Thread: P0101 & p02299 faults
  1. P0101 & p02299 faults
    Aug 2007
    Hi all, I have the faults showing on a 2.0 tdi 140bhp engine, been told it could be a million things but obviously it's a maf and low boost fault, all pipes and maf have been checked or changed, hoping somebody has encountered these issues and have a successful fix. Cheets
  2. Re: P0101 & p02299 faults
    Apr 2018
    N.Ireland
    9 Post(s)
    Is it modified in any way? Remap? does it hit limp mode at certain roads? inclines?
    MK7 Golf Estate '14 GT TDI CR150 DSG. Engine Mods: Stage 1, Rear Intake Trim
  3. Re: P0101 & p02299 faults
    1840 Post(s)
    I think that second code would be
    16683 (P0299) - Boost Pressure Regulation: Control Range Not Reached
    Not P02299. In my experience this is always a problem with the vacuum control system such as a boost solenoid fault or more often, a vacuum pipe leak BUT with code
    16485 (P0101) - Mass Air Flow Sensor (G70): Implausible Signal
    I also think about a blocked cat or DPF so what is the cars year and engine code?
  1. P0101 MAF range performance
    By Muckie1 in forum A1
    Last Post: 05-08-2020, 10:35 PM
  2. Audi S5 with fault codes P0101, P0171 and P0174.
    By Robwest100 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 21-01-2019, 02:44 PM
  3. Help with VAG COM Faults
    By Grover2000 in forum VCDS - General Questions
    Last Post: 30-07-2012, 01:35 PM
  4. A6 faults
    By barrett130 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-01-2010, 11:54 PM
  5. new faults on vag-com help please
    By zorgman in forum Touran - Sharan - Caravelle
    Last Post: 10-02-2008, 04:54 PM
