Thread: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
Results 11 to 20 of 29
  1. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #11
    Sep 2009
    Burton Upon Trent, England
    Hi Crasher thanks as always for your reply, Injectors in the original engine were 03L130277s but when they failed we replaced with 03L130277B refurbs with new calibration codes and coded these with VCD's to the ecu. We replaced the engine (engine came without injectors) and put the refurb injectors back in in the same order 1- 4. The HPFP came with the replaced engine so we left it on to see if that was the issue. along with the Crank sensor cam sensor. then we changed the solenoid valves one at a time from the replaced engine as the fault still exists after testing. EGR was also replaced with a new one.
  2. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #12
    Sep 2009
    What should the maximum deviation be on these injectors mine on an A5 3.0 TDI 6cyl are about 0.2 difference, These on the faulty engine are all over the place, why would this be so when VCDs coded the correct values given to us. I know its a different animal. Are we looking for a fault or a condition of the fault?20210405_213900.jpg20210408_132351.jpg
    I read this somewhere
    Look at them as percentages of your IQ value at idle. I would not worry about your injectors.
    With an IQ of 2.5 balance corrections of:
    less than +/- 0.25 are excellent. 10%
    less than +/- 0.5 are good. 20%
    less than +/- 0.75 are fair. 30%
    1.0 or more - time to start planning investigation and correction. 40%
    1.5 or more - you need to take action now. 60%
    These are just my own rules of thumb, after looking at hundreds of sets of data; I have never had a disinterested authority expound on the matter.
    The commonly proposed balance limit of +/-2.0 mg/stroke is ludicrous - one cylinder may not even be working.
    Your balance corrections (smooth idle adjustment) is less than 10% of your IQ.
  3. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #13
    Sep 2009
    This was VCDs LOG
    Wednesday 7 April 2021 17:31:17:00009-VCID:7CF741F7F7EB6E6657-8028 VCDS Version: Release 20.4.1 (x64) Data version: 20200331 DS317.0
    03L 906 023 FS ADVMB 1.6l R4 CR td H43 9970
    G003 F0 G004 F0 G009 F0 G012 F0 G022 F0 G028 F0 G043 F0 G048 F0 G049 F0 G050 F0 G051 F0 G101 F0
    Marker TIME Loc. IDE00021 TIME Loc. IDE00025 TIME Loc. IDE00083 TIME Loc. IDE00086 TIME Loc. IDE00188-ENG102817 TIME Loc. IDE00201-ENG102664 TIME Loc. IDE00359-ENG102866 TIME Loc. IDE00365-ENG99400 TIME Loc. IDE00366-ENG101187 TIME Loc. IDE00367-ENG101684 TIME Loc. IDE00368-ENG103465 TIME Loc. IDE00473-ENG102104
    STAMP Engine speed STAMP Coolant temperature STAMP Throttle valve position (absolute) STAMP Accelerator position STAMP Fuel high pressure: actual value-FUP_FIL STAMP High fuel pressure: specified value-FUP_SP_KPA STAMP Limitation: smoke-TQI_SLM STAMP Injection amount deviation cylinder 1-FAC_CYL_BAL1 STAMP Injection amount deviation cylinder 2-FAC_CYL_BAL2 STAMP Injection amount deviation cylinder 3-FAC_CYL_BAL3 STAMP Injection amount deviation cylinder 4-FAC_CYL_BAL4 STAMP EGR Vacuum Regulator Solen.val.: activation-ANG_SP_EGRV[0]
    /min °C % % MPa kPa Nm mg/stroke mg/stroke mg/stroke mg/stroke %
    2.01 0 2.21 6 2.42 89.4 0.12 15 0.34 0 0.53 0 0.74 1023.97 0.96 0.0002 1.17 0.0002 1.37 0.0002 1.59 0.0002 1.79 0
    4.62 0 4.84 6 5.03 89.4 2.63 15 2.87 0 3.1 0 3.29 1023.97 3.5 0.0002 3.7 0.0002 3.91 0.0002 4.13 0.0002 4.39 0
    7.13 0 7.36 6 7.58 89.4 5.24 15 5.45 0 5.65 0 5.87 1023.97 6.09 0.0002 6.29 0.0002 6.49 0.0002 6.7 0.0002 6.9 0
    9.65 0 9.87 6 10.07 89.4 7.78 15 7.99 0 8.21 0 8.41 1023.97 8.62 0.0002 8.81 0.0002 9.01 0.0002 9.22 0.0002 9.43 0
    12.14 0 12.35 6 12.55 89.4 10.29 15 10.49 0 10.7 0 10.91 1023.97 11.12 0.0002 11.31 0.0002 11.51 0.0002 11.72 0.0002 11.93 0
    14.66 0 14.9 6 15.13 89.4 12.75 15 12.96 0 13.18 0 13.4 1023.97 13.62 0.0002 13.82 0.0002 14.04 0.0002 14.25 0.0002 14.45 0
    17.23 0 17.44 5 17.64 89.4 15.32 15 15.53 0 15.74 0 15.96 1023.97 16.18 0.0002 16.4 0.0002 16.62 0.0002 16.81 0.0002 17.02 0
    19.77 0 19.99 6 20.2 89.4 17.86 15 18.06 0 18.26 0 18.47 1023.97 18.67 0.0002 18.91 0.0002 19.15 0.0002 19.37 0.0002 19.56 0
    22.37 0 22.57 6 22.79 89.4 20.41 15 20.62 0 20.82 0 21.04 1023.97 21.25 0.0002 21.45 0.0002 21.66 0.0002 21.92 0.0002 22.15 0
    24.92 0 25.16 6 25.37 89.8 22.99 15 23.2 0 23.41 0 23.62 1023.97 23.82 0.0002 24.03 0.0002 24.23 0.0002 24.44 0.0002 24.67 0
    27.46 0 27.67 6 27.91 89.4 25.57 15 25.79 0.092 25.99 0 26.2 1023.97 26.41 0.0002 26.63 0.0002 26.82 0.0002 27.03 0.0002 27.24 0
    29.99 0 30.21 6 30.43 89.4 28.12 15 28.32 0.092 28.53 0 28.73 1023.97 28.94 0.0002 29.15 0.0002 29.38 0.0002 29.57 0.0002 29.78 0
    32.57 266 32.78 6 32.99 88.6 30.67 15 30.91 0.116 31.12 0 31.32 1023.97 31.54 0.0002 31.75 0.0002 31.95 0.0002 32.16 0.0002 32.38 0
    35.13 1013 35.32 6 35.53 89 33.21 15 33.43 33.167 33.65 33532.715 33.86 138.78 34.06 0.0002 34.27 0.0002 34.46 0.0002 34.67 -0.1339 34.91 0
    37.67 996 37.89 5 38.09 88.6 35.74 15 35.96 27.863 36.17 27490.234 36.38 136.09 36.58 -1.2614 36.79 1.2655 37.01 1.2387 37.22 -2.1385 37.43 0
    40.24 1022 40.46 6 40.68 88.6 38.3 15 38.5 26.477 38.71 27319.336 38.93 135 39.17 -1.9616 39.39 2.8596 39.6 1.9851 39.81 -2.8992 40.02 0
    42.93 1029 43.17 6 43.39 88.6 40.92 15 41.13 27.917 41.33 27337.646 41.54 136.41 41.76 -1.8023 41.97 2.493 42.18 1.7979 42.43 -2.5289 42.68 0
    45.47 1010 45.67 6 45.89 88.6 43.59 15 43.79 25.885 44 25616.455 44.21 136.69 44.43 -2.4238 44.67 1.6635 44.88 1.687 45.08 -2.2231 45.27 0
    47.99 999 48.2 6 48.42 88.6 46.09 15 46.29 25.195 46.5 25164.795 46.71 135.59 46.93 -1.6328 47.17 1.6145 47.38 1.5471 47.58 -2.1913 47.78 0
    50.58 942 50.78 6 50.99 89 48.64 15 48.85 25.104 49.07 24993.896 49.28 132.03 49.49 -1.8346 49.71 1.3863 49.94 1.4449 50.17 -1.8466 50.38 0
    53.17 943 53.38 6 53.58 88.6 51.21 15 51.42 24.841 51.63 24993.896 51.83 131.53 52.04 -1.3369 52.25 1.3314 52.45 1.2658 52.68 -1.3215 52.93 0
    55.69 938 55.92 6 56.13 88.6 53.78 15 53.99 25.134 54.21 24993.896 54.43 132 54.67 -1.2702 54.89 1.628 55.07 1.8562 55.28 -1.8408 55.49 17.126
    58.22 942 58.45 6 58.69 89 56.33 15 56.54 25.012 56.75 24993.896 56.95 132.03 57.19 -1.6899 57.4 1.6185 57.6 1.3698 57.81 -1.736 58.01 12.91
    60.79 943 60.99 6 61.19 88.6 58.9 15 59.09 24.933 59.3 24993.896 59.51 132.19 59.73 -1.4098 59.94 1.468 60.15 1.3361 60.35 -1.1984 60.57 12.55
    63.26 940 63.47 6 63.7 88.6 61.4 15 61.6 24.896 61.82 24993.896 62.03 132.06 62.23 -1.4076 62.44 1.1897 62.65 1.1329 62.85 -1.4914 63.06 12.531
    65.82 944 66.03 7 66.23 89 63.92 15 64.12 25.11 64.32 24993.896 64.53 132.56 64.73 -1.0776 64.96 1.2937 65.2 1.5738 65.42 -1.5885 65.62 12.111
    68.42 930 68.61 7 68.82 89 66.46 15 66.7 24.841 66.92 24993.896 67.12 132.25 67.32 -1.3468 67.53 1.0523 67.73 1.0355 67.96 -1.4753 68.2 12.27
    71.04 932 71.26 7 71.46 88.6 69.03 15 69.23 24.988 69.46 24993.896 69.71 131.41 69.96 -1.3101 70.2 1.2318 70.42 1.4998 70.61 -1.513 70.82 12.471
    73.6 929 73.8 7 74.02 88.6 71.7 15 71.92 24.982 72.11 24993.896 72.32 131.44 72.53 -1.4383 72.73 1.3014 72.96 1.1571 73.2 -1.0487 73.42 12.691
    76.2 932 76.44 7 76.65 88.6 74.22 15 74.46 25.11 74.7 24993.896 74.92 131.03 75.11 -1.4511 75.32 0.9787 75.52 1.2578 75.72 -0.9948 75.95 12.73
    78.75 929 78.96 8 79.19 88.6 76.85 15 77.06 25.146 77.28 24993.896 77.5 131.44 77.72 -1.1409 77.93 0.9373 78.12 1.576 78.34 -1.3288 78.54 12.65
    81.4 920 81.61 8 81.82 88.6 79.4 15 79.6 24.982 79.8 24993.896 80.02 130.88 80.25 -1.3372 80.5 0.8264 80.74 1.1164 80.98 -1.3398 81.21 12.75
    83.96 920 84.14 8 84.35 88.6 82.04 15 82.24 25.134 82.46 24993.896 82.66 130.5 82.86 -1.3566 83.07 1.0952 83.28 1.1329 83.5 -1.1153 83.74 12.91
    86.5 925 86.73 8 86.94 89 84.56 15 84.78 24.841 85 24993.896 85.26 130.53 85.48 -1.2545 85.66 1.3277 85.88 1.4643 86.06 -1.1527 86.27 12.711
    89.08 920 89.3 9 89.54 88.6 87.14 15 87.35 24.933 87.56 24993.896 87.78 130.69 88.04 -1.0776 88.26 1.2475 88.47 1.2786 88.67 -1.2926 88.88 12.45
    91.64 919 91.85 9 92.06 88.6 89.77 15 89.99 25.018 90.18 24993.896 90.4 131.06 90.6 -1.0238 90.8 1.0373 91.02 1.3138 91.25 -0.941 91.44 12.871
    94.24 908 94.43 9 94.63 88.6 92.28 15 92.54 24.957 92.77 24993.896 92.99 129.94 93.18 -1.5438 93.39 0.9472 93.6 1.1435 93.8 -0.8659 94.02 12.37
    96.86 915 97.05 9 97.28 88.6 94.84 15 95.04 25.018 95.28 24993.896 95.55 129.5 95.78 -0.9278 96.02 1.0047 96.24 1.045 96.44 -0.8535 96.64 12.691
    99.39 908 99.6 9 99.8 89 97.52 15 97.74 24.896 97.92 24993.896 98.14 130.13 98.34 -1.0311 98.55 0.8696 98.78 1.3618 98.99 -1.3138 99.18 12.151
    102.03 909 102.28 10 102.52 89 100.03 15 100.27 25.012 100.49 24993.896 100.69 129.91 100.88 -1.2823 101.1 1.3424 101.31 0.8769 101.53 -1.368 101.78 12.25
    104.64 880 104.86 10 105.06 89 102.73 15 102.93 25.049 103.14 24993.896 103.36 129.53 103.56 -1.008 103.78 2.3257 104.02 1.5991 104.24 -1.6537 104.44 8.649
    107.22 899 107.44 10 107.64 88.6 105.3 15 105.54 25.043 105.75 24993.896 105.95 128.44 106.15 -2.1312 106.36 1.9836 106.57 2.2645 106.79 -1.4504 107.02 9.135
    109.78 904 110 10 110.21 89 107.86 15 108.06 25.024 108.31 24993.896 108.54 128.78 108.75 -1.4998 108.94 1.2373 109.16 2.1799 109.35 -1.821 109.56 8.611
    112.34 900 112.54 11 112.76 88.6 110.42 15 110.64 25.031 110.86 24993.896 111.06 129.06 111.29 -1.9327 111.52 1.4544 111.72 1.6075 111.93 -1.3852 112.13 8.948
    114.86 879 115.07 11 115.29 88.6 112.96 15 113.16 25.085 113.37 24993.896 113.58 128.47 113.8 -1.4427 114.04 1.4918 114.25 2.2334 114.44 -1.6709 114.65 8.836
    117.37 875 117.58 11 117.8 88.6 115.51 15 115.72 25.031 115.93 24993.896 116.13 127.16 116.34 -1.9419 116.54 1.0835 116.76 1.8298 116.96 -1.8485 117.16 8.649
    119.92 875 120.13 11 120.33 88.6 118.06 15 118.27 25.049 118.46 24993.896 118.67 127.22 118.88 -2.2143 119.08 1.5453 119.3 2.4527 119.52 -1.8943 119.72 8.76
    122.43 874 122.64 11 122.86 88.6 120.56 15 120.78 24.988 120.97 24993.896 121.18 127.16 121.38 -1.5313 121.59 1.1633 121.81 1.7562 122.03 -1.3969 122.22 8.723
    124.92 869 125.14 12 125.35 88.6 123.06 15 123.27 25.104 123.46 24993.896 123.67 127 123.87 -1.6046 124.08 1.6936 124.3 2.3103 124.52 -1.9957 124.71 8.574
    127.52 850 127.72 12 127.94 88.6 125.56 15 125.77 24.957 125.97 24993.896 126.18 125.13 126.38 -2.1173 126.59 1.8254 126.82 2.4198 127.07 -1.435 127.3 8.199
    130.03 849 130.22 12 130.43 88.6 128.14 15 128.35 24.963 128.56 24993.896 128.77 125.41 128.97 -1.6255 129.18 1.3241 129.38 1.7298 129.58 -1.5116 129.81 8.237
    132.57 853 132.81 12 133.02 88.6 130.63 15 130.84 24.957 131.05 24993.896 131.31 125.28 131.52 -1.6148 131.71 1.3457 131.92 1.7778 132.12 -1.5042 132.33 8.162
    135.11 849 135.32 13 135.56 88.6 133.22 15 133.44 25.079 133.64 24993.896 133.85 125.31 134.06 -2.4194 134.28 1.9862 134.47 1.7478 134.68 -1.5174 134.89 8.311
    137.67 825 137.86 13 138.07 88.6 135.77 15 135.97 25.073 136.19 24993.896 136.4 123.16 136.61 -1.6643 136.83 1.4475 137.06 2.4813 137.27 -1.4372 137.46 8.199
    140.27 827 140.47 13 140.68 88.6 138.31 15 138.53 25.092 138.72 24993.896 138.93 123.66 139.14 -1.8108 139.36 1.446 139.58 1.7544 139.81 -2.0378 140.06 7.3
    142.82 827 143.06 13 143.28 89 140.88 15 141.09 25.061 141.32 24993.896 141.56 123.31 141.77 -1.8214 141.96 1.4713 142.16 2.4835 142.37 -2.0301 142.58 6.857
    145.41 829 145.62 14 145.82 88.6 143.47 15 143.68 25.012 143.88 24993.896 144.09 123.5 144.32 -2.4513 144.56 1.4167 144.78 1.7434 144.99 -1.4713 145.21 7.562
    147.96 827 148.17 14 148.38 88.6 146.06 15 146.27 25 146.47 24993.896 146.68 123.63 146.89 -1.7199 147.11 1.4178 147.33 1.743 147.56 -1.9459 147.77 8.087
    150.52 803 150.72 14 150.94 88.6 148.6 15 148.8 24.921 149.02 24993.896 149.22 121.53 149.44 -1.7371 149.66 2.0352 149.86 2.626 150.07 -1.4292 150.31 6.691
    153.06 802 153.27 14 153.46 88.6 151.16 15 151.36 25.018 151.57 24993.896 151.8 121.44 152.02 -1.7892 152.21 1.2981 152.42 2.4209 152.62 -1.9049 152.82 7.675
    155.75 809 155.97 14 156.18 88.6 153.67 15 153.88 25.171 154.09 24993.896 154.33 121.28 154.59 -1.7752 154.83 1.3955 155.08 2.5674 155.32 -1.7957 155.54 7.375
    158.24 803 158.45 15 158.66 88.6 156.38 15 156.59 25.018 156.8 24993.896 157 121.28 157.22 -1.8448 157.43 1.3211 157.63 2.4256 157.84 -1.8031 158.05 7.001
    160.75 781 160.97 15 161.19 88.6 158.88 15 159.09 24.805 159.3 24993.896 159.49 120.91 159.7 -2.5113 159.91 1.4819 160.11 2.2301 160.33 -1.8983 160.55 7.6
    163.34 780 163.56 15 163.75 88.6 161.4 15 161.6 24.872 161.84 24993.896 162.06 119.91 162.25 -2.396 162.46 2.0444 162.67 1.8397 162.87 -1.9803 163.1 6.882
    165.97 781 166.18 15 166.39 88.6 163.97 15 164.19 24.921 164.4 24993.896 164.61 119.34 164.85 -2.4143 165.1 2.0825 165.34 1.7108 165.55 -1.9657 165.75 7.487
    168.59 783 168.81 15 169.01 88.6 166.61 15 166.85 24.896 167.06 24993.896 167.26 119.38 167.47 -2.3916 167.69 2.0074 167.9 1.8294 168.1 -1.9367 168.35 7.263
    171.12 780 171.34 16 171.56 88.6 169.21 15 169.42 24.908 169.62 24993.896 169.85 119.59 170.09 -2.2949 170.3 1.3215 170.5 1.8353 170.7 -1.8463 170.91 7.413
    173.67 783 173.88 16 174.08 88.6 171.77 15 171.98 25.177 172.18 24993.896 172.38 119.53 172.6 -1.7009 172.84 1.7522 173.05 1.713 173.24 -1.8412 173.45 6.644
    176.16 782 176.37 16 176.59 88.6 174.3 15 174.5 25.012 174.7 24993.896 174.9 120 175.1 -2.359 175.33 1.7057 175.55 2.5036 175.75 -1.3834 175.96 7.487
    178.7 779 178.91 16 179.12 88.6 176.81 15 177.01 24.872 177.21 24993.896 177.42 119.75 177.62 -2.3839 177.85 1.8375 178.09 2.4388 178.3 -1.3607 178.5 7.188
    181.3 786 181.5 16 181.71 88.6 179.35 15 179.59 24.988 179.81 24993.896 180.01 119.75 180.21 -1.7214 180.42 1.3676 180.62 2.5033 180.85 -1.9789 181.09 6.929
    183.85 782 184.09 17 184.3 88.6 181.93 15 182.13 25.104 182.34 24993.896 182.55 119.44 182.75 -1.6657 182.96 1.32 183.16 2.3963 183.37 -2.1144 183.6 7.225
    186.41 786 186.63 17 186.87 88.6 184.5 15 184.72 24.982 184.91 24993.896 185.12 119.91 185.35 -1.7295 185.59 1.3691 185.8 1.6709 185.99 -2.0268 186.2 7.225
    188.96 779 189.17 17 189.38 88.6 187.09 15 187.3 25.079 187.5 24993.896 187.71 119.66 187.91 -2.2154 188.12 1.3534 188.35 1.7221 188.57 -1.3889 188.76 7.039
    191.47 777 191.68 17 191.88 88.6 189.6 15 189.82 25.11 190.01 24993.896 190.22 119.66 190.42 -1.6994 190.61 1.8529 190.85 2.3619 191.07 -2.0876 191.26 7.487
    194.07 782 194.26 17 194.47 88.6 192.11 15 192.36 25.061 192.58 24993.896 192.77 119.66 192.98 -2.3487 193.18 1.3314 193.39 2.4059 193.63 -1.3713 193.86 6.763
    196.59 778 196.81 18 197.01 88.6 194.69 15 194.9 25.153 195.12 24993.896 195.33 119.59 195.53 -2.4179 195.74 1.3204 195.94 1.7961 196.15 -2.0228 196.37 7.039
    199.16 778 199.37 18 199.59 89 197.22 15 197.42 25.031 197.63 24993.896 197.88 119.56 198.12 -1.6372 198.33 1.2966 198.53 2.3524 198.74 -1.8514 198.94 7.899
    201.77 776 201.98 18 202.19 88.6 199.8 15 200.02 24.86 200.22 24993.896 200.43 119.5 200.64 -1.7694 200.88 1.3966 201.13 2.419 201.37 -2.0975 201.58 6.953
    204.3 778 204.52 18 204.73 88.6 202.41 15 202.62 24.89 202.83 24993.896 203.03 119.31 203.24 -1.7401 203.44 1.832 203.65 1.7148 203.87 -1.387 204.09 7.562
    206.87 781 207.09 18 207.31 88.6 204.93 15 205.14 24.847 205.38 24993.896 205.62 119.44 205.83 -2.355 206.03 1.3321 206.24 1.7555 206.46 -1.8697 206.66 7.487
    209.48 775 209.68 18 209.89 88.6 207.51 15 207.72 25.085 207.92 24993.896 208.13 119.72 208.38 -2.422 208.62 1.3856 208.84 2.4637 209.05 -1.9763 209.27 7.637
    212.11 779 212.32 19 212.51 88.6 210.13 15 210.37 25.049 210.58 24993.896 210.78 119.91 210.99 -2.322 211.19 1.2801 211.4 1.8049 211.63 -1.3537 211.88 6.763
    214.63 779 214.88 19 215.1 88.6 212.72 15 212.93 24.927 213.14 24993.896 213.37 120 213.59 -2.2147 213.77 1.3449 213.98 2.4919 214.19 -1.3724 214.41 0
    217.19 779 217.41 19 217.64 89 215.3 15 215.52 24.969 215.73 24993.896 215.93 119.47 216.14 -2.2839 216.36 1.6306 216.57 1.7254 216.77 -1.4156 216.98 0
    219.71 780 219.91 19 220.14 88.6 217.85 15 218.04 25.012 218.25 24993.896 218.46 119.69 218.68 -2.3399 218.88 1.2743 219.1 1.799 219.29 -1.8672 219.5 0
    222.21 781 222.42 19 222.63 88.6 220.35 15 220.55 24.957 220.77 24993.896 220.98 119.16 221.18 -1.6742 221.39 1.2764 221.6 2.3795 221.8 -1.2753 222.01 0
    224.8 780 225.01 19 225.21 88.6 222.86 15 223.07 25.018 223.27 24993.896 223.48 119.88 223.69 -1.7053 223.91 1.7181 224.15 1.7785 224.39 -1.2647 224.6 0
    227.35 778 227.54 20 227.75 88.6 225.42 15 225.64 25.049 225.86 24993.896 226.07 119.63 226.28 -2.3315 226.48 1.2318 226.68 2.4205 226.9 -1.8038 227.14 0
    229.85 789 230.05 20 230.27 88.6 227.95 15 228.16 24.939 228.38 24993.896 228.6 119.53 228.8 -2.207 229.01 1.1691 229.21 2.4996 229.42 -1.6599 229.64 0
    232.4 780 232.64 20 232.85 88.6 230.48 15 230.69 25.049 230.91 24993.896 231.14 119.53 231.36 -2.4322 231.56 1.327 231.76 1.7646 231.97 -1.7793 232.19 0
    234.92 782 235.15 20 235.39 88.6 233.05 15 233.26 24.939 233.46 24993.896 233.67 119.75 233.89 -2.374 234.11 1.2614 234.3 1.8173 234.51 -1.7331 234.72 0
    237.53 779 237.73 20 237.94 89 235.6 15 235.8 25.043 236.02 24993.896 236.24 119.38 236.45 -1.7166 236.65 1.5035 236.89 2.5494 237.11 -1.6661 237.32 0
    240.05 777 240.27 20 240.48 88.6 238.16 15 238.38 25 238.6 24993.896 238.79 119.75 239 -1.6895 239.21 1.7368 239.41 2.3374 239.63 -1.2753 239.85 0
    242.61 772 242.8 21 243 88.6 240.68 15 240.89 25.61 241.11 27435.303 241.3 133.03 241.51 0.0002 241.72 0.0002 241.92 0.0002 242.15 -0.9025 242.39 30.034
    245.1 2293 245.29 21 245.5 88.6 243.21 23 243.41 55.78 243.62 44287.109 243.84 142 244.03 -0.8857 244.23 1.0593 244.44 2.1678 244.65 0.0002 244.88 18.442
    247.6 760 247.8 21 248.02 88.6 245.7 15 245.91 34.326 246.14 32647.705 246.35 120.16 246.55 -1.0139 246.77 1.1695 246.97 0.8172 247.18 -1.1138 247.39 12.671
    250.14 779 250.35 21 250.54 88.6 248.23 15 248.43 26.813 248.64 26348.877 248.86 119.63 249.07 -1.4259 249.27 1.4834 249.48 1.6569 249.69 -1.1501 249.91 7.675
    252.64 780 252.85 21 253.05 88.6 250.75 15 250.96 25.116 251.17 24993.896 251.39 119.81 251.6 -2.2854 251.8 1.6251 252.01 1.7489 252.22 -1.3288 252.42 7.039
    255.15 781 255.38 21 255.6 88.6 253.27 15 253.48 25.079 253.68 24993.896 253.89 119.34 254.11 -1.6965 254.33 1.3189 254.53 1.7807 254.73 -1.7401 254.94 7.076
    257.67 776 257.89 22 258.11 88.6 255.8 15 256 24.951 256.21 24993.896 256.42 119.81 256.64 -1.598 256.85 1.2695 257.05 2.3996 257.26 -1.936 257.46 7.225
    260.18 779 260.39 22 260.6 88.6 258.32 15 258.53 24.908 258.73 24993.896 258.94 119.88 259.14 -1.5892 259.35 1.6628 259.54 1.7679 259.75 -1.9946 259.96 7.75
    262.8 777 263.01 22 263.21 88.6 260.8 15 261.01 25.024 261.23 24993.896 261.43 119.59 261.65 -2.1803 261.9 1.8463 262.15 1.7276 262.39 -1.3999 262.6 7.562
    265.35 784 265.55 22 265.76 88.6 263.42 15 263.64 24.957 263.86 24993.896 264.06 119.66 264.26 -2.0942 264.47 1.3453 264.68 1.747 264.9 -2.0514 265.13 7.375
    267.89 785 268.1 23 268.3 88.6 265.96 15 266.17 25.012 266.39 24993.896 266.61 119.81 266.82 -2.2546 267.04 1.8064 267.25 1.7364 267.45 -1.4669 267.66 8.162
    270.39 785 270.61 23 270.81 88.6 268.5 15 268.71 24.988 268.92 24993.896 269.13 119.66 269.35 -2.1935 269.55 1.4398 269.76 1.7507 269.96 -2.0371 270.17 7.787
    272.89 777 273.1 23 273.3 88.6 271.02 15 271.23 24.988 271.44 24993.896 271.64 119.75 271.85 -1.6137 272.05 1.9419 272.25 2.2348 272.46 -1.4925 272.68 7.637
    275.39 783 275.6 23 275.8 88.6 273.5 15 273.71 25.049 273.92 24993.896 274.13 119.75 274.35 -2.2209 274.55 1.3321 274.76 1.7137 274.98 -1.4731 275.18 7.6
    277.91 783 278.14 23 278.35 89 276.02 15 276.23 25.085 276.43 24993.896 276.64 119.59 276.86 -1.4976 277.07 1.4149 277.29 1.6339 277.49 -2.066 277.7 8.049
    280.49 782 280.7 24 280.9 88.6 278.55 15 278.76 24.994 278.96 24993.896 279.17 119.97 279.4 -2.0927 279.64 1.9598 279.86 1.6914 280.06 -1.5976 280.27 8.012
    283.03 779 283.24 24 283.46 88.6 281.12 15 281.32 25.043 281.54 24993.896 281.76 119.75 281.96 -2.122 282.17 2.0807 282.4 2.2931 282.62 -1.6269 282.82 7.562
    285.58 779 285.78 24 285.98 88.6 283.68 15 283.92 25.049 284.13 24993.896 284.33 119.44 284.54 -1.483 284.74 1.4577 284.95 2.4037 285.17 -2.0968 285.38 7.637
    288.26 776 288.46 24 288.7 88.6 286.18 15 286.43 24.963 286.68 24993.896 286.93 119.53 287.18 -2.1788 287.44 1.4405 287.65 2.3059 287.84 -1.5764 288.05 7.787
    290.86 784 291.06 24 291.27 88.6 288.95 15 289.18 24.963 289.41 24993.896 289.61 120.13 289.81 -1.5365 290.02 1.8701 290.24 2.2817 290.45 -1.5797 290.66 8.087
    293.46 787 293.71 24 293.95 88.6 291.48 15 291.7 25.085 291.92 24993.896 292.13 119.59 292.35 -1.5163 292.57 2.0133 292.78 2.4491 292.98 -1.5017 293.21 8.087
    296.06 782 296.27 24 296.47 88.6 294.17 15 294.36 24.927 294.57 24993.896 294.79 119.81 295 -1.8745 295.21 1.4061 295.45 1.5987 295.67 -1.539 295.86 7.675
    298.67 786 298.86 25 299.06 88.6 296.71 15 296.95 24.957 297.17 24993.896 297.36 119.31 297.57 -2.1089 297.79 2.0711 298 2.3473 298.21 -1.4735 298.45 7.712
    301.2 780 301.42 25 301.6 88.6 299.27 15 299.48 25.024 299.7 24993.896 299.91 120.03 300.11 -2.1839 300.32 2.1048 300.54 2.2561 300.75 -1.6126 300.96 8.348
    303.74 782 303.96 25 304.2 88.6 301.81 15 302.02 24.908 302.22 24993.896 302.46 119.38 302.7 -1.8496 302.91 1.4434 303.11 1.6482 303.32 -2.0144 303.54 8.273
    306.32 779 306.54 25 306.75 88.6 304.42 15 304.62 24.957 304.82 24993.896 305.03 119.53 305.24 -2.1092 305.46 1.791 305.7 2.3923 305.91 -1.5079 306.11 8.087
    308.86 778 309.07 25 309.28 88.6 306.95 15 307.17 24.969 307.36 24993.896 307.57 119.53 307.78 -1.9459 307.99 1.4193 308.21 1.6386 308.45 -1.6731 308.67 8.311
    311.45 786 311.67 25 311.86 89 309.48 15 309.71 24.89 309.97 24993.896 310.2 119.59 310.42 -2.0671 310.61 2.0133 310.82 1.5636 311.04 -1.6225 311.25 8.348
    314.07 785 314.28 25 314.48 88.6 312.07 15 312.28 25.012 312.48 24993.896 312.71 119.06 312.96 -1.52 313.21 1.5123 313.45 1.632 313.67 -1.6434 313.86 7.039
    316.67 778 316.87 26 317.07 88.6 314.71 15 314.96 24.829 315.2 24993.896 315.42 119.91 315.61 -1.9111 315.82 1.3834 316.04 1.6163 316.24 -2.185 316.45 8.311
    319.31 778 319.54 26 319.75 88.6 317.28 15 317.49 24.957 317.71 24993.896 317.95 119.53 318.21 -1.9397 318.47 1.9572 318.7 2.2898 318.92 -2.229 319.11 7.899
    321.98 776 322.2 26 322.43 88.6 319.95 15 320.2 25.11 320.46 24993.896 320.71 119.44 320.95 -1.4779 321.17 2.0664 321.36 1.6899 321.57 -1.5848 321.78 8.237
    324.5 778 324.71 26 324.95 88.6 322.62 15 322.83 25 323.03 24993.896 323.23 119.56 323.45 -1.9217 323.66 1.4808 323.86 2.237 324.07 -2.1162 324.29 8.012
    327.21 779 327.45 26 327.7 89 325.17 15 325.35 25.043 325.55 24993.896 325.77 119.91 325.97 -1.5255 326.2 1.3621 326.45 2.3648 326.7 -2.2693 326.97 7.6
    329.94 780 330.16 26 330.35 88.6 327.95 15 328.17 24.951 328.35 24993.896 328.57 119.44 328.79 -2.0865 329 1.9701 329.2 1.7104 329.45 -2.0825 329.7 8.499
    332.59 779 332.79 26 333 88.6 330.57 15 330.79 24.939 331 24993.896 331.21 119.59 331.45 -1.9283 331.7 2.0503 331.95 1.7009 332.16 -2.237 332.37 8.124
    335.16 781 335.37 26 335.57 88.6 333.2 15 333.45 25.055 333.66 24993.896 333.85 119.53 334.06 -2.0173 334.29 2.0276 334.51 1.6064 334.71 -1.6401 334.94 8.087
    337.74 787 337.95 27 338.16 88.6 335.78 15 335.98 25.092 336.21 24993.896 336.45 119.44 336.69 -2.0587 336.91 1.4713 337.1 1.6394 337.31 -2.2319 337.54 8.424
    340.29 780 340.49 27 340.73 88.6 338.37 15 338.57 25.031 338.78 24993.896 338.98 120.16 339.21 -2.162 339.46 2.0565 339.68 1.6851 339.87 -1.5398 340.09 7.899
    342.89 775 343.1 27 343.3 88.6 340.96 15 341.2 25.104 341.42 24993.896 341.63 119.53 341.83 -2.107 342.05 1.9129 342.25 1.6771 342.46 -2.1308 342.68 8.273
    345.33 779 345.53 27 345.74 88.6 343.51 15 343.71 24.951 343.93 24993.896 344.12 119.78 344.31 -2.0133 344.51 1.8921 344.71 1.6851 344.93 -2.1887 345.12 8.461
    347.94 784 348.13 27 348.34 88.6 345.97 15 346.21 25.012 346.43 24993.896 346.62 119.66 346.82 -1.981 347.03 1.5302 347.24 1.5874 347.47 -1.6386 347.71 8.237
    350.46 963 350.69 27 350.89 88.6 348.54 15 348.75 25.085 348.97 24993.896 349.21 119.59 349.42 -1.4412 349.62 1.5357 349.84 2.2883 350.03 -1.5108 350.25 8.012
    353.01 1187 353.22 27 353.46 88.6 351.1 15 351.3 26.862 351.51 27484.131 351.72 118.84 351.96 -3.3324 352.19 0.0002 352.38 0.0002 352.59 0.0002 352.79 47.417
    355.53 819 355.74 28 355.98 88.6 353.67 15 353.87 30.914 354.07 32952.881 354.28 144.56 354.5 0.0002 354.71 0.0002 354.92 0.0002 355.12 0.0002 355.33 32.097
    358.09 773 358.3 28 358.5 88.6 356.2 15 356.39 30.035 356.6 29473.877 356.81 118.31 357.01 -1.0728 357.24 0.6828 357.48 1.5592 357.7 -1.219 357.88 8.536
    360.64 776 360.85 28 361.06 88.6 358.73 15 358.95 25.012 359.16 24993.896 359.36 120.06 359.57 -1.4292 359.78 1.3039 360 2.1491 360.22 -1.6273 360.46 8.873
    363.23 778 363.44 28 363.63 88.6 361.26 15 361.49 24.963 361.73 24993.896 361.94 119.72 362.14 -1.873 362.36 1.7016 362.57 1.5555 362.77 -1.8628 362.99 8.499
    365.72 776 365.94 28 366.14 88.6 363.84 15 364.05 25.055 364.27 24993.896 364.48 119.47 364.69 -2.196 364.88 1.2995 365.09 1.6291 365.3 -1.9799 365.52 8.273
    368.24 780 368.48 28 368.7 88.6 366.36 15 366.57 25.018 366.77 24993.896 366.98 119.47 367.2 -1.5167 367.39 1.9397 367.6 2.2707 367.81 -1.3512 368.01 8.948
    370.78 776 371 28 371.24 88.6 368.88 15 369.09 24.89 369.3 24993.896 369.5 120.25 369.73 -1.55 369.94 2.1305 370.14 2.0755 370.36 -2.2048 370.57 8.386
    373.37 787 373.57 28 373.78 88.6 371.48 15 371.69 25.104 371.89 24993.896 372.1 119.72 372.3 -2.1803 372.51 2.1085 372.73 1.5427 372.95 -1.6276 373.16 8.348
    375.91 779 376.11 29 376.32 88.6 374 15 374.23 24.896 374.43 24993.896 374.63 119.56 374.84 -2.1349 375.05 2.0605 375.25 1.6064 375.49 -1.505 375.71 8.685
    378.5 778 378.74 29 378.96 88.6 376.53 15 376.75 25.043 377 24993.896 377.24 119.47 377.45 -2.1978 377.65 1.4918 377.86 1.6368 378.08 -2.1286 378.29 8.386
    381.08 777 381.29 29 381.5 89 379.16 15 379.37 25.061 379.57 24993.896 379.78 119.66 380 -2.2623 380.24 1.5321 380.45 2.1297 380.65 -1.6211 380.86 8.873
    383.57 779 383.78 29 384.02 88.6 381.72 15 381.92 24.872 382.14 24993.896 382.35 119.47 382.55 -1.5518 382.76 2.2147 382.98 2.2352 383.17 -1.5361 383.37 8.199
    386.13 785 386.34 29 386.54 88.6 384.24 15 384.46 24.933 384.65 24993.896 384.86 119.53 385.08 -2.2184 385.29 2.1854 385.51 2.0451 385.72 -1.6068 385.92 8.723
    388.69 780 388.9 29 389.1 88.6 386.77 15 387.01 24.951 387.22 24993.896 387.42 119.44 387.63 -1.4995 387.83 2.274 388.04 2.2499 388.25 -1.5515 388.48 8.461
    391.25 778 391.47 29 391.67 88.6 389.31 15 389.52 25.055 389.77 24993.896 390.01 119.31 390.22 -2.1678 390.42 1.5061 390.62 1.6211 390.83 -2.1242 391.04 8.424
    393.76 784 393.98 30 394.18 88.6 391.88 15 392.1 25.049 392.31 24993.896 392.51 119.59 392.73 -1.5031 392.94 1.598 393.14 2.1316 393.35 -2.0206 393.56 8.798
    396.27 784 396.51 30 396.72 88.6 394.38 15 394.59 25.122 394.79 24993.896 395.01 119.66 395.23 -2.2301 395.43 2.1814 395.63 1.4947 395.84 -2.2348 396.05 8.611
    398.83 777 399.04 30 399.27 88.6 396.92 15 397.14 24.939 397.35 24993.896 397.55 119.31 397.77 -1.5394 398.01 1.5573 398.22 2.1634 398.42 -1.4394 398.63 8.911
    401.4 778 401.6 30 401.81 88.6 399.51 15 399.72 24.988 399.92 24993.896 400.13 119.97 400.33 -1.5914 400.54 1.5306 400.76 2.2466 400.98 -2.2352 401.19 8.199
    403.98 782 404.2 30 404.4 88.6 402.02 15 402.28 25.031 402.51 24993.896 402.72 120.25 402.92 -1.6423 403.11 1.5555 403.32 1.5537 403.52 -2.2612 403.76 8.798
    406.54 783 406.77 30 406.99 88.6 404.61 15 404.83 24.982 405.05 24993.896 405.27 119.38 405.5 -1.984 405.72 1.6016 405.92 1.5442 406.12 -2.0195 406.33 8.873
    409.06 780 409.27 30 409.5 88.6 407.18 15 407.39 25.055 407.58 24993.896 407.79 120.03 408.03 -1.5998 408.24 1.5145 408.44 2.3041 408.65 -2.2641 408.85 8.273
    411.62 782 411.82 30 412.03 88.6 409.7 15 409.9 24.866 410.11 24993.896 410.33 119.59 410.54 -1.5526 410.77 1.5665 410.99 2.1905 411.19 -2.0202 411.41 8.461
    414.16 776 414.38 30 414.58 88.6 412.25 15 412.44 24.951 412.65 24993.896 412.85 119.59 413.06 -2.2436 413.29 2.1751 413.53 2.3601 413.74 -2.2444 413.94 8.311
    416.74 1300 416.93 31 417.14 88.6 414.79 15 415.02 24.939 415.25 24993.896 415.44 119.53 415.65 -2.0569 415.86 1.5658 416.08 3.7671 416.3 0.0002 416.52 45.988
    419.28 838 419.49 31 419.68 88.6 417.36 15 417.57 46.686 417.78 46356.201 417.99 137.41 418.19 0.0002 418.41 0.0002 418.61 0.0002 418.82 0.0002 419.03 36.702
    421.77 1576 421.99 31 422.19 88.6 419.89 15 420.09 52.124 420.3 54614.258 420.51 145.25 420.72 0.0002 420.92 0.0002 421.13 0.0002 421.35 0.0002 421.55 54.64
    424.3 770 424.54 31 424.76 88.6 422.41 15 422.61 31.311 422.82 31274.414 423.03 118.53 423.24 -1.1369 423.44 0.8729 423.65 1.2651 423.85 -1.0992 424.06 12.43
    426.86 776 427.08 31 427.3 88.6 424.95 15 425.16 25.806 425.36 25329.59 425.57 119.88 425.8 -2.032 426.04 1.3274 426.26 2.1026 426.44 -1.0955 426.65 8.499
    429.51 779 429.7 31 429.91 88.6 427.54 15 427.76 24.89 427.95 24993.896 428.16 120.09 428.37 -1.5745 428.57 1.6123 428.8 1.9378 429.06 -1.2417 429.29 9.473
    432.07 778 432.3 31 432.55 88.6 430.11 15 430.32 25.012 430.55 24993.896 430.8 120.03 431.04 -2.1074 431.25 1.2578 431.44 1.5907 431.65 -1.8027 431.86 8.273
    434.81 778 435.04 31 435.25 89 432.8 15 433.06 25 433.28 24993.896 433.48 119.56 433.69 -1.5299 433.91 1.4526 434.12 2.1393 434.33 -1.8397 434.55 8.798
    437.33 776 437.55 31 437.81 88.6 435.45 15 435.66 24.963 435.88 24993.896 436.08 119.69 436.29 -1.535 436.51 2.1404 436.71 2.2228 436.91 -1.4607 437.12 8.836
    440 778 440.2 32 440.41 89 438.04 15 438.25 25.061 438.45 24993.896 438.65 119.44 438.86 -2.1784 439.07 1.502 439.3 1.5793 439.55 -1.4874 439.79 8.424
    442.51 774 442.7 32 442.9 88.6 440.61 15 440.82 24.963 441.04 24993.896 441.26 120.13 441.44 -1.5192 441.65 2.1026 441.85 1.4401 442.06 -1.5716 442.29 8.798
    445.05 779 445.29 32 445.51 88.6 443.11 15 443.33 25.043 443.55 24993.896 443.79 119.53 444 -1.5343 444.2 2.2209 444.4 2.2176 444.61 -1.4753 444.83 9.398
    447.63 777 447.83 32 448.04 88.6 445.71 15 445.92 25.116 446.12 24993.896 446.33 120.13 446.55 -2.1598 446.79 2.0173 447.01 1.5778 447.2 -2.1217 447.41 8.798
    450.12 780 450.33 32 450.55 88.6 448.26 15 448.45 24.957 448.65 24993.896 448.86 119.63 449.08 -1.4647 449.29 1.5566 449.51 2.0803 449.7 -1.4786 449.91 9.023
    452.65 778 452.86 32 453.07 88.6 450.79 15 451 25.024 451.2 24993.896 451.41 120.19 451.61 -1.5354 451.81 2.0393 452.04 2.2147 452.26 -2.2125 452.44 8.723
    455.21 779 455.42 33 455.62 88.6 453.29 15 453.5 24.86 453.7 24993.896 453.91 119.63 454.13 -1.4969 454.34 2.0916 454.55 2.2081 454.79 -2.0188 455.02 8.798
    457.69 786 457.91 33 458.12 88.6 455.83 15 456.04 25.031 456.25 24993.896 456.45 120.06 456.65 -2.2162 456.86 2.1206 457.07 1.4563 457.28 -1.5643 457.49 8.723
    460.31 784 460.53 33 460.73 88.6 458.33 15 458.55 24.921 458.81 24993.896 459.04 119.84 459.26 -1.966 459.45 1.5376 459.66 1.5105 459.87 -1.9441 460.07 9.659
    462.8 779 463.02 33 463.22 89 460.93 15 461.14 24.994 461.35 24993.896 461.56 119.84 461.77 -1.5548 461.97 1.5028 462.17 2.0466 462.38 -1.5299 462.59 9.172
    465.33 779 465.57 33 465.79 88.6 463.41 15 463.62 25.043 463.83 24993.896 464.06 119.59 464.28 -2.1151 464.48 1.9583 464.68 1.5409 464.89 -1.4874 465.1 9.172
    467.85 784 468.07 33 468.28 88.6 465.99 15 466.2 25 466.4 24993.896 466.61 119.91 466.82 -1.5764 467.03 2.2004 467.23 1.4292 467.43 -1.5584 467.64 9.247
    470.37 780 470.58 33 470.83 89 468.48 15 468.69 25.061 468.91 24993.896 469.13 119.47 469.33 -2.2022 469.54 1.4361 469.73 2.2209 469.94 -2.1385 470.16 8.461
    472.98 777 473.19 33 473.41 88.6 471.04 15 471.24 25.012 471.44 24993.896 471.65 119.47 471.85 -1.4907 472.08 1.528 472.33 2.0561 472.57 -2.0166 472.78 9.172
    475.59 775 475.83 33 476.07 88.6 473.62 15 473.83 25.085 474.07 24993.896 474.3 119.72 474.49 -2.2704 474.7 2.0543 474.91 1.4434 475.13 -1.5405 475.35 8.723
    478.21 778 478.41 33 478.62 88.6 476.29 15 476.49 24.951 476.69 24993.896 476.89 119.81 477.09 -1.9488 477.33 2.0349 477.57 2.2048 477.79 -2.0715 477.99 8.685
    480.74 797 480.96 34 481.18 88.6 478.83 15 479.07 28.143 479.28 28106.689 479.48 135.84 479.69 0.0002 479.9 0.0002 480.1 0.0002 480.32 0.0002 480.54 30.589
    483.33 1798 483.58 34 483.79 88.6 481.39 44 481.59 35.767 481.83 51562.5 482.05 167.78 482.24 0.0002 482.45 0.5297 482.66 0.6249 482.88 -0.9597 483.09 3.998
    485.87 764 486.07 34 486.29 88.6 483.99 15 484.19 55.841 484.4 51153.564 484.61 161.44 484.83 0.0002 485.03 0.3151 485.23 0.8234 485.44 -0.7443 485.65 17.542
    488.46 778 488.68 34 488.88 88.6 486.49 15 486.71 28.29 486.92 27758.789 487.12 118.94 487.35 -1.2834 487.6 0.9113 487.84 2.0675 488.05 -0.978 488.25 8.685
    491.01 779 491.22 34 491.43 88.6 489.09 15 489.3 24.744 489.5 24993.896 489.71 119.66 489.91 -1.8521 490.12 1.0549 490.37 1.8943 490.61 -1.5332 490.81 8.986
    493.52 780 493.74 34 493.95 89 491.65 15 491.85 24.89 492.07 24993.896 492.27 119.31 492.49 -1.5357 492.7 1.7994 492.9 1.5332 493.11 -1.3244 493.32 9.061
    496.07 784 496.27 34 496.49 88.6 494.15 15 494.36 24.994 494.58 24993.896 494.79 119.84 494.99 -1.9561 495.2 1.405 495.41 1.5449 495.63 -2.0667 495.85 8.386
    498.61 780 498.82 34 499.01 88.6 496.7 15 496.9 25.043 497.11 24993.896 497.32 119.59 497.52 -1.5295 497.74 1.4046 497.95 1.5745 498.15 -2.1048 498.37 9.435
    501.11 781 501.32 34 501.52 88.6 499.22 15 499.43 25.085 499.65 24993.896 499.85 119.78 500.07 -1.9686 500.27 1.5339 500.49 1.5332 500.7 -2.2213 500.9 8.499
    503.69 777 503.9 35 504.13 88.6 501.74 15 501.95 24.939 502.15 24993.896 502.38 120.22 502.63 -2.1191 502.87 1.5127 503.08 2.1473 503.27 -1.4427 503.48 9.473
    506.28 778 506.48 35 506.69 88.6 504.37 15 504.59 24.988 504.79 24993.896 504.99 119.94 505.2 -1.5661 505.4 2.2041 505.63 2.1601 505.87 -1.5097 506.09 8.873
    508.8 779 509.02 35 509.23 88.6 506.9 15 507.13 25.024 507.35 24993.896 507.55 119.66 507.75 -2.0162 507.96 1.5471 508.17 2.1568 508.39 -2.1686 508.6 9.81
    511.37 778 511.57 35 511.77 88.6 509.44 15 509.65 25 509.88 24993.896 510.07 119.91 510.28 -1.5555 510.49 1.5621 510.71 2.1411 510.92 -2.1165 511.15 9.023
    513.9 783 514.12 35 514.31 89 511.98 15 512.19 24.872 512.41 24993.896 512.63 119.53 512.82 -1.4094 513.03 1.5295 513.24 2.1122 513.46 -1.9821 513.67 9.473
    516.41 775 516.65 35 516.87 88.6 514.52 15 514.73 24.902 514.93 24993.896 515.15 119.91 515.37 -1.5434 515.57 1.4987 515.77 2.1539 515.98 -1.5284 516.19 8.911
    518.95 1045 519.16 35 519.37 89 517.07 15 517.29 25.031 517.49 24993.896 517.7 119.69 517.9 -1.4262 518.12 1.5742 518.32 2.1107 518.54 -2.0957 518.74 9.435
    521.43 1777 521.65 36 521.87 88.6 519.57 15 519.79 38.824 520 34259.033 520.2 125.22 520.41 -0.8392 520.62 1.0201 520.81 0.8322 521.01 -1.0706 521.22 1.495
    524.12 760 524.32 36 524.53 88.6 522.06 15 522.27 49.902 522.49 43060.303 522.7 144.06 522.92 -0.5382 523.16 0.8527 523.42 0.807 523.66 -1.0362 523.91 15.913
    526.66 782 526.87 36 527.07 88.6 524.73 15 524.94 27.191 525.16 27032.471 525.41 118.94 525.61 -1.4511 525.81 1.3508 526.02 2.0327 526.24 -1.3098 526.45 9.885
    529.17 781 529.41 36 529.62 88.6 527.28 15 527.48 25.073 527.69 24993.896 527.91 120 528.11 -2.036 528.31 1.698 528.52 1.509 528.74 -1.2882 528.96 9.135
    531.82 778 532.04 36 532.25 89 529.81 15 530.02 25.14 530.23 24993.896 530.44 119.41 530.67 -1.5262 530.92 1.4317 531.16 1.9441 531.41 -2.0085 531.62 9.435
    534.37 777 534.56 36 534.77 89 532.45 15 532.67 24.969 532.91 24993.896 533.12 119.69 533.31 -1.9419 533.52 1.4892 533.73 1.5116 533.94 -1.9243 534.15 9.023
    536.87 786 537.06 36 537.27 88.6 534.99 15 535.2 25.012 535.41 24993.896 535.62 119.91 535.82 -1.5203 536.03 2.0935 536.23 1.9027 536.44 -1.5218 536.66 9.323
    539.42 782 539.66 36 539.87 88.6 537.48 15 537.68 25.134 537.91 24993.896 538.12 119.44 538.32 -2.0462 538.53 1.3848 538.74 1.531 538.96 -1.5251 539.18 9.622
    541.95 778 542.16 36 542.38 88.6 540.06 15 540.27 24.969 540.48 24993.896 540.68 119.88 540.91 -1.5046 541.12 2.0169 541.32 1.9463 541.54 -2.0444 541.75 8.836
    544.43 777 544.66 36 544.87 88.6 542.57 15 542.78 25.012 542.98 24993.896 543.19 119.53 543.41 -2.029 543.61 1.4207 543.81 1.5332 544.02 -2.0935 544.23 8.986
    546.97 779 547.17 36 547.4 89 545.06 15 545.27 24.872 545.48 24993.896 545.7 119.59 545.9 -1.472 546.12 2.1583 546.32 2.0514 546.54 -1.94 546.76 9.584
    549.55 779 549.75 37 549.96 88.6 547.63 15 547.84 25.049 548.04 24993.896 548.25 119.69 548.46 -2.1385 548.68 1.4592 548.92 1.5251 549.14 -1.3845 549.34 9.061
    552.07 784 552.28 37 552.48 89 550.17 15 550.39 24.994 550.6 24993.896 550.8 119.75 551.01 -1.8906 551.21 1.4603 551.42 2.021 551.65 -2.122 551.87 9.023
    554.65 782 554.87 37 555.07 88.6 552.69 15 552.91 25.104 553.13 24993.896 553.33 119.44 553.53 -1.5134 553.73 1.4859 553.94 1.9331 554.17 -2.0876 554.41 9.285
    557.17 787 557.42 37 557.66 88.6 555.29 15 555.5 24.896 555.7 24993.896 555.91 120.06 556.12 -2.0909 556.32 2.0759 556.54 1.925 556.76 -1.5277 556.97 9.135
    559.78 786 559.99 37 560.19 88.6 557.87 15 558.07 25.024 558.29 24993.896 558.51 119.44 558.72 -2.1147 558.92 1.4885 559.16 1.8723 559.38 -1.513 559.57 9.473
    562.28 777 562.48 37 562.69 89 560.4 15 560.62 25.085 560.81 24993.896 561.02 119.5 561.23 -2.0799 561.43 1.4607 561.65 2.1169 561.87 -2.0799 562.07 9.097
    564.81 780 565.02 37 565.23 88.6 562.91 15 563.12 24.939 563.31 24993.896 563.51 119.31 563.72 -2.0235 563.92 1.4372 564.17 2.058 564.41 -2.1275 564.62 9.36
    567.32 784 567.53 37 567.74 88.6 565.44 15 565.65 25.085 565.87 24993.896 566.07 120.03 566.29 -1.5291 566.5 1.4577 566.7 1.8803 566.9 -1.5083 567.12 9.21
    569.92 785 570.14 37 570.33 89 567.95 15 568.16 25.092 568.37 24993.896 568.57 119.53 568.78 -2.007 568.98 1.3816 569.19 1.528 569.42 -1.4863 569.68 9.473
    572.42 778 572.67 37 572.89 88.6 570.54 15 570.75 25.14 570.94 24993.896 571.17 119.69 571.39 -1.4731 571.57 2.0184 571.78 1.7859 571.98 -1.5046 572.19 8.948
    575 785 575.2 38 575.44 88.6 573.09 15 573.28 25.018 573.5 24993.896 573.71 119.75 573.92 -1.7577 574.17 2.0396 574.38 1.4035 574.58 -1.5361 574.78 8.723
    577.53 775 577.74 38 577.94 88.6 575.66 15 575.86 24.951 576.06 24993.896 576.28 119.38 576.49 -1.955 576.7 1.8408 576.94 2.0323 577.14 -1.3691 577.32 8.911
    580 779 580.22 38 580.43 88.6 578.15 15 578.34 24.872 578.54 24993.896 578.74 119.81 578.96 -1.4731 579.18 2.1151 579.38 1.4995 579.58 -1.4456 579.78 9.135
    582.5 779 582.72 38 582.95 88.6 580.62 15 580.84 25.073 581.04 24993.896 581.24 119.75 581.46 -1.8503 581.69 1.498 581.88 1.4705 582.08 -1.8437 582.3 9.547
    585.02 777 585.24 38 585.48 88.6 583.14 15 583.34 25 583.54 24993.896 583.76 120.47 583.98 -1.4987 584.2 1.4262 584.4 2.0656 584.62 -2.0462 584.82 8.76
    587.54 776 587.74 38 587.98 88.6 585.69 15 585.88 24.89 586.1 24993.896 586.3 119.59 586.5 -1.4724 586.72 2.1085 586.93 2.1107 587.12 -1.5138 587.32 9.323
    590.08 802 590.28 38 590.49 88.6 588.2 15 588.4 25.024 588.6 24993.896 588.81 119.81 589.02 -2.1349 589.24 4.631 589.45 0.5539 589.66 0.0002 589.86 32.256
    592.61 1528 592.8 38 593.01 89 590.73 15 590.93 37.781 591.14 34283.447 591.34 123.41 591.56 -0.8048 591.76 0.9318 591.98 2.5388 592.19 0.0002 592.4 51.385
    595.14 1573 595.36 38 595.58 88.6 593.24 15 593.45 31.39 593.64 31280.518 593.86 118.97 594.06 -0.9428 594.26 2.6607 594.5 0.0002 594.73 0.0002 594.95 54.561
    597.74 764 597.97 38 598.18 89 595.79 15 595.99 31.329 596.24 31182.861 596.48 118.06 596.71 -1.0018 596.9 0.8974 597.1 1.216 597.31 -0.9721 597.52 12.25
    600.29 776 600.48 38 600.7 89 598.38 15 598.58 25.458 598.79 25085.449 599 119.75 599.25 -1.8899 599.48 1.2618 599.68 1.4929 599.88 -1.4786 600.09 8.836
    602.77 779 603.01 38 603.24 88.6 600.88 15 601.1 25.104 601.32 24993.896 601.53 119.22 601.74 -2.0027 601.95 1.2739 602.16 1.5379 602.36 -1.8349 602.58 8.611
    605.36 777 605.57 38 605.77 88.6 603.48 15 603.69 25.049 603.88 24993.896 604.09 120 604.29 -1.4973 604.5 1.9763 604.74 2.1122 604.95 -2.0199 605.16 9.697
    607.86 778 608.06 39 608.26 88.6 605.99 15 606.21 24.872 606.4 24993.896 606.6 119.22 606.81 -2.0393 607.01 1.4068 607.24 1.4976 607.45 -1.4537 607.65 9.509
    610.45 776 610.66 39 610.86 88.6 608.5 15 608.75 25 608.99 24993.896 609.21 119.41 609.4 -1.4954 609.6 1.4255 609.81 2.0898 610.03 -2.0206 610.24 8.611
    612.99 782 613.21 39 613.4 88.6 611.08 15 611.29 24.908 611.51 24993.896 611.74 119.69 611.97 -1.8924 612.16 1.4489 612.37 1.4544 612.57 -1.7243 612.78 9.921
    615.49 789 615.71 39 615.91 88.6 613.6 15 613.81 24.921 614.02 24993.896 614.23 120 614.45 -2.0799 614.64 2.0147 614.86 1.4061 615.07 -1.5196 615.27 8.798
    618.04 778 618.24 39 618.47 89 616.11 15 616.32 25.012 616.53 24993.896 616.75 119.41 616.99 -1.4237 617.21 2.025 617.4 1.4881 617.61 -1.4431 617.83 9.509
    620.61 776 620.83 39 621.04 89 618.66 15 618.86 25.012 619.07 24993.896 619.27 119.63 619.5 -2.0843 619.75 1.4588 619.99 1.4929 620.21 -1.9902 620.4 8.723
    623.21 777 623.4 39 623.6 88.6 621.25 15 621.49 25.146 621.71 24993.896 621.89 119.81 622.1 -1.8089 622.3 1.4995 622.51 1.9975 622.75 -1.4936 622.99 9.172
    625.76 778 625.99 39 626.21 88.6 623.81 15 624.02 24.951 624.24 24993.896 624.45 119.44 624.65 -2.0243 624.86 1.3032 625.07 1.5123 625.27 -2.0224 625.5 9.509
    628.38 779 628.59 40 628.79 88.6 626.4 15 626.6 25.012 626.81 24993.896 627.01 120.31 627.26 -1.9825 627.5 2.0645 627.74 2.0114 627.96 -1.7492 628.18 9.921
    630.99 780 631.2 40 631.4 88.6 629 15 629.24 25 629.47 24993.896 629.67 119.56 629.89 -1.9466 630.1 1.776 630.31 1.4976 630.51 -1.984 630.75 9.061
    633.51 775 633.73 40 633.94 89 631.61 15 631.83 24.902 632.04 24993.896 632.25 120.31 632.47 -1.468 632.67 1.4358 632.89 2.0499 633.1 -2.0642 633.3 9.247
    636.04 781 636.26 40 636.47 88.6 634.15 15 634.36 24.835 634.58 24993.896 634.8 119.47 635 -1.3504 635.22 1.4973 635.42 2.0642 635.62 -1.3999 635.83 9.061
    638.77 1575 638.99 40 639.19 88.6 636.67 15 636.89 25.049 637.1 24993.896 637.3 119.66 637.53 -1.5028 637.79 1.6932 638.03 2.0979 638.29 -1.5266 638.53 12.61
    641.37 1857 641.57 40 641.78 88.6 639.41 15 639.62 32.886 639.82 32202.148 640.03 119.59 640.28 -1.0003 640.52 3.8865 640.74 0.0002 640.94 0.0002 641.16 49.084
    643.89 2147 644.1 40 644.3 88.6 642 15 642.19 31.427 642.4 31707.764 642.6 118.59 642.81 -0.9677 643.03 0.8234 643.27 1.0882 643.49 -2.0982 643.68 0
    646.38 758 646.59 40 646.8 88.6 644.53 15 644.74 44.647 644.94 41271.973 645.14 134.03 645.33 -0.3096 645.54 0.7575 645.78 0.5495 645.98 -0.7963 646.18 16.875
    648.98 976 649.18 40 649.38 88.6 647.04 15 647.28 27.399 647.48 27014.16 647.68 133.19 647.89 0.0002 648.1 0.0002 648.3 0.0002 648.54 0.0002 648.76 41.306
    651.52 1796 651.72 40 651.94 88.6 649.59 16 649.82 30.872 650.04 33923.34 650.24 154.34 650.45 0.0002 650.65 0.0002 650.86 0.0002 651.08 0.0002 651.3 36.066
    654.1 2096 654.3 40 654.52 88.6 652.16 20 652.37 35.101 652.57 38232.422 652.82 158.63 653.06 0.0002 653.26 0.0002 653.46 0.0002 653.67 0.0002 653.89 27.811
    656.59 2205 656.82 40 657.06 89 654.72 24 654.94 57.086 655.14 57232.666 655.33 145.84 655.56 0.0002 655.77 0.0002 655.97 0.0002 656.18 0.0002 656.38 34.161
    659.19 1995 659.4 41 659.6 88.6 657.27 15 657.46 33.82 657.67 32147.217 657.89 120.72 658.11 -0.8 658.32 0.7982 658.55 1.0963 658.77 -2.5326 658.97 17.775
    661.83 1918 662.07 41 662.28 89 659.83 15 660.08 31.165 660.32 31896.973 660.54 120.56 660.75 -0.6462 660.97 0.7993 661.18 1.1523 661.38 -2.5831 661.59 0
    664.37 1872 664.58 41 664.82 88.6 662.48 15 662.69 31.256 662.91 31921.387 663.12 119.97 663.32 -0.8018 663.54 0.6099 663.75 0.9794 663.96 -1.854 664.17 0.002
    666.93 761 667.14 41 667.35 88.6 665.03 15 665.23 38.782 665.44 35559.082 665.66 124.63 665.87 -0.6509 666.08 0.4576 666.32 0.9904 666.54 -0.6444 666.72 15.388
    669.47 777 669.68 41 669.89 88.6 667.58 15 667.8 26.941 668 26477.051 668.2 119.72 668.41 -1.483 668.61 1.0622 668.86 1.8822 669.07 -0.8612 669.27 9.172
    672.12 779 672.34 41 672.54 89 670.11 15 670.36 24.951 670.61 24993.896 670.85 119.41 671.07 -1.3925 671.27 1.1409 671.48 1.9184 671.68 -1.5405 671.89 9.247
    674.68 788 674.89 42 675.14 89 672.75 15 672.97 25.018 673.19 24993.896 673.4 119.66 673.63 -1.9247 673.85 1.8327 674.05 1.253 674.27 -1.4152 674.48 10.034
    677.25 779 677.46 42 677.66 89 675.36 15 675.55 24.969 675.76 24993.896 675.96 119.28 676.17 -1.8631 676.4 1.9279 676.64 1.3918 676.84 -1.6441 677.04 9.996
    679.85 778 680.04 42 680.25 88.6 677.89 15 678.14 25.104 678.35 24993.896 678.55 119.34 678.76 -1.9118 678.96 1.4046 679.17 1.981 679.4 -1.8935 679.63 9.323
    682.36 778 682.55 42 682.76 88.6 680.44 15 680.65 24.939 680.89 24993.896 681.1 119.56 681.3 -1.6485 681.51 1.4182 681.71 1.9107 681.92 -1.6558 682.14 9.172
    684.86 787 685.05 42 685.26 88.6 682.97 15 683.19 24.89 683.39 24993.896 683.6 120.03 683.79 -2.0111 684 1.932 684.19 1.4339 684.4 -1.9247 684.64 9.846
    687.4 776 687.62 42 687.83 88.6 685.47 15 685.69 25.049 685.9 24993.896 686.11 119.44 686.31 -1.9466 686.51 1.2047 686.72 1.4563 686.94 -1.9129 687.16 10.446
    689.96 778 690.16 42 690.41 88.6 688.04 15 688.24 24.939 688.45 24993.896 688.66 119.44 688.92 -1.8635 689.14 1.2607 689.35 1.4387 689.54 -1.8759 689.75 9.772
    692.66 786 692.91 43 693.15 88.6 690.66 15 690.92 25.031 691.16 24993.896 691.4 119.53 691.62 -1.6145 691.8 1.4314 692.01 1.9027 692.22 -1.5691 692.42 9.772
    695.22 778 695.42 43 695.65 88.6 693.36 15 693.56 24.835 693.77 24993.896 693.97 119.66 694.18 -1.3962 694.39 1.5848 694.59 1.4211 694.8 -1.3772 695.02 10.071
    697.77 784 697.99 43 698.2 88.6 695.87 15 696.05 24.994 696.26 24993.896 696.46 119.44 696.67 -1.2226 696.91 1.8759 697.15 1.5731 697.36 -1.4193 697.56 10.071
    700.41 778 700.66 43 700.89 88.6 698.41 15 698.65 24.902 698.86 24993.896 699.06 119.44 699.27 -1.3482 699.49 1.4185 699.71 1.8371 699.92 -1.5793 700.16 10.258
    702.98 783 703.19 43 703.41 88.6 701.1 15 701.3 25.012 701.52 24993.896 701.73 119.56 701.93 -1.9378 702.15 1.8997 702.37 1.1867 702.57 -1.4013 702.78 9.659
    705.56 780 705.76 43 705.96 89 703.65 15 703.87 24.835 704.06 24993.896 704.27 119.44 704.49 -1.3973 704.7 1.9382 704.91 1.4145 705.15 -1.5778 705.37 10.109
    708.14 776 708.33 43 708.54 88.6 706.17 15 706.42 25.043 706.65 24993.896 706.87 119.34 707.06 -1.3999 707.27 1.3962 707.49 1.4065 707.7 -1.9173 707.92 9.584
    710.67 787 710.89 43 711.1 88.6 708.75 15 708.96 24.921 709.18 24993.896 709.41 119.59 709.63 -1.6427 709.83 1.4017 710.05 1.1827 710.26 -1.4281 710.46 9.659
    713.17 776 713.38 43 713.58 88.6 711.31 15 711.51 25.116 711.72 24993.896 711.92 120.44 712.13 -1.4174 712.32 1.8368 712.53 1.6258 712.73 -1.4526 712.94 9.81
    715.67 778 715.89 43 716.09 88.6 713.78 15 713.99 25.146 714.2 24993.896 714.41 119.53 714.63 -1.8895 714.83 1.1479 715.05 1.3808 715.26 -1.4017 715.46 10.146
    718.17 781 718.38 43 718.58 88.6 716.29 15 716.5 24.957 716.71 24993.896 716.92 119.5 717.13 -1.3991 717.33 1.9675 717.55 1.9184 717.76 -1.2296 717.96 9.659
    720.67 786 720.88 43 721.08 89 718.79 15 718.99 25.079 719.2 24993.896 719.42 119.72 719.64 -1.91 719.84 1.8807 720.04 1.3874 720.25 -1.9382 720.46 10.558
    723.17 776 723.37 43 723.55 89 721.28 15 721.48 24.994 721.68 24993.896 721.91 120.19 722.13 -1.4178 722.33 1.9199 722.54 1.6496 722.75 -1.4068 722.95 10.184
    725.7 778 725.93 43 726.15 88.6 723.76 15 723.96 25.012 724.19 24993.896 724.44 119.56 724.67 -1.2299 724.88 1.8822 725.08 1.8499 725.28 -1.3988 725.49 10.371
    728.28 776 728.48 44 728.69 89 726.35 15 726.55 24.988 726.76 24993.896 726.97 119.66 727.19 -1.4724 727.45 1.1926 727.67 1.3794 727.88 -1.88 728.08 10.333
    730.75 778 730.95 44 731.19 88.6 728.9 15 729.09 24.902 729.3 24993.896 729.52 119.59 729.73 -1.3805 729.94 1.9041 730.15 1.4002 730.34 -1.3827 730.54 10.146
    733.29 788 733.5 44 733.7 89 731.43 15 731.65 24.951 731.84 24993.896 732.05 119.34 732.26 -1.9635 732.47 1.8254 732.69 1.576 732.91 -1.3958 733.09 10.184
    735.91 786 736.1 44 736.31 88.6 733.95 15 734.19 24.927 734.4 24993.896 734.59 119.5 734.8 -1.8551 735.01 1.5174 735.21 1.3955 735.44 -1.1757 735.68 10.596
    738.44 777 738.68 44 738.9 88.6 736.52 15 736.74 24.963 736.96 24993.896 737.17 120.19 737.39 -1.3841 737.6 1.2208 737.81 1.4273 738.01 -1.9111 738.22 10.222
    740.97 2120 741.19 44 741.45 89 739.1 21 739.32 25.818 739.52 26104.736 739.73 136.25 739.93 0.0002 740.15 0.0002 740.35 0.0002 740.56 -1.6573 740.76 18.802
    743.54 760 743.75 44 743.96 88.6 741.66 15 741.86 34.735 742.07 32281.494 742.29 120 742.5 -0.6597 742.7 0.8172 742.92 0.8802 743.13 -0.9989 743.34 16.621
    746.07 776 746.28 44 746.48 88.6 744.19 15 744.41 26.752 744.61 26184.082 744.82 119.91 745.02 -1.4127 745.23 1.2783 745.45 1.8177 745.67 -1.019 745.87 10.446
    748.66 787 748.86 44 749.07 88.6 746.71 15 746.96 25.012 747.2 24993.896 747.41 119.56 747.61 -1.8485 747.81 1.2526 748.02 1.3805 748.24 -1.2981 748.45 9.622
    751.19 777 751.41 44 751.61 88.6 749.28 15 749.48 25.012 749.7 24993.896 749.92 119.47 750.12 -1.394 750.32 1.4112 750.53 1.9151 750.74 -1.8573 750.96 9.547
    753.77 776 753.99 44 754.2 88.6 751.82 15 752.02 24.805 752.23 24993.896 752.46 119.75 752.71 -1.4204 752.95 1.1065 753.16 1.9085 753.36 -1.8968 753.56 10.408
    756.29 778 756.5 44 756.71 88.6 754.41 15 754.61 24.86 754.82 24993.896 755.02 119.59 755.23 -1.8573 755.45 1.8961 755.67 1.3775 755.88 -1.2226 756.09 9.697
    758.92 779 759.13 44 759.34 88.6 756.96 15 757.21 25.012 757.44 24993.896 757.65 119.59 757.84 -1.8397 758.05 1.5185 758.27 1.3742 758.48 -1.3739 758.7 9.735
    761.47 776 761.69 44 761.88 88.6 759.55 15 759.77 25.012 759.98 24993.896 760.22 120.13 760.43 -1.4207 760.63 1.3823 760.84 1.9312 761.04 -1.4328 761.25 9.959
    763.99 778 764.23 44 764.44 88.6 762.09 15 762.3 24.969 762.52 24993.896 762.73 119.69 762.96 -1.2589 763.17 1.8694 763.37 1.7793 763.58 -1.1475 763.78 10.184
    766.56 778 766.76 44 766.99 88.6 764.64 15 764.85 24.963 765.07 24993.896 765.27 120 765.49 -1.4332 765.73 1.2622 765.95 1.4526 766.14 -1.8166 766.35 9.921
    769.13 790 769.34 45 769.54 88.6 767.23 15 767.45 25.031 767.63 24993.896 767.84 119.44 768.05 -1.5709 768.26 1.4336 768.5 1.2065 768.71 -1.9148 768.91 10.408
    771.67 780 771.88 45 772.1 88.6 769.75 15 769.97 25.165 770.18 24993.896 770.38 119.44 770.6 -1.9052 770.82 1.5449 771.02 1.4211 771.26 -1.3416 771.48 10.446
    774.28 779 774.52 45 774.76 88.6 772.31 15 772.51 25.031 772.73 24993.896 772.93 119.44 773.15 -1.8287 773.35 1.3504 773.56 1.3475 773.77 -1.8027 774.02 10.596
    776.9 778 777.1 45 777.31 88.6 774.98 15 775.17 24.908 775.37 24993.896 775.58 120.03 775.79 -1.4105 776.02 1.3823 776.26 1.3856 776.48 -1.7965 776.68 10.596
    779.42 787 779.62 45 779.83 89 777.51 15 777.73 24.805 777.93 24993.896 778.13 119.44 778.34 -1.1358 778.55 1.8723 778.77 1.825 779.01 -1.8426 779.22 9.885
    781.93 778 782.13 45 782.34 89 780.04 15 780.26 24.969 780.48 24993.896 780.67 120.19 780.88 -1.335 781.1 1.3566 781.31 1.8492 781.52 -1.8617 781.73 10.67
    784.52 786 784.73 45 784.92 88.6 782.55 15 782.77 24.933 782.99 24993.896 783.18 119.47 783.39 -1.7818 783.6 1.5299 783.82 1.3167 784.04 -1.1772 784.27 10.745
    787.01 776 787.23 45 787.42 88.6 785.12 15 785.33 25.031 785.54 24993.896 785.75 120.19 785.95 -1.342 786.16 1.8338 786.36 1.0739 786.56 -1.3947 786.77 10.709
    789.54 778 789.79 45 790.03 88.6 787.62 15 787.83 25.061 788.04 24993.896 788.26 119.38 788.48 -1.7346 788.68 1.5123 788.9 1.3859 789.1 -1.3098 789.31 10.97
    792.14 778 792.34 45 792.55 88.6 790.24 15 790.44 25.116 790.65 24993.896 790.85 119.53 791.06 -1.8569 791.27 1.0596 791.5 1.3742 791.71 -1.3387 791.93 10.596
    794.74 775 794.94 45 795.14 88.6 792.79 15 793.03 24.957 793.24 24993.896 793.44 120.13 793.65 -1.4061 793.86 1.8177 794.06 1.4753 794.29 -1.7818 794.53 10.371
    797.29 789 797.52 45 797.72 88.6 795.35 15 795.56 24.878 795.79 24993.896 796.03 119.53 796.25 -1.8518 796.45 1.8049 796.65 1.3215 796.86 -1.8368 797.07 10.783
    799.83 777 800.04 45 800.27 89 797.92 15 798.13 25.079 798.35 24993.896 798.56 119.38 798.78 -1.7203 799 1.5713 799.21 1.3885 799.42 -1.401 799.62 10.634
    802.39 777 802.59 45 802.8 88.6 800.47 15 800.67 25.049 800.88 24993.896 801.1 119.59 801.31 -1.8855 801.54 1.7855 801.76 1.1501 801.96 -1.3834 802.18 10.858
    804.93 781 805.14 45 805.34 89 803.02 15 803.24 25.14 803.43 24993.896 803.64 119.47 803.85 -1.8412 804.07 1.4943 804.3 1.7873 804.51 -1.3999 804.71 10.371
    807.5 778 807.71 45 807.92 88.6 805.58 15 805.79 24.982 805.99 24993.896 806.21 120.25 806.42 -1.3951 806.63 1.7793 806.85 1.8576 807.09 -1.8056 807.31 10.371
    810.09 778 810.31 45 810.5 89 808.12 15 808.35 25.043 808.59 24993.896 808.81 119.41 809 -1.4863 809.2 1.3541 809.41 1.3918 809.61 -1.5229 809.85 11.157
    812.6 776 812.82 45 813.02 88.6 810.71 15 810.92 25.153 811.12 24993.896 811.34 119.44 811.56 -1.8364 811.75 1.0446 811.95 1.3874 812.16 -1.7562 812.37 10.446
    815.11 778 815.33 45 815.53 88.6 813.22 15 813.43 24.982 813.65 24993.896 813.86 119.38 814.07 -1.1951 814.27 1.3739 814.49 1.3885 814.7 -1.8082 814.9 10.709
    817.64 777 817.88 45 818.1 88.6 815.73 15 815.94 25.043 816.14 24993.896 816.37 120.28 816.61 -1.7917 816.82 1.368 817.02 1.8401 817.23 -1.7276 817.43 10.371
    820.2 787 820.41 46 820.62 88.6 818.29 15 818.5 24.847 818.7 24993.896 818.91 119.41 819.14 -1.4874 819.37 1.3079 819.59 1.3281 819.79 -1.8141 820 10.558
    822.7 776 822.9 46 823.11 89 820.84 15 821.04 25.043 821.25 24993.896 821.45 120.22 821.66 -1.3134 821.88 1.3603 822.09 1.4255 822.28 -1.3325 822.49 10.408
    825.21 778 825.41 46 825.63 88.6 823.32 15 823.53 25.165 823.73 24993.896 823.93 119.47 824.15 -1.8122 824.37 1.0783 824.59 1.3614 824.77 -1.7884 824.99 10.297
    827.78 778 827.97 46 828.19 88.6 825.88 15 826.08 24.939 826.27 24993.896 826.49 119.53 826.71 -1.7613 826.93 1.7844 827.13 1.1311 827.38 -1.8203 827.59 10.483
    830.38 788 830.58 46 830.78 88.6 828.4 15 828.63 24.933 828.88 24993.896 829.09 119.59 829.29 -1.0618 829.49 1.3808 829.69 1.7617 829.91 -1.0549 830.14 10.333
    832.89 777 833.1 46 833.29 89 830.99 15 831.21 25.079 831.41 24993.896 831.63 119.38 831.84 -1.3149 832.03 1.3153 832.25 1.7265 832.46 -1.732 832.68 10.634
    835.43 777 835.63 46 835.84 88.6 833.51 15 833.71 24.902 833.92 24993.896 834.13 119.59 834.36 -1.3325 834.57 1.3742 834.78 1.7789 834.99 -1.4233 835.21 10.67
    837.93 775 838.15 46 838.38 88.6 836.05 15 836.25 24.969 836.47 24993.896 836.67 120.06 836.89 -1.316 837.12 1.294 837.32 1.8657 837.53 -1.3526 837.73 10.558
    840.46 1016 840.67 46 840.91 88.6 838.57 15 838.77 25.049 838.99 24993.896 839.2 119.53 839.4 -1.7771 839.62 1.4929 839.81 1.4046 840.04 -0.637 840.25 39.638
    843.07 752 843.29 46 843.49 88.6 841.15 18 841.37 25.604 841.57 36303.711 841.79 165.13 841.99 0.0002 842.19 0.0002 842.41 0.7301 842.66 -1.0399 842.87 30.589
    845.66 1772 845.87 46 846.07 88.6 843.69 15 843.91 40.137 844.16 42279.053 844.38 136.88 844.6 0.0002 844.79 0.7696 844.99 0.9725 845.2 -0.7586 845.41 0.995
    848.2 1944 848.41 46 848.62 88.6 846.29 15 846.49 32.343 846.71 32037.354 846.93 120.94 847.15 -0.6601 847.36 0.811 847.57 2.5447 847.79 0.0002 847.99 50.83
    850.67 771 850.91 46 851.12 88.6 848.81 15 849.03 31.085 849.23 31964.111 849.43 119.28 849.65 -0.8165 849.86 0.637 850.06 1.1398 850.27 -0.6865 850.47 14.83
    853.19 783 853.43 46 853.64 88.6 851.31 15 851.53 26.489 851.75 25958.252 851.95 119.38 852.17 -1.7463 852.38 0.9472 852.59 1.3153 852.79 -1.2937 852.99 10.596
    855.71 776 855.93 46 856.15 88.6 853.84 15 854.04 25.049 854.25 24993.896 854.45 119.5 854.68 -1.4749 854.9 1.1534 855.09 1.3823 855.29 -1.3138 855.51 10.371
    858.23 777 858.44 46 858.69 88.6 856.35 15 856.56 25.061 856.77 24993.896 856.97 120.16 857.19 -1.3775 857.4 1.8177 857.61 1.8415 857.83 -1.836 858.03 10.184
    860.77 777 860.96 46 861.19 88.6 858.89 15 859.09 24.896 859.29 24993.896 859.51 119.63 859.71 -1.3599 859.93 1.7983 860.16 1.7826 860.35 -1.1051 860.55 10.071
    863.25 778 863.47 47 863.67 89 861.4 15 861.61 24.988 861.8 24993.896 862.01 119.47 862.23 -1.4607 862.43 1.3999 862.64 1.3523 862.84 -1.4859 863.04 10.745
    865.79 776 865.99 47 866.2 88.6 863.89 15 864.09 25.018 864.29 24993.896 864.49 119.47 864.69 -1.7774 864.95 1.368 865.19 1.3936 865.4 -1.7478 865.59 10.67
    868.36 774 868.58 47 868.79 88.6 866.44 15 866.68 27.38 866.9 42858.887 867.09 162 867.29 0.0002 867.51 0.0002 867.71 0.0002 867.95 -0.603 868.16 18.874
    870.92 871 871.11 47 871.31 88.6 868.99 15 869.2 29.12 869.42 29339.6 869.61 139.31 869.81 0.0002 870.03 0.0002 870.23 0.0002 870.45 0.0002 870.69 37.256
    873.44 776 873.66 47 873.87 88.6 871.5 15 871.71 30.511 871.95 29962.158 872.18 118.28 872.36 -1.3475 872.58 0.8308 872.78 1.6921 873.01 -1.2845 873.21 12.711
    875.95 778 876.17 47 876.36 88.6 874.07 15 874.28 25.031 874.48 24993.896 874.7 119.66 874.91 -1.2025 875.11 1.0589 875.31 1.7631 875.51 -0.9641 875.71 10.333
    878.5 776 878.71 47 878.95 89 876.57 44 876.77 39.862 876.98 47839.355 877.21 161.94 877.45 0.0002 877.67 0.0002 877.85 0.2239 878.07 0.0002 878.28 29.558
    881.04 789 881.25 47 881.46 88.6 879.16 15 879.36 28.9 879.59 28344.727 879.79 118.91 879.99 -1.6987 880.2 1.1164 880.42 1.3504 880.64 -0.9069 880.84 11.195
    883.56 780 883.79 47 883.99 88.6 881.7 15 881.92 25.061 882.11 24993.896 882.31 119.44 882.51 -1.6646 882.71 1.0791 882.94 1.3281 883.16 -1.4962 883.35 10.071
    886.16 776 886.35 47 886.56 89 884.2 15 884.41 24.939 884.61 24993.896 884.83 119.41 885.04 -1.4277 885.25 1.2655 885.46 1.3072 885.71 -1.3731 885.94 10.709
    888.69 779 888.91 47 889.11 88.6 886.77 15 886.97 25.049 887.2 24993.896 887.41 119.47 887.61 -1.6731 887.81 1.4863 888.01 1.2515 888.21 -1.6679 888.46 10.82
    891.21 783 891.46 47 891.7 88.6 889.33 15 889.54 25 889.74 24993.896 889.95 120.22 890.16 -1.8012 890.36 1.7203 890.57 1.0622 890.77 -1.2732 890.98 10.596
    893.79 789 894 48 894.22 88.6 891.91 15 892.11 24.872 892.33 24993.896 892.53 119.41 892.74 -1.4185 892.95 1.2735 893.16 1.7957 893.36 -1.3724 893.59 10.483
    896.32 778 896.52 48 896.73 88.6 894.44 15 894.66 25.055 894.85 24993.896 895.07 119.41 895.27 -1.7133 895.47 1.3153 895.7 1.3343 895.91 -1.6954 896.11 10.67
    898.86 779 899.07 48 899.28 88.6 896.96 15 897.19 24.963 897.41 24993.896 897.61 119.69 897.83 -1.7371 898.03 1.2929 898.24 1.2926 898.45 -1.7357 898.68 10.895
    901.46 778 901.69 48 901.91 88.6 899.5 15 899.71 24.939 899.95 24993.896 900.16 119.41 900.36 -1.6826 900.58 1.3995 900.8 1.2973 901.01 -1.3252 901.21 10.67
    903.99 777 904.2 48 904.42 89 902.1 15 902.31 25.183 902.52 24993.896 902.72 120.38 902.95 -1.3387 903.16 1.7536 903.36 1.3328 903.58 -1.6877 903.79 10.895
    906.47 777 906.69 48 906.91 88.6 904.61 15 904.82 25.085 905.03 24993.896 905.23 119.31 905.44 -1.7203 905.66 1.1149 905.85 1.3427 906.06 -1.7767 906.27 11.121
    908.98 778 909.2 48 909.4 88.6 907.11 15 907.33 24.933 907.54 24993.896 907.74 119.53 907.95 -1.0142 908.16 1.7379 908.36 1.6899 908.57 -1.0538 908.77 10.297
    911.49 788 911.71 48 911.92 88.6 909.6 15 909.81 25.031 910.02 24993.896 910.24 119.31 910.44 -1.3709 910.66 1.3698 910.85 1.7657 911.06 -1.3515 911.28 11.044
    914 777 914.22 48 914.47 88.6 912.12 15 912.33 25.079 912.55 24993.896 912.76 119.56 912.96 -1.2589 913.18 1.2801 913.36 1.4544 913.57 -1.2446 913.78 10.67
    916.62 776 916.83 48 917.05 88.6 914.71 15 914.92 25.031 915.13 24993.896 915.33 119.47 915.54 -1.7415 915.74 1.7122 915.97 1.2435 916.21 -1.7961 916.42 10.558
    919.21 788 919.42 48 919.62 88.6 917.25 15 917.46 25.201 917.68 24993.896 917.88 119.41 918.1 -1.2812 918.3 1.6895 918.51 1.7968 918.72 -1.1497 918.97 10.634
    921.77 1277 921.97 48 922.21 88.6 919.83 15 920.05 40.436 920.26 42626.953 920.47 138.38 920.71 0.0002 920.95 0.0002 921.16 0.0002 921.35 0.0002 921.56 45.433
    924.33 2039 924.55 48 924.75 88.6 922.43 43 922.64 46.667 922.86 48303.223 923.07 159.19 923.28 0.0002 923.5 0.0002 923.71 0.0002 923.92 0.0002 924.12 43.289
    926.93 2050 927.13 48 927.34 88.6 924.96 27 925.18 61.182 925.38 58477.783 925.58 154 925.79 0.0002 926 0.0002 926.22 0.0002 926.47 0.0002 926.71 33.923
    929.44 756 929.64 48 929.86 88.6 927.54 17 927.75 59.137 927.98 54223.633 928.19 166.44 928.39 0.0002 928.59 0.0002 928.8 0.7579 929.01 0.0002 929.23 29.955
    931.98 783 932.19 48 932.39 89 930.07 15 930.27 28.809 930.48 28240.967 930.7 118.47 930.89 -1.4991 931.09 0.8623 931.29 1.8737 931.5 -1.0161 931.74 11.751
    934.48 776 934.69 48 934.89 88.6 932.59 15 932.79 25.122 933 24993.896 933.23 119.47 933.44 -1.6163 933.63 0.9132 933.84 1.3142 934.05 -1.5533 934.27 10.521
    936.99 776 937.22 49 937.44 88.6 935.09 15 935.3 24.927 935.51 24993.896 935.73 119.59 935.95 -1.0622 936.15 1.2263 936.35 1.6734 936.56 -1.0684 936.77 10.297
    939.5 782 939.74 49 939.98 88.6 937.64 15 937.86 25.049 938.07 24993.896 938.27 120.13 938.48 -1.2541 938.69 1.739 938.89 1.3566 939.08 -1.3145 939.29 9.996
    942.05 778 942.26 49 942.49 89 940.19 15 940.38 24.939 940.59 24993.896 940.8 119.59 941.02 -1.075 941.23 1.2735 941.44 1.6687 941.64 -1.0395 941.85 10.184
    944.63 777 944.84 49 945.05 88.6 942.73 15 942.94 24.969 943.13 24993.896 943.34 120.16 943.55 -1.294 943.76 1.7053 943.99 1.7968 944.23 -1.3164 944.44 10.558
    947.15 778 947.35 49 947.56 88.6 945.27 15 945.48 24.963 945.69 24993.896 945.89 119.5 946.09 -1.3101 946.3 1.765 946.51 1.6734 946.73 -1.3211 946.95 10.558
    949.73 781 949.95 49 950.15 89 947.76 15 947.99 25 948.24 24993.896 948.48 119.53 948.69 -1.6958 948.89 1.4511 949.1 1.3134 949.3 -1.7881 949.51 10.483
    952.2 777 952.4 49 952.61 88.6 950.35 15 950.56 25.049 950.76 24993.896 950.98 119.34 951.18 -1.0205 951.37 1.7152 951.57 1.2801 951.78 -1.2508 952 10.82
    954.75 779 954.95 49 955.15 88.6 952.82 15 953.02 25.012 953.24 24993.896 953.46 119.41 953.66 -1.42 953.88 1.3101 954.09 1.3134 954.29 -1.6972 954.5 11.121
    957.3 777 957.51 50 957.72 88.6 955.36 15 955.58 25 955.79 24993.896 956.01 119.53 956.23 -1.6632 956.45 1.4094 956.65 1.2735 956.86 -1.2764 957.08 10.521
    959.94 779 960.15 50 960.35 88.6 957.92 15 958.13 25.055 958.35 24993.896 958.56 120.03 958.77 -1.3387 959.02 0.9772 959.27 1.7148 959.51 -1.361 959.73 10.67
    962.51 777 962.75 50 962.95 88.6 960.56 15 960.77 24.969 961.01 24993.896 961.22 120.03 961.42 -1.2797 961.63 1.2537 961.85 1.3134 962.06 -1.6654 962.27 10.67
    965.03 785 965.26 50 965.48 88.6 963.15 15 963.36 25.018 963.58 24993.896 963.79 120.03 964 -1.7917 964.21 1.6097 964.41 0.9919 964.62 -1.2863 964.82 10.596
    967.55 776 967.77 50 967.99 88.6 965.7 15 965.9 25.085 966.11 24993.896 966.31 119.53 966.51 -1.6573 966.72 1.2673 966.92 1.7009 967.13 -1.6493 967.35 11.121
    970.06 778 970.28 50 970.49 89 968.19 15 968.41 24.994 968.62 24993.896 968.82 119.44 969.03 -0.9963 969.24 1.7522 969.44 1.6302 969.65 -1.0333 969.85 11.121
    972.55 777 972.78 50 972.99 88.6 970.68 15 970.89 24.988 971.1 24993.896 971.32 119.53 971.52 -1.3486 971.74 1.2017 971.93 1.245 972.14 -1.7071 972.35 11.494
    975.08 777 975.3 50 975.52 88.6 973.19 15 973.4 24.988 973.6 24993.896 973.81 120.25 974.02 -1.3087 974.25 1.2417 974.44 1.3233 974.65 -1.2332 974.86 11.157
    977.61 776 977.81 50 978.04 88.6 975.74 15 975.94 24.908 976.16 24993.896 976.37 119.41 976.57 -1.0142 976.78 1.2882 976.99 1.6401 977.19 -1.0446 977.4 10.634
    980.15 776 980.36 50 980.56 89 978.27 15 978.49 24.963 978.68 24993.896 978.89 120.19 979.09 -1.2732 979.29 1.6738 979.52 1.3519 979.75 -1.6416 979.94 10.745
    982.69 776 982.9 50 983.11 88.6 980.78 15 981 24.89 981.19 24993.896 981.4 119.34 981.61 -1.6892 981.82 1.3043 982.04 1.2464 982.28 -1.3123 982.49 10.783
    985.25 776 985.45 50 985.65 88.6 983.31 15 983.54 25 983.78 24993.896 983.99 120.19 984.19 -1.249 984.39 1.5932 984.59 1.3728 984.79 -1.2365 985.03 10.97
    987.75 773 987.96 50 988.17 88.6 985.86 15 986.07 24.835 986.28 24993.896 986.49 119.41 986.69 -1.6936 986.91 1.275 987.11 1.245 987.31 -1.6906 987.53 11.008
    990.28 787 990.49 50 990.69 88.6 988.37 15 988.58 25.018 988.8 24993.896 989.03 120.19 989.23 -1.7144 989.43 1.2237 989.64 1.2417 989.85 -1.6683 990.07 11.195
    992.79 776 993.04 50 993.29 88.6 990.89 15 991.1 25.024 991.31 24993.896 991.52 120 991.75 -1.6892 991.96 0.9553 992.18 1.2995 992.38 -1.7152 992.59 10.933
    995.44 778 995.66 50 995.88 88.6 993.53 15 993.74 25.061 993.93 24993.896 994.14 120.03 994.34 -1.1867 994.55 1.2589 994.79 1.2753 995.03 -0.9758 995.24 10.895
    998.03 778 998.24 50 998.44 88.6 996.09 15 996.29 24.988 996.53 24993.896 996.75 120.09 996.96 -1.2153 997.16 1.7137 997.37 1.4303 997.57 -1.227 997.79 10.82
    1000.54 776 1000.79 50 1001.03 89 998.66 15 998.87 24.908 999.07 24993.896 999.28 119.5 999.49 -1.2413 999.69 1.7331 999.91 1.6496 1000.13 -1.2629 1000.34 10.783
    1003.16 779 1003.37 50 1003.58 88.6 1001.24 15 1001.44 24.969 1001.66 24993.896 1001.88 119.41 1002.1 -1.2922 1002.32 1.7437 1002.53 1.68 1002.75 -1.0267 1002.96 10.858
    1005.74 776 1005.93 50 1006.14 88.6 1003.79 15 1004.03 24.933 1004.25 24993.896 1004.45 120.25 1004.65 -1.1886 1004.86 1.2065 1005.06 1.3457 1005.29 -1.6046 1005.53 11.232
    1008.29 787 1008.52 50 1008.74 88.6 1006.34 15 1006.55 24.921 1006.79 24993.896 1007.03 119.28 1007.25 -1.646 1007.45 1.635 1007.65 0.9633 1007.86 -1.7038 1008.07 11.494
    1010.81 778 1011.04 50 1011.27 89 1008.94 15 1009.16 24.841 1009.37 24993.896 1009.58 119.41 1009.78 -1.6683 1010 1.3248 1010.19 1.2113 1010.4 -1.2541 1010.61 10.82
    1013.43 779 1013.64 50 1013.85 88.6 1011.49 15 1011.69 25.012 1011.91 24993.896 1012.13 120.03 1012.34 -1.3017 1012.55 1.6496 1012.79 1.2797 1013.03 -1.2332 1013.24 10.858
    1015.94 778 1016.16 50 1016.37 88.6 1014.07 15 1014.27 25.018 1014.49 24993.896 1014.69 119.44 1014.91 -1.3277 1015.12 1.2413 1015.32 1.6467 1015.53 -1.2973 1015.74 11.121
    1018.49 777 1018.69 50 1018.89 88.6 1016.58 15 1016.78 24.927 1017 24993.896 1017.2 120.19 1017.4 -1.7152 1017.61 1.6211 1017.81 0.9762 1018.04 -1.2332 1018.28 10.558
    1021.06 788 1021.29 50 1021.53 88.6 1019.1 15 1019.31 24.957 1019.54 24993.896 1019.78 119.44 1020 -1.2973 1020.2 1.2354 1020.41 1.2351 1020.63 -1.6635 1020.85 10.67
    1023.69 788 1023.89 50 1024.1 88.6 1021.75 15 1021.95 24.908 1022.15 24993.896 1022.36 119.53 1022.56 -1.2446 1022.79 1.2592 1023.04 0.9791 1023.28 -1.2413 1023.49 10.933
    1026.26 776 1026.45 50 1026.65 88.6 1024.31 15 1024.54 24.994 1024.76 24993.896 1024.95 119.44 1025.16 -1.6687 1025.37 1.3171 1025.58 1.2113 1025.8 -1.2252 1026.04 10.82
    1028.81 777 1029.05 50 1029.26 88.6 1026.86 15 1027.06 25.049 1027.3 24993.896 1027.55 119.44 1027.76 -1.2585 1027.95 1.2384 1028.16 1.6654 1028.38 -1.5727 1028.6 11.044
    1031.36 788 1031.57 51 1031.8 88.6 1029.46 15 1029.67 24.994 1029.87 24993.896 1030.08 119.53 1030.31 -1.3134 1030.55 1.6657 1030.75 0.989 1030.95 -1.3101 1031.15 10.895
    1033.85 787 1034.06 51 1034.29 88.6 1032.01 15 1032.2 24.994 1032.41 24993.896 1032.61 120.03 1032.82 -1.238 1033.03 1.2065 1033.23 1.3215 1033.44 -1.2318 1033.65 11.232
    1036.43 786 1036.65 51 1036.85 88.6 1034.52 15 1034.73 24.805 1034.93 24993.896 1035.14 119.31 1035.35 -1.2618 1035.57 1.2801 1035.81 1.2413 1036.02 -1.739 1036.22 11.008
    1038.99 1618 1039.21 51 1039.42 88.6 1037.07 15 1037.29 25.031 1037.49 24993.896 1037.71 119.44 1037.92 -2.1572 1038.13 1.2336 1038.35 3.2137 1038.57 0.0002 1038.79 53.529
    1041.54 1805 1041.73 51 1041.94 88.6 1039.62 15 1039.83 30.701 1040.04 31420.898 1040.24 118.69 1040.45 -1.1875 1040.65 1.5079 1040.86 0.0002 1041.09 0.0002 1041.33 44.241
    1044.09 2457 1044.33 51 1044.54 89 1042.13 15 1042.34 43.658 1042.58 44073.486 1042.8 141.13 1043.01 0.0002 1043.21 0.0002 1043.42 0.0002 1043.63 0.0002 1043.85 40.749
    1046.61 760 1046.83 51 1047.04 89 1044.74 15 1044.96 54.742 1045.17 47674.561 1045.37 161.66 1045.58 0.0002 1045.8 0.4089 1045.99 1.2219 1046.2 -0.3591 1046.41 18.802
    1049.19 782 1049.4 51 1049.6 88.6 1047.24 15 1047.46 28.369 1047.67 27630.615 1047.87 118.69 1048.1 -1.6108 1048.36 0.6088 1048.58 1.2948 1048.78 -0.9571 1048.98 11.345
    1051.8 778 1052 51 1052.21 89 1049.85 15 1050.09 25.012 1050.31 24993.896 1050.52 120.03 1050.74 -1.1523 1050.95 1.012 1051.16 1.5398 1051.37 -1.3325 1051.59 11.157
    1054.35 786 1054.6 51 1054.84 88.6 1052.41 15 1052.61 24.969 1052.85 24993.896 1053.09 119.38 1053.31 -1.2428 1053.51 1.1713 1053.71 1.1889 1053.92 -1.3614 1054.13 11.42
    1056.96 779 1057.17 51 1057.38 88.6 1055.05 15 1055.25 24.878 1055.45 24993.896 1055.66 119.38 1055.88 -1.1644 1056.1 1.2464 1056.34 1.1809 1056.56 -1.5822 1056.76 11.382
    1059.59 787 1059.83 51 1060.04 89 1057.6 15 1057.86 24.982 1058.09 24993.896 1058.31 119.41 1058.51 -0.9501 1058.71 1.6643 1058.92 1.5167 1059.13 -0.9725 1059.35 11.382
    1062.17 776 1062.38 51 1062.59 88.6 1060.24 15 1060.46 25.024 1060.67 24993.896 1060.88 119.38 1061.1 -1.1886 1061.33 1.2017 1061.53 1.5518 1061.74 -0.9549 1061.96 11.345
    1064.75 777 1064.96 51 1065.18 88.6 1062.81 15 1063.01 25 1063.21 24993.896 1063.42 119.38 1063.63 -1.5852 1063.85 1.5665 1064.11 1.2208 1064.34 -1.1582 1064.55 11.644
    1067.34 776 1067.56 51 1067.76 88.6 1065.39 15 1065.6 25.079 1065.84 24993.896 1066.05 119.38 1066.25 -1.5965 1066.46 1.5456 1066.68 1.1889 1066.9 -1.2094 1067.11 11.082
    1069.84 776 1070.05 51 1070.25 89 1067.96 15 1068.17 24.902 1068.37 24993.896 1068.59 119.38 1068.81 -1.1886 1069.01 1.6353 1069.21 1.1695 1069.42 -1.2413 1069.63 11.195
    1072.35 777 1072.6 51 1072.86 88.6 1070.46 15 1070.68 25.073 1070.89 24993.896 1071.09 119.38 1071.31 -1.2285 1071.51 1.1889 1071.73 1.1871 1071.93 -1.5661 1072.14 11.771
    1075.09 778 1075.31 51 1075.5 88.6 1073.1 15 1073.35 25.085 1073.59 24993.896 1073.83 119.38 1074.04 -1.1644 1074.23 1.2592 1074.44 1.1904 1074.65 -1.2446 1074.85 11.494
    1077.63 778 1077.85 51 1078.09 88.6 1075.71 15 1075.91 24.994 1076.11 24993.896 1076.35 119.44 1076.59 -1.1516 1076.81 1.1728 1077.01 1.6174 1077.21 -1.1245 1077.42 11.42
    1080.22 788 1080.42 51 1080.63 88.6 1078.31 15 1078.5 24.908 1078.71 24993.896 1078.93 119.38 1079.14 -0.9611 1079.35 1.2625 1079.59 0.9458 1079.81 -1.2493 1080.01 10.933
    1082.85 1638 1083.1 51 1083.35 88.6 1080.85 15 1081.09 42.047 1081.31 40466.309 1081.5 141.56 1081.71 -0.7546 1081.92 0.659 1082.13 0.9183 1082.35 -0.6737 1082.6 6
    1085.47 1996 1085.67 51 1085.88 89 1083.58 15 1083.79 45.386 1083.99 44097.9 1084.19 153.5 1084.4 0.0002 1084.6 0.6612 1084.84 1.0732 1085.06 -2.8332 1085.26 0
    1088.19 762 1088.39 52 1088.59 88.6 1086.1 15 1086.36 44.885 1086.6 40411.377 1086.85 134.88 1087.1 -0.7352 1087.34 0.6121 1087.56 0.8458 1087.76 -0.5733 1087.98 17.542
    1090.71 780 1090.92 52 1091.14 88.6 1088.81 15 1089 27.362 1089.22 26916.504 1089.42 119.16 1089.62 -1.323 1089.85 0.937 1090.08 1.0875 1090.3 -0.7249 1090.5 11.911
    1093.31 787 1093.5 52 1093.71 88.6 1091.34 15 1091.56 24.994 1091.76 24993.896 1091.96 119.59 1092.17 -1.5116 1092.38 0.9989 1092.61 1.1424 1092.86 -1.0175 1093.08 11.082
    1095.85 779 1096.07 52 1096.26 88.6 1093.92 15 1094.14 25.208 1094.35 24993.896 1094.58 119.28 1094.81 -1.5079 1095 1.2431 1095.22 1.1519 1095.42 -1.1933 1095.65 11.569
    1098.38 785 1098.6 52 1098.79 88.6 1096.47 15 1096.68 25 1096.9 24993.896 1097.11 119.31 1097.32 -1.1468 1097.51 1.1871 1097.72 1.1871 1097.92 -1.1563 1098.14 11.494
    1100.92 779 1101.12 52 1101.35 88.6 1099 15 1099.21 25.134 1099.42 24993.896 1099.64 119.38 1099.87 -1.5888 1100.09 1.1311 1100.28 1.1406 1100.5 -1.1593 1100.71 11.682
    1103.46 785 1103.67 52 1103.89 88.6 1101.56 15 1101.76 24.988 1101.96 24993.896 1102.18 119.31 1102.39 -1.1534 1102.62 1.6097 1102.83 0.8992 1103.04 -1.1706 1103.26 11.85
    1106 779 1106.22 52 1106.42 88.6 1104.12 15 1104.33 24.908 1104.52 24993.896 1104.74 119.28 1104.94 -1.5321 1105.14 0.9121 1105.36 1.1073 1105.59 -1.1772 1105.79 12.091
    1108.5 775 1108.7 52 1108.92 88.6 1106.62 15 1106.84 24.969 1107.03 24993.896 1107.26 119.38 1107.46 -1.2043 1107.66 1.1695 1107.87 1.5661 1108.1 -1.2508 1108.29 11.607
    1111.02 778 1111.23 52 1111.44 88.6 1109.14 15 1109.38 25.171 1109.57 24993.896 1109.78 120.28 1109.98 -1.1695 1110.18 1.5515 1110.39 1.1984 1110.62 -1.5511 1110.84 11.569
    1113.6 776 1113.79 52 1114 88.6 1111.64 15 1111.88 24.841 1112.11 24993.896 1112.31 119.25 1112.54 -0.8989 1112.74 1.1772 1112.94 1.635 1113.16 -1.2556 1113.38 11.494
    1116.14 777 1116.35 53 1116.54 88.6 1114.22 15 1114.42 25.049 1114.64 24993.896 1114.85 120.22 1115.04 -1.219 1115.26 1.5661 1115.46 1.1475 1115.66 -1.142 1115.9 11.711
    1118.66 778 1118.9 53 1119.14 88.6 1116.74 15 1116.96 24.78 1117.17 24993.896 1117.4 119.38 1117.64 -1.5929 1117.85 1.1823 1118.04 1.2127 1118.26 -1.6035 1118.46 11.644
    1121.26 776 1121.46 53 1121.66 88.6 1119.34 15 1119.54 25.012 1119.74 24993.896 1119.96 119.31 1120.18 -1.5273 1120.41 1.5182 1120.64 1.5566 1120.85 -0.8571 1121.04 11.87
    1123.79 778 1124 53 1124.21 89 1121.88 15 1122.1 24.988 1122.28 24993.896 1122.49 119.16 1122.7 -1.1801 1122.9 1.2512 1123.14 0.8641 1123.38 -1.1706 1123.6 11.81
    1126.36 776 1126.56 53 1126.78 88.6 1124.41 15 1124.64 24.878 1124.88 24993.896 1125.11 119.38 1125.3 -0.8428 1125.51 1.216 1125.71 1.5632 1125.92 -1.2043 1126.14 12.311
    1128.9 777 1129.11 53 1129.3 88.6 1126.99 15 1127.19 24.963 1127.4 24993.896 1127.63 120.22 1127.82 -1.1545 1128.02 1.5855 1128.23 1.1267 1128.43 -1.1772 1128.66 11.87
    1131.4 776 1131.62 53 1131.82 88.6 1129.51 15 1129.72 24.841 1129.93 24993.896 1130.16 119.38 1130.37 -1.1468 1130.56 1.5068 1130.77 1.5632 1130.97 -1.1497 1131.18 11.951
    1133.96 774 1134.16 53 1134.4 88.6 1132.03 15 1132.23 24.994 1132.43 24993.896 1132.66 119.22 1132.9 -1.2332 1133.11 1.5182 1133.31 1.0849 1133.53 -1.1545 1133.76 12.07
    1136.49 777 1136.69 53 1136.9 88.6 1134.62 15 1134.82 24.847 1135.03 24993.896 1135.23 119.25 1135.44 -1.1772 1135.64 1.5855 1135.87 1.5731 1136.06 -0.8637 1136.28 12.35
    1139.03 776 1139.24 53 1139.44 89 1137.12 15 1137.33 25.043 1137.54 24993.896 1137.74 119.25 1137.95 -1.5691 1138.16 1.5171 1138.39 1.1519 1138.61 -1.1355 1138.81 12.131
    1141.66 777 1141.89 53 1142.12 89 1139.66 15 1139.91 24.963 1140.16 24993.896 1140.36 119.28 1140.57 -1.5416 1140.78 1.5661 1140.99 0.8355 1141.19 -1.6137 1141.41 12.511
    1144.2 776 1144.41 54 1144.64 88.6 1142.31 15 1142.51 24.89 1142.71 24993.896 1142.91 119.47 1143.15 -0.8348 1143.37 1.1897 1143.58 1.1472 1143.78 -1.1307 1143.99 12.21
    1146.77 776 1146.98 54 1147.18 88.6 1144.87 15 1145.06 24.927 1145.27 24993.896 1145.47 120.13 1145.68 -1.1724 1145.91 0.8293 1146.15 1.1779 1146.37 -1.1197 1146.57 12.131
    1149.37 777 1149.57 54 1149.77 88.6 1147.42 15 1147.64 25.018 1147.87 24993.896 1148.06 119.47 1148.26 -1.5804 1148.47 1.5346 1148.68 0.8641 1148.92 -1.1801 1149.15 12.25
    1151.91 775 1152.16 54 1152.36 88.6 1149.98 15 1150.19 24.866 1150.4 24993.896 1150.61 119.44 1150.81 -1.5467 1151.03 1.5357 1151.25 1.5489 1151.46 -0.8989 1151.66 12.45
    1154.43 777 1154.64 54 1154.87 89 1152.55 15 1152.76 24.988 1152.97 24993.896 1153.18 119.38 1153.4 -1.5086 1153.61 1.1571 1153.81 1.5233 1154.01 -1.4987 1154.22 12.691
    1157.02 788 1157.22 54 1157.43 88.6 1155.08 15 1155.3 24.982 1155.5 24993.896 1155.71 119.28 1155.92 -0.8699 1156.16 1.1637 1156.4 1.1523 1156.61 -1.2043 1156.81 12.851
    1159.66 776 1159.87 54 1160.08 88.6 1157.66 15 1157.91 24.927 1158.16 24993.896 1158.4 120.19 1158.61 -1.1215 1158.81 1.528 1159.03 1.5266 1159.24 -1.5072 1159.44 12.45
    1162.18 777 1162.41 54 1162.66 88.6 1160.29 15 1160.5 24.988 1160.72 24993.896 1160.94 119.28 1161.15 -0.819 1161.36 1.6258 1161.56 1.5903 1161.77 -0.8637 1161.97 12.23
    1164.82 775 1165.02 54 1165.23 88.6 1162.9 15 1163.11 25.055 1163.31 24993.896 1163.52 119.31 1163.73 -1.4984 1163.93 0.8399 1164.16 1.16 1164.4 -1.1494 1164.62 12.23
    1167.39 778 1167.6 54 1167.79 89 1165.44 15 1165.66 25.024 1165.9 24993.896 1166.12 119.31 1166.33 -1.5929 1166.54 0.8641 1166.74 1.5489 1166.95 -1.4987 1167.16 12.83
    1169.92 789 1170.16 54 1170.4 88.6 1168 15 1168.22 24.939 1168.43 24993.896 1168.65 119.38 1168.87 -1.0776 1169.08 1.1779 1169.3 1.1596 1169.51 -1.5295 1169.71 12.871
    1172.48 777 1172.68 54 1172.91 88.6 1170.61 15 1170.81 24.939 1171.02 24993.896 1171.22 119.31 1171.43 -1.5493 1171.65 1.5013 1171.86 1.1171 1172.06 -1.153 1172.27 12.35
    1175.16 789 1175.38 54 1175.57 89 1173.16 15 1173.4 25.085 1173.62 24993.896 1173.83 119.25 1174.03 -1.5028 1174.24 0.8106 1174.45 1.1362 1174.66 -1.5174 1174.91 12.75
    1177.68 776 1177.92 54 1178.18 88.6 1175.78 15 1175.99 25.079 1176.19 24993.896 1176.42 119.38 1176.66 -1.5453 1176.88 1.0432 1177.06 1.205 1177.26 -1.5171 1177.46 12.331
    1180.38 777 1180.57 54 1180.78 88.6 1178.42 15 1178.67 24.866 1178.88 24993.896 1179.08 119.25 1179.29 -1.0974 1179.5 1.576 1179.72 1.5009 1179.94 -1.071 1180.17 12.671
    1182.82 777 1183.03 55 1183.23 88.6 1180.98 15 1181.19 25.049 1181.4 24993.896 1181.6 119.38 1181.81 -1.58 1182.01 1.1292 1182.22 1.0977 1182.42 -1.5423 1182.63 12.79
    1185.36 775 1185.56 55 1185.76 88.6 1183.43 15 1183.67 24.988 1183.88 24993.896 1184.08 120.06 1184.3 -1.1355 1184.51 1.5068 1184.71 1.1263 1184.92 -1.1065 1185.15 13.17
    1187.88 776 1188.08 55 1188.3 89 1185.97 15 1186.19 25.055 1186.41 24993.896 1186.63 119.47 1186.82 -1.5167 1187.03 1.0963 1187.23 1.1472 1187.43 -1.4841 1187.67 13.29
    1190.42 789 1190.63 55 1190.82 88.6 1188.5 15 1188.71 25.031 1188.92 24993.896 1189.13 119.44 1189.33 -1.0798 1189.54 1.1355 1189.75 1.1347 1189.97 -1.5335 1190.19 12.93
    1192.93 775 1193.16 55 1193.38 88.6 1191.03 15 1191.25 25.049 1191.46 24993.896 1191.67 119.28 1191.89 -1.4475 1192.08 0.8183 1192.29 1.1043 1192.5 -1.4629 1192.72 13.11
    1195.5 1888 1195.72 55 1195.93 88.6 1193.58 37 1193.8 31.555 1194 40948.486 1194.21 160.06 1194.44 0.0002 1194.68 0.0002 1194.9 0.0002 1195.08 0.0002 1195.29 41.544
    1198.09 1589 1198.3 55 1198.5 88.6 1196.14 15 1196.34 30.878 1196.55 31665.039 1196.77 119 1196.98 0.0002 1197.19 0.0002 1197.44 0.0002 1197.68 0.0002 1197.89 36.543
    1200.68 2186 1200.87 55 1201.07 89 1198.71 15 1198.94 53.284 1199.17 47650.146 1199.38 141.09 1199.58 0.0002 1199.79 0.0002 1200 0.0002 1200.22 0.0002 1200.46 50.909
    1203.21 2396 1203.43 55 1203.61 88.6 1201.28 22 1201.48 56.58 1201.7 57464.6 1201.91 140.09 1202.11 0.0002 1202.33 0.0002 1202.55 0.0002 1202.76 0.0002 1202.97 28.763
    1205.73 2057 1205.97 55 1206.21 89 1203.82 22 1204.03 54.138 1204.24 53796.387 1204.47 158.72 1204.71 0.0002 1204.92 0.0002 1205.12 0.0002 1205.32 0.0002 1205.53 46.068
    1208.46 1600 1208.68 55 1208.87 89 1206.42 21 1206.62 47.797 1206.83 47546.387 1207.04 155.09 1207.24 0.0002 1207.47 0.0002 1207.72 0.0002 1207.98 0.0002 1208.22 54.878
    1211.21 780 1211.43 55 1211.62 88.6 1209.08 15 1209.3 30.322 1209.51 31347.656 1209.72 119.44 1209.97 -0.637 1210.23 0.7403 1210.47 0.6312 1210.72 -0.4821 1210.98 16.965
    1213.76 778 1213.97 56 1214.21 89 1211.83 15 1212.04 25.421 1212.24 25061.035 1212.47 119.56 1212.71 -1.1171 1212.92 0.859 1213.12 1.3457 1213.33 -0.5502 1213.55 13.21
    1216.32 777 1216.53 56 1216.74 88.6 1214.43 15 1214.63 25.043 1214.84 24993.896 1215.05 120.22 1215.26 -1.0465 1215.47 0.9036 1215.71 1.0098 1215.93 -0.9436 1216.12 13.01
    1218.93 777 1219.12 56 1219.33 88.6 1216.97 15 1217.21 24.969 1217.43 24993.896 1217.63 119.38 1217.83 -1.4398 1218.04 1.3848 1218.25 0.6802 1218.47 -1.1146 1218.71 13.37
    1221.46 778 1221.67 56 1221.87 88.6 1219.54 15 1219.75 24.872 1219.97 24993.896 1220.21 119.5 1220.42 -0.7835 1220.62 1.0684 1220.82 1.4292 1221.03 -0.7355 1221.24 13.409
    1223.97 788 1224.22 56 1224.46 88.6 1222.08 15 1222.3 25.116 1222.51 24993.896 1222.71 120.19 1222.93 -1.361 1223.13 1.4511 1223.33 0.6689 1223.54 -1.0703 1223.74 13.29
    1226.55 778 1226.76 56 1226.97 88.6 1224.68 15 1224.87 24.969 1225.08 24993.896 1225.29 119.34 1225.49 -0.737 1225.72 1.0754 1225.93 1.3852 1226.13 -1.0157 1226.35 13.69
    1229.13 778 1229.35 56 1229.55 88.6 1227.22 15 1227.43 25.085 1227.62 24993.896 1227.82 120.16 1228.03 -1.0139 1228.24 1.0512 1228.47 1.0446 1228.71 -1.1007 1228.93 13.37
    1231.71 778 1231.93 56 1232.13 89 1229.76 15 1229.97 24.988 1230.22 24993.896 1230.42 120.28 1230.62 -1.0736 1230.82 1.3808 1231.03 0.7235 1231.24 -1.0509 1231.47 13.589
    1234.33 778 1234.54 56 1234.75 89 1232.35 15 1232.55 24.866 1232.76 24993.896 1232.97 119.34 1233.23 -1.3999 1233.47 1.1168 1233.71 1.1106 1233.93 -1.5258 1234.13 13.49
    1236.94 776 1237.13 57 1237.34 88.6 1234.97 15 1235.23 25.018 1235.46 24993.896 1235.68 120.06 1235.88 -1.0256 1236.1 0.7312 1236.31 1.4369 1236.51 -1.3563 1236.72 13.49
    1239.47 777 1239.69 57 1239.88 88.6 1237.55 15 1237.77 24.969 1237.99 24993.896 1238.21 119.34 1238.43 -0.7454 1238.62 1.1168 1238.83 1.3999 1239.04 -0.7854 1239.24 13.71
    1241.98 791 1242.22 57 1242.43 88.6 1240.09 15 1240.3 25.055 1240.52 24993.896 1240.73 120.19 1240.96 -1.0476 1241.18 1.0706 1241.37 1.0241 1241.58 -1.0732 1241.77 13.71
    1244.63 778 1244.83 57 1245.04 88.6 1242.63 15 1242.84 24.908 1243.04 24993.896 1243.25 119.34 1243.48 -1.1054 1243.73 1.0673 1243.97 1.045 1244.22 -1.398 1244.43 13.69
    1247.14 776 1247.35 57 1247.57 88.6 1245.25 15 1245.47 24.939 1245.68 24993.896 1245.88 119.34 1246.09 -1.0684 1246.29 0.9377 1246.5 1.0703 1246.73 -0.7612 1246.94 13.817
    1249.74 775 1249.98 57 1250.19 88.6 1247.78 15 1247.99 25.018 1248.24 24993.896 1248.48 119.25 1248.7 -1.4328 1248.9 0.9567 1249.1 1.0622 1249.31 -1.3852 1249.52 13.887
    1252.3 776 1252.52 57 1252.73 88.6 1250.39 15 1250.6 25 1250.82 24993.896 1251.02 119.34 1251.23 -1.4204 1251.45 1.3376 1251.66 0.963 1251.88 -1.0395 1252.09 14.098
    1254.81 777 1255.01 57 1255.23 88.6 1252.94 15 1253.14 25.012 1253.34 24993.896 1253.55 119.34 1253.76 -1.3947 1253.97 0.9871 1254.17 1.0575 1254.38 -1.3801 1254.6 14.272
    1257.3 777 1257.52 57 1257.73 88.6 1255.45 15 1255.63 24.829 1255.84 24993.896 1256.05 119.34 1256.27 -0.7117 1256.48 1.0256 1256.69 1.3614 1256.89 -0.7191 1257.09 14.307
    1259.8 789 1260.01 57 1260.23 88.6 1257.94 15 1258.14 25.031 1258.35 24993.896 1258.57 120.28 1258.77 -1.3277 1258.98 1.4098 1259.19 1.0336 1259.39 -1.4204 1259.6 13.73
    1262.35 780 1262.57 57 1262.77 88.6 1260.45 15 1260.65 25.024 1260.85 24993.896 1261.06 120.38 1261.26 -0.9534 1261.48 0.9392 1261.72 1.056 1261.94 -1.3442 1262.14 13.852
    1264.9 790 1265.11 57 1265.32 88.6 1262.98 15 1263.2 25.018 1263.41 24993.896 1263.62 119.28 1263.83 -0.8908 1264.03 1.0384 1264.26 0.7216 1264.49 -1.0487 1264.71 14.236
    1267.41 775 1267.62 57 1267.82 89 1265.53 15 1265.74 25.11 1265.96 24993.896 1266.16 119.5 1266.37 -1.2508 1266.57 1.168 1266.78 1.0432 1267 -1.4185 1267.21 14.342
    1269.96 776 1270.16 57 1270.38 88.6 1268.03 15 1268.26 25.049 1268.5 24993.896 1268.71 119.28 1268.9 -0.8732 1269.11 1.0271 1269.32 1.0802 1269.54 -1.3449 1269.75 14.236
    1272.51 776 1272.73 57 1272.93 88.6 1270.59 15 1270.8 25.079 1271.02 24993.896 1271.25 119.34 1271.45 -1.361 1271.65 0.7473 1271.86 1.045 1272.07 -1.4607 1272.27 14.551
    1275.04 787 1275.27 57 1275.51 88.6 1273.13 15 1273.34 25.092 1273.55 24993.896 1273.77 119.34 1274.01 -1.4204 1274.23 1.3768 1274.42 0.6513 1274.62 -1.3805 1274.83 13.75
    1277.64 777 1277.85 57 1278.07 89 1275.73 15 1275.93 24.768 1276.15 24993.896 1276.35 119.28 1276.56 -1.0501 1276.77 1.4511 1277.02 1.0271 1277.24 -1.5482 1277.43 14.063
    1280.15 777 1280.35 58 1280.56 88.6 1278.28 15 1278.49 25 1278.69 24993.896 1278.91 120.22 1279.11 -1.0571 1279.31 1.3951 1279.53 0.9886 1279.74 -0.9293 1279.94 13.922
    1282.65 777 1282.86 58 1283.07 89 1280.78 15 1281 25.012 1281.19 24993.896 1281.4 119.28 1281.6 -1.4361 1281.81 0.7117 1282.03 1.1472 1282.25 -1.3512 1282.45 14.027
    1285.18 777 1285.38 58 1285.59 88.6 1283.27 15 1283.49 24.805 1283.69 24993.896 1283.91 119.56 1284.11 -0.6989 1284.31 1.3713 1284.54 1.3988 1284.76 -0.8791 1284.96 14.412
    1287.71 777 1287.92 58 1288.12 88.6 1285.8 15 1286.02 25.085 1286.21 24993.896 1286.42 120.38 1286.63 -1.049 1286.85 1.4991 1287.06 0.9373 1287.3 -1.398 1287.51 14.377
    1290.26 777 1290.46 58 1290.67 88.6 1288.33 15 1288.56 24.86 1288.8 24993.896 1289.01 119.25 1289.2 -0.6718 1289.41 1.0622 1289.63 1.3889 1289.84 -0.9421 1290.04 14.445
    1292.83 776 1293.04 58 1293.24 88.6 1290.87 15 1291.08 25.018 1291.32 24993.896 1291.56 119.28 1291.77 -1.4698 1291.97 0.7363 1292.17 1.3299 1292.38 -1.2669 1292.59 14.412
    1295.42 778 1295.62 58 1295.83 88.6 1293.45 15 1293.65 24.878 1293.86 24993.896 1294.09 119.13 1294.34 -1.0846 1294.58 0.6799 1294.79 1.3779 1294.99 -1.3306 1295.21 14.726
    1297.92 778 1298.13 58 1298.34 88.6 1296.04 15 1296.24 24.902 1296.45 24993.896 1296.65 119.13 1296.86 -1.4138 1297.09 1.3695 1297.31 1.4383 1297.52 -0.6557 1297.72 14.551
    1300.48 777 1300.69 58 1300.9 88.6 1298.58 15 1298.79 25.024 1298.99 24993.896 1299.21 120.16 1299.42 -1.0443 1299.63 1.323 1299.85 1.4065 1300.08 -1.4061 1300.28 14.342
    1303.13 777 1303.35 58 1303.56 88.6 1303.76 15 1303.97 25.061 1304.17 24993.896 1304.38 119.19 1304.6 -0.8652 1304.83 1.1951 1305.03 1.0142 1305.23 -0.9355 1305.44 14.377
    1305.65 779 1305.85 58 1306.08 89 1306.29 15 1306.49 24.994 1306.71 24993.896 1306.92 120.16 1307.12 -1.0509 1307.33 1.045 1307.55 0.8974 1307.74 -1.0509 1307.95 15.355
    1308.16 777 1308.38 58 1308.6 88.6 1308.82 15 1309.04 24.86 1309.24 24993.896 1309.46 119.28 1309.68 -2.437 1309.89 0.9168 1310.09 1.1951 1310.33 -1.0062 1310.55 14.516
    1310.77 786 1310.97 58 1311.17 88.6 1311.37 15 1311.58 25.104 1311.79 24993.896 1311.98 120.28 1312.19 -1.0318 1312.4 1.4002 1312.6 0.8802 1312.83 -1.3709 1313.04 14.551
    1313.24 777 1313.46 58 1313.67 88.6 1313.88 15 1314.1 24.866 1314.33 24993.896 1314.54 119.13 1314.74 -0.6685 1314.96 1.0479 1315.17 1.4801 1315.38 -2.407 1315.6 14.551
    1315.83 785 1316.07 58 1316.29 88.6 1316.48 15 1316.69 25.11 1316.9 24993.896 1317.1 119.34 1317.32 -1.361 1317.54 0.9168 1317.73 1.0175 1317.94 -1.4336 1318.15 14.201
    1318.37 777 1318.58 58 1318.79 88.6 1318.99 15 1319.21 25 1319.43 24993.896 1319.63 119.28 1319.84 -0.9146 1320.08 1.4306 1320.29 0.7553 1320.48 -1.4607 1320.68 14.935
    1320.89 791 1321.1 58 1321.34 88.6 1321.57 15 1321.79 24.89 1321.98 24993.896 1322.19 119.19 1322.4 -1.1915 1322.6 0.8959 1322.83 1.3566 1323.04 -1.0703 1323.24 15.041
    1323.46 777 1323.67 58 1323.87 88.6 1324.09 15 1324.31 25.018 1324.51 24993.896 1324.71 119.19 1324.92 -0.878 1325.12 1.0336 1325.34 0.9406 1325.56 -1.3805 1325.74 14.377
    1325.95 775 1326.16 58 1326.38 88.6 1326.59 15 1326.81 24.969 1327 24993.896 1327.21 120.06 1327.42 -1.0505 1327.62 2.1696 1327.85 2.4773 1328.1 0.0002 1328.36 42.734
    1328.59 1083 1328.8 58 1329 88.6 1329.21 15 1329.43 30.786 1329.64 30328.369 1329.84 118 1330.06 -2.1323 1330.26 0.0002 1330.46 0.0002 1330.67 0.0002 1330.88 51.544
    1331.12 1454 1331.36 59 1331.57 88.6 1331.77 15 1331.97 31.47 1332.18 30883.789 1332.39 119.19 1332.61 -0.6022 1332.83 0.4602 1333.03 1.2116 1333.24 -0.6795 1333.45 17.685
    1333.65 781 1333.86 59 1334.07 88.6 1334.27 15 1334.48 25.568 1334.69 25067.139 1334.89 119.69 1335.1 -1.3182 1335.33 0.458 1335.55 1.0065 1335.75 -0.7008 1335.95 15.109
    1336.16 779 1336.37 59 1336.61 88.6 1336.82 15 1337.02 25.665 1337.24 37347.412 1337.46 160.19 1337.67 0.0002 1337.87 0.0002 1338.11 0.0002 1338.33 0.0002 1338.54 33.368
    1338.75 815 1338.95 59 1339.16 88.6 1339.37 15 1339.62 29.761 1339.86 29162.598 1340.07 119.06 1340.27 -1.2581 1340.48 0.9472 1340.68 3.3119 1340.89 0.0002 1341.12 54.72
    1341.34 1815 1341.54 59 1341.74 88.6 1341.94 15 1342.14 30.725 1342.38 31616.211 1342.58 119.63 1342.78 -0.652 1342.99 0.8146 1343.19 0.6033 1343.4 -0.7429 1343.64 18.352
    1343.85 776 1344.05 59 1344.25 88.6 1344.46 15 1344.66 26.154 1344.89 25634.766 1345.11 119.53 1345.32 -1.2948 1345.53 1.5745 1345.74 0.8179 1345.94 -0.6931 1346.15 15.948
    1346.39 783 1346.6 59 1346.8 88.6 1347 15 1347.21 24.994 1347.42 24993.896 1347.63 119.16 1347.84 -2.3685 1348.04 1.0062 1348.26 1.0322 1348.47 -1.3292 1348.67 14.97
    1348.89 787 1349.11 59 1349.31 88.6 1349.51 15 1349.72 25 1349.92 24993.896 1350.15 119.28 1350.39 -1.3709 1350.6 0.6495 1350.8 0.989 1351 -1.3515 1351.21 14.9
    1351.42 777 1351.64 59 1351.85 88.6 1352.05 15 1352.26 24.872 1352.48 24993.896 1352.68 119.5 1352.89 -1.1662 1353.11 0.9952 1353.32 0.8992 1353.53 -2.4106 1353.73 14.656
    1353.94 777 1354.16 59 1354.36 88.6 1354.56 15 1354.77 24.988 1354.99 24993.896 1355.21 120.09 1355.42 -1.0252 1355.65 1.1486 1355.87 0.9747 1356.07 -1.1516 1356.29 14.795
    1356.5 779 1356.7 59 1356.91 88.6 1357.12 15 1357.32 24.969 1357.53 24993.896 1357.74 119.38 1357.94 -0.9179 1358.19 0.8703 1358.41 0.6674 1358.64 -1.0205 1358.83 14.656
    1359.03 786 1359.25 59 1359.45 89 1359.68 15 1359.93 24.817 1360.17 24993.896 1360.39 119.38 1360.59 -2.3451 1360.79 1.0095 1361 1.2387 1361.21 -2.4297 1361.43 15.041
    1361.67 789 1361.88 59 1362.07 88.6 1362.28 15 1362.49 24.969 1362.69 24993.896 1362.93 119.16 1363.17 -0.8989 1363.43 0.8992 1363.67 2.3791 1363.89 -0.9963 1364.07 15.215
    1364.27 787 1364.49 59 1364.71 88.6 1364.92 15 1365.14 25.079 1365.33 24993.896 1365.53 119.22 1365.73 -0.9051 1365.93 0.9025 1366.18 0.9458 1366.43 -1.1596 1366.67 14.691
    1366.89 788 1367.09 59 1367.29 88.6 1367.49 15 1367.71 24.982 1367.93 24993.896 1368.17 119.28 1368.39 -1.2797 1368.57 0.707 1368.79 1.0673 1369.01 -1.4189 1369.21 14.516
    1369.41 777 1369.64 59 1369.83 88.6 1370.03 15 1370.25 24.921 1370.46 24993.896 1370.67 119.5 1370.93 -1.2812 1371.14 1.1567 1371.34 1.1439 1371.54 -1.3772 1371.75 14.9
    1371.97 790 1372.19 60 1372.41 88.6 1372.61 15 1372.81 25.031 1373.02 24993.896 1373.23 119.16 1373.45 -1.3515 1373.69 1.3951 1373.9 1.0095 1374.09 -1.4204 1374.29 15.424
    1374.5 783 1374.71 60 1374.94 89 1375.14 15 1375.34 24.988 1375.55 24993.896 1375.75 119.5 1375.97 -1.134 1376.18 1.0479 1376.4 1.3775 1376.61 -1.2827 1376.81 15.144
    1377.03 778 1377.23 60 1377.44 88.6 1377.66 15 1377.86 24.994 1378.06 24993.896 1378.27 119.94 1378.47 -1.0318 1378.69 1.379 1378.93 1.3823 1379.15 -1.2973 1379.34 15.109
    1379.55 778 1379.76 60 1379.97 88.6 1380.19 15 1380.41 24.841 1380.61 24993.896 1380.81 119 1381.01 -1.0256 1381.21 0.8817 1381.45 1.3856 1381.69 -2.3484 1381.9 15.041
    1382.1 780 1382.31 60 1382.53 88.6 1382.75 15 1382.96 25.018 1383.19 24993.896 1383.42 119 1383.65 -1.0736 1383.85 1.4002 1384.07 1.1615 1384.29 -2.4092 1384.5 15.669
    1384.7 779 1384.92 60 1385.14 88.6 1385.34 15 1385.53 25.043 1385.75 24993.896 1385.96 120.09 1386.19 -0.8765 1386.41 1.2563 1386.61 0.8703 1386.81 -0.8894 1387.01 15.388
    1387.23 778 1387.44 60 1387.69 88.6 1387.9 15 1388.09 24.774 1388.29 24993.896 1388.51 119.06 1388.73 -1.0542 1388.93 1.2819 1389.14 1.1472 1389.34 -1.1131 1389.56 15.529
    1389.75 779 1389.97 60 1390.18 88.6 1390.4 15 1390.61 24.957 1390.82 24993.896 1391.02 119.38 1391.23 -1.3087 1391.45 1.1809 1391.69 2.3791 1391.9 -0.8941 1392.09 15.773
    1392.3 776 1392.5 60 1392.71 88.6 1392.93 15 1393.15 25.018 1393.36 24993.896 1393.56 119.22 1393.77 -1.2014 1393.98 2.3506 1394.19 0.8945 1394.43 -1.1388 1394.64 15.529
    1394.83 779 1395.04 60 1395.25 88.6 1395.45 15 1395.69 24.902 1395.9 24993.896 1396.09 119.28 1396.29 -2.4238 1396.5 0.8531 1396.71 0.8945 1396.92 -1.3068 1397.15 15.669
    1397.37 788 1397.57 60 1397.77 88.6 1397.98 15 1398.19 24.982 1398.45 24993.896 1398.69 119 1398.9 -1.1724 1399.09 0.9714 1399.31 1.2047 1399.5 -1.1179 1399.71 15.529
    1399.93 777 1400.16 60 1400.37 88.6 1400.57 15 1400.77 25.031 1400.98 24993.896 1401.19 120.03 1401.43 -0.9165 1401.64 0.9395 1401.85 1.3728 1402.05 -1.1805 1402.25 15.564
    1402.47 773 1402.69 60 1402.94 88.6 1403.17 15 1403.4 25.012 1403.59 24993.896 1403.79 119.5 1404.01 -1.3087 1404.21 1.112 1404.45 2.3934 1404.66 -0.9022 1404.86 15.32
    1405.08 777 1405.29 60 1405.49 89 1405.7 15 1405.92 25.031 1406.11 24993.896 1406.32 119.16 1406.52 -1.1776 1406.73 1.1571 1406.94 1.0095 1407.15 -1.2508 1407.35 15.494
    1407.55 772 1407.76 60 1407.97 88.6 1408.22 15 1408.45 25.024 1408.67 24993.896 1408.86 119.44 1409.08 -1.2669 1409.28 0.9058 1409.49 0.9183 1409.74 -0.8875 1409.98 15.529
    1410.19 776 1410.38 60 1410.59 88.6 1410.8 15 1411 24.927 1411.22 24993.896 1411.44 119.28 1411.65 -0.9392 1411.85 1.3299 1412.05 1.0146 1412.26 -0.9501 1412.48 15.564
    1412.71 772 1412.89 61 1413.1 88.6 1413.31 15 1413.52 24.939 1413.72 24993.896 1413.94 119.38 1414.14 -2.3725 1414.37 1.1779 1414.57 0.8897 1414.77 -1.3277 1414.98 15.703
    1415.2 788 1415.39 61 1415.61 89 1415.8 15 1416.01 25.049 1416.24 24993.896 1416.48 119.22 1416.69 -1.1951 1416.88 1.1728 1417.09 1.331 1417.29 -1.1805 1417.5 16.081
    1417.72 776 1417.94 61 1418.13 88.6 1418.34 15 1418.55 24.902 1418.75 24993.896 1418.98 119.44 1419.19 -0.8879 1419.39 1.3057 1419.61 1.2094 1419.82 -1.0413 1420.02 14.9
    1420.24 777 1420.48 61 1420.7 88.6 1420.89 15 1421.1 25.031 1421.31 24993.896 1421.53 119.94 1421.73 -1.038 1421.94 1.3969 1422.13 0.7106 1422.34 -0.9963 1422.54 15.564
    1422.75 792 1422.97 61 1423.19 88.6 1423.39 15 1423.61 25.012 1423.83 24993.896 1424.04 119.16 1424.24 -1.16 1424.49 0.9857 1424.73 1.056 1424.94 -1.2973 1425.14 15.599
    1425.36 788 1425.57 61 1425.78 88.6 1426 15 1426.23 24.841 1426.43 24993.896 1426.63 119.16 1426.84 -1.3757 1427.04 1.0816 1427.25 0.9615 1427.48 -0.8875 1427.69 15.529
    1427.89 778 1428.11 61 1428.32 88.6 1428.53 15 1428.75 24.902 1428.98 24993.896 1429.19 119.22 1429.38 -0.8941 1429.59 0.997 1429.79 1.0047 1430 -2.2553 1430.24 15.843
    1430.48 777 1430.7 61 1430.89 88.6 1431.11 15 1431.32 24.835 1431.53 24993.896 1431.75 119.16 1431.98 -0.6909 1432.19 0.9747 1432.38 1.1728 1432.59 -1.0637 1432.8 15.388
    1433 781 1433.23 61 1433.44 88.6 1433.64 15 1433.86 25.092 1434.07 24993.896 1434.27 120.16 1434.49 -0.9886 1434.71 1.197 1434.89 1.0878 1435.1 -0.9692 1435.3 15.669
    1435.51 788 1435.75 61 1436.01 88.6 1436.25 15 1436.49 24.969 1436.71 24993.896 1436.91 120.03 1437.11 -0.9355 1437.31 1.283 1437.52 2.2319 1437.75 -1.1439 1438 15.669
    1438.24 779 1438.45 61 1438.65 88.6 1438.86 15 1439.08 25.085 1439.28 24993.896 1439.49 119.22 1439.71 -1.3112 1439.9 0.8688 1440.11 0.8641 1440.31 -1.2973 1440.51 15.285
    1440.75 787 1441 61 1441.24 88.6 1441.46 15 1441.65 24.927 1441.86 24993.896 1442.07 119.28 1442.27 -0.8989 1442.49 0.9648 1442.71 1.1842 1442.91 -2.1583 1443.11 15.669
    1443.32 778 1443.53 61 1443.75 88.6 1444 15 1444.24 24.933 1444.46 24993.896 1444.65 119.16 1444.86 -1.1292 1445.07 2.2528 1445.27 0.9311 1445.48 -1.2094 1445.69 15.738
    1445.89 777 1446.11 61 1446.32 89 1446.53 15 1446.75 24.994 1447 24993.896 1447.25 119.22 1447.48 -1.1388 1447.69 2.1374 1447.89 0.8736 1448.11 -0.8718 1448.33 15.703
    1448.55 776 1448.75 61 1448.99 88.6 1449.21 15 1449.4 25.043 1449.61 24993.896 1449.82 120.03 1450.02 -1.238 1450.24 1.1713 1450.46 2.2158 1450.65 -1.0285 1450.86 15.878
    1451.08 788 1451.28 61 1451.5 88.6 1451.74 15 1451.96 24.768 1452.16 24993.896 1452.36 119.38 1452.57 -0.8875 1452.78 1.2721 1453.01 1.1842 1453.23 -2.1967 1453.44 15.144
    1453.64 778 1453.86 61 1454.08 88.6 1454.29 15 1454.49 25 1454.71 24993.896 1454.91 120.09 1455.12 -0.9355 1455.32 1.2526 1455.53 0.848 1455.77 -1.3599 1456.01 15.738
    1456.22 782 1456.42 61 1456.62 89 1456.83 15 1457.05 24.963 1457.26 24993.896 1457.47 119.38 1457.67 -1.0476 1457.87 1.3105 1458.08 1.1842 1458.29 -1.0413 1458.51 15.109
    1458.72 778 1458.92 62 1459.13 88.6 1459.33 15 1459.54 24.963 1459.77 24993.896 1460.01 119.16 1460.22 -0.9165 1460.41 1.2578 1460.62 0.8945 1460.82 -0.8699 1461.03 15.424
    1461.24 790 1461.44 62 1461.65 88.6 1461.85 15 1462.06 25.049 1462.28 24993.896 1462.54 119.22 1462.78 -1.238 1462.99 0.8831 1463.18 1.1728 1463.39 -2.1469 1463.61 15.32
    1463.82 787 1464.04 62 1464.26 89 1464.46 15 1464.66 24.969 1464.87 24993.896 1465.08 119.81 1465.3 -0.9611 1465.54 0.9154 1465.75 1.0146 1465.95 -1.3438 1466.16 15.808
    1466.36 776 1466.57 62 1466.8 88.6 1467.05 15 1467.28 25.049 1467.48 24993.896 1467.69 120.09 1467.91 -0.9868 1468.13 1.008 1468.34 1.3024 1468.54 -1.3197 1468.76 15.041
    1468.96 777 1469.17 62 1469.38 88.6 1469.59 15 1469.8 24.78 1470.05 24993.896 1470.29 120.03 1470.5 -1.3259 1470.7 1.3391 1470.91 0.9904 1471.13 -0.9772 1471.33 14.97
    1471.54 789 1471.75 62 1471.95 88.6 1472.15 15 1472.36 24.969 1472.58 24993.896 1472.79 119.22 1473 -0.9611 1473.2 0.9772 1473.41 1.2721 1473.61 -0.9216 1473.82 15.459
    1474.05 776 1474.29 62 1474.51 88.6 1474.69 15 1474.9 24.817 1475.11 24993.896 1475.31 119.16 1475.53 -0.6748 1475.74 1.0095 1475.93 1.1585 1476.13 -0.9293 1476.34 15.669
    1476.55 780 1476.8 62 1477.05 88.6 1477.29 15 1477.51 24.835 1477.7 24993.896 1477.9 119.28 1478.1 -1.3629 1478.31 0.8721 1478.55 1.2882 1478.79 -1.2717 1479 15.179
    1479.2 779 1479.4 62 1479.61 88.6 1479.83 15 1480.05 25.018 1480.29 24993.896 1480.52 119.28 1480.72 -1.3577 1480.93 0.8494 1481.14 0.9923 1481.34 -1.3211 1481.55 15.843
    1481.79 776 1482 62 1482.2 88.6 1482.41 15 1482.62 24.969 1482.82 24993.896 1483.05 119.22 1483.29 -0.9868 1483.54 0.8531 1483.79 1.3728 1484 -0.6462 1484.2 15.25
    1484.41 776 1484.63 62 1484.85 89 1485.06 15 1485.29 25.122 1485.51 24993.896 1485.71 120.19 1485.92 -0.9293 1486.12 0.9985 1486.33 1.3361 1486.55 -1.264 1486.8 15.529
    1487.04 779 1487.26 62 1487.47 89 1487.69 15 1487.9 24.951 1488.1 24993.896 1488.31 120.03 1488.55 -1.1596 1488.79 1.2878 1489 0.9696 1489.2 -1.019 1489.4 16.118
    1489.61 776 1489.83 62 1490.04 88.6 1490.25 15 1490.45 24.994 1490.65 24993.896 1490.86 119.28 1491.08 -1.9928 1491.29 0.9586 1491.5 1.2127 1491.7 -0.8718 1491.91 14.97
    1492.13 777 1492.33 62 1492.56 88.6 1492.77 15 1492.97 24.988 1493.19 24993.896 1493.4 120.09 1493.6 -0.8652 1493.82 0.9069 1494.04 1.3123 1494.24 -1.2204 1494.44 15.599
    1494.65 775 1494.85 62 1495.08 88.6 1495.33 15 1495.59 25.122 1495.82 24993.896 1496.04 119.22 1496.23 -0.9915 1496.44 0.9919 1496.65 1.2515 1496.85 -1.1948 1497.08 15.494
    1497.33 779 1497.56 62 1497.77 88.6 1497.97 15 1498.19 25.055 1498.4 24993.896 1498.6 119.88 1498.82 -0.9772 1499.04 1.3731 1499.22 0.6403 1499.43 -1.0205 1499.64 15.529
    1499.84 790 1500.08 62 1500.33 88.6 1500.55 15 1500.75 24.835 1500.95 24993.896 1501.16 119.38 1501.38 -1.0139 1501.58 0.9809 1501.8 1.1823 1502 -0.9915 1502.2 15.564
    1502.41 778 1502.62 62 1502.83 88.6 1503.05 15 1503.25 25.024 1503.46 24993.896 1503.66 119.06 1503.87 -0.9597 1504.09 1.3215 1504.31 0.6352 1504.51 -0.9406 1504.71 15.529
    1504.92 793 1505.13 63 1505.35 88.6 1505.59 15 1505.8 25.024 1506 24993.896 1506.22 119.38 1506.44 -0.8795 1506.65 1.2977 1506.85 1.3087 1507.09 -0.8396 1507.31 15.25
    1507.51 777 1507.71 63 1507.92 88.6 1508.13 15 1508.35 25 1508.59 24993.896 1508.8 119.91 1509 -0.9886 1509.2 0.9696 1509.41 0.8531 1509.63 -1.3021 1509.84 15.25
    1510.06 777 1510.27 63 1510.47 89 1510.67 15 1510.87 25.122 1511.1 24993.896 1511.34 119 1511.55 -0.6605 1511.75 0.9168 1511.95 1.2387 1512.16 -0.6286 1512.37 14.481
    1512.58 774 1512.8 63 1513 88.6 1513.21 15 1513.41 25.012 1513.62 24993.896 1513.84 120.25 1514.06 -0.9871 1514.28 1.2226 1514.48 0.8114 1514.69 -1.03 1514.91 15.459
    1515.12 777 1515.35 63 1515.59 88.6 1515.81 15 1516.02 25.018 1516.23 24993.896 1516.43 119.44 1516.64 -0.8092 1516.85 0.8703 1517.09 1.9199 1517.3 -0.9567 1517.5 15.634
    1517.7 786 1517.91 63 1518.13 89 1518.34 15 1518.55 25.073 1518.75 24993.896 1518.96 119.31 1519.16 -0.9787 1519.37 0.8992 1519.57 1.283 1519.78 -0.934 1519.99 15.703
    1520.21 776 1520.41 63 1520.62 88.6 1520.85 15 1521.07 24.933 1521.27 24993.896 1521.49 119.22 1521.7 -0.6619 1521.9 1.008 1522.11 1.3537 1522.32 -0.6575 1522.52 0
    1522.73 775 1522.93 63 1523.14 88.6 1523.37 15 1523.59 24.994 1523.79 24993.896 1524 120.44 1524.2 -1.2907 1524.41 1.3713 1524.63 0.6737 1524.87 -1.3742 1525.08 0
    1525.28 777 1525.49 63 1525.71 88.6 1525.91 15 1526.12 24.805 1526.33 24993.896 1526.53 119.5 1526.73 -1.3259 1526.94 0.922 1527.15 0.9985 1527.37 -1.0333 1527.59 0
    1527.78 776 1527.97 63 1528.18 88.6 1528.39 15 1528.62 25 1528.84 24993.896 1529.02 119.47 1529.23 -0.6619 1529.44 1.342 1529.66 1.3874 1529.88 -0.8861 1530.11 0
    1530.32 790 1530.51 63 1530.72 88.6 1530.94 15 1531.16 25.079 1531.37 24993.896 1531.58 120.25 1531.78 -0.9787 1531.99 1.0047 1532.21 1.4065 1532.41 -1.2878 1532.63 0
    1532.87 775 1533.09 63 1533.3 88.6 1533.52 15 1533.73 25.024 1533.94 24993.896 1534.16 120.28 1534.38 -1.0252 1534.62 0.6575 1534.84 0.9981 1535.03 -1.3259 1535.24 0
    1535.45 776 1535.65 63 1535.87 88.6 1536.09 15 1536.29 24.896 1536.5 24993.896 1536.71 119.41 1536.93 -0.6799 1537.15 0.971 1537.36 1.4145 1537.56 -0.9534 1537.76 0
    1537.97 775 1538.17 63 1538.42 89 1538.65 15 1538.87 25.031 1539.06 24993.896 1539.27 120.19 1539.49 -1.2907 1539.7 0.6125 1539.9 1.3599 1540.12 -1.2732 1540.32 0
    1540.53 777 1540.73 63 1540.94 88.6 1541.15 15 1541.36 24.774 1541.56 24993.896 1541.77 119.41 1541.99 -1.0205 1542.19 0.9073 1542.41 1.3153 1542.66 -1.4043 1542.92 0
    1543.16 778 1543.41 63 1543.66 88.6 1543.9 15 1544.12 25.085 1544.32 24993.896 1544.52 119.5 1544.73 -1.3387 1544.93 0.637 1545.16 0.9696 1545.4 -0.6671 1545.62 0
    1545.81 778 1546.02 63 1546.24 88.6 1546.45 15 1546.66 25.049 1546.9 24993.896 1547.12 120.25 1547.3 -1.0076 1547.51 1.3775 1547.72 0.9553 1547.92 -1.0413 1548.15 0
    1548.39 777 1548.6 63 1548.79 88.6 1549 15 1549.21 24.835 1549.41 24993.896 1549.65 119.5 1549.87 -0.6671 1550.06 1.3599 1550.27 1.3105 1550.48 -0.7004 1550.68 0
    1550.91 776 1551.17 63 1551.41 89 1551.66 15 1551.9 25.055 1552.11 24993.896 1552.31 119.34 1552.52 -1.3339 1552.74 1.3457 1552.94 0.7586 1553.16 -0.963 1553.4 0
    1553.62 778 1553.8 64 1554.01 88.6 1554.22 15 1554.43 25.012 1554.65 24993.896 1554.87 119.5 1555.06 -1.3339 1555.27 0.9329 1555.48 0.9714 1555.68 -1.3339 1555.91 0
    1556.16 776 1556.4 64 1556.61 88.6 1556.81 15 1557.01 24.969 1557.22 24993.896 1557.43 120.31 1557.65 -1.2907 1557.87 0.5891 1558.06 1.3889 1558.27 -1.3101 1558.49 0
    1558.7 776 1558.93 64 1559.18 88.6 1559.41 15 1559.63 25.049 1559.83 24993.896 1560.03 120.31 1560.24 -0.9501 1560.44 1.3376 1560.67 1.3647 1560.88 -0.9501 1561.08 0
    1561.3 777 1561.51 64 1561.71 89 1561.93 15 1562.18 25.049 1562.43 24993.896 1562.66 120.41 1562.89 -1.2988 1563.1 0.696 1563.32 0.9776 1563.53 -1.3387 1563.73 0
    1563.94 778 1564.16 64 1564.38 89 1564.58 15 1564.79 25 1565.01 24993.896 1565.21 119.44 1565.42 -0.9212 1565.64 0.9311 1565.85 0.9729 1566.07 -1.3387 1566.28 0
    1566.48 788 1566.69 64 1566.93 89 1567.17 15 1567.38 24.86 1567.58 24993.896 1567.78 119.56 1567.99 -1.2907 1568.21 1.3438 1568.42 1.2688 1568.63 -0.9772 1568.83 0
    1569.04 777 1569.24 64 1569.45 88.6 1569.67 15 1569.89 25.049 1570.1 24993.896 1570.31 119.44 1570.51 -0.9534 1570.72 0.9809 1570.93 0.9487 1571.16 -1.0124 1571.38 7.001
    1571.58 1596 1571.79 64 1571.99 88.6 1572.2 15 1572.42 36.279 1572.64 35437.012 1572.84 125.91 1573.04 -0.4927 1573.25 0.4649 1573.46 0.2265 1573.68 -0.4799 1573.92 21.143
    1574.14 763 1574.35 64 1574.57 88.6 1574.79 42 1574.99 64.331 1575.2 50933.838 1575.42 159.16 1575.64 0.0002 1575.84 0.0002 1576.04 0.0002 1576.25 -0.3928 1576.46 18.929
    1576.67 786 1576.88 64 1577.08 88.6 1577.29 15 1577.49 29.224 1577.7 28771.973 1577.93 119.25 1578.17 -1.0168 1578.38 0.7553 1578.57 0.922 1578.78 -0.585 1578.99 16.478
    1579.21 783 1579.42 64 1579.63 88.6 1579.83 15 1580.03 25.146 1580.23 24993.896 1580.44 119.34 1580.69 -0.9036 1580.92 0.8066 1581.14 1.2431 1581.35 -1.1109 1581.57 15.32
    1581.77 789 1581.98 64 1582.19 88.6 1582.43 15 1582.67 24.805 1582.88 24993.896 1583.08 119.25 1583.29 -0.9066 1583.49 0.7982 1583.7 0.8846 1583.93 -0.5869 1584.17 14.76
    1584.39 778 1584.59 64 1584.79 88.6 1585 15 1585.21 24.963 1585.43 24993.896 1585.67 119 1585.88 -1.2442 1586.08 0.6238 1586.29 0.8974 1586.51 -1.0889 1586.71 15.878
    1586.92 777 1587.14 64 1587.35 88.6 1587.56 15 1587.76 24.707 1587.97 24993.896 1588.18 119.25 1588.41 -0.7854 1588.62 0.8959 1588.81 1.1102 1589.02 -0.8509 1589.21 15.564
    1589.42 779 1589.64 64 1589.85 88.6 1590.06 15 1590.26 24.969 1590.47 24993.896 1590.67 119.09 1590.89 -0.8685 1591.09 0.8513 1591.29 0.8656 1591.5 -1.153 1591.71 15.459
    1591.93 788 1592.17 64 1592.39 88.6 1592.6 15 1592.82 24.951 1593.03 24993.896 1593.23 119.44 1593.44 -1.2076 1593.67 1.16 1593.89 1.171 1594.09 -0.8509 1594.3 15.355
    1594.5 779 1594.71 64 1594.93 89 1595.17 15 1595.39 25.018 1595.6 24993.896 1595.82 119.13 1596.03 -1.2076 1596.23 0.8751 1596.45 0.9121 1596.69 -0.9194 1596.89 15.388
    1597.09 778 1597.3 65 1597.5 88.6 1597.71 15 1597.93 25.018 1598.15 24993.896 1598.35 119.38 1598.57 -0.7916 1598.77 0.9069 1598.98 1.2332 1599.19 -1.7448 1599.4 14.795
    1599.6 779 1599.81 65 1600.02 88.6 1600.22 15 1600.44 25.043 1600.68 24993.896 1600.9 119 1601.1 -1.1545 1601.32 0.5744 1601.53 0.8366 1601.73 -1.0618 1601.94 15.878
    1602.15 778 1602.35 65 1602.56 88.6 1602.76 15 1602.97 24.78 1603.19 24993.896 1603.41 119.22 1603.6 -0.8908 1603.81 1.2384 1604.02 0.8286 1604.24 -0.8538 1604.46 14.97
    1604.69 775 1604.9 65 1605.09 88.6 1605.3 15 1605.51 24.957 1605.71 24993.896 1605.93 120.09 1606.15 -0.9066 1606.35 1.2384 1606.56 0.7663 1606.76 -0.8923 1606.97 15.005
    1607.18 789 1607.4 65 1607.59 89 1607.79 15 1608 25.012 1608.21 24993.896 1608.44 119.09 1608.68 -0.9498 1608.9 1.1823 1609.1 0.752 1609.32 -0.6301 1609.53 14.76
    1609.73 780 1609.94 65 1610.14 88.6 1610.34 15 1610.55 24.969 1610.76 24993.896 1610.98 119.22 1611.19 -0.7996 1611.4 0.856 1611.6 1.1102 1611.82 -1.1948 1612.03 15.494
    1612.23 779 1612.43 65 1612.65 88.6 1612.85 15 1613.06 24.927 1613.26 24993.896 1613.47 120.09 1613.69 -0.8571 1613.9 1.2893 1614.09 0.7601 1614.29 -1.1626 1614.5 15.005
    1614.71 790 1614.95 65 1615.19 88.6 1615.4 15 1615.6 24.835 1615.82 24993.896 1616.03 119.31 1616.23 -0.926 1616.44 1.1823 1616.65 1.0864 1616.85 -0.926 1617.06 15.459
    1617.27 779 1617.47 65 1617.7 88.6 1617.93 15 1618.15 24.939 1618.35 24993.896 1618.57 120.03 1618.78 -0.7725 1618.98 1.2493 1619.2 1.208 1619.44 -1.0443 1619.66 16.261
    1619.86 774 1620.06 65 1620.27 88.6 1620.47 15 1620.69 24.921 1620.9 24993.896 1621.09 119.34 1621.3 -0.8571 1621.51 1.1823 1621.71 0.8352 1621.93 -0.5612 1622.15 16.081
    1622.35 777 1622.57 65 1622.78 88.6 1622.99 15 1623.19 25.024 1623.41 24993.896 1623.6 119.38 1623.81 -0.822 1624.02 0.8798 1624.23 0.9296 1624.43 -1.5145 1624.65 14.865
    1624.84 774 1625.05 65 1625.26 88.6 1625.47 15 1625.69 25.049 1625.9 24993.896 1626.1 119.88 1626.32 -0.8747 1626.53 0.7777 1626.73 0.7857 1626.95 -1.1867 1627.2 15.424
    1627.44 780 1627.65 65 1627.85 88.6 1628.07 15 1628.28 24.969 1628.48 24993.896 1628.69 119.41 1628.91 -1.2138 1629.11 1.2493 1629.31 0.7729 1629.52 -1.1691 1629.74 15.25
    1629.95 790 1630.18 65 1630.4 89 1630.6 15 1630.81 24.799 1631.01 38714.6 1631.22 158.63 1631.45 0.0002 1631.69 0.0002 1631.9 0.0002 1632.09 0.0002 1632.3 26.462
    1632.51 1528 1632.71 65 1632.93 88.6 1633.15 33 1633.35 45.325 1633.57 54736.328 1633.78 146.25 1633.98 0.0002 1634.19 0.0002 1634.41 0.0002 1634.62 0.0002 1634.83 9.735
    1635.03 2410 1635.24 65 1635.47 89 1635.7 65 1635.92 50.635 1636.11 55090.332 1636.32 165.44 1636.53 0.0002 1636.73 0.0002 1636.95 0.0002 1637.17 0.0002 1637.37 11.83
    1637.58 2609 1637.78 65 1637.99 88.6 1638.2 65 1638.41 55.298 1638.61 54766.846 1638.82 140 1639.03 0.0002 1639.23 0.0002 1639.45 0.0002 1639.67 0.0002 1639.87 21.7
    1640.08 2602 1640.29 65 1640.51 88.6 1640.71 15 1640.96 41.962 1641.21 40283.203 1641.46 154.78 1641.69 0.0002 1641.9 0.0002 1642.1 0.4444 1642.32 -0.3854 1642.53 19.159
    1642.73 763 1642.94 65 1643.17 88.6 1643.37 15 1643.57 27.716 1643.78 27307.129 1643.98 119.13 1644.21 -0.9443 1644.46 0.6561 1644.68 0.811 1644.88 -0.4283 1645.09 15.808
    1645.29 793 1645.5 65 1645.73 89 1645.98 15 1646.22 25.012 1646.43 24993.896 1646.62 119.28 1646.84 -1.1117 1647.04 0.7978 1647.24 0.885 1647.47 -0.7084 1647.69 15.32
    1647.9 790 1648.1 66 1648.31 88.6 1648.52 15 1648.74 25.079 1648.98 24993.896 1649.22 118.91 1649.44 -1.5134 1649.65 0.8483 1649.86 0.7777 1650.06 -1.0955 1650.27 15.599
    1650.48 775 1650.72 66 1650.93 88.6 1651.12 15 1651.33 25.055 1651.54 24993.896 1651.76 119.22 1651.97 -1.019 1652.18 0.8974 1652.38 1.1377 1652.58 -0.974 1652.79 15.773
    1653 777 1653.22 66 1653.47 88.6 1653.67 15 1653.87 24.994 1654.08 24993.896 1654.29 119.06 1654.48 -0.718 1654.7 1.0835 1654.88 1.1951 1655.1 -0.5902 1655.32 14.83
    1655.54 777 1655.74 66 1655.98 88.6 1656.2 15 1656.4 25.018 1656.62 24993.896 1656.83 119.28 1657.02 -0.7293 1657.24 0.9582 1657.45 1.2607 1657.64 -0.7004 1657.86 15.773
    1658.06 776 1658.28 66 1658.5 88.6 1658.73 15 1658.95 24.896 1659.14 24993.896 1659.35 119 1659.56 -0.7213 1659.76 1.0769 1659.98 1.32 1660.21 -1.4222 1660.41 15.459
    1660.62 772 1660.83 66 1661.02 89 1661.26 15 1661.49 25.116 1661.71 24993.896 1661.9 119.25 1662.1 -0.9436 1662.32 0.7392 1662.52 1.1025 1662.74 -1.2871 1662.95 15.529
    1663.16 775 1663.36 66 1663.58 88.6 1663.79 15 1664 24.768 1664.21 24993.896 1664.4 119.5 1664.61 -0.9626 1664.84 1.1805 1665.04 0.9329 1665.25 -0.6173 1665.47 15.109
    1665.67 784 1665.86 66 1666.08 88.6 1666.28 15 1666.5 24.939 1666.74 24993.896 1666.95 120.22 1667.14 -1.0988 1667.34 1.2882 1667.54 0.7392 1667.76 -1.1084 1668 15.948
    1668.22 779 1668.42 66 1668.62 89 1668.82 15 1669.04 25.079 1669.26 24993.896 1669.47 119.22 1669.67 -0.9725 1669.88 0.7729 1670.06 1.2398 1670.28 -0.9274 1670.5 16.28
    1670.73 774 1670.92 66 1671.15 88.6 1671.36 15 1671.56 25.085 1671.78 24993.896 1672.02 119.69 1672.27 -1.2878 1672.47 0.7136 1672.68 1.1442 1672.9 -1.361 1673.11 15.669
    1673.3 779 1673.52 66 1673.74 88.6 1673.92 15 1674.14 24.713 1674.34 24993.896 1674.54 119.31 1674.77 -0.9567 1674.97 0.8491 1675.16 0.9216 1675.37 -0.7132 1675.59 16.478
    1675.78 774 1676 66 1676.22 88.6 1676.42 15 1676.64 25.018 1676.85 24993.896 1677.06 118.78 1677.28 -1.2347 1677.52 1.0402 1677.73 0.8992 1677.92 -0.8956 1678.14 16.01
    1678.34 788 1678.55 67 1678.76 88.6 1678.98 15 1679.16 25.104 1679.37 24993.896 1679.58 119.28 1679.8 -1.2493 1680.01 0.6704 1680.23 0.8048 1680.42 -1.3197 1680.64 15.285
    1680.86 781 1681.08 67 1681.28 88.6 1681.51 15 1681.73 25.079 1681.92 24993.896 1682.14 119.06 1682.36 -1.19 1682.56 0.7004 1682.76 1.0406 1682.99 -1.1981 1683.2 15.355
    1683.39 784 1683.6 67 1683.82 88.6 1684.04 15 1684.26 24.957 1684.48 24993.896 1684.66 119.28 1684.87 -1.4174 1685.08 0.5554 1685.28 1.1479 1685.52 -1.3647 1685.73 14.412
    1685.92 780 1686.14 67 1686.35 89 1686.55 15 1686.78 24.963 1687.02 24993.896 1687.22 119.66 1687.42 -0.8956 1687.62 0.986 1687.82 0.9209 1688.04 -0.8048 1688.28 14.131
    1688.52 779 1688.76 67 1688.97 89 1689.17 15 1689.39 25.085 1689.6 24993.896 1689.8 118.84 1690.01 -0.614 1690.23 0.7458 1690.43 1.3794 1690.64 -1.1834 1690.84 15.424
    1691.04 771 1691.26 67 1691.47 88.6 1691.66 15 1691.88 25.049 1692.07 24993.896 1692.28 118.63 1692.52 -0.8461 1692.76 0.6737 1692.97 1.0813 1693.17 -1.3017 1693.38 15.529
    1693.58 780 1693.79 67 1694.01 88.6 1694.23 15 1694.44 24.744 1694.64 24993.896 1694.85 119.75 1695.06 -0.9736 1695.28 0.8194 1695.51 0.6784 1695.71 -0.6184 1695.9 13.071
    1696.1 785 1696.3 67 1696.52 89 1696.76 15 1696.97 24.969 1697.16 24993.896 1697.37 118.59 1697.58 -1.0783 1697.78 0.9194 1698.02 0.8553 1698.25 -0.9659 1698.44 16.208
    1698.64 786 1698.85 67 1699.05 88.6 1699.28 15 1699.53 24.939 1699.77 24993.896 1699.99 119.66 1700.18 -0.8798 1700.4 0.9611 1700.61 0.6081 1700.82 -0.7238 1701.05 15.599
    1701.29 779 1701.51 67 1701.7 88.6 1701.9 15 1702.11 24.786 1702.32 24993.896 1702.55 119.66 1702.8 -1.0655 1703.04 1.3061 1703.25 1.1186 1703.46 -0.6392 1703.67 16.081
    1703.89 777 1704.1 67 1704.3 89 1704.54 15 1704.77 24.951 1704.96 24993.896 1705.16 118.91 1705.37 -0.6348 1705.58 1.0648 1705.8 1.3772 1706.05 -0.8443 1706.29 15.388
    1706.51 777 1706.7 67 1706.9 88.6 1707.1 15 1707.31 25.049 1707.55 24993.896 1707.79 119.78 1708.01 -0.6268 1708.2 0.8575 1708.41 0.934 1708.61 -0.6411 1708.82 13.39
    1709.05 783 1709.29 67 1709.51 88.6 1709.71 15 1709.92 25.134 1710.14 24993.896 1710.36 119.19 1710.57 -0.926 1710.79 0.845 1711 1.015 1711.2 -0.6828 1711.41 16.82
    1711.64 773 1711.83 67 1712.05 88.6 1712.3 15 1712.51 25.061 1712.71 24993.896 1712.92 119.69 1713.12 -0.8238 1713.33 0.9326 1713.55 0.8172 1713.79 -1.3764 1714 15.738
    1714.2 780 1714.41 67 1714.61 88.6 1714.82 15 1715.05 24.817 1715.3 24993.896 1715.54 120.28 1715.75 -0.7758 1715.95 1.446 1716.15 0.6495 1716.36 -0.8355 1716.56 15.074
    1716.78 794 1717 67 1717.2 88.6 1717.41 15 1717.61 25.116 1717.82 24993.896 1718.03 119.22 1718.26 -0.8872 1718.47 0.9124 1718.68 0.9912 1718.88 -0.6557 1719.09 16.695
    1719.3 774 1719.53 67 1719.75 88.6 1719.95 15 1720.16 24.982 1720.36 24993.896 1720.57 118.63 1720.79 -1.1977 1721.01 0.9776 1721.21 0.6802 1721.42 -0.8333 1721.62 16.046
    1721.83 785 1722.04 67 1722.25 89 1722.45 15 1722.65 24.963 1722.86 24993.896 1723.07 120.28 1723.28 -0.8271 1723.51 1.0325 1723.72 1.1087 1723.92 -0.8652 1724.13 16.226
    1724.34 781 1724.55 67 1724.8 88.6 1725.04 15 1725.26 25.031 1725.45 24993.896 1725.66 118.78 1725.88 -0.8414 1726.08 1.0241 1726.29 0.6202 1726.51 -0.8234 1726.72 16.208
    1726.92 792 1727.13 67 1727.34 88.6 1727.54 15 1727.76 25.146 1727.96 24993.896 1728.16 120.38 1728.37 -0.7 1728.58 0.8066 1728.79 1.1541 1729 -1.2336 1729.2 16.64
    1729.41 780 1729.61 67 1729.82 88.6 1730.06 15 1730.28 25 1730.47 24993.896 1730.68 119.5 1730.89 -0.8062 1731.11 0.8498 1731.32 1.0703 1731.55 -1.1563 1731.77 16.676
    1731.97 784 1732.19 67 1732.4 89 1732.6 15 1732.83 25.177 1733.07 24993.896 1733.29 119.66 1733.49 -0.9531 1733.7 1.179 1733.9 0.6531 1734.11 -0.9886 1734.32 16.19
    1734.53 783 1734.73 68 1734.94 88.6 1735.15 15 1735.35 24.725 1735.58 24993.896 1735.82 120.22 1736.06 -0.7275 1736.27 0.9608 1736.46 1.1292 1736.67 -0.6499 1736.88 15.459
    1737.08 779 1737.32 68 1737.54 88.6 1737.75 15 1737.96 25.012 1738.17 24993.896 1738.37 118.78 1738.58 -0.5821 1738.82 0.655 1739.03 1.3614 1739.23 -1.2552 1739.43 15.843
    1739.64 772 1739.85 68 1740.07 88.6 1740.29 15 1740.49 25.018 1740.69 24993.896 1740.9 120.22 1741.11 -0.7436 1741.33 0.8417 1741.56 0.7568 1741.77 -1.1322 1741.97 15.773
    1742.19 777 1742.41 68 1742.62 88.6 1742.82 15 1743.04 24.872 1743.25 24993.896 1743.47 118.56 1743.68 -1.0743 1743.88 0.7165 1744.09 1.0435 1744.33 -0.8077 1744.57 16.081
    1744.78 787 1744.98 68 1745.19 88.6 1745.41 15 1745.62 24.969 1745.82 24993.896 1746.04 119.34 1746.24 -0.9154 1746.45 0.77 1746.65 0.8128 1746.86 -0.9165 1747.07 17.018
    1747.29 772 1747.48 68 1747.68 88.6 1747.88 15 1748.09 24.994 1748.33 24993.896 1748.57 118.59 1748.78 -1.1245 1748.98 0.6286 1749.19 1.0428 1749.39 -1.1735 1749.6 16.46
    1749.83 786 1750.07 68 1750.29 88.6 1750.49 15 1750.69 24.994 1750.9 24993.896 1751.11 119.41 1751.32 -1.4654 1751.54 0.9985 1751.72 0.7183 1751.93 -1.4416 1752.14 15.494
    1752.34 780 1752.58 68 1752.82 88.6 1753.03 15 1753.23 25.122 1753.44 24993.896 1753.65 120.25 1753.85 -0.9967 1754.08 1.4083 1754.32 1.179 1754.54 -1.03 1754.72 16.37
    1754.93 778 1755.14 68 1755.34 88.6 1755.58 15 1755.82 25.055 1756.03 24993.896 1756.23 118.56 1756.44 -1.0443 1756.66 0.5887 1756.87 1.0402 1757.08 -1.1659 1757.32 15.215
    1757.54 790 1757.74 68 1757.95 88.6 1758.15 15 1758.36 25.061 1758.6 24993.896 1758.84 119.66 1759.05 -0.5707 1759.25 0.8223 1759.47 0.9274 1759.68 -0.7436 1759.88 13.51
    1760.09 777 1760.31 68 1760.51 88.6 1760.71 15 1760.92 24.994 1761.13 24993.896 1761.34 119.63 1761.55 -1.0794 1761.75 0.9018 1761.97 0.6037 1762.18 -0.8396 1762.38 16.513
    1762.6 785 1762.82 68 1763 89 1763.21 15 1763.42 25.043 1763.63 24993.896 1763.86 119.47 1764.12 -0.6828 1764.33 0.8494 1764.53 0.9399 1764.74 -0.5982 1764.96 11.87
    1765.16 786 1765.37 68 1765.58 88.6 1765.78 15 1765.99 24.994 1766.19 24993.896 1766.4 119.78 1766.62 -1.0479 1766.84 1.4251 1767.04 0.5001 1767.25 -0.7784 1767.47 14.795
    1767.69 777 1767.9 68 1768.14 88.6 1768.35 15 1768.55 25.031 1768.76 24993.896 1768.96 118.78 1769.17 -0.6934 1769.4 0.7872 1769.61 1.4083 1769.81 -0.5594 1770.01 17.632
    1770.22 769 1770.44 68 1770.66 88.6 1770.88 15 1771.08 24.982 1771.3 24993.896 1771.52 119.72 1771.72 -1.0109 1771.93 0.648 1772.16 0.6912 1772.38 -1.4336 1772.58 14.97
    1772.79 782 1773 68 1773.22 88.6 1773.44 15 1773.67 24.951 1773.88 24993.896 1774.07 119.66 1774.28 -0.7084 1774.49 0.8081 1774.69 1.0754 1774.92 -1.1197 1775.13 16.261
    1775.33 785 1775.55 68 1775.76 88.6 1775.97 15 1776.19 25.116 1776.4 24993.896 1776.61 119.34 1776.81 -1.3984 1777.02 0.4755 1777.24 0.7575 1777.45 -1.4376 1777.66 14.83
    1777.88 785 1778.08 68 1778.3 88.6 1778.5 15 1778.71 30.426 1778.94 47161.865 1779.18 161 1779.4 0.0002 1779.58 0.0002 1779.79 0.0002 1780 0.0002 1780.21 5.382
    1780.43 2100 1780.64 68 1780.84 88.6 1781.05 79 1781.27 48.889 1781.49 53588.867 1781.7 160.97 1781.94 0.0002 1782.18 0.0002 1782.4 0.0002 1782.58 0.0002 1782.79 32.097
    1782.99 2662 1783.2 68 1783.44 88.6 1783.68 68 1783.89 53.766 1784.09 54486.084 1784.3 139.75 1784.52 0.0002 1784.72 0.0002 1784.93 0.0002 1785.15 0.0002 1785.34 7.001
    1785.54 2540 1785.74 68 1785.95 88.6 1786.2 15 1786.44 44.922 1786.68 41571.045 1786.9 168.19 1787.09 0.0002 1787.3 0.0002 1787.52 0.4107 1787.73 -0.2844 1787.94 23.763
    1788.18 766 1788.4 68 1788.58 88.6 1788.79 15 1789 28.381 1789.22 27844.238 1789.44 118.78 1789.68 -0.9549 1789.89 0.8619 1790.09 0.7498 1790.3 -0.5594 1790.51 15.948
    1790.72 788 1790.94 68 1791.18 88.6 1791.4 15 1791.6 24.786 1791.8 24993.896 1792.01 119.75 1792.21 -1.0575 1792.44 0.6773 1792.68 0.596 1792.89 -0.8359 1793.09 13.609
    1793.3 791 1793.52 68 1793.72 88.6 1793.94 15 1794.18 25.024 1794.4 24993.896 1794.6 118.75 1794.8 -0.8875 1795.01 0.7608 1795.22 0.9751 1795.44 -0.5711 1795.68 16.19
    1795.9 768 1796.09 68 1796.3 88.6 1796.51 15 1796.71 24.982 1796.94 24993.896 1797.18 119.28 1797.4 -1.3951 1797.6 0.4913 1797.8 1.0699 1798.01 -1.3735 1798.22 15.074
    1798.44 778 1798.68 69 1798.91 88.6 1799.1 15 1799.31 25.079 1799.51 24993.896 1799.72 118.5 1799.94 -0.9084 1800.18 0.8656 1800.4 0.8868 1800.59 -0.8319 1800.8 16.333
    1801 783 1801.2 69 1801.44 88.6 1801.68 15 1801.91 24.689 1802.1 24993.896 1802.31 119.91 1802.51 -1.1131 1802.72 1.1706 1802.94 0.8355 1803.18 -1.0787 1803.4 13.33
    1803.61 792 1803.82 69 1804.02 88.6 1804.23 15 1804.46 25.208 1804.71 24993.896 1804.95 118.44 1805.17 -0.8762 1805.38 0.5817 1805.59 1.0413 1805.79 -1.175 1806 16.748
    1806.21 791 1806.45 69 1806.66 88.6 1806.85 15 1807.06 25.171 1807.27 24993.896 1807.49 119.09 1807.71 -0.8513 1807.95 1.0369 1808.16 1.1073 1808.36 -1.0479 1808.57 14.76
    1808.77 788 1808.98 69 1809.21 88.6 1809.45 15 1809.66 25 1809.85 24993.896 1810.06 120.34 1810.27 -0.7055 1810.49 1.5442 1810.71 1.1761 1810.95 -0.8626 1811.16 17.595
    1811.36 768 1811.58 69 1811.79 88.6 1811.99 15 1812.21 24.878 1812.45 24993.896 1812.67 119.69 1812.88 -0.7835 1813.09 1.0659 1813.29 0.5041 1813.5 -0.7659 1813.71 16.118
    1813.95 777 1814.16 69 1814.36 89 1814.55 15 1814.76 25.275 1814.97 24993.896 1815.21 118.47 1815.45 -0.4634 1815.66 0.6326 1815.86 1.5416 1816.06 -0.4697 1816.27 17.685
    1816.49 767 1816.7 69 1816.91 88.6 1817.11 15 1817.32 25.085 1817.52 24993.896 1817.73 118.44 1817.97 -0.8253 1818.23 0.7681 1818.47 0.8333 1818.72 -0.6799 1818.96 16.965
    1819.19 779 1819.38 69 1819.59 88.6 1819.8 15 1820.02 24.969 1820.22 24993.896 1820.42 119.16 1820.62 -0.8026 1820.83 0.5744 1821.05 1.0285 1821.27 -0.596 1821.49 18.658
    1821.72 767 1821.93 69 1822.13 88.6 1822.35 15 1822.56 25.085 1822.76 24993.896 1822.98 119.56 1823.23 -1.4973 1823.47 1.1069 1823.68 0.5715 1823.87 -1.0571 1824.08 13.57
    1824.3 787 1824.52 69 1824.73 88.6 1824.97 15 1825.18 24.969 1825.38 24993.896 1825.6 120.19 1825.81 -0.5286 1826.01 1.4947 1826.22 0.8623 1826.44 -0.585 1826.63 15.424
    1826.84 792 1827.04 69 1827.25 88.6 1827.46 15 1827.68 25.073 1827.88 24993.896 1828.1 119.44 1828.32 -1.4742 1828.52 0.6718 1828.73 0.6 1828.97 -0.6429 1829.22 12.671
    1829.42 787 1829.62 69 1829.83 88.6 1830.05 15 1830.27 25.085 1830.48 24993.896 1830.72 119.25 1830.93 -0.8461 1831.13 0.588 1831.33 0.7857 1831.53 -0.8007 1831.73 17.36
    1831.98 767 1832.21 69 1832.43 88.6 1832.63 15 1832.85 24.982 1833.06 24993.896 1833.26 118.44 1833.47 -1.0655 1833.68 0.7799 1833.88 0.4931 1834.09 -0.7396 1834.29 14.098
    1834.5 792 1834.72 69 1834.94 89 1835.13 15 1835.34 25.146 1835.55 24993.896 1835.77 119.28 1835.99 -0.7974 1836.21 0.8084 1836.43 1.0472 1836.63 -0.5902 1836.85 18.405
    1837.06 769 1837.26 69 1837.47 88.6 1837.68 15 1837.88 25.073 1838.09 24993.896 1838.29 118.41 1838.5 -0.473 1838.73 0.562 1838.98 0.7843 1839.19 -0.7799 1839.39 16.928
    1839.59 785 1839.8 70 1840.02 88.6 1840.23 15 1840.45 24.994 1840.66 24993.896 1840.88 120.06 1841.09 -0.7905 1841.29 0.7169 1841.5 0.7282 1841.74 -0.7564 1841.99 14.272
    1842.23 780 1842.45 70 1842.64 88.6 1842.85 15 1843.06 25.201 1843.26 24993.896 1843.49 119.25 1843.74 -0.6989 1843.97 1.4412 1844.18 0.6 1844.38 -0.9296 1844.6 15.215
    1844.81 790 1845.01 70 1845.23 88.6 1845.45 15 1845.66 25.043 1845.87 24993.896 1846.08 119.16 1846.28 -1.0542 1846.49 0.5297 1846.73 0.7088 1846.94 -0.8267 1847.14 16.928
    1847.34 777 1847.55 70 1847.77 88.6 1847.98 15 1848.19 25.043 1848.39 24993.896 1848.6 119.19 1848.82 -0.707 1849.02 0.7615 1849.23 1.0498 1849.45 -0.7198 1849.64 16.406
    1849.85 762 1850.06 70 1850.26 88.6 1850.48 15 1850.7 25 1850.92 24993.896 1851.12 119.88 1851.33 -0.7564 1851.55 0.7938 1851.77 1.0575 1851.98 -1.0333 1852.19 16.766
    1852.39 778 1852.6 70 1852.8 88.6 1853.01 15 1853.24 24.835 1853.49 24993.896 1853.72 119.69 1853.94 -0.8286 1854.14 1 1854.35 0.3972 1854.57 -0.559 1854.78 17.433
    1854.98 792 1855.2 70 1855.41 89 1855.62 15 1855.82 24.957 1856.03 24993.896 1856.24 119.59 1856.48 -1.1384 1856.69 1.0673 1856.89 0.7231 1857.1 -1.052 1857.31 13.33
    1857.51 789 1857.74 70 1857.99 88.6 1858.25 15 1858.47 25.061 1858.68 24993.896 1858.87 118.44 1859.08 -0.8154 1859.29 0.7623 1859.49 1.0933 1859.73 -0.3876 1859.95 18.207
    1860.14 765 1860.35 70 1860.56 89 1860.76 15 1860.99 25 1861.25 24993.896 1861.46 119.66 1861.68 -1.5694 1861.88 0.3126 1862.1 0.5568 1862.31 -1.5599 1862.51 12.891
    1862.73 787 1862.95 70 1863.13 88.6 1863.34 15 1863.55 24.774 1863.77 24993.896 1864.02 120.28 1864.25 -0.5854 1864.46 1.5368 1864.66 0.6634 1864.87 -0.5228 1865.07 16.171
    1865.28 793 1865.51 70 1865.76 88.6 1866 15 1866.21 25.079 1866.41 24993.896 1866.63 119.22 1866.85 -0.7469 1867.06 1.0575 1867.26 0.4931 1867.5 -1.0831 1867.72 17
    1867.93 778 1868.13 70 1868.34 89 1868.55 15 1868.76 24.725 1868.98 24993.896 1869.2 120.06 1869.39 -0.7751 1869.6 0.9205 1869.81 1.5647 1870.01 -0.5722 1870.25 14.412
    1870.46 785 1870.66 70 1870.88 89 1871.09 15 1871.3 25.043 1871.51 24993.896 1871.75 119.28 1871.96 -1.0684 1872.16 0.5645 1872.38 0.941 1872.59 -1.6178 1872.79 12.91
    1873 780 1873.22 70 1873.43 89 1873.63 15 1873.84 25.085 1874.05 24993.896 1874.28 119.25 1874.53 -1.0571 1874.74 1.0285 1874.94 0.5136 1875.15 -0.7564 1875.35 15.285
    1875.56 787 1875.78 70 1876 88.6 1876.2 15 1876.4 25.012 1876.61 31976.318 1876.81 137.72 1877.04 -0.3583 1877.28 2.8468 1877.49 0.0002 1877.69 0.0002 1877.91 0
    1878.12 1013 1878.32 70 1878.54 88.6 1878.76 15 1878.96 30.292 1879.18 29913.33 1879.39 119.31 1879.59 -1.0534 1879.8 0.8663 1880.02 0.6257 1880.21 -0.6755 1880.42 17.145
    1880.63 786 1880.85 70 1881.06 88.6 1881.3 15 1881.51 25.049 1881.71 24993.896 1881.92 116.84 1882.12 0.0002 1882.33 0.0002 1882.56 0.0002 1882.77 0.0002 1882.97 0
    1883.17 1518 1883.38 71 1883.6 88.6 1883.82 15 1884.04 30.829 1884.23 31048.584 1884.44 119.28 1884.65 -0.5396 1884.85 0.6246 1885.08 5.1243 1885.29 0.0002 1885.49 0
    1885.71 966 1885.93 71 1886.13 88.6 1886.34 37 1886.58 54.718 1886.8 49066.162 1886.99 164.97 1887.2 0.0002 1887.41 0.0002 1887.61 0.1738 1887.83 -0.8967 1888.03 6.906
    1888.23 767 1888.44 71 1888.64 88.6 1888.85 15 1889.09 28.735 1889.31 28125 1889.5 119.56 1889.71 -0.8472 1889.91 0.8516 1890.12 0.7656 1890.35 -0.7696 1890.59 16.118
    1890.81 782 1891 71 1891.2 89 1891.41 15 1891.63 25.079 1891.84 24993.896 1892.06 118.31 1892.27 -0.4957 1892.49 0.4067 1892.7 1.1702 1892.91 -0.8542 1893.13 16.928
    1893.34 784 1893.56 71 1893.77 88.6 1893.99 15 1894.21 24.768 1894.42 24993.896 1894.62 119.41 1894.86 -0.5352 1895.08 0.6059 1895.3 0.9754 1895.5 -0.626 1895.7 9.584
    1895.91 780 1896.12 71 1896.34 88.6 1896.53 15 1896.74 25 1896.96 24993.896 1897.17 120.22 1897.39 -0.6685 1897.61 1.3885 1897.82 1.0395 1898.02 -0.4986 1898.22 17.468
    1898.42 795 1898.64 71 1898.86 89 1899.06 15 1899.26 25.171 1899.47 24993.896 1899.68 119.13 1899.89 -0.819 1900.1 0.5034 1900.3 0.7425 1900.5 -0.6828 1900.71 18.568
    1900.92 779 1901.14 71 1901.35 89 1901.55 15 1901.76 24.939 1901.96 24993.896 1902.17 118.34 1902.41 -0.6861 1902.62 0.6359 1902.81 1.5258 1903.01 -0.3704 1903.22 17.775
    1903.43 765 1903.67 71 1903.91 88.6 1904.11 15 1904.31 24.988 1904.52 24993.896 1904.72 119.56 1904.92 -0.8176 1905.16 0.4913 1905.41 0.9952 1905.63 -0.5261 1905.82 17.307
    1906.03 789 1906.23 71 1906.44 89 1906.67 15 1906.91 25.012 1907.15 24993.896 1907.37 118.88 1907.57 -1.3519 1907.78 0.6242 1907.98 1.435 1908.19 -1.3054 1908.41 16.801
    1908.63 776 1908.82 71 1909.03 88.6 1909.24 15 1909.46 24.933 1909.68 24993.896 1909.91 119.16 1910.16 -0.8798 1910.38 1.3314 1910.6 1.3054 1910.79 -0.9132 1911 15.179
    1911.2 780 1911.41 71 1911.61 88.6 1911.81 15 1912.02 25.122 1912.22 24993.896 1912.43 119.81 1912.65 -1.2523 1912.87 0.7202 1913.07 0.9216 1913.29 -1.3259 1913.51 16.171
    1913.72 777 1913.92 71 1914.17 88.6 1914.42 15 1914.63 25 1914.83 24993.896 1915.04 119.94 1915.26 -1.2988 1915.47 0.6191 1915.68 1.294 1915.93 -0.937 1916.17 13.789
    1916.38 780 1916.58 71 1916.78 88.6 1916.99 15 1917.21 24.969 1917.42 24993.896 1917.63 119.94 1917.83 -0.4862 1918.04 0.6228 1918.26 0.2324 1918.47 -0.2741 1918.68 19.318
    1918.93 789 1919.17 71 1919.39 88.6 1919.59 15 1919.8 25.293 1920 24993.896 1920.21 119.94 1920.43 -0.9901 1920.67 1.0314 1920.88 0.5777 1921.08 -0.4862 1921.28 17.433
    1921.49 792 1921.7 72 1921.92 88.6 1922.13 15 1922.33 25.317 1922.54 24993.896 1922.76 119.31 1922.97 -1.0699 1923.18 0.6674 1923.42 1.0959 1923.64 -0.6876 1923.86 15.005
    1924.06 781 1924.26 72 1924.47 88.6 1924.68 15 1924.93 25.171 1925.16 24993.896 1925.37 119.41 1925.56 -0.9597 1925.77 0.562 1925.98 0.8194 1926.18 -0.707 1926.43 18.929
    1926.68 766 1926.93 72 1927.17 88.6 1927.39 15 1927.58 24.615 1927.79 24993.896 1928 120.06 1928.2 -1.5643 1928.44 0.8403 1928.66 0.9805 1928.85 -0.5037 1929.06 13.887
    1929.26 767 1929.48 72 1929.69 88.6 1929.9 15 1930.09 25.146 1930.3 24993.896 1930.51 119.22 1930.73 -1.0076 1930.94 1.4303 1931.15 0.5905 1931.35 -0.9388 1931.57 13.631
    1931.79 791 1931.99 72 1932.2 88.6 1932.45 15 1932.69 25.092 1932.9 24993.896 1933.09 118.34 1933.3 -0.4012 1933.51 0.5989 1933.72 1.1567 1933.94 -0.6718 1934.15 11.951
    1934.35 786 1934.57 72 1934.78 88.6 1934.98 15 1935.19 24.969 1935.4 24993.896 1935.6 118.47 1935.81 -1.1036 1936.01 0.722 1936.22 0.548 1936.44 -0.7832 1936.66 16.1
    1936.86 782 1937.06 72 1937.27 88.6 1937.48 15 1937.69 25.031 1937.9 24993.896 1938.1 119.59 1938.31 -0.7993 1938.51 1.0596 1938.72 1.075 1938.95 -0.7755 1939.18 19.794
    1939.4 779 1939.6 72 1939.81 88.6 1940.01 15 1940.21 24.872 1940.44 24993.896 1940.66 119.94 1940.85 -0.9194 1941.06 1.1058 1941.27 0.5693 1941.49 -0.7883 1941.7 13.11
    1941.94 792 1942.15 72 1942.35 88.6 1942.57 15 1942.78 25.104 1942.97 24993.896 1943.2 119.31 1943.44 -0.559 1943.68 0.4898 1943.9 1.0904 1944.1 -1.1457 1944.32 17.126
    1944.54 783 1944.75 72 1944.95 88.6 1945.19 15 1945.4 25.104 1945.61 24993.896 1945.81 119.5 1946.02 -1.5727 1946.21 0.3419 1946.44 0.5235 1946.65 -1.5295 1946.84 13.71
    1947.05 785 1947.25 72 1947.45 89 1947.67 15 1947.89 24.847 1948.08 24993.896 1948.29 119.25 1948.5 -1.056 1948.69 0.6242 1948.94 0.7733 1949.16 -0.7875 1949.36 8.723
    1949.56 787 1949.77 72 1949.97 88.6 1950.19 15 1950.41 25.055 1950.61 24993.896 1950.81 119.94 1951.01 -0.8623 1951.23 1.4768 1951.44 0.3638 1951.64 -0.8758 1951.85 13.47
    1952.07 796 1952.28 72 1952.47 88.6 1952.69 15 1952.95 24.817 1953.19 24993.896 1953.45 120.34 1953.69 -0.7176 1953.95 0.9252 1954.19 1.1054 1954.41 -1.1464 1954.61 14.377
    1954.82 783 1955.03 72 1955.24 89 1955.47 15 1955.71 24.677 1955.96 24993.896 1956.19 119.88 1956.42 -0.5949 1956.61 1.5134 1956.83 0.3616 1957.03 -0.6279 1957.24 16.261
    1957.45 791 1957.71 72 1957.95 88.6 1958.17 15 1958.37 24.835 1958.57 24993.896 1958.77 119.88 1958.99 -0.7564 1959.2 1.1124 1959.42 0.5305 1959.61 -0.7502 1959.83 9.473
    1960.03 787 1960.24 72 1960.45 89 1960.67 15 1960.85 24.957 1961.05 24993.896 1961.27 119.88 1961.49 -0.6477 1961.71 1.0846 1961.95 0.8183 1962.19 -0.3756 1962.42 22.412
    1962.61 766 1962.81 72 1963.03 88.6 1963.23 15 1963.45 25.061 1963.67 24993.896 1963.87 118.25 1964.08 -1.1149 1964.27 0.4979 1964.49 1.1117 1964.71 -0.8066 1964.95 14.412
    1965.17 782 1965.35 72 1965.57 88.6 1965.77 15 1965.97 24.963 1966.19 24993.896 1966.41 119.22 1966.61 -0.8212 1966.81 0.5828 1967.03 0.8183 1967.23 -0.9868 1967.45 18.839
    1967.71 765 1967.95 72 1968.16 89 1968.35 15 1968.57 24.994 1968.77 24993.896 1968.97 119.5 1969.2 -1.0926 1969.41 0.5568 1969.61 0.9523 1969.83 -1.4801 1970.03 12.77
    1970.25 784 1970.45 72 1970.69 88.6 1970.92 15 1971.11 24.719 1971.31 24993.896 1971.53 119.34 1971.75 -0.689 1971.96 1.093 1972.2 0.7183 1972.42 -0.6315 1972.61 15.179
    1972.83 793 1973.03 72 1973.25 88.6 1973.46 15 1973.69 25.055 1973.92 24993.896 1974.11 119.19 1974.31 -0.974 1974.53 0.7711 1974.73 1.0985 1974.95 -0.3737 1975.16 20.111
    1975.36 766 1975.57 72 1975.77 88.6 1975.99 15 1976.21 25.122 1976.43 24993.896 1976.65 118.22 1976.85 -1.1776 1977.04 0.5495 1977.25 1.1098 1977.45 -1.1054 1977.66 17.378
    1977.85 765 1978.06 72 1978.27 88.6 1978.48 15 1978.69 24.988 1978.92 24993.896 1979.09 118.31 1979.3 -1.1486 1979.49 0.5363 1979.71 1.1142 1979.95 -0.7941 1980.19 15.041
    1980.4 782 1980.59 72 1980.8 88.6 1981 15 1981.21 24.963 1981.44 24993.896 1981.66 119.81 1981.87 -1.1062 1982.08 0.7762 1982.28 0.7187 1982.49 -0.5301 1982.71 10.783
    1982.96 793 1983.2 73 1983.45 88.6 1983.66 15 1983.85 24.982 1984.07 24993.896 1984.28 118.31 1984.51 -0.5931 1984.73 0.5217 1984.95 0.5957 1985.16 -1.1201 1985.35 16.478
    1985.57 783 1985.77 73 1985.99 88.6 1986.2 15 1986.45 24.664 1986.69 24993.896 1986.92 120.06 1987.11 -0.611 1987.31 0.8044 1987.53 0.7725 1987.75 -0.8187 1987.97 13.451
    1988.2 794 1988.42 73 1988.61 88.6 1988.81 15 1989.03 25.134 1989.23 24993.896 1989.45 119.19 1989.67 -0.677 1989.87 0.5788 1990.07 0.8458 1990.27 -0.7257 1990.48 17.253
    1990.71 780 1990.94 73 1991.16 89 1991.35 15 1991.56 24.969 1991.78 24993.896 1991.99 119.78 1992.2 -0.7854 1992.41 1.0758 1992.61 0.5458 1992.83 -0.8476 1993.03 13.11
    1993.24 787 1993.45 73 1993.68 88.6 1993.86 15 1994.07 24.982 1994.28 24993.896 1994.5 120.06 1994.71 -0.5107 1994.95 0.5686 1995.16 0.8044 1995.35 -0.7172 1995.56 18.315
    1995.79 768 1995.99 73 1996.21 88.6 1996.47 15 1996.71 25.256 1996.95 24993.896 1997.16 119.19 1997.36 -0.8004 1997.57 0.8234 1997.77 0.7982 1997.99 -0.8304 1998.19 18.784
    1998.43 767 1998.64 73 1998.84 88.6 1999.04 15 1999.25 25.049 1999.47 24993.896 1999.69 118.19 1999.91 -1.1117 2000.11 0.6898 2000.32 0.5858 2000.52 -1.142 2000.73 14.9
    2000.95 789 2001.15 73 2001.36 88.6 2001.56 15 2001.78 24.982 2001.99 24993.896 2002.2 119.31 2002.41 -1.0783 2002.61 0.5682 2002.83 0.6235 2003.03 -1.5156 2003.24 12.35
    2003.45 781 2003.66 73 2003.86 88.6 2004.07 15 2004.27 25.043 2004.48 24993.896 2004.7 119.94 2004.91 -1.557 2005.11 0.5715 2005.3 0.6422 2005.51 -1.5083 2005.72 12.891
    2005.96 789 2006.2 73 2006.41 88.6 2006.61 15 2006.83 25.055 2007.05 24993.896 2007.24 120.34 2007.45 -0.6015 2007.66 1.5273 2007.86 0.3737 2008.07 -0.6085 2008.28 15.808
    2008.48 792 2008.69 73 2008.91 88.6 2009.1 15 2009.31 25.116 2009.52 24993.896 2009.72 120.13 2009.95 -3.2881 2010.19 0.0002 2010.43 0.0002 2010.61 0.0002 2010.82 6.5
    2011.03 1800 2011.25 73 2011.45 88.6 2011.65 15 2011.85 44.299 2012.06 41766.357 2012.28 152.69 2012.51 0.0002 2012.71 0.0002 2012.94 0.0002 2013.16 0.0002 2013.36 13.251
    2013.58 2188 2013.78 73 2014 88.6 2014.2 15 2014.41 45.947 2014.61 43994.141 2014.84 156.38 2015.04 0.0002 2015.24 0.0002 2015.45 0.0002 2015.66 0.0002 2015.86 0
    2016.07 1834 2016.27 73 2016.48 88.6 2016.7 15 2016.9 31.006 2017.1 31604.004 2017.31 121.16 2017.51 -0.1456 2017.71 0.6744 2017.93 0.5008 2018.14 -0.7875 2018.34 16.063
    2018.55 784 2018.77 73 2018.97 88.6 2019.19 15 2019.41 26.447 2019.61 25988.77 2019.83 119.13 2020.04 -0.8861 2020.24 0.5382 2020.45 0.752 2020.66 -0.9036 2020.85 15.984
    2021.05 778 2021.26 73 2021.47 88.6 2021.69 15 2021.91 24.799 2022.1 24993.896 2022.31 120 2022.51 -1.1021 2022.72 0.8941 2022.94 0.7447 2023.16 -0.6403 2023.36 10.034
    2023.58 787 2023.79 73 2024 88.6 2024.22 15 2024.44 25.171 2024.66 24993.896 2024.86 119.16 2025.08 -0.7608 2025.29 0.5052 2025.49 1.1186 2025.7 -0.5953 2025.91 17.613
    2026.11 779 2026.32 73 2026.52 88.6 2026.73 15 2026.95 24.896 2027.16 24993.896 2027.36 118.31 2027.57 -0.5689 2027.77 0.6663 2027.98 1.0867 2028.2 -0.5195 2028.4 19
    2028.6 768 2028.8 74 2029.01 88.6 2029.22 15 2029.45 25.055 2029.66 24993.896 2029.85 118.25 2030.06 -0.3836 2030.25 0.8161 2030.46 1.4453 2030.7 -1.0252 2030.92 16.766
    2031.14 783 2031.34 74 2031.54 89 2031.75 15 2031.95 25.085 2032.15 24993.896 2032.35 118.25 2032.56 -1.0509 2032.76 0.6759 2032.97 0.5795 2033.2 -0.9879 2033.41 16.063
    2033.6 790 2033.81 74 2034.02 88.6 2034.22 15 2034.45 25.262 2034.66 24993.896 2034.86 119.19 2035.08 -0.715 2035.29 0.5528 2035.49 0.8114 2035.71 -0.7531 2035.95 16.946
    2036.16 766 2036.35 74 2036.56 88.6 2036.77 15 2036.99 25 2037.19 24993.896 2037.41 118.19 2037.61 -0.577 2037.83 0.6762 2038.05 0.5352 2038.26 -0.8216 2038.46 16.785
    2038.71 783 2038.96 74 2039.2 88.6 2039.41 15 2039.6 24.902 2039.81 24993.896 2040.01 119.97 2040.22 -0.6715 2040.44 1.019 2040.66 0.5345 2040.86 -0.8103 2041.08 13.631
    2041.29 795 2041.49 74 2041.7 89 2041.92 15 2042.11 25.049 2042.32 24993.896 2042.53 120.38 2042.73 -0.5136 2042.95 1.0549 2043.16 0.6656 2043.36 -0.4964 2043.58 17.577
    2043.79 778 2043.99 74 2044.2 88.6 2044.42 15 2044.61 25.183 2044.82 24993.896 2045.03 119.28 2045.23 -0.7656 2045.45 0.7755 2045.66 0.7839 2045.85 -0.7575 2046.06 18.262
    2046.26 778 2046.47 74 2046.7 88.6 2046.91 15 2047.11 25.055 2047.33 24993.896 2047.54 118.19 2047.74 -0.3532 2047.96 0.5301 2048.18 1.0714 2048.38 -1.0805 2048.58 15.948
    2048.79 764 2048.99 74 2049.22 88.6 2049.48 15 2049.71 24.725 2049.93 24993.896 2050.13 120.09 2050.33 -1.078 2050.54 1.2036 2050.75 0.6993 2050.97 -0.5473 2051.2 8.685
    2051.41 788 2051.6 74 2051.81 88.6 2052.01 15 2052.22 24.896 2052.46 24993.896 2052.68 120.34 2052.87 -0.6605 2053.08 1.5328 2053.29 0.5978 2053.49 -0.6253 2053.71 17.722
    2053.93 777 2054.13 74 2054.33 88.6 2054.54 15 2054.75 25.165 2054.97 24993.896 2055.21 118.38 2055.43 -0.3679 2055.62 0.8414 2055.83 1.5064 2056.05 -0.6011 2056.26 17.558
    2056.47 764 2056.72 74 2056.96 88.6 2057.18 15 2057.37 25.049 2057.58 24993.896 2057.79 119.5 2057.99 -1.5445 2058.21 0.6048 2058.43 0.5491 2058.63 -1.0893 2058.83 12.79
    2059.04 779 2059.25 74 2059.47 89 2059.73 15 2059.96 25.214 2060.18 24993.896 2060.37 119.19 2060.58 -0.5363 2060.79 1.0692 2060.99 1.0688 2061.21 -0.7399 2061.43 17.865
    2061.63 777 2061.83 74 2062.04 88.6 2062.25 15 2062.47 24.908 2062.73 24993.896 2062.96 119.69 2063.18 -0.8048 2063.37 0.7839 2063.58 0.8114 2063.79 -0.8095 2063.99 15.32
    2064.21 785 2064.43 74 2064.63 88.6 2064.83 15 2065.04 25.055 2065.25 24993.896 2065.48 119.5 2065.7 -1.5233 2065.9 0.6737 2066.1 0.4883 2066.31 -1.1032 2066.52 12.531
    2066.74 787 2066.98 74 2067.19 88.6 2067.39 15 2067.61 24.908 2067.82 24993.896 2068.02 120.25 2068.24 -0.5711 2068.48 0.5048 2068.68 0.9967 2068.87 -0.5491 2069.07 16.621
    2069.28 793 2069.49 75 2069.71 88.6 2069.92 15 2070.12 25.226 2070.33 24993.896 2070.55 119.13 2070.76 -0.7864 2070.97 0.7557 2071.2 1.4808 2071.41 -0.3279 2071.61 17.198
    2071.82 766 2072.03 75 2072.24 88.6 2072.47 15 2072.69 25 2072.89 24993.896 2073.09 118.13 2073.29 -1.2142 2073.49 0.4986 2073.73 0.7227 2073.95 -1.0556 2074.16 12.691
    2074.37 784 2074.57 75 2074.78 88.6 2074.99 15 2075.23 24.603 2075.44 24993.896 2075.64 119.91 2075.84 -1.1248 2076.05 1.1893 2076.27 0.6898 2076.49 -0.5583 2076.73 12.711
    2076.95 795 2077.15 75 2077.35 88.6 2077.56 15 2077.76 25.024 2077.99 24993.896 2078.23 119.13 2078.44 -0.6942 2078.64 0.5938 2078.84 0.7663 2079.05 -0.7414 2079.27 19
    2079.47 767 2079.69 75 2079.89 88.6 2080.09 15 2080.3 24.969 2080.52 24993.896 2080.74 118.25 2080.98 -1.0446 2081.19 0.7008 2081.39 1.0494 2081.6 -1.0747 2081.8 15.424
    2082.01 784 2082.23 75 2082.45 88.6 2082.65 15 2082.85 24.957 2083.06 24993.896 2083.27 119.69 2083.49 -1.5742 2083.73 0.9776 2083.94 1.1168 2084.14 -0.4876 2084.35 17.577
    2084.55 788 2084.76 75 2084.98 88.6 2085.2 15 2085.4 24.841 2085.6 24993.896 2085.81 119.84 2086.02 -0.5678 2086.24 1.0435 2086.48 0.3983 2086.69 -0.536 2086.89 16.046
    2087.1 1015 2087.3 75 2087.51 88.6 2087.74 15 2087.98 31.635 2088.19 31274.414 2088.39 118.84 2088.59 -0.6096 2088.8 0.5858 2089.01 0.93 2089.23 -0.7828 2089.44 17.343
    2089.64 770 2089.83 75 2090.04 88.6 2090.25 15 2090.48 25.537 2090.7 25329.59 2090.9 118.56 2091.11 -0.5751 2091.33 2.7999 2091.55 0.0002 2091.75 0.0002 2091.97 0
    2092.19 1161 2092.39 75 2092.6 88.6 2092.82 15 2093.02 30.603 2093.25 30157.471 2093.46 119.44 2093.65 0.0002 2093.85 0.0002 2094.06 0.0002 2094.27 0.0002 2094.5 0
    2094.74 1625 2094.96 75 2095.15 88.6 2095.36 15 2095.58 31.342 2095.79 31201.172 2095.99 121.03 2096.21 -0.514 2096.41 0.7619 2096.63 0.6242 2096.85 -0.7429 2097.05 17.865
    2097.26 772 2097.49 75 2097.71 88.6 2097.91 15 2098.11 25.385 2098.31 25268.555 2098.51 119.41 2098.75 -0.5649 2098.96 0.6026 2099.15 1.0479 2099.36 -0.4107 2099.58 18.857
    2099.8 766 2100.01 75 2100.22 88.6 2100.42 15 2100.63 25.024 2100.83 24993.896 2101.04 118.19 2101.27 -1.038 2101.51 0.4422 2101.73 0.8806 2101.93 -1.1212 2102.14 14.307
    2102.34 782 2102.55 75 2102.77 88.6 2103.01 15 2103.22 24.567 2103.42 24993.896 2103.63 119.97 2103.83 -0.6301 2104.04 0.607 2104.27 0.5627 2104.49 -0.5645 2104.69 12.61
    2104.91 797 2105.12 75 2105.32 88.6 2105.53 15 2105.74 24.719 2105.94 24993.896 2106.16 120.31 2106.37 -0.5129 2106.58 0.8776 2106.8 1.0194 2107.02 -0.6524 2107.24 18.964
    2107.44 780 2107.66 75 2107.88 88.6 2108.08 15 2108.29 25.055 2108.52 24993.896 2108.74 118.19 2108.94 -1.0509 2109.15 0.5759 2109.35 1.1355 2109.56 -0.8352 2109.79 15.808
    2110.03 782 2110.24 75 2110.44 88.6 2110.66 15 2110.88 24.695 2111.09 24993.896 2111.29 120.06 2111.54 -0.8 2111.78 1.2138 2112.02 1.0944 2112.24 -0.5726 2112.43 17.558
    2112.64 779 2112.84 75 2113.05 88.6 2113.27 15 2113.49 25.092 2113.69 24993.896 2113.91 118.34 2114.13 -0.3389 2114.35 0.522 2114.55 1.5676 2114.77 -0.4092 2114.99 16.46
    2115.19 763 2115.41 75 2115.63 88.6 2115.83 15 2116.04 24.969 2116.28 24993.896 2116.5 119.59 2116.72 -1.5691 2116.91 0.2855 2117.12 0.6088 2117.33 -1.2017 2117.55 11.99
    2117.79 789 2118.04 76 2118.28 89 2118.49 15 2118.68 25.208 2118.89 24993.896 2119.1 119.22 2119.3 -0.6938 2119.53 0.566 2119.74 0.7832 2119.94 -0.6118 2120.15 18.532
    2120.35 778 2120.56 76 2120.79 88.6 2121.03 15 2121.24 25.14 2121.44 24993.896 2121.66 119.69 2121.87 -0.8223 2122.07 0.5572 2122.29 0.5667 2122.51 -0.6088 2122.71 13.47
    2122.92 785 2123.13 76 2123.35 88.6 2123.57 15 2123.79 25.226 2124 24993.896 2124.2 119.91 2124.41 -1.1201 2124.62 0.8403 2124.82 0.4913 2125.06 -0.5773 2125.28 8.424
    2125.49 789 2125.71 76 2125.91 88.6 2126.12 15 2126.33 24.939 2126.54 24993.896 2126.74 120.25 2126.95 -0.5949 2127.15 1.2515 2127.36 0.3587 2127.6 -0.5524 2127.84 19.476
    2128.05 765 2128.25 76 2128.45 89 2128.66 15 2128.87 25.049 2129.09 24993.896 2129.3 118.41 2129.5 -0.3166 2129.7 0.6696 2129.9 1.0369 2130.11 -0.4719 2130.35 8.012
    2130.58 784 2130.8 76 2131 88.6 2131.21 15 2131.43 25.079 2131.63 24993.896 2131.84 119.81 2132.05 -1.0366 2132.25 0.4528 2132.45 0.7333 2132.66 -0.8315 2132.87 14.342
    2133.09 782 2133.3 76 2133.5 88.6 2133.71 15 2133.91 24.927 2134.12 24993.896 2134.35 119.94 2134.59 -0.5627 2134.8 0.5927 2134.99 1.3977 2135.2 -0.284 2135.41 17.36
    2135.63 778 2135.83 76 2136.03 88.6 2136.23 15 2136.44 24.908 2136.66 24993.896 2136.87 119.97 2137.09 -0.6191 2137.31 1.208 2137.52 0.4865 2137.73 -0.4298 2137.94 15.634
    2138.16 778 2138.37 76 2138.61 88.6 2138.82 15 2139.02 24.768 2139.24 24993.896 2139.45 119.84 2139.65 -0.5693 2139.87 0.6469 2140.11 0.6901 2140.31 -0.6129 2140.51 18.172
    2140.72 764 2140.92 76 2141.13 88.6 2141.35 15 2141.57 25.024 2141.77 24993.896 2141.99 119.06 2142.21 -0.6597 2142.42 0.4792 2142.62 1.0322 2142.87 -0.4612 2143.11 16.891
    2143.32 765 2143.51 76 2143.72 89 2143.92 15 2144.13 25.055 2144.35 24993.896 2144.57 118.13 2144.77 -1.0014 2144.99 0.6026 2145.21 0.7832 2145.41 -0.9014 2145.62 16.316
    2145.85 784 2146.07 76 2146.27 88.6 2146.48 15 2146.68 24.695 2146.89 24993.896 2147.13 119.84 2147.38 -0.811 2147.62 0.8927 2147.84 1.0695 2148.05 -0.5748 2148.27 18.585
    2148.48 779 2148.69 76 2148.91 88.6 2149.14 15 2149.37 24.969 2149.59 24993.896 2149.8 120.19 2150.02 -0.6334 2150.23 1.2409 2150.43 0.4506 2150.64 -0.4309 2150.88 18.495
    2151.12 767 2151.33 76 2151.53 88.6 2151.74 15 2151.96 25.104 2152.17 24993.896 2152.38 118.13 2152.63 -0.7279 2152.89 0.4971 2153.11 0.5041 2153.32 -0.9187 2153.51 12.35
    2153.72 789 2153.92 76 2154.13 88.6 2154.37 15 2154.59 24.841 2154.8 24993.896 2155.02 120.31 2155.23 -0.6238 2155.44 1.2732 2155.66 0.6242 2155.88 -0.3613 2156.11 18.045
    2156.31 783 2156.51 76 2156.72 88.6 2156.93 15 2157.14 24.768 2157.38 24993.896 2157.63 119.91 2157.88 -0.4894 2158.12 0.5733 2158.33 0.8117 2158.53 -0.6022 2158.74 20.27
    2158.96 766 2159.16 76 2159.37 88.6 2159.59 15 2159.8 25.031 2160.02 24993.896 2160.24 118.25 2160.45 -1.0333 2160.65 0.5876 2160.87 0.5678 2161.09 -0.6242 2161.29 16.28
    2161.51 786 2161.71 76 2161.92 88.6 2162.13 15 2162.37 24.658 2162.59 24993.896 2162.8 118.06 2163.01 -0.5162 2163.21 0.6037 2163.42 0.7275 2163.65 -0.637 2163.9 12.99
    2164.13 765 2164.35 76 2164.55 89 2164.76 15 2164.96 24.982 2165.17 24993.896 2165.39 119.44 2165.61 -1.4804 2165.8 0.3814 2166.01 0.4931 2166.21 -1.1962 2166.42 12.91
    2166.65 790 2166.89 77 2167.1 89 2167.3 15 2167.52 25.018 2167.73 24993.896 2167.93 120.47 2168.14 -0.8623 2168.36 1.193 2168.57 0.4173 2168.79 -0.4261 2169 17.722
    2169.2 779 2169.41 77 2169.65 89 2169.89 15 2170.1 25.116 2170.3 24993.896 2170.52 118.19 2170.74 -1.0703 2170.95 0.5696 2171.15 2.871 2171.38 0.0002 2171.6 7.001
    2171.8 1870 2171.99 77 2172.2 88.6 2172.41 15 2172.65 71.051 2172.89 66107.178 2173.1 151.81 2173.3 0.0002 2173.51 0.0002 2173.71 0.0002 2173.92 0.0002 2174.14 33.447
    2174.36 2649 2174.56 77 2174.76 88.6 2174.97 15 2175.18 38.654 2175.39 37725.83 2175.6 162.19 2175.8 0.0002 2176.02 0.0002 2176.23 0.0002 2176.44 0.0002 2176.65 1.996
    2176.89 2627 2177.11 77 2177.31 88.6 2177.51 49 2177.72 52.393 2177.93 53961.182 2178.14 139.53 2178.35 0.0002 2178.54 0.0002 2178.75 0.0002 2178.96 0.0002 2179.18 0
    2179.38 1323 2179.6 77 2179.8 88.6 2180 15 2180.21 31.732 2180.42 30529.785 2180.64 118.81 2180.85 -0.5019 2181.05 0.5982 2181.24 0.54 2181.45 -0.4865 2181.65 17.09
    2181.9 774 2182.14 77 2182.35 88.6 2182.54 15 2182.75 24.774 2182.96 24993.896 2183.17 119.97 2183.39 -0.5803 2183.61 0.5184 2183.81 0.7619 2184.01 -0.4821 2184.22 9.584
    2184.43 787 2184.65 77 2184.9 89 2185.14 15 2185.35 25.055 2185.55 24993.896 2185.75 119.19 2185.96 -0.759 2186.18 0.5601 2186.39 1.4669 2186.6 -0.4162 2186.8 18.64
    2187.01 767 2187.21 77 2187.42 89 2187.64 15 2187.86 25.122 2188.06 24993.896 2188.27 118.22 2188.49 -1.0542 2188.7 0.5187 2188.9 1.1424 2189.14 -0.7399 2189.36 14.656
    2189.57 782 2189.77 77 2189.98 88.6 2190.19 15 2190.4 25.11 2190.65 24993.896 2190.9 119.69 2191.13 -0.5239 2191.34 0.5722 2191.53 0.5612 2191.74 -0.5557 2191.95 14.97
    2192.15 785 2192.39 77 2192.6 88.6 2192.8 15 2193.01 25.061 2193.21 24993.896 2193.42 119.31 2193.64 -1.5119 2193.86 0.4276 2194.06 0.5217 2194.26 -1.0794 2194.47 12.21
    2194.68 789 2194.89 77 2195.1 89 2195.3 15 2195.52 24.835 2195.74 24993.896 2195.95 119.91 2196.16 -0.7293 2196.4 1.0889 2196.64 1.0168 2196.85 -0.3668 2197.05 16.928
    2197.26 779 2197.48 77 2197.68 88.6 2197.89 15 2198.1 25.275 2198.3 24993.896 2198.52 118.28 2198.73 -0.5707 2198.94 0.5986 2199.16 1.4815 2199.39 -0.3433 2199.6 15.843
    2199.8 765 2200.02 77 2200.23 88.6 2200.44 15 2200.65 25.079 2200.89 24993.896 2201.1 119.38 2201.29 -1.056 2201.5 0.4122 2201.71 0.8626 2201.93 -1.0472 2202.15 12.311
    2202.39 788 2202.6 77 2202.8 88.6 2203.02 15 2203.23 24.921 2203.43 24993.896 2203.65 119.84 2203.87 -0.8527 2204.09 1.0201 2204.29 0.303 2204.5 -0.4338 2204.71 13.35
    2204.93 779 2205.15 77 2205.36 88.6 2205.56 15 2205.77 24.768 2205.97 24993.896 2206.18 119.38 2206.41 -0.5517 2206.63 0.4741 2206.83 1.0271 2207.03 -0.3616 2207.24 19.318
    2207.45 767 2207.67 77 2207.89 88.6 2208.1 15 2208.31 25.079 2208.51 24993.896 2208.72 118.16 2208.93 -1.0142 2209.17 0.5279 2209.38 0.2466 2209.58 -0.4503 2209.79 17.487
    2209.99 782 2210.2 78 2210.42 88.6 2210.64 15 2210.84 25.079 2211.04 24993.896 2211.25 119.34 2211.46 -1.4526 2211.67 0.2042 2211.88 0.6374 2212.08 -0.9655 2212.29 12.77
    2212.51 788 2212.71 78 2212.92 88.6 2213.14 15 2213.35 25.049 2213.56 24993.896 2213.76 119.84 2213.97 -0.5788 2214.17 0.7399 2214.39 0.6802 2214.6 -0.4774 2214.81 7.712
    2215.02 788 2215.23 78 2215.44 88.6 2215.67 15 2215.88 25.049 2216.08 24993.896 2216.29 119.19 2216.5 -0.9769 2216.7 1.1442 2216.93 0.967 2217.17 -0.3909 2217.38 18.622
    2217.58 768 2217.79 78 2218.01 88.6 2218.21 15 2218.43 25.049 2218.67 24993.896 2218.89 118.22 2219.1 -0.7517 2219.31 0.5056 2219.51 0.4129 2219.72 -0.3957 2219.93 15.669
    2220.17 779 2220.38 78 2220.58 88.6 2220.78 15 2220.99 25.208 2221.2 24993.896 2221.42 118.28 2221.63 -0.711 2221.83 0.544 2222.04 1.034 2222.25 -0.3737 2222.45 19.952
    2222.68 766 2222.93 78 2223.17 88.6 2223.38 15 2223.58 24.866 2223.79 24993.896 2224.01 119.31 2224.23 -0.7315 2224.43 0.381 2224.65 0.7513 2224.85 -0.5026 2225.07 21.222
    2225.29 770 2225.51 78 2225.72 88.6 2225.93 15 2226.16 25.104 2226.35 24993.896 2226.56 118.16 2226.77 -0.9919 2226.97 0.4814 2227.19 0.5799 2227.4 -0.6964 2227.59 15.984
    2227.8 787 2228.01 78 2228.23 88.6 2228.43 15 2228.65 24.78 2228.84 24993.896 2229.05 119.53 2229.26 -1.0575 2229.46 0.5264 2229.68 0.778 2229.9 -0.6484 2230.1 14.377
    2230.32 768 2230.53 78 2230.73 88.6 2230.94 15 2231.15 24.677 2231.35 24993.896 2231.56 119.59 2231.77 -1.4383 2231.97 0.629 2232.2 1.6163 2232.44 -0.5946 2232.65 12.43
    2232.84 786 2233.05 78 2233.26 88.6 2233.48 15 2233.68 25.238 2233.9 25042.725 2234.09 119.19 2234.3 -0.8077 2234.51 0.9073 2234.71 0.5704 2234.93 -0.3756 2235.15 12.73
    2235.35 795 2235.57 78 2235.78 88.6 2235.99 15 2236.21 24.805 2236.44 24993.896 2236.65 118.44 2236.84 -0.7934 2237.05 0.165 2237.25 0.6213 2237.46 -0.6806 2237.69 17.812
    2237.9 770 2238.09 78 2238.3 88.6 2238.51 15 2238.71 25.031 2238.94 24993.896 2239.15 118.22 2239.35 -0.4078 2239.56 0.3236 2239.76 1.4669 2239.97 -0.2371 2240.19 16.028
    2240.4 780 2240.59 78 2240.8 88.6 2241 15 2241.21 25.061 2241.44 24993.896 2241.65 119.56 2241.85 -0.7806 2242.07 0.481 2242.28 0.6865 2242.49 -0.6693 2242.7 13.39
    2242.94 789 2243.15 78 2243.35 89 2243.57 15 2243.78 24.695 2243.98 24993.896 2244.19 120.06 2244.41 -0.2027 2244.6 0.4726 2244.81 1.3281 2245.01 -0.7758 2245.22 13.029
    2245.44 786 2245.66 78 2245.86 88.6 2246.06 15 2246.27 24.805 2246.47 24993.896 2246.69 119.78 2246.9 -0.707 2247.09 0.6575 2247.3 0.5671 2247.5 -0.4298 2247.71 14.795
    2247.93 757 2248.15 78 2248.34 88.6 2248.55 15 2248.75 25.049 2248.96 24993.896 2249.19 119.19 2249.4 -1.0717 2249.59 1.1798 2249.8 0.956 2249.99 -0.3389 2250.2 17.973
    2250.43 787 2250.65 78 2250.85 88.6 2251.05 15 2251.26 24.799 2251.46 24993.896 2251.69 119.25 2251.9 -0.7041 2252.1 0.3781 2252.31 0.7421 2252.51 -0.4807 2252.72 18.063
    2252.95 767 2253.19 78 2253.41 88.6 2253.61 15 2253.81 24.927 2254.02 24993.896 2254.22 119.84 2254.45 -0.5806 2254.69 0.4898 2254.9 0.9234 2255.1 -0.6748 2255.32 17.036
    2255.53 780 2255.73 78 2255.94 88.6 2256.16 15 2256.38 24.664 2256.58 24993.896 2256.78 120.13 2256.99 -0.7 2257.19 0.5975 2257.4 0.9296 2257.59 -1.1908 2257.79 12.61
    2258 784 2258.21 78 2258.45 88.6 2258.69 15 2258.89 25.244 2259.1 24993.896 2259.32 119.69 2259.52 -1.0787 2259.73 1.1241 2259.95 0.8048 2260.19 -0.9322 2260.4 12.871
    2260.59 785 2260.8 78 2261 88.6 2261.21 15 2261.45 24.725 2261.7 24993.896 2261.93 120.47 2262.15 -0.6143 2262.35 1.1069 2262.56 0.3917 2262.76 -0.4437 2262.96 15.355
    2263.18 781 2263.4 78 2263.6 89 2263.82 15 2264.02 25.165 2264.23 24993.896 2264.44 118.31 2264.65 -1.6174 2264.87 0.6539 2265.07 0.4993 2265.28 -0.5444 2265.48 18.423
    2265.69 768 2265.9 78 2266.1 88.6 2266.31 15 2266.5 25.018 2266.72 24993.896 2266.94 118.38 2267.16 -0.2767 2267.36 0.4664 2267.58 1.505 2267.78 -0.5305 2267.98 8.424
    2268.2 788 2268.44 79 2268.69 88.6 2268.89 15 2269.1 25.293 2269.32 24993.896 2269.52 119.78 2269.74 -0.7758 2269.96 0.5466 2270.18 2.3678 2270.39 0.0002 2270.59 1.996
    2270.8 1577 2271 79 2271.23 88.6 2271.44 15 2271.65 31.189 2271.84 31176.758 2272.05 120.78 2272.26 -2.4685 2272.47 0.0002 2272.7 0.0002 2272.92 0.0002 2273.12 0
    2273.32 2120 2273.53 79 2273.74 89 2273.96 15 2274.2 43.494 2274.41 47906.494 2274.61 157.06 2274.82 0.0002 2275.04 0.0002 2275.24 0.0002 2275.45 0.0002 2275.67 0
    2275.86 1459 2276.07 79 2276.28 88.6 2276.5 15 2276.7 29.84 2276.91 30963.135 2277.12 116.19 2277.33 -0.5656 2277.54 0.0932 2277.75 0.2496 2277.96 -0.202 2278.2 18.712
    2278.44 780 2278.65 79 2278.85 89 2279.06 15 2279.28 25.702 2279.5 25189.209 2279.7 119.66 2279.91 -1.2552 2280.12 0.3946 2280.33 0.7319 2280.52 -0.4158 2280.74 17.288
    2280.96 768 2281.18 79 2281.38 88.6 2281.58 15 2281.78 25 2282 24993.896 2282.22 118.66 2282.46 -0.8366 2282.69 0.8092 2282.9 0.7385 2283.12 -0.6447 2283.32 14.377
    2283.52 797 2283.74 79 2283.96 88.6 2284.19 15 2284.38 24.805 2284.58 24993.896 2284.8 119.34 2285 -0.7238 2285.23 0.4594 2285.46 1.4486 2285.67 -0.2646 2285.88 16.928
    2286.08 764 2286.3 79 2286.5 89 2286.72 15 2286.93 25.012 2287.13 24993.896 2287.34 120.44 2287.54 -0.8637 2287.74 0.8809 2287.98 0.4268 2288.22 -0.4803 2288.47 11.85
    2288.71 789 2288.94 79 2289.15 89 2289.36 15 2289.58 24.896 2289.78 24993.896 2289.98 119.53 2290.22 -1.4943 2290.43 0.2086 2290.62 0.5847 2290.82 -0.8267 2291.04 17.36
    2291.25 766 2291.47 79 2291.71 88.6 2291.93 15 2292.12 25.104 2292.32 25018.311 2292.54 119.09 2292.74 -0.8015 2292.96 0.6484 2293.17 0.5689 2293.38 -0.4521 2293.58 16.333
    2293.78 766 2294 79 2294.21 89 2294.43 15 2294.63 25.262 2294.84 24993.896 2295.04 119.66 2295.26 -1.0637 2295.46 0.3572 2295.67 0.6898 2295.87 -0.6 2296.08 14.83
    2296.3 781 2296.5 79 2296.72 88.6 2296.94 15 2297.14 24.683 2297.36 24993.896 2297.58 118.47 2297.78 -0.5935 2298 0.3444 2298.22 0.7205 2298.46 -0.4561 2298.68 16.946
    2298.87 785 2299.08 79 2299.28 88.6 2299.5 15 2299.71 25.214 2299.93 24993.896 2300.14 119.53 2300.34 -1.4749 2300.54 0.3748 2300.74 0.2913 2300.97 -0.4341 2301.22 18.532
    2301.43 767 2301.63 79 2301.84 88.6 2302.04 15 2302.26 24.963 2302.46 24993.896 2302.67 119.97 2302.87 -0.1957 2303.08 0.3708 2303.29 0.9875 2303.5 -0.4268 2303.72 16.171
    2303.97 780 2304.21 79 2304.43 89 2304.64 15 2304.84 24.622 2305.04 24993.896 2305.24 119.38 2305.47 -1.1263 2305.71 0.5371 2305.93 1.3145 2306.14 -1.023 2306.34 9.323
    2306.54 789 2306.75 79 2306.96 88.6 2307.17 15 2307.38 24.835 2307.58 24993.896 2307.8 119.56 2308 -0.5052 2308.23 0.2723 2308.46 0.5187 2308.67 -0.4345 2308.87 17.847
    2309.08 766 2309.28 79 2309.49 88.6 2309.71 15 2309.93 24.719 2310.14 24993.896 2310.33 118.41 2310.54 -0.5488 2310.75 0.4664 2310.97 0.6865 2311.21 -0.473 2311.43 13.789
    2311.63 781 2311.83 79 2312.03 88.6 2312.24 15 2312.47 25.134 2312.71 24993.896 2312.93 119.94 2313.13 -0.6788 2313.33 0.1734 2313.54 0.577 2313.75 -0.6682 2313.97 18.46
    2314.22 782 2314.46 79 2314.68 89 2314.9 15 2315.11 25.262 2315.32 24993.896 2315.52 119.97 2315.74 -0.3873 2315.97 0.458 2316.22 0.5462 2316.46 -0.377 2316.67 15.773
    2316.87 803 2317.08 79 2317.28 89 2317.49 15 2317.72 24.719 2317.97 25006.104 2318.2 119.28 2318.4 -0.6894 2318.62 0.8322 2318.83 1.2186 2319.04 -0.6238 2319.24 14.236
    2319.47 803 2319.72 79 2319.96 88.6 2320.19 15 2320.39 24.805 2320.6 24993.896 2320.8 118.25 2321.01 -0.7132 2321.22 0.3558 2321.46 0.7407 2321.71 -1.0047 2321.92 12.151
    2322.11 791 2322.32 79 2322.53 88.6 2322.75 15 2322.96 24.677 2323.17 24993.896 2323.37 119.81 2323.57 -0.6414 2323.78 0.1899 2324 0.4221 2324.21 -0.4902 2324.43 19.318
    2324.62 766 2324.83 79 2325.05 88.6 2325.26 15 2325.47 25.079 2325.71 24993.896 2325.93 120.75 2326.11 -0.8509 2326.32 0.7843 2326.53 0.6231 2326.75 -0.8278 2326.97 11.157
    2327.21 762 2327.44 80 2327.62 88.6 2327.83 15 2328.04 25.073 2328.24 24993.896 2328.47 118.75 2328.7 -0.7117 2328.89 0.8176 2329.1 1.476 2329.3 -0.1935 2329.51 19.556
    2329.73 764 2329.93 80 2330.13 88.6 2330.34 15 2330.54 24.841 2330.75 24993.896 2330.98 117.94 2331.19 -0.9183 2331.39 0.4715 2331.62 0.5491 2331.82 -0.7542 2332.02 10.895
    2332.23 784 2332.44 80 2332.64 88.6 2332.86 15 2333.06 25.299 2333.27 24993.896 2333.48 119.25 2333.7 -1.0589 2333.91 0.2071 2334.11 0.7656 2334.32 -0.9172 2334.54 18.622
    2334.75 762 2334.98 80 2335.19 88.6 2335.39 15 2335.6 25.214 2335.8 24993.896 2336.01 120.34 2336.24 -0.2408 2336.49 0.4843 2336.74 0.5136 2336.98 -0.466 2337.19 18.207
    2337.39 796 2337.62 80 2337.83 88.6 2338.04 15 2338.24 25.171 2338.48 24993.896 2338.68 119.53 2338.88 -0.5407 2339.09 0.4627 2339.29 0.5865 2339.5 -0.7268 2339.73 12.17
    2339.94 780 2340.13 80 2340.34 89 2340.54 15 2340.74 24.902 2340.97 24993.896 2341.2 119.5 2341.41 -0.9187 2341.62 0.555 2341.82 1.1999 2342.03 -1.1816 2342.25 9.473
    2342.48 759 2342.69 80 2342.89 89 2343.11 15 2343.32 25.317 2343.52 24993.896 2343.73 118.09 2343.94 -0.8864 2344.14 0.7949 2344.36 0.648 2344.57 -0.3836 2344.78 16.01
    2345.01 786 2345.25 80 2345.49 88.6 2345.7 15 2345.9 24.829 2346.11 24993.896 2346.33 119.97 2346.54 -0.262 2346.75 0.1796 2346.98 0.2177 2347.19 -0.3712 2347.39 17.92
    2347.6 783 2347.81 80 2348.01 88.6 2348.23 15 2348.43 25.293 2348.64 24993.896 2348.84 119.34 2349.05 -0.8359 2349.26 0.9465 2349.47 0.9721 2349.66 -0.8172 2349.87 13.852
    2350.08 803 2350.29 80 2350.51 88.6 2350.73 15 2350.93 24.725 2351.13 25006.104 2351.34 118.22 2351.54 -1.5119 2351.77 0.6275 2352.01 1.7401 2352.22 -0.5927 2352.41 17.92
    2352.62 791 2352.83 80 2353.05 88.6 2353.26 15 2353.47 25.201 2353.67 24993.896 2353.88 120.22 2354.1 -0.5034 2354.3 0.3005 2354.51 0.213 2354.72 -0.5583 2354.92 16.1
    2355.12 783 2355.31 80 2355.52 88.6 2355.76 15 2355.98 25.262 2356.19 24993.896 2356.4 120.03 2356.6 -0.4814 2356.81 0.1749 2357.02 0.5788 2357.26 -0.8773 2357.48 11.569
    2357.67 763 2357.88 80 2358.08 89 2358.29 15 2358.52 25.146 2358.77 24993.896 2359.01 119.56 2359.23 -1.1413 2359.42 0.4982 2359.64 1.2636 2359.83 -1.201 2360.04 8.574
    2360.27 767 2360.49 80 2360.69 89 2360.9 15 2361.1 24.719 2361.31 25030.518 2361.53 118.53 2361.77 -0.7597 2361.99 1.1179 2362.18 1.2515 2362.39 -1.3255 2362.58 8.012
    2362.79 793 2363.03 80 2363.28 89 2363.48 15 2363.68 25.33 2363.88 25018.311 2364.09 119.44 2364.29 -1.2296 2364.53 0.6451 2364.77 0.8385 2364.99 -0.6011 2365.18 11.731
    2365.39 759 2365.58 80 2365.79 89 2366.03 15 2366.27 25.195 2366.49 24993.896 2366.69 119.59 2366.91 -1.2124 2367.12 0.4459 2367.32 1.0754 2367.55 -1.0022 2367.8 11.911
    2368.04 781 2368.25 80 2368.45 89 2368.65 15 2368.86 24.963 2369.08 24993.896 2369.29 119.31 2369.5 -0.9388 2369.7 1.0095 2369.91 0.9637 2370.11 -0.8978 2370.32 12.151
    2370.54 791 2370.76 80 2370.97 88.6 2371.19 15 2371.4 24.689 2371.6 24993.896 2371.81 118.59 2372.04 -2.6344 2372.26 2.5534 2372.47 0.0002 2372.68 0.0002 2372.88 0
    2373.09 1753 2373.3 80 2373.54 89 2373.75 15 2373.95 46.472 2374.16 45318.604 2374.36 152.53 2374.57 0.0002 2374.8 0.0002 2375.05 0.0002 2375.29 0.0002 2375.5 33.289
    2375.7 2519 2375.9 80 2376.1 88.6 2376.3 15 2376.53 41.87 2376.75 38531.494 2376.95 166.78 2377.16 0.0002 2377.37 0.0002 2377.57 0.0002 2377.79 -0.2302 2378.01 24.08
    2378.19 762 2378.4 80 2378.61 88.6 2378.83 15 2379.05 28.326 2379.28 27624.512 2379.49 119.19 2379.69 -0.819 2379.91 0.7392 2380.12 1.3797 2380.32 -0.4257 2380.54 15.669
    2380.76 781 2380.94 80 2381.15 88.6 2381.36 15 2381.58 25.305 2381.8 24993.896 2382.04 120.41 2382.26 -0.3953 2382.47 0.5473 2382.68 0.7956 2382.88 -0.6942 2383.09 14.412
    2383.3 764 2383.53 80 2383.74 88.6 2383.94 15 2384.15 25.208 2384.36 24993.896 2384.58 119.91 2384.82 -0.6444 2385.06 0.6689 2385.27 0.5825 2385.47 -0.8872 2385.68 10.933
    2385.88 785 2386.09 80 2386.32 88.6 2386.56 15 2386.77 24.719 2386.97 24993.896 2387.19 118.19 2387.4 -0.5957 2387.6 0.5023 2387.82 0.7205 2388.07 -0.3887 2388.3 12.45
    2388.52 800 2388.72 80 2388.94 89 2389.15 15 2389.35 25.293 2389.56 24993.896 2389.78 119.88 2389.98 -0.6766 2390.18 0.1566 2390.39 0.5513 2390.61 -0.5664 2390.82 21.381
    2391.03 770 2391.23 81 2391.44 88.6 2391.66 15 2391.86 25.323 2392.06 24993.896 2392.26 120.03 2392.47 -1.1743 2392.69 0.7736 2392.9 1.6071 2393.1 -0.1972 2393.32 14.201
    2393.54 781 2393.74 81 2393.95 88.6 2394.15 15 2394.36 24.847 2394.58 24993.896 2394.84 118.41 2395.06 -1.7708 2395.26 0.6682 2395.46 0.5089 2395.67 -0.5568 2395.88 18.495
    2396.1 794 2396.32 81 2396.54 88.6 2396.73 15 2396.94 25.208 2397.16 24993.896 2397.38 120.13 2397.58 -0.6927 2397.83 0.34 2398.07 0.533 2398.29 -0.5469 2398.48 18.568
    2398.68 787 2398.89 81 2399.11 88.6 2399.33 15 2399.57 24.707 2399.79 24993.896 2399.99 117.78 2400.19 -0.7659 2400.4 0.8447 2400.61 0.4818 2400.84 -0.444 2401.06 14.236
    2401.27 790 2401.48 81 2401.68 89 2401.89 15 2402.1 25 2402.33 24993.896 2402.55 118.19 2402.75 -0.4484 2402.97 0.5488 2403.19 0.7308 2403.4 -0.161 2403.61 18.675
    2403.84 780 2404.06 81 2404.26 88.6 2404.46 15 2404.67 24.835 2404.88 24993.896 2405.09 119.5 2405.3 -0.5356 2405.5 0.5898 2405.7 0.2195 2405.91 -0.4151 2406.11 16.838
    2406.34 781 2406.55 81 2406.75 88.6 2406.94 15 2407.15 25.348 2407.36 25000 2407.6 120 2407.84 -0.4602 2408.05 0.5338 2408.25 0.3745 2408.47 -0.169 2408.68 18.063
    2408.88 781 2409.1 81 2409.34 89 2409.55 15 2409.74 24.78 2409.95 24993.896 2410.16 119.81 2410.38 -1.1519 2410.6 0.3294 2410.84 1.0256 2411.06 -0.4016 2411.26 19.159
    2411.46 773 2411.67 81 2411.87 88.6 2412.09 15 2412.31 25.287 2412.51 24993.896 2412.71 120.28 2412.92 -0.2086 2413.13 0.3906 2413.35 1.0336 2413.58 -0.4979 2413.8 17.542
    2414 782 2414.21 81 2414.41 88.6 2414.62 15 2414.84 25.323 2415.06 24993.896 2415.26 120.03 2415.46 -0.3038 2415.67 0.5253 2415.87 0.6916 2416.1 -1.015 2416.34 20.349
    2416.55 776 2416.74 81 2416.95 88.6 2417.16 15 2417.36 25.244 2417.56 24993.896 2417.76 120.47 2417.97 -0.652 2418.19 0.496 2418.41 1.32 2418.62 -0.4125 2418.86 17.18
    2419.1 783 2419.32 81 2419.52 88.6 2419.73 15 2419.93 25.232 2420.14 24993.896 2420.36 119.44 2420.58 -1.2655 2420.77 0.2748 2420.98 0.6173 2421.18 -0.6821 2421.39 16.496
    2421.62 775 2421.85 81 2422.07 88.6 2422.27 15 2422.49 25.085 2422.69 24993.896 2422.9 118.88 2423.11 -0.8048 2423.35 0.4063 2423.57 0.7692 2423.76 -0.329 2423.96 14.97
    2424.17 790 2424.38 81 2424.61 88.6 2424.85 15 2425.07 24.902 2425.27 24993.896 2425.47 118.78 2425.67 -1.0047 2425.87 0.2316 2426.11 1.1457 2426.35 -0.1741 2426.57 13.431
    2426.76 798 2426.97 81 2427.19 88.6 2427.4 15 2427.61 24.786 2427.86 25006.104 2428.06 117.94 2428.26 -1.6189 2428.47 0.106 2428.69 0.6865 2428.91 -0.0764 2429.12 16.928
    2429.35 782 2429.58 81 2429.8 89 2429.99 15 2430.2 24.982 2430.4 24993.896 2430.61 120.78 2430.86 -0.3734 2431.08 0.0782 2431.27 0.5484 2431.48 -0.3192 2431.69 17.216
    2431.9 771 2432.11 81 2432.31 88.6 2432.51 15 2432.72 24.805 2432.92 24993.896 2433.13 118.97 2433.34 -1.0062 2433.54 0.1467 2433.75 0.7692 2433.96 -0.2379 2434.16 17.378
    2434.37 776 2434.6 81 2434.82 88.6 2435.02 15 2435.23 25.012 2435.43 24993.896 2435.64 118.78 2435.86 -0.7388 2436.08 0.1448 2436.28 0.4741 2436.48 -0.0943 2436.69 12.871
    2436.91 789 2437.12 81 2437.36 88.6 2437.57 15 2437.76 25.14 2437.97 24993.896 2438.16 119.91 2438.37 -0.7901 2438.61 0.0134 2438.87 1.1091 2439.09 0.0005 2439.3 11.157
    2439.5 772 2439.71 82 2439.91 88.6 2440.12 15 2440.35 25.031 2440.57 24993.896 2440.77 119.91 2440.97 -0.7326 2441.18 -0.0738 2441.38 2.7959 2441.6 0.0002 2441.82 0
    2442.01 1235 2442.21 82 2442.42 88.6 2442.63 31 2442.86 55.444 2443.07 51501.465 2443.26 165.59 2443.47 0.0002 2443.69 0.0002 2443.9 0.0002 2444.1 0.0002 2444.32 0
    2444.52 1960 2444.74 82 2444.94 88.6 2445.15 77 2445.35 49.475 2445.57 49932.861 2445.77 164.19 2445.98 0.0002 2446.18 0.0002 2446.39 0.0002 2446.62 0.0002 2446.86 0
    2447.06 2065 2447.26 82 2447.47 88.6 2447.67 15 2447.88 32.532 2448.12 31756.592 2448.33 117.72 2448.53 -0.6403 2448.74 -0.121 2448.94 0.0756 2449.14 -0.0884 2449.38 29.239
    2449.63 774 2449.88 82 2450.11 88.6 2450.33 15 2450.53 26.758 2450.73 26330.566 2450.94 119.72 2451.13 -0.6923 2451.37 0.1445 2451.59 0.7004 2451.78 -0.3452 2451.99 16.406
    2452.19 760 2452.4 82 2452.61 88.6 2452.84 15 2453.05 25.336 2453.26 24993.896 2453.47 120.41 2453.69 -0.2368 2453.91 0.1778 2454.12 1.3757 2454.33 -0.1419 2454.53 13.957
    2454.74 773 2454.96 82 2455.16 88.6 2455.37 15 2455.59 25.012 2455.78 24993.896 2455.99 118.59 2456.19 -0.7583 2456.4 0.1727 2456.63 0.4938 2456.87 -0.1404 2457.09 16.063
    2457.29 782 2457.49 82 2457.7 88.6 2457.9 15 2458.12 24.811 2458.34 24993.896 2458.54 118.91 2458.75 -1.0941 2458.95 0.0471 2459.16 0.6802 2459.37 -0.0786 2459.58 18.027
    2459.78 770 2459.99 82 2460.2 88.6 2460.4 15 2460.63 25.11 2460.88 25018.311 2461.12 119.94 2461.33 -0.7235 2461.53 0.0339 2461.73 0.7828 2461.94 -0.1943 2462.14 16.478
    2462.37 769 2462.58 82 2462.78 88.6 2462.99 15 2463.2 24.969 2463.4 24993.896 2463.63 118.75 2463.88 -0.7502 2464.14 0.0643 2464.38 0.8128 2464.62 -0.0496 2464.84 13.19
    2465.02 776 2465.23 82 2465.44 88.6 2465.64 15 2465.88 25.061 2466.13 24993.896 2466.38 119.06 2466.62 -0.4605 2466.84 -0.0159 2467.06 1.0245 2467.26 0.0302 2467.47 13.071
    2467.69 790 2467.91 82 2468.12 89 2468.33 15 2468.53 25.165 2468.74 24993.896 2468.95 119.34 2469.15 -0.7854 2469.38 -0.0683 2469.63 1.0256 2469.86 0.0753 2470.06 11.082
    2470.27 775 2470.49 82 2470.71 88.6 2470.92 15 2471.13 24.982 2471.38 24993.896 2471.62 118.88 2471.84 -0.4862 2472.03 -0.1807 2472.24 1.0831 2472.46 0.1317 2472.66 13.15
    2472.87 774 2473.09 82 2473.28 89 2473.49 15 2473.7 24.902 2473.9 24993.896 2474.12 118.69 2474.34 -0.6846 2474.53 -0.2518 2474.73 1.0783 2474.94 0.2393 2475.16 12.511
    2475.38 791 2475.62 82 2475.84 88.6 2476.03 15 2476.24 25.183 2476.44 24993.896 2476.65 119.34 2476.87 -1.1886 2477.09 -0.1913 2477.28 0.5902 2477.49 0.4964 2477.71 17.253
    2477.92 775 2478.13 82 2478.37 88.6 2478.59 15 2478.77 24.908 2478.98 24993.896 2479.19 118.91 2479.39 -0.395 2479.63 -0.6132 2479.88 0.5883 2480.13 0.3056 2480.39 1.257
    2480.6 1765 2480.79 82 2481 88.6 2481.2 15 2481.41 54.132 2481.65 61706.543 2481.89 147.38 2482.1 0.0002 2482.3 0.0002 2482.52 0.0002 2482.74 0.0002 2482.95 0
    2483.15 2312 2483.39 83 2483.6 88.6 2483.79 15 2484 34.326 2484.2 33288.574 2484.41 127.13 2484.64 -0.2012 2484.85 -0.6942 2485.04 0.5202 2485.25 0.4561 2485.46 17.468
    2485.68 768 2485.89 83 2486.1 88.6 2486.3 15 2486.52 26.886 2486.73 26184.082 2486.93 119.56 2487.14 -1.1669 2487.36 -0.1298 2487.56 0.6517 2487.76 0.132 2487.97 17.722
    2488.19 795 2488.39 83 2488.61 88.6 2488.81 15 2489.01 25.153 2489.22 24993.896 2489.43 119.94 2489.64 -0.7604 2489.88 -0.0723 2490.05 1.1171 2490.27 0.065 2490.48 12.471
    2490.68 751 2490.9 83 2491.15 88.6 2491.39 15 2491.63 25.354 2491.8 25012.207 2492.01 119.94 2492.22 -0.6923 2492.44 0.0108 2492.66 0.6788 2492.89 -0.0119 2493.13 13.251
    2493.3 750 2493.52 83 2493.73 88.6 2493.94 15 2494.17 25.33 2494.42 24993.896 2494.65 120.03 2494.83 -0.4327 2495.05 0.0353 2495.26 0.4803 2495.47 -0.1635 2495.7 13.631
    2495.94 753 2496.18 83 2496.42 88.6 2496.59 15 2496.8 25.293 2497.01 24993.896 2497.22 119.88 2497.44 -0.3488 2497.7 0.0932 2497.94 0.5341 2498.16 -0.1551 2498.35 18.333
    2498.57 802 2498.78 83 2498.98 88.6 2499.19 15 2499.41 24.707 2499.6 24993.896 2499.8 119.13 2500.01 -0.3638 2500.22 0.1562 2500.44 0.2434 2500.66 -0.1016 2500.83 16.171
    2501.04 786 2501.25 83 2501.46 89 2501.68 15 2501.93 25.244 2502.1 25006.104 2502.32 119.38 2502.52 -1.2493 2502.73 0.2071 2502.94 0.9743 2503.15 -0.6004 2503.35 10.408
    2503.56 767 2503.77 83 2503.98 88.6 2504.19 15 2504.39 24.805 2504.59 24993.896 2504.8 118.34 2505.01 -1.4702 2505.21 0.3206 2505.44 1.4965 2505.65 -0.3463 2505.85 18.982
    2506.06 797 2506.26 83 2506.47 88.6 2506.69 15 2506.95 25.262 2507.19 24993.896 2507.44 120.88 2507.65 -1.9184 2507.85 0.0002 2508.07 0.0002 2508.28 0.0002 2508.48 0
    2508.69 1567 2508.95 83 2509.2 88.6 2509.44 15 2509.67 30.994 2509.85 30737.305 2510.06 116.44 2510.27 -0.7531 2510.49 0.4854 2510.7 0.6923 2510.94 -0.3898 2511.16 15.948
    2511.35 793 2511.56 83 2511.76 88.6 2511.97 15 2512.2 25.397 2512.44 24993.896 2512.65 118.84 2512.85 -0.9871 2513.07 0.3287 2513.28 3.4642 2513.48 0.0002 2513.71 33.368
    2513.96 2576 2514.2 83 2514.43 88.6 2514.63 32 2514.84 50.616 2515.04 53674.316 2515.25 139.22 2515.46 0.0002 2515.7 0.0002 2515.91 0.0002 2516.11 0.0002 2516.32 5.858
    2516.53 2614 2516.73 83 2516.95 88.6 2517.17 32 2517.37 45.557 2517.58 53961.182 2517.78 137.19 2517.98 0.0002 2518.21 0.0002 2518.45 0.0002 2518.67 0.0002 2518.86 8.723
    2519.07 2597 2519.28 83 2519.48 88.6 2519.7 32 2519.92 43.933 2520.13 53326.416 2520.34 135.81 2520.54 0.0002 2520.75 0.0002 2520.96 0.0002 2521.21 0.0002 2521.45 18.045
    2521.67 2628 2521.86 83 2522.07 88.6 2522.27 15 2522.48 43.811 2522.71 43194.58 2522.96 166.06 2523.21 0.0002 2523.46 0.0002 2523.71 0.9809 2523.95 -0.4748 2524.16 13.01
    2524.36 717 2524.57 83 2524.78 88.6 2524.98 15 2525.21 29.077 2525.45 32879.639 2525.68 127.34 2525.88 0.0002 2526.1 0.0002 2526.31 0.0002 2526.52 0.0002 2526.72 0
    2526.97 1440 2527.2 83 2527.42 88.6 2527.63 15 2527.84 30.841 2528.05 30718.994 2528.27 118.38 2528.49 -0.6835 2528.7 0.8396 2528.91 0.1533 2529.11 -0.4147 2529.32 23.048
    2529.54 769 2529.74 83 2529.96 88.6 2530.21 15 2530.46 25.043 2530.7 25012.207 2530.92 119.88 2531.13 -4.0388 2531.34 0.0002 2531.55 0.0002 2531.77 0.0002 2531.99 0
    2532.2 2293 2532.41 83 2532.61 88.6 2532.82 15 2533.04 34.186 2533.24 32604.98 2533.46 126.56 2533.71 0.0002 2533.97 0.0002 2534.21 0.4477 2534.45 -0.317 2534.67 16.243
    2534.87 768 2535.07 84 2535.28 88.6 2535.49 15 2535.72 27.344 2535.95 26934.814 2536.19 118.75 2536.36 -0.8604 2536.57 4.0146 2536.78 0.0002 2536.99 0.0002 2537.21 46.068
    2537.45 2610 2537.67 84 2537.88 88.6 2538.1 15 2538.31 35.663 2538.52 34338.379 2538.74 132.81 2538.96 -0.414 2539.2 0.2133 2539.41 0.0544 2539.61 -0.1928 2539.82 25.43
    2540.02 760 2540.23 84 2540.46 88.6 2540.7 15 2540.92 27.557 2541.11 26794.434 2541.31 118.25 2541.51 -0.8011 2541.72 0.3463 2541.96 1.5537 2542.2 -0.7 2542.42 8.873
    2542.62 785 2542.82 84 2543.03 89 2543.23 15 2543.46 25.348 2543.71 24993.896 2543.95 120.22 2544.17 -0.1917 2544.36 0.3019 2544.57 0.9762 2544.79 -0.4536 2544.99 11.044
    2545.2 738 2545.42 84 2545.62 88.6 2545.82 15 2546.03 25.085 2546.24 25018.311 2546.46 120.72 2546.7 -0.1946 2546.91 0.6429 2547.11 1.7617 2547.32 -0.807 2547.53 11.79
    2547.73 787 2547.96 84 2548.21 88.6 2548.47 15 2548.71 25.214 2548.96 24993.896 2549.22 118.56 2549.45 -0.7711 2549.66 0.5378 2549.86 0.4038 2550.06 -0.3232 2550.27 11.911
    2550.48 792 2550.71 84 2550.96 88.6 2551.21 15 2551.45 25.061 2551.67 24993.896 2551.86 119.88 2552.07 -0.5997 2552.29 0.3708 2552.49 0.3898 2552.7 -0.1547 2552.92 12.17
    2553.12 791 2553.34 84 2553.55 89 2553.75 15 2553.96 25.275 2554.21 24993.896 2554.45 118.53 2554.67 -0.3712 2554.86 0.1027 2555.07 0.9725 2555.28 -0.0844 2555.48 10.783
    2555.71 789 2555.96 84 2556.2 88.6 2556.42 15 2556.63 24.89 2556.85 24993.896 2557.06 118.63 2557.26 -0.4495 2557.47 0.0086 2557.7 0.3979 2557.95 0.0222 2558.16 15.599
    2558.36 783 2558.57 85 2558.79 88.6 2559 15 2559.2 24.878 2559.41 24993.896 2559.61 119.38 2559.82 -1.1757 2560.03 -0.0441 2560.23 0.5784 2560.46 0.1302 2560.71 11.951
    2560.95 789 2561.17 85 2561.38 88.6 2561.6 15 2561.82 24.835 2562.03 24993.896 2562.24 118.94 2562.46 -1.0736 2562.71 -0.1555 2562.97 0.663 2563.2 0.2734 2563.42 16.513
    2563.62 777 2563.84 85 2564.05 88.6 2564.27 15 2564.49 24.841 2564.7 24993.896 2564.92 118.47 2565.11 -0.3997 2565.32 -0.2163 2565.54 1.1428 2565.75 0.2049 2565.96 12.151
    2566.22 784 2566.46 85 2566.7 88.6 2566.92 15 2567.12 25.079 2567.34 24993.896 2567.54 119.72 2567.75 -0.6429 2567.96 -0.3968 2568.2 0.6392 2568.42 0.2847 2568.61 14.621
    2568.82 782 2569.03 85 2569.24 88.6 2569.46 15 2569.7 24.872 2569.91 24993.896 2570.11 118.94 2570.31 -0.47 2570.52 -0.2646 2570.73 1.0966 2570.95 0.1888 2571.17 10.146
    2571.36 775 2571.57 85 2571.78 88.6 2571.98 15 2572.21 24.963 2572.45 24993.896 2572.67 119.38 2572.86 -0.6751 2573.07 -0.5865 2573.28 0.5931 2573.48 0.5806 2573.71 16.785
    2573.96 773 2574.21 85 2574.45 88.6 2574.67 15 2574.87 25.317 2575.08 24993.896 2575.28 119.16 2575.49 -1.0223 2575.72 -0.2012 2575.95 0.8974 2576.17 0.299 2576.36 12.99
    2576.57 777 2576.78 85 2576.98 88.6 2577.21 15 2577.46 25.262 2577.69 24993.896 2577.92 119.38 2578.11 -1.0142 2578.32 -0.2492 2578.53 0.5653 2578.74 0.7663 2578.95 17.685
    2579.22 773 2579.45 85 2579.67 88.6 2579.86 15 2580.07 24.951 2580.28 24993.896 2580.48 119.84 2580.69 -0.696 2580.92 -0.8059 2581.11 0.5737 2581.31 0.5316 2581.52 14.97
    2581.72 791 2581.95 85 2582.21 89 2582.43 15 2582.65 24.963 2582.84 24993.896 2583.05 118.63 2583.25 -0.355 2583.47 -0.826 2583.69 0.484 2583.91 0.4492 2584.11 12.091
    2584.32 790 2584.54 85 2584.75 88.6 2584.95 15 2585.21 24.847 2585.45 24993.896 2585.69 119.78 2585.92 -0.5678 2586.12 -0.93 2586.34 0.5814 2586.55 0.8751 2586.75 14.131
    2586.95 783 2587.21 85 2587.45 88.6 2587.67 15 2587.86 24.957 2588.07 24993.896 2588.28 118.44 2588.49 -0.6015 2588.71 -0.8608 2588.97 0.5594 2589.21 0.9908 2589.45 11.87
    2589.69 791 2589.91 85 2590.11 88.6 2590.31 15 2590.53 25.208 2590.75 24993.896 2590.95 119.38 2591.2 -1.1373 2591.42 -0.3151 2591.59 0.5627 2591.79 0.9384 2591.99 15.25
    2592.21 784 2592.45 85 2592.7 88.6 2592.91 15 2593.11 25.043 2593.32 24993.896 2593.53 119.78 2593.73 -0.5502 2593.95 -1.0677 2594.17 0.3338 2594.35 0.5257 2594.55 13.31
    2594.77 791 2594.97 85 2595.21 88.6 2595.43 15 2595.63 25.214 2595.83 24993.896 2596.03 119.41 2596.25 -0.9981 2596.46 -0.273 2596.69 0.7088 2596.89 1.0922 2597.12 13.53
    2597.33 778 2597.53 85 2597.74 88.6 2597.97 15 2598.18 25.116 2598.38 24993.896 2598.59 118.63 2598.79 -0.5887 2599.01 -0.9952 2599.21 0.5008 2599.43 0.5843 2599.63 11.931
    2599.83 774 2600.03 85 2600.25 88.6 2600.47 15 2600.71 24.817 2600.94 24993.896 2601.13 118.94 2601.33 -1.1439 2601.55 -0.3265 2601.75 0.7604 2601.95 1.0611 2602.16 17.558
    2602.35 782 2602.56 85 2602.77 88.6 2602.99 15 2603.21 24.841 2603.42 24993.896 2603.62 118.84 2603.83 -0.5198 2604.04 -0.5638 2604.25 1.1508 2604.47 0.2939 2604.68 13.251
    2604.87 773 2605.07 85 2605.29 89 2605.5 15 2605.71 24.988 2605.94 24993.896 2606.14 119.78 2606.35 -0.5598 2606.56 -1.1556 2606.77 0.2789 2606.98 0.6601 2607.21 16.513
    2607.42 782 2607.61 85 2607.82 88.6 2608.03 15 2608.25 24.829 2608.48 24993.896 2608.71 128.47 2608.94 0.0002 2609.13 0.0002 2609.33 0.0002 2609.55 0.5162 2609.76 0.757
    2609.97 2459 2610.21 85 2610.43 88.6 2610.63 15 2610.84 41.473 2611.05 53631.592 2611.25 156.25 2611.47 0.0002 2611.72 0.0002 2611.94 0.0002 2612.14 0.0002 2612.33 20.746
    2612.55 2664 2612.75 85 2612.97 89 2613.18 15 2613.4 36.627 2613.61 35607.91 2613.81 151.28 2614.01 -0.0613 2614.22 -0.1155 2614.47 0.5631 2614.71 0.1324 2614.94 14.131
    2615.14 788 2615.37 85 2615.57 89 2615.77 15 2615.99 27.582 2616.21 27160.645 2616.42 120.13 2616.61 -0.6253 2616.82 -0.4572 2617.03 0.3056 2617.25 0.1657 2617.47 17.487
    2617.71 782 2617.93 85 2618.13 88.6 2618.33 15 2618.53 24.622 2618.74 24993.896 2618.97 118.47 2619.21 -0.6392 2619.43 -0.1862 2619.63 0.3657 2619.85 0.05 2620.06 17.09
    2620.29 804 2620.49 85 2620.71 88.6 2620.94 15 2621.14 24.902 2621.35 24993.896 2621.55 119.25 2621.77 -0.4744 2621.97 -0.009 2622.18 0.5795 2622.38 -0.0229 2622.59 15.355
    2622.79 759 2622.99 85 2623.22 88.6 2623.47 15 2623.67 25.415 2623.87 24993.896 2624.09 120.16 2624.29 -0.1804 2624.49 0.0233 2624.71 0.96 2624.94 -0.0258 2625.13 14.865
    2625.33 754 2625.55 85 2625.75 88.6 2625.97 15 2626.21 25.33 2626.42 24993.896 2626.62 120.03 2626.83 -0.1954 2627.05 0.0002 2627.27 0.8465 2627.46 -0.2455 2627.68 17.36
    2627.89 781 2628.08 85 2628.29 88.6 2628.5 15 2628.73 24.603 2628.97 25012.207 2629.18 118.16 2629.37 -0.8095 2629.58 0.2514 2629.79 1.8075 2629.99 -0.1946 2630.22 8.536
    2630.46 780 2630.68 85 2630.87 88.6 2631.08 15 2631.29 24.835 2631.49 24993.896 2631.72 119.59 2631.97 -0.8011 2632.18 0.4554 2632.38 1.0322 2632.58 -0.5653 2632.79 9.772
    2633.01 763 2633.22 86 2633.47 88.6 2633.68 15 2633.87 25.085 2634.07 25158.691 2634.28 119.38 2634.49 -1.5178 2634.71 0.3437 2634.94 1.4834 2635.15 -0.5338 2635.35 8.237
    2635.55 776 2635.75 86 2635.98 88.6 2636.21 15 2636.42 25.079 2636.62 24993.896 2636.82 119.06 2637.03 -0.8557 2637.25 0.6744 2637.45 1.5713 2637.66 -0.4605 2637.86 12.711
    2638.07 792 2638.27 86 2638.48 88.6 2638.73 15 2638.95 25.244 2639.18 25054.932 2639.37 117.25 2639.58 -0.3792 2639.8 0.2565 2640.01 1.1988 2640.21 -0.1613 2640.43 13.51
    2640.65 770 2640.86 86 2641.07 88.6 2641.27 15 2641.48 24.921 2641.71 24993.896 2641.94 120.03 2642.13 -0.8176 2642.33 0.2759 2642.54 0.6986 2642.75 -0.2503 2642.97 16.441
    2643.21 776 2643.44 86 2643.65 88.6 2643.85 15 2644.05 24.841 2644.26 24993.896 2644.47 118.66 2644.7 -0.7469 2644.91 0.0727 2645.11 0.974 2645.33 -0.0412 2645.53 11.711
    2645.74 790 2645.99 86 2646.23 88.6 2646.44 15 2646.63 24.835 2646.85 24993.896 2647.06 118.97 2647.27 -0.3437 2647.47 -0.0394 2647.69 0.9923 2647.89 0.0452 2648.09 12.671
    2648.29 776 2648.5 86 2648.74 88.6 2648.96 15 2649.16 25.043 2649.37 24993.896 2649.57 118.72 2649.77 -0.6173 2649.98 -0.2357 2650.19 1.0128 2650.39 0.1452 2650.61 11.89
    2650.82 792 2651.02 86 2651.24 88.6 2651.46 15 2651.65 25.146 2651.85 24993.896 2652.06 119.81 2652.29 -0.7374 2652.49 -0.3697 2652.7 0.6513 2652.9 0.3939 2653.11 16.478
    2653.33 786 2653.53 86 2653.75 88.6 2653.97 15 2654.17 24.817 2654.37 24993.896 2654.57 119.03 2654.78 -1.0333 2655.01 -0.2496 2655.22 1.0128 2655.42 0.2163 2655.64 12.871
    2655.86 771 2656.07 86 2656.27 88.6 2656.51 15 2656.74 24.969 2656.95 24993.896 2657.15 119.41 2657.35 -0.7374 2657.56 -0.6396 2657.78 0.5191 2658.01 0.6898 2658.22 17.145
    2658.41 783 2658.62 86 2658.83 88.6 2659.05 15 2659.26 24.921 2659.47 24993.896 2659.67 118.97 2659.87 -1.1677 2660.08 -0.3968 2660.29 0.9747 2660.53 0.251 2660.77 12.511
    2661.01 782 2661.22 86 2661.41 88.6 2661.62 15 2661.83 25.183 2662.05 24993.896 2662.26 119 2662.47 -1.0941 2662.67 -0.2254 2662.87 0.5491 2663.07 0.9241 2663.27 9.996
    2663.52 1216 2663.77 86 2664.01 89 2664.22 15 2664.41 43.054 2664.62 38464.355 2664.83 164.81 2665.04 0.0002 2665.27 0.0002 2665.51 0.0002 2665.75 0.0002 2665.97 0
    2666.17 1910 2666.37 86 2666.58 88.6 2666.8 47 2667.01 42.688 2667.22 44482.422 2667.42 136.88 2667.61 0.0002 2667.82 0.0002 2668.03 0.0002 2668.27 0.0002 2668.51 0
    2668.72 1828 2668.92 86 2669.14 88.6 2669.35 15 2669.56 31.024 2669.78 31597.9 2670.02 116.91 2670.27 -1.0446 2670.48 -0.7524 2670.68 0.7359 2670.89 0.195 2671.11 19.952
    2671.32 755 2671.52 86 2671.73 88.6 2671.93 15 2672.14 26.831 2672.36 26123.047 2672.57 118.22 2672.78 -1.0717 2673.03 -0.5964 2673.27 1.208 2673.49 0.5198 2673.68 12.97
    2673.89 764 2674.1 86 2674.3 88.6 2674.53 15 2674.78 25.256 2675.02 24993.896 2675.24 119.81 2675.44 -0.6861 2675.64 -0.3089 2675.85 0.4367 2676.05 0.2075 2676.28 16.01
    2676.52 775 2676.74 86 2676.93 88.6 2677.13 45 2677.34 64.551 2677.55 72698.975 2677.78 139.38 2678.03 0.0002 2678.24 0.0002 2678.44 0.0002 2678.66 0.0002 2678.87 0
    2679.07 983 2679.28 86 2679.54 89 2679.77 15 2679.99 29.205 2680.19 30175.781 2680.39 119.53 2680.61 -0.1844 2680.81 0.0002 2681.02 0.3477 2681.25 0.3774 2681.45 17.865
    2681.65 770 2681.85 86 2682.06 88.6 2682.28 15 2682.53 24.988 2682.76 24993.896 2682.96 108.81 2683.17 0.0002 2683.37 0.0002 2683.58 0.0002 2683.79 0.0002 2684.02 0
    2684.24 2114 2684.44 86 2684.64 88.6 2684.85 15 2685.05 33.557 2685.27 32208.252 2685.49 119.66 2685.69 -0.8542 2685.89 -0.1745 2686.1 0.2115 2686.31 0.0009 2686.55 18.765
    2686.8 799 2687.05 86 2687.28 88.6 2687.5 15 2687.7 26.556 2687.91 26232.91 2688.12 117.25 2688.32 -0.8725 2688.56 -0.1276 2688.81 1.3548 2689.02 0.1518 2689.22 12.21
    2689.44 791 2689.66 86 2689.87 88.6 2690.07 15 2690.32 25.043 2690.57 24993.896 2690.78 120.72 2690.98 -0.5312 2691.19 0.0379 2691.41 0.6696 2691.61 -0.1229 2691.82 9.584
    2692.04 758 2692.25 86 2692.47 89 2692.69 15 2692.9 25.391 2693.1 24993.896 2693.33 120.25 2693.58 -0.4378 2693.82 0.0599 2694.03 0.1873 2694.23 -0.0361 2694.43 23.128
    2694.64 784 2694.86 86 2695.07 88.6 2695.28 15 2695.48 25.354 2695.69 24993.896 2695.91 119.31 2696.13 -1.2094 2696.33 0.0738 2696.58 1.0842 2696.82 -0.0855 2697.04 11.87
    2697.24 793 2697.44 86 2697.65 88.6 2697.86 15 2698.1 25.244 2698.31 24993.896 2698.51 119.41 2698.72 -1.0333 2698.94 -0.0064 2699.15 0.7044 2699.36 0.0709 2699.61 10.483
    2699.85 792 2700.07 86 2700.26 88.6 2700.47 15 2700.69 25.146 2700.9 24993.896 2701.11 119.41 2701.36 -0.9871 2701.6 -0.098 2701.82 1.1384 2702.01 0.0804 2702.22 13.01
    2702.43 772 2702.64 86 2702.86 88.6 2703.12 15 2703.35 24.799 2703.57 24993.896 2703.77 118.91 2703.97 -1.1549 2704.18 -0.1188 2704.39 0.6956 2704.61 0.1555 2704.86 11.195
    2705.1 791 2705.31 86 2705.51 88.6 2705.71 15 2705.92 25.244 2706.13 24993.896 2706.35 119.41 2706.56 -1.019 2706.76 -0.169 2706.97 0.559 2707.19 0.5664 2707.4 16.766
    2707.61 775 2707.86 86 2708.11 88.6 2708.35 15 2708.57 25.293 2708.76 24993.896 2708.97 119.47 2709.18 -1.0399 2709.38 -0.2598 2709.61 0.7337 2709.85 0.243 2710.08 11.307
    2710.27 771 2710.48 86 2710.69 89 2710.91 15 2711.13 24.957 2711.37 24993.896 2711.59 119.25 2711.8 -1.1549 2712.01 -0.2287 2712.21 0.5147 2712.42 0.9143 2712.64 17.018
    2712.87 775 2713.08 87 2713.28 88.6 2713.5 15 2713.71 24.963 2713.91 24993.896 2714.13 118.63 2714.37 -0.5616 2714.58 -0.9699 2714.78 0.2906 2715 0.6396 2715.22 14.795
    2715.43 784 2715.63 87 2715.87 88.6 2716.09 15 2716.29 24.817 2716.49 24993.896 2716.7 118.81 2716.91 -0.4415 2717.13 -0.5147 2717.37 0.3862 2717.58 0.5118 2717.78 11.971
    2717.99 790 2718.19 87 2718.4 88.6 2718.61 15 2718.83 24.908 2719.03 24993.896 2719.24 119.81 2719.45 -0.696 2719.65 -1.1728 2719.87 0.5154 2720.11 1.1102 2720.33 18.135
    2720.53 776 2720.73 87 2720.94 88.6 2721.16 15 2721.37 24.927 2721.58 24993.896 2721.77 118.88 2721.98 -1.0684 2722.19 -0.51 2722.4 1.0424 2722.62 0.2595 2722.84 11.456
    2723.05 771 2723.25 87 2723.46 88.6 2723.67 15 2723.88 24.902 2724.14 24993.896 2724.36 119.34 2724.58 -1.0831 2724.78 -0.3096 2724.98 0.5539 2725.19 1.0835 2725.4 17.648
    2725.62 775 2725.83 87 2726.03 88.6 2726.22 15 2726.43 24.817 2726.64 24993.896 2726.87 118.53 2727.08 -0.4349 2727.28 -0.5235 2727.5 1.1362 2727.72 0.5253 2727.93 12.511
    2728.14 790 2728.38 87 2728.63 88.6 2728.86 15 2729.08 24.817 2729.28 24993.896 2729.5 118.53 2729.71 -0.5374 2729.92 -1.0128 2730.13 1.1124 2730.37 0.7209 2730.59 14.551
    2730.79 783 2731 87 2731.22 88.6 2731.44 15 2731.65 24.908 2731.87 24993.896 2732.09 118.88 2732.29 -0.3774 2732.49 -0.5242 2732.7 1.0003 2732.91 0.4331 2733.13 11.83
    2733.37 792 2733.58 87 2733.78 88.6 2733.98 15 2734.19 24.902 2734.41 24993.896 2734.63 119.25 2734.87 -1.0142 2735.09 -0.2591 2735.31 0.6678 2735.51 1.108 2735.72 17.451
    2735.94 773 2736.16 87 2736.37 89 2736.59 15 2736.8 24.994 2737.01 24993.896 2737.21 119.94 2737.42 -0.5422 2737.63 -1.0838 2737.88 0.525 2738.11 1.1699 2738.33 17.433
    2738.53 775 2738.73 87 2738.93 88.6 2739.13 15 2739.38 24.982 2739.63 24993.896 2739.87 119.31 2740.08 -1.0223 2740.28 -0.4455 2740.5 0.5455 2740.72 1.104 2740.93 17.632
    2741.14 778 2741.38 87 2741.62 88.6 2741.83 15 2742.03 24.939 2742.24 24993.896 2742.44 119.84 2742.65 -0.5103 2742.87 -1.1578 2743.09 0.254 2743.3 1.0388 2743.52 15.355
    2743.73 783 2743.93 87 2744.14 88.6 2744.37 15 2744.59 24.927 2744.79 24993.896 2744.99 118.81 2745.2 -0.4448 2745.41 -0.5294 2745.63 1.1406 2745.87 0.5458 2746.09 11.79
    2746.31 790 2746.51 87 2746.72 88.6 2746.94 15 2747.15 25.238 2747.37 24993.896 2747.59 119.34 2747.8 -1.1087 2748.01 -0.5213 2748.21 0.7648 2748.42 1.1036 2748.63 18.207
    2748.87 770 2749.08 87 2749.28 89 2749.48 15 2749.69 24.969 2749.89 24993.896 2750.12 118.63 2750.34 -0.536 2750.55 -1.1695 2750.77 0.2543 2750.99 0.9322 2751.2 14.83
    2751.4 783 2751.62 87 2751.84 88.6 2752.04 15 2752.25 24.908 2752.45 24993.896 2752.66 118.84 2752.88 -1.1406 2753.14 -1 2753.35 1.208 2753.54 0.2836 2753.75 10.933
    2753.96 773 2754.16 87 2754.38 88.6 2754.6 15 2754.8 24.951 2755.01 24993.896 2755.21 119.94 2755.42 -0.5436 2755.64 -1.1274 2755.86 0.5411 2756.05 0.7169 2756.26 13.852
    2756.46 791 2756.67 87 2756.89 89 2757.11 15 2757.31 24.768 2757.51 24993.896 2757.72 119.25 2757.94 -1.1021 2758.15 -0.2701 2758.38 0.971 2758.6 0.3832 2758.8 13.431
    2759.01 773 2759.21 87 2759.42 89 2759.64 15 2759.86 25.043 2760.05 24993.896 2760.26 118.53 2760.47 -0.5327 2760.69 -1.0124 2760.9 0.3843 2761.14 1.052 2761.35 13.57
    2761.55 785 2761.76 87 2761.96 88.6 2762.17 15 2762.4 24.78 2762.64 24993.896 2762.88 118.53 2763.1 -0.5488 2763.3 -1.0135 2763.51 0.4301 2763.71 0.5272 2763.92 11.771
    2764.16 785 2764.4 87 2764.61 88.6 2764.81 15 2765.02 24.805 2765.24 24993.896 2765.45 118.81 2765.65 -0.3789 2765.87 -0.522 2766.07 1.0043 2766.28 0.4309 2766.48 18.063
    2766.69 772 2766.92 87 2767.15 88.6 2767.36 15 2767.56 24.921 2767.77 24993.896 2767.99 119.75 2768.21 -1.056 2768.41 -1.175 2768.65 0.6729 2768.87 1.1076 2769.08 18.027
    2769.3 777 2769.51 87 2769.71 88.6 2769.92 15 2770.16 25.018 2770.4 24993.896 2770.62 119.34 2770.8 -0.5261 2771.01 -1.1237 2771.22 0.2686 2771.44 1.0399 2771.66 15.005
    2771.89 776 2772.09 87 2772.29 89 2772.5 15 2772.71 24.835 2772.93 24993.896 2773.15 118.69 2773.37 -0.2573 2773.58 -0.6693 2773.8 0.3807 2774.01 0.5089 2774.22 11.85
    2774.44 790 2774.66 87 2774.91 88.6 2775.15 15 2775.37 24.86 2775.58 24993.896 2775.8 119.91 2776.01 -0.5294 2776.22 -0.9633 2776.44 0.273 2776.66 0.6931 2776.9 17.055
    2777.11 785 2777.31 87 2777.52 88.6 2777.74 15 2777.96 24.927 2778.16 24993.896 2778.38 118.88 2778.57 -0.4334 2778.78 -0.507 2778.99 1.1007 2779.19 0.4151 2779.42 11.711
    2779.63 771 2779.83 87 2780.04 88.6 2780.24 15 2780.45 25.012 2780.68 24993.896 2780.91 119.97 2781.1 -0.5213 2781.31 -1.0761 2781.51 0.2888 2781.72 0.7593 2781.94 13.922
    2782.18 776 2782.4 87 2782.59 88.6 2782.8 15 2783.01 24.835 2783.21 24993.896 2783.43 118.81 2783.65 -0.4349 2783.85 -0.5228 2784.06 1.0036 2784.26 0.3807 2784.47 13.19
    2784.69 772 2784.91 87 2785.1 89 2785.31 15 2785.52 24.86 2785.73 24993.896 2785.94 118.53 2786.19 -0.7136 2786.41 -1.0791 2786.6 0.5056 2786.81 0.7403 2787.01 16.37
    2787.22 784 2787.44 87 2787.67 88.6 2787.87 15 2788.07 24.817 2788.28 24993.896 2788.49 118.88 2788.71 -1.1757 2788.93 -0.536 2789.15 1.0589 2789.34 0.355 2789.55 12.97
    2789.77 772 2789.98 87 2790.19 89 2790.43 15 2790.65 25.293 2790.83 24993.896 2791.04 119.91 2791.25 -0.5085 2791.46 -1.149 2791.7 0.574 2791.94 1.2028 2792.19 10.82
    2792.4 772 2792.6 87 2792.81 88.6 2793.01 15 2793.22 25.055 2793.45 24993.896 2793.68 119.44 2793.89 -0.7183 2794.09 -1.1607 2794.3 0.5286 2794.52 1.1377 2794.74 17.036
    2794.95 778 2795.19 87 2795.4 88.6 2795.6 15 2795.8 25.33 2796.01 24993.896 2796.22 120.13 2796.44 0.0002 2796.68 0.0002 2796.9 0.0002 2797.09 0.6975 2797.3 18.423
    2797.52 768 2797.74 87 2797.94 88.6 2798.19 15 2798.43 24.438 2798.65 25152.588 2798.85 117.66 2799.05 -0.0027 2799.25 -0.1584 2799.45 0.6403 2799.68 0.7275 2799.9 21.779
    2800.09 767 2800.29 87 2800.5 88.6 2800.7 15 2800.94 25.488 2801.18 25006.104 2801.4 120.13 2801.6 -0.0884 2801.82 -0.0064 2802.02 1.4098 2802.23 0.5766 2802.44 13.49
    2802.68 753 2802.9 87 2803.1 88.6 2803.32 15 2803.53 26.001 2803.73 25103.76 2803.94 120.13 2804.18 -0.3232 2804.4 0.0002 2804.59 0.7169 2804.79 1.3775 2805 18.568
    2805.21 752 2805.43 87 2805.65 88.6 2805.84 15 2806.05 25.641 2806.25 25036.621 2806.44 117.78 2806.69 -1.1673 2806.94 -0.1591 2807.18 0.0002 2807.41 0.5953 2807.6 17.433
    2807.81 771 2808.01 87 2808.22 88.6 2808.44 15 2808.66 25.684 2808.87 25238.037 2809.08 120.78 2809.3 0.0002 2809.52 -0.0141 2809.73 0.7059 2809.94 1.3314 2810.18 21.301
    2810.4 761 2810.6 87 2810.8 88.6 2811.01 15 2811.21 25.665 2811.44 24993.896 2811.69 120.44 2811.89 0.0002 2812.09 -0.6682 2812.3 1.1922 2812.52 0.8897 2812.73 22.89
    2812.94 727 2813.18 87 2813.41 88.6 2813.6 15 2813.81 25.336 2814.02 24993.896 2814.24 120.38 2814.44 -0.2305 2814.68 0.0002 2814.9 0.1763 2815.09 0.7066 2815.3 17.828
    2815.52 753 2815.73 87 2815.94 89 2816.18 15 2816.4 25.317 2816.6 24993.896 2816.81 120.19 2817.02 0.0002 2817.24 -0.1514 2817.46 0.0002 2817.7 0.1082 2817.92 26.541
    2818.12 752 2818.33 87 2818.53 88.6 2818.74 15 2818.96 25.989 2819.18 25024.414 2819.4 119.84 2819.59 -0.4638 2819.8 -0.1152 2820.02 0.1998 2820.23 0.3448 2820.44 20.508
    2820.68 755 2820.91 87 2821.11 88.6 2821.31 15 2821.52 25.842 2821.73 25000 2821.94 120.34 2822.18 -0.0716 2822.41 -0.169 2822.6 0.0002 2822.81 0.3518 2823.02 18.28
    2823.24 773 2823.44 87 2823.68 88.6 2823.9 15 2824.1 25.653 2824.32 25115.967 2824.53 120.03 2824.73 -0.6641 2824.95 0.0002 2825.2 0.3265 2825.43 0.0529 2825.65 29.558
    2825.85 769 2826.06 87 2826.26 88.6 2826.47 15 2826.69 24.969 2826.9 25018.311 2827.09 120.41 2827.29 0.0002 2827.5 -0.1199 2827.71 1.1347 2827.95 0.3631 2828.19 25.826
    2828.4 752 2828.59 87 2828.8 88.6 2829.02 15 2829.23 29.169 2829.44 49749.756 2829.7 153.94 2829.93 0.0002 2830.15 0.0002 2830.35 0.0002 2830.57 0.0002 2830.79 0.995
    2830.99 2495 2831.2 88 2831.43 88.6 2831.65 15 2831.85 34.778 2832.05 34161.377 2832.25 131.19 2832.45 -1.958 2832.69 -0.9831 2832.9 0.8963 2833.1 0.0566 2833.31 28.685
    2833.51 756 2833.72 88 2833.94 88.6 2834.15 15 2834.35 27.625 2834.56 27770.996 2834.76 120.84 2834.97 -0.3832 2835.19 0.0002 2835.41 0.2514 2835.6 0.566 2835.81 22.81
    2836.02 761 2836.24 87 2836.45 89 2836.66 15 2836.86 25.72 2837.07 25085.449 2837.29 120.66 2837.49 -1.1149 2837.7 -0.4887 2837.92 1.0944 2838.11 0.6458 2838.32 11.951
    2838.52 749 2838.73 87 2838.96 88.6 2839.21 15 2839.45 25.781 2839.66 25122.07 2839.86 120.75 2840.07 -0.1719 2840.29 -0.525 2840.51 0.8736 2840.71 3.6199 2840.95 4.999
    2841.17 1428 2841.38 87 2841.59 88.6 2841.79 15 2842 31.122 2842.21 30694.58 2842.45 117.41 2842.66 -0.7213 2842.86 -0.314 2843.06 1.4705 2843.27 0.1536 2843.49 17.108
    2843.71 757 2843.95 87 2844.17 89 2844.37 15 2844.58 25.5 2844.78 25054.932 2844.99 116.88 2845.2 -3.4163 2845.41 -1.0329 2845.61 0.0002 2845.81 0.0002 2846.02 0
    2846.23 2277 2846.45 87 2846.67 88.6 2846.88 15 2847.1 34.204 2847.31 32208.252 2847.51 123.56 2847.72 0.0002 2847.96 0.0002 2848.2 0.0002 2848.42 0.0002 2848.63 26.541
    2848.84 749 2849.04 87 2849.25 88.6 2849.46 15 2849.71 27.582 2849.94 27032.471 2850.14 120.41 2850.34 -0.7711 2850.55 -0.1723 2850.75 0.3177 2850.96 0.1481 2851.2 15.564
    2851.42 776 2851.61 87 2851.82 88.6 2852.03 15 2852.23 24.872 2852.46 24993.896 2852.71 118.72 2852.94 -0.5184 2853.15 -0.3668 2853.34 0.347 2853.55 0.1719 2853.77 15.878
    2853.98 785 2854.21 87 2854.46 89 2854.71 15 2854.95 25.244 2855.16 24993.896 2855.36 119.75 2855.56 -0.6623 2855.77 -0.5209 2855.98 0.57 2856.21 0.5748 2856.45 18.243
    2856.67 774 2856.87 87 2857.08 88.6 2857.28 15 2857.49 24.86 2857.7 24993.896 2857.91 118.84 2858.11 -0.3279 2858.32 -0.3192 2858.54 1.0809 2858.74 0.1778 2858.95 11.121
    2859.17 770 2859.38 87 2859.59 89 2859.79 15 2860 25.049 2860.2 24993.896 2860.42 119.91 2860.62 -0.5213 2860.82 -0.7136 2861.03 0.3778 2861.24 0.3869 2861.46 10.297
    2861.7 785 2861.91 87 2862.11 88.6 2862.31 15 2862.52 24.811 2862.74 24993.896 2862.95 118.84 2863.16 -1.0941 2863.36 -0.4484 2863.57 0.6641 2863.78 0.963 2863.98 16.891
    2864.21 770 2864.46 87 2864.7 88.6 2864.91 15 2865.11 25.244 2865.31 24993.896 2865.52 119.25 2865.74 -0.9439 2865.95 -0.4129 2866.17 0.5338 2866.38 1.0307 2866.6 18.063
    2866.81 776 2867.02 87 2867.23 89 2867.46 15 2867.7 24.908 2867.91 24993.896 2868.11 119.75 2868.32 -0.7055 2868.54 -1.1047 2868.74 0.2598 2868.96 0.9491 2869.2 17.433
    2869.42 776 2869.62 87 2869.82 88.6 2870.03 15 2870.23 24.878 2870.45 24993.896 2870.67 118.91 2870.87 -0.4016 2871.07 -0.529 2871.28 1.0443 2871.49 0.2466 2871.71 11.044
    2871.96 791 2872.2 87 2872.42 88.6 2872.61 15 2872.82 24.756 2873.03 24993.896 2873.23 119.25 2873.46 -1.1549 2873.7 -0.5239 2873.92 1.149 2874.11 0.2895 2874.31 13.21
    2874.51 773 2874.72 87 2874.96 88.6 2875.21 15 2875.45 24.847 2875.66 24993.896 2875.86 118.88 2876.07 -1.1215 2876.29 -0.5125 2876.5 0.9461 2876.7 0.3884 2876.92 12.99
  4. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #14
    135 Post(s)
    2026 Post(s)
    I think the refurbished injectors are at fault, I don't think they can maintain the correct IMA value recorded on the body, we will only fit VDO A2C9626040080 new units.
  5. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #15
    Sep 2009
    Burton Upon Trent, England
    Thanks for your fast reply as always, pitty i cant adjust them with VCDs or by manually cracking off the locknut and checking output with VCDs.
  6. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #16
    Feb 2020
    Bradford
    41 Post(s)
    The fitting of these cr injectors have caused a fair bit of problems. They need a new sealing washer, for the seat to be cleaned and a new bolt for the clamp.
  7. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #17
    Sep 2009
    I agree Roverfan, i would expect compression to suffer and possibly a wheezing noise from blowby.
  8. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #18
    Feb 2020
    Bradford
    41 Post(s)
    Yes, the seconds thoughts are due to it being the second set of injectors. It's strange that the original set would not start the car and the recons have all failed. I drive a cayc approaching 200k so it's a frightening prospect.
    BTW if you need any comparative data I can help
  9. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #19
    Sep 2009
    Hi Roverfan, thanks i was hoping the data i provided and videos would help with diagnostics both you and Crasher have provided some viable reasons with justification. As crasher said new injectors would rule out the possibility of of recon faulty injectors. When we first received the 4 recon injectors one of those wouldn't code and and he sent us another code which I thought was very strange that he could generate a code without the injector unless it worked on a value that had already predetermined. Would be nice to know what an acceptable reading for the injectors should be and tolerance allowed for this particular model
  10. Re: VW Passat 2013 - CAYC 1.6 TDI - noisy and rough idle when warm.
    #20
    Feb 2020
    Bradford
    41 Post(s)
    Hi Lambretta, I checked the fuel pressure and it seems right, planning to check the voltages (I'll get back to you if anything). I am not too sure about entirely testing recons as the parts they replace are the mechanical washers, spacers which ultimately effect the opening. As crasher said they don't appear to be able hold to their ima value however the test for the piezo element is a leakage tester - it pumps the operating voltage into the injector (100v), the piezo crystal holds this voltage/charge (this is injector open state) for a specified time and then the tester discharges (closes) the piezo, the voltage coming back into the tester determines if the piezo is good or not.
    The recon industry tosses the bad piezo elements but they claim to be able to recon the rest of the injector but the tolerances when new are such that no IMA is the same!
    If you don't see a clear reason to doubt the injector deviations (which normally signifies bad injectors) as being anything but due to injectors themselves then I suppose it does seem if it is the injectors. I'm not saying it's not the injectors but the situation does seem rare that 2 sets have gone from what we assume was decent daily runner. Rare but possible
  1. 1.6 CAYC rough idle
    By lightbreeze in forum Golf MK6 - 2009 - 2013
    Last Post: 13-11-2020, 12:04 AM
  2. Please Help Rough idle when engine is warm
    By d1s in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 30-08-2015, 02:12 PM
  3. rough idle once engine is warm
    By liamthecoder in forum Golf MK4 - 1999 - 2004
    Last Post: 04-12-2012, 11:42 PM
  4. Idle rough on warm-up
    By patrickhorton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-11-2011, 04:46 PM
  5. ADR 20v engine noisy tapping at warm idle
    By Mike65 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 18-04-2007, 01:39 PM
