Thread: 2013 T5 Starting issues: Starter Relay?
  1. 2013 T5 Starting issues: Starter Relay?
    Mar 2021
    Winklen, Austria
    Hi guys, this is my first post on this forum.
    I have been having some starting issues on my 2013 T5. I had intermittent starting for about a month. Usually in the morning it would give me trouble, but once I got it to fire, either by ignition or roll start. It would then start fine for the rest of the day and it could be a weak before I had an issue. Sometimes, tapping on the starter body with a hammer would get it to start. But now there is absolutely nothing.
    I have checked the ignition switch and also confirmed with a known operating switch, everything is fine. I am getting 12 volts to the starter, I can jump the start from the solenoid to direct 12 v power and get the starter to turn over no issue. Checking power to the excite wire (ignition wire to the solenoid), when i have someone turn the key I am not getting 12 volts. So it leads me to believe that either the wire is broken somewhere, or perhaps there is a starter relay. If there is a starter relay can someone please tell me which relay I need to look for, so I can check it.
    If someone can lead me to a potential starter relay or something else, please let me know. I have searched the internet and can not seem to find anything regarding a starter relay.
    Paul
  2. Re: 2013 T5 Starting issues: Starter Relay?
    1836 Post(s)
    If you private message me the VIN I can have a look at the wiring diagram on Monday.
  3. Re: 2013 T5 Starting issues: Starter Relay?
    Mar 2021
    Winklen, Austria
    Thanks, will do.
  4. Re: 2013 T5 Starting issues: Starter Relay?
    1836 Post(s)
    The wiring diagrams I have are in German which is obviously not an issue for yourself, I still struggle my way through antreib und whatever!... I will look into it on Monday and probably email you some diagrams.
  5. Re: 2013 T5 Starting issues: Starter Relay?
    Mar 2021
    Winklen, Austria
    Thank you
    If I figure out the issue I will post back in this thread for anyone else having the same issue in the future.
    Paul
  6. Re: 2013 T5 Starting issues: Starter Relay?
    1836 Post(s)
    Remind me tomorrow
  1. Starter motor problems, relay 106?
    By oscarbigfeet in forum Alhambra
    Last Post: 26-09-2016, 09:30 AM
  2. Question Starter motor & relay
    By VdoubleYa in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-06-2016, 12:34 PM
  3. Starter Motor Relay. (goes behind the dashboard)
    By Zeb in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-12-2008, 07:03 PM
  4. Where to find VW GOLF MK4 starter relay
    By Dj_Ghost in forum Golf MK4 - 1999 - 2004
    Last Post: 18-01-2008, 11:54 PM
  5. HELP! Where is my starter / ignition relay?
    By H18JGM in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-11-2007, 11:53 PM
