts etc, any recommendations on brands to buy/avoid?
    And is it doable by an averagely skilled bloke?!
  6. Re: Aircon noise
    134 Post(s)
    2009 Post(s)
    Hmmm, yes the condensers can leak but it is more often the pressure switch, did they do a leak test with dye? It is a very feasible DIY job and the EIS range from ECP is fine as the genine 3C0 820 411 G is daft money at £601.25. The Mahle branded part from ECP is even cheap than EIS but they don't have such a good stock. We have used a lot of these and had no problems.
  7. Re: Aircon noise
    Feb 2017
    Preston, UK
    He said a leak test wit Nitrogen? Is it cheaper/easier to try the pressure switch??
  8. Re: Aircon noise
    Jan 2012
    10 Post(s)
    88 Post(s)
    Nitrogen is used as it is inert and does not contain water molecules, with moisture being the enemy of HVAC systems. As you have to empty the system for condenser replacement (replace the dryer too, which is a must) why not simply fit a new sensor while it's empty, I don't believe they are expensive. That's what I did when replacing my compressor, condenser (used the OE Behr version), dryer, pipe seals and aux belt a few years ago (DIY). Local AC shop discharged my system and refilled after the work for a one off payment of £50. Work was done over a weekend and refilled the following one
    1 2 0
  1. Please Help Aircon noise
    By mikeuk in forum Golf MK7 - 2013 - 2019
    Last Post: 10-07-2018, 01:09 PM
  2. Question Aircon heater problem, very loud broken noise! Help!!
    By Mattt555 in forum Golf MK6 - 2009 - 2013
    Last Post: 12-06-2016, 10:28 AM
  3. noise under glovebox... Aircon?
    By patomlin76 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-02-2010, 12:14 AM
  4. Noise from alternator/ cam belt area when aircon off
    By Marc1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 30-09-2009, 08:28 PM
  5. Noise from aircon
    By blakey in forum Audi A4 - Archive Topics
    Last Post: 16-04-2007, 03:55 PM
