Thread: Diesel engine is slow to heat up.
  1. Diesel engine is slow to heat up.
    Mar 2019
    Hertfordshire, UK
    My Audi takes ages for its diesel engine to warm up, according to the temperature gauge, probably about 5 miles before the temp reaches normal.
    I have purchased a new thermostat in its housing but have not fitted it yet as the water temperature seems unequal either side of the thermostat which tells me its working OK.
    Also the fan funs for a while after parking the car which is odd. Even when the radiator is not hot.
    Any ideas?
    2014 Audi A4 Avant S Line AWD Blue 45k miles plus several Jags.
  2. Re: Diesel engine is slow to heat up.
    Apr 2018
    N.Ireland
    9 Post(s)
    5 miles is good! i could drive 10 miles to work some days and it isn't up to temp. The fans run on my mrs newer a3 2013 but i think again this is normal.
    MK7 Golf Estate '14 GT TDI CR150 DSG. Engine Mods: Stage 1, Rear Intake Trim
  3. Re: Diesel engine is slow to heat up.
    Nov 2006
    Crewe, Cheshire
    67 Post(s)
    Agree with Jim, 5 miles is very normal.
    When the fan runs on at shutdown, it's usually because the engine has just finished or is in the middle of a DPF regen.
    The fans run on for a few minutes to cool the very hot DPF.
  4. Re: Diesel engine is slow to heat up.
    Mar 2019
    Hertfordshire, UK
    Thanks guys. I wont worry any more if it sounds normal.
  5. Re: Diesel engine is slow to heat up.
    1840 Post(s)
    Ignore what the gauge says, it bares no relation to reality.
  1. 1.6 Diesel slow to warm up
    By mikeosborne13 in forum Golf MK6 - 2009 - 2013
    Last Post: 28-01-2012, 09:34 AM
  2. Slow warm up of diesel engine
    By RodA in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-10-2011, 10:42 AM
  3. Slow to Heat Up Alhambra
    By mike_watts in forum Alhambra
    Last Post: 13-09-2011, 09:57 PM
  4. Alhambra 130TDI flashing diesel pre heat light
    By Donkey01 in forum Alhambra
    Last Post: 08-08-2010, 04:16 PM
  5. 80 Diesel pre heat light
    By Burnside in forum 80 - 90
    Last Post: 28-07-2008, 11:25 PM
