Thread: Mk5 Golf - Starting Issue but not when parked on hill!
  1. Mk5 Golf - Starting Issue but not when parked on hill!
    Jan 2021
    solihull
    Can you help??
    I have a strange issue in with my mk5 2.0l diesel, it has an issue starting if its left for approx 6 / 8 hrs, it takes 5 / 6 quite long attempts to start it, its as though the diesel flows back to the tank and takes a while to get back to the engine. When it has been started once, it has no issue starting again unless left for a long period, at work or overnight.
    I have recently found out that if left on a slope, this was in a car park, it starts fine!
    So last night, i reversed my car on the small wheel ramps I have, approx 300mm high, to test, and it started first time no issues.
    Any idea what this could be??? i am baffled.
    Thanks in advance
    Nick
  2. Re: Mk5 Golf - Starting Issue but not when parked on hill!
    1840 Post(s)
    Has the lift pump in the tank been checked?
  3. Re: Mk5 Golf - Starting Issue but not when parked on hill!
    Jan 2021
    solihull
    no i have only checked for any leaks to hoses around the fuel filter, would the lift pump be likely, can this be checked or is it just replace it and see....
  4. Re: Mk5 Golf - Starting Issue but not when parked on hill!
    1840 Post(s)
    You can run it with a suitable diagnostic system and see if it delivers fuel to the filter unit, I have also seen symptoms like yours when someone has been in there and connected the hoses up the wrong way around, yes you Mr RAC and AA breakdown chaps!
  1. Please Help A4 b8 2.0 TFSI CVT - From stop/hill issue
    By ChristianL in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 27-09-2014, 05:15 AM
  2. 1.9tdi (BKC) Wont start if parked on hill - HELP!
    By andwat in forum Golf MK5 - 2004 - 2009
    Last Post: 27-04-2012, 11:25 PM
  3. starting problem whan parked uphill
    By alltalk in forum Passat - B5 Forum - 1997 -2005
    Last Post: 22-04-2012, 02:40 PM
  4. Please Help A4 B5 2.5TDI AFB Wont start when parked on a hill ??
    By elefant_man in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 31-10-2009, 09:51 PM
  5. Golf GT TDI starting issue
    By help in forum Archive posts
    Last Post: 15-10-2006, 02:15 PM
