Thread: Dipstick position on B5 1.8 T engine?
  1. Dipstick position on B5 1.8 T engine?
    Mar 2016
    Minervois, France
    53 Post(s)
    I can't put the Audi over my pit as the VW is stuck there waiting for its new engine.
    So I bought an electric pump and fittings to drain the sump without having to crawl underneath to remove the cover to get to the drain plug while lying on the cold concrete floor.
    But now I'm not sure if the suction pipe will reach deep enough via the dipstick tube.
    Can anyone tell me if it will reach the bottom of the lowest part of the sump?
    Did this forum help you? Help make sure it's here next time! Follow the instructions at the top of the page to make a suitable donation using PayPal .
    1996 A4 B5 (S2) Avant 1.8T (petrol) 150 bhp code AEB automatic with 79,125 kms = 49,450 miles on 30/07/23
    VW T25 Camper, Alfa 33 1.4 ie, 2 Alfa 33's for parts.
  2. Re: Dipstick position on B5 1.8 T engine?
    1840 Post(s)
    It should reach as that is how the Americans tend to do it although on that engine it became a bit of a disaster in the states due to not getting the sludge out.
  3. Re: Dipstick position on B5 1.8 T engine?
    Mar 2016
    Minervois, France
    53 Post(s)
    Thank you.
    Oh, the b****y sludge! Maybe I'll use the drain plug after all
  4. Re: Dipstick position on B5 1.8 T engine?
    1840 Post(s)
    In the Golf the 1.8T suffers sludge but I have seen more longitudinal 1.8T engines die due to sludge than I have ever experienced in a single type of engine in 40 years, possible apart from the T3 CT air cooled engine, that was an awful engine to start with. When I take the sump off of these the sludge is always worse at the shallow rear end where oil drips and drains.
  5. Re: Dipstick position on B5 1.8 T engine?
    Mar 2016
    Minervois, France
    53 Post(s)
    I checked the inside of the sump and the oil pickup with my endoscope 3 years (10k miles) ago and found everything I could see was nice and clean.
    I change the oil and filter every 5,000 miles, and there was unlikely to be any significant sludge build up.
    So, as it's still too cold to be crawling on the garage floor, I decided to use the pump this time.
    The plastic suction pipe supplied gets soft when it's in the warm oil, but after some fiddling I managed to suck out the correct amount, until I was sure the sump was empty, and on refilling, it and the filter took the usual amount of 4.4 litres, with the large volume filter which I use.
    I should have the pit available for the next oil change - it may be years before I do another 5,000 miles, but I plan to get a metal tube for the suction pipe so I'm sure it's not bent if I use the pump again.
  1. Oil Dipstick Part Number CDUC Engine Please?
    By sanstorm999 in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 24-10-2020, 12:22 PM
  2. A6 C7 2.0 TDi 177 CGLC 2012 Engine Oil Dipstick
    By AMR1 in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 10-11-2016, 12:03 AM
  3. Engine oil spraying out of dipstick?
    By mark850 in forum Golf MK5 - 2004 - 2009
    Last Post: 21-07-2016, 12:37 PM
  4. engine dipstick conversion..is it poss??
    By christech in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-09-2011, 10:36 PM
  5. Broken engine oil dipstick
    By Abbs985uk in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-02-2008, 09:50 AM
