Thread: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
Results 1 to 8 of 8
  1. 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    Mar 2021
    Ireland
    Hello to one an all,
    I have a MK5 2.0 TDI VW Golf BKD Engine that is giving me some grief.
    Mileage: 236,xxx Km
    I will attempt to keep this description concise and as brief as possible.
    It all started out perhaps 6 months ago, occasionally when pulling off the car would feel like it wanted to stall - shudder a little but never actually did cut out on me, this was I guess a slight nuisance if that, and never really occurred with such regularity that I felt like digging deeper into the problem.
    Perhaps a month to 6 weeks after that, the first occurrence of what is the major/consistent issue that I have happened which is: car operating/driving normally without any known trigger on my part and it will start to shudder/judder particularly when the accelerator is applied, this can get very heavy and violent if the accelerator is continued to be pressed to the extent that I have always had to back off the pedal. After this occurred once or twice I probably by fluke found out by turning off and on the ignition this issue could be reset, and the car would immediately go back to driving fine until the issue would occur again. As time has progressed the time between resetting the fault and the fault re-occurring has decreased and decreased to the point where it could happen every quarter of a mile.
    I have had the opportunity to plug the car into VCDS, the reoccurring faults are P1263,1267,1269 PD Injector Unit Implausible Signal these tend to occur at any one time for 3 cylinders, never all 4 cylinders together but it can be any combination of the 4 cyclinders (no cylinder is immune so to speak), the fault doesn't occur when the car is cold, it is always at least warm when the fault occurs, as mentioned the fault can always be reset by turning off and on the ignition and even on one occasion whilst I had VCDS up I was able to 'Clear codes' via VCDS and this reset the fault until it happened again.
    Attempts to rectify So-Far:
    - Replaced injector/glow plug wiring loom under rocker cover (Genuine VW Replacement)
    - ECU has been swapped (Step taken by local Auto Electrician)
    - Resistance/Continuity Check of wiring between injectors and ECU
    - Checked lift pump in tank for any blockage
    - Checked wiring looms around the engine bay to check for any chaffing of cables but none to be found
    Where should I go next?
    Fuel Supply - Tandem Pump? Am I correct in saying there is no way to check fuel pressure with VCDS for this engine?
    Help greatly appreciated,
    Thanks in advance.
  2. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    134 Post(s)
    1996 Post(s)
    Was the fuel in the tank black? There is no fuel pressure sensor on the BKD, just temperature.
  3. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    Mar 2021
    Ireland
    Hi Crasher,
    Yes, at the time I had recently put a fuel additive in (Redex if I recall correctly) and had put the discolouration down to that?
    That tank of fuel would be gone out of system now, is it worth removing the fuel filter cover to check for discolouration there now?
  4. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    134 Post(s)
    1996 Post(s)
    Yes, that is the next step, I expect the fuel in the filter will be very oily.
  5. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    Mar 2021
    Ireland
    Ok, I have checked the fuel filter/fuel filter housing, some pictures attached below, thought it might show signs of more oil?
  6. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    Mar 2021
    Ireland
    Would this be leading towards a Tandem Pump issue?
  7. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    Mar 2021
    Ireland
    Fault_Condition_04.jpgFault_Condition_01.jpgFault_Condition_02.jpgFault_Condition_03.jpg
    Just adding some VCDS data in non-fault and fault conditions might help someone shed some light on this:
    First 2 pictures show healthy condition
    Next 4 pictures show various fault conditions, just a side note all 4 'INJECTOR STATUS' were reading 128.0 when fault first occurred this pictures was taken shortly after when I had pulled the car over to side of road.
  8. Re: 2006 MK5 Golf 2.0 TDI (BKD Engine) - Possible Misfiring
    134 Post(s)
    1996 Post(s)
    Fit a clear piece of fuel line in the return from the fuel temperature sender.
  1. Fabia 1.4 16v 2006 Misfiring
    By nolfese in forum Fabia
    Last Post: 14-09-2016, 11:03 AM
  2. Question 2006 golf mk 5 1.9 tdi engine code bkc 103hp
    By mr steve t in forum Golf MK5 - 2004 - 2009
    Last Post: 21-04-2016, 12:04 PM
  3. Question Golf 1.8t AUM engine. Misfiring P0300/P0304
    By atomicgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 17-05-2015, 01:06 PM
  4. Golf 2006 BMN engine non start
    By raveon09 in forum Golf MK5 - 2004 - 2009
    Last Post: 11-03-2011, 06:07 PM
  5. 2006 A6 misfiring?
    By Red-penquin in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-11-2008, 11:22 AM
bkd
